Remmina - no characters, only rectangles
Hi,
since the last Remmina update (snap package) the program only shows rectangles instead of charactes - see picture attached. I also tried the remmina-git from AUR but that is not helping.
Can anyone help?
Thanks
crus
Can you try the version from repos? The issue appears to be with fonts. Can you try another font?
Its a common snap problem … you need to refresh font cache…
