So my target computer is a Windows machine.
When I am on my container pinging the machine does not work, all the packets are lost.
When I try to ping the same address from my local machine, it works.
Is there a possibility that docker and some network settings from my local machine inhibit the connection? A VPN is also running so that I can reach the remote machine. My code seems to work from another windows machine.
I can provide you with the information you may need. I am a little lost here, so maybe you have a hint. It has been a troublesome and sad week without no progress at all.
I appreciate any help!
