I am quite new working with Manjaro and right now I have it installed in a Raspberry Pi.
Now I would like to connect from my Mac on a remote desktop connection to the PI.
I have read on another post from this forum about how to install TigerVnc in Manjaro and how to enable it. I think i got it all set up now, but I am not able to find info about how to connect from a Mac machine.
Do I need to install any additional app in the Mac?, how to stablish the connection?
Any further support on that issue?
Thanks everyone for suggestions, it seems like I am able to connect now, at least the vnc connection is open, but I just see a black screen…any clue what could be wrong?
The ssh connection is only the bridge - so if the black screen you are looking at is the terminal - it is expected. The target system must have some kind of x-display running - without x using vnc makes no sense as ssh would be all you need.
Did you setup your Pi device according to the earlier mentioned TigerVNC guide?
As I am a mac owner/user - I have verified my advise - and suffice you have followed the document on configuring the target system - and done so correct - you should get what ever desktop is running on the target.
But there may be issues rising from using e.g. KDE on the target - which I have no capacity to troubleshoot.
