Hello together,
im using remmina to connect via rdp to windows servers. Suddenly i have the issue, after it works for many months, that remmina shows a picture with very high transparency, so that it is not possible to detect anything on the screen.
The problem only appears when maximazing the window. If i pull the window to a smaller size so that the window doesn’t fit the proportions needed by the remote server, the picture looks fine. When pulling the window larger suddenly a big transparency appears.
Does anyone else have the same problem and can tell me how to fix it?
The problem only appears when using rdp. When i connect to a linux server with ssh everything works fine.
Best regards
