dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.12-1-MANJARO-ARM (builduser@on2-runner) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Tue Feb 14 22:16:04 UTC 2023
[ 0.000000] Machine model: Radxa Zero
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'secmon@5000000': base 0x0000000005000000, size 3 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000e4800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000f4806fff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x00000000052fffff]
[ 0.000000] node 0: [mem 0x0000000005300000-0x00000000072fffff]
[ 0.000000] node 0: [mem 0x0000000007300000-0x00000000f4806fff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000f4806fff]
[ 0.000000] On node 0, zone DMA: 14329 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 20 pages/cpu s42664 r8192 d31064 u81920
[ 0.000000] pcpu-alloc: s42664 r8192 d31064 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 985830
[ 0.000000] Kernel command line: initrd=/initramfs-linux.img root=PARTUUID=b435d49e-02 rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 3596500K/4005916K available (12736K kernel code, 2418K rwdata, 5192K rodata, 3776K init, 669K bss, 147272K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000366] Console: colour dummy device 80x25
[ 0.000425] printk: console [tty0] enabled
[ 0.000463] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000475] pid_max: default: 32768 minimum: 301
[ 0.000693] LSM: Security Framework initializing
[ 0.000734] Yama: becoming mindful.
[ 0.000866] AppArmor: AppArmor initialized
[ 0.001040] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001066] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003060] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.003077] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003156] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003357] rcu: Hierarchical SRCU implementation.
[ 0.003362] rcu: Max phase no-delay instances is 1000.
[ 0.007657] EFI services will not be available.
[ 0.008227] smp: Bringing up secondary CPUs ...
[ 0.008893] Detected VIPT I-cache on CPU1
[ 0.009047] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.009668] Detected VIPT I-cache on CPU2
[ 0.009764] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.010390] Detected VIPT I-cache on CPU3
[ 0.010487] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.010550] smp: Brought up 1 node, 4 CPUs
[ 0.010563] SMP: Total of 4 processors activated.
[ 0.010568] CPU features: detected: 32-bit EL0 Support
[ 0.010572] CPU features: detected: 32-bit EL1 Support
[ 0.010579] CPU features: detected: CRC32 instructions
[ 0.010645] CPU: All CPU(s) started at EL2
[ 0.010660] alternatives: applying system-wide alternatives
[ 0.012930] devtmpfs: initialized
[ 0.026050] Registered cp15_barrier emulation handler
[ 0.026076] Registered setend emulation handler
[ 0.026269] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026288] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033008] pinctrl core: initialized pinctrl subsystem
[ 0.033664] DMI not present or invalid.
[ 0.034343] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.035534] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.035679] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.035885] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.035929] audit: initializing netlink subsys (disabled)
[ 0.036165] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.037619] thermal_sys: Registered thermal governor 'fair_share'
[ 0.037627] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.037631] thermal_sys: Registered thermal governor 'step_wise'
[ 0.037635] thermal_sys: Registered thermal governor 'user_space'
[ 0.037690] cpuidle: using governor ladder
[ 0.037712] cpuidle: using governor menu
[ 0.037967] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.038072] ASID allocator initialised with 65536 entries
[ 0.039389] Serial: AMBA PL011 UART driver
[ 0.053717] platform ff900000.vpu: Fixing up cyclic dependency with ff600000.hdmi-tx
[ 0.058633] platform hdmi-connector: Fixing up cyclic dependency with ff600000.hdmi-tx
[ 0.069059] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.069080] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.069086] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.069090] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.069096] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.069100] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.069105] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.069109] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.069554] cryptd: max_cpu_qlen set to 1000
[ 0.070840] ACPI: Interpreter disabled.
[ 0.071826] iommu: Default domain type: Translated
[ 0.071834] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.072395] SCSI subsystem initialized
[ 0.072536] libata version 3.00 loaded.
[ 0.072774] usbcore: registered new interface driver usbfs
[ 0.072809] usbcore: registered new interface driver hub
[ 0.072835] usbcore: registered new device driver usb
[ 0.073196] pps_core: LinuxPPS API ver. 1 registered
[ 0.073202] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.073931] Advanced Linux Sound Architecture Driver Initialized.
[ 0.074561] NetLabel: Initializing
[ 0.074566] NetLabel: domain hash size = 128
[ 0.074571] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.074628] NetLabel: unlabeled traffic allowed by default
[ 0.074833] vgaarb: loaded
[ 0.075155] clocksource: Switched to clocksource arch_sys_counter
[ 0.075439] VFS: Disk quotas dquot_6.6.0
[ 0.075491] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.076106] AppArmor: AppArmor Filesystem Enabled
[ 0.076157] pnp: PnP ACPI: disabled
[ 0.083021] NET: Registered PF_INET protocol family
[ 0.083282] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.086323] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.086368] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.086384] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.086644] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.087500] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.087713] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.087808] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.088167] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.088217] PCI: CLS 0 bytes, default 64
[ 0.088846] Trying to unpack rootfs image as initramfs...
[ 0.089326] kvm [1]: IPA Size Limit: 40 bits
[ 0.105306] kvm [1]: vgic interrupt IRQ9
[ 0.105454] kvm [1]: Hyp mode initialized successfully
[ 0.107306] Initialise system trusted keyrings
[ 0.107553] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.113169] zbud: loaded
[ 0.152235] NET: Registered PF_ALG protocol family
[ 0.152268] Key type asymmetric registered
[ 0.152274] Asymmetric key parser 'x509' registered
[ 0.152409] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.152671] io scheduler mq-deadline registered
[ 0.152678] io scheduler kyber registered
[ 0.152922] io scheduler bfq registered
[ 0.158455] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[ 0.176793] soc soc0: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2) Detected
[ 0.180179] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.182009] Serial: AMBA driver
[ 0.182505] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart
[ 0.188345] printk: console [ttyAML0] enabled
[ 0.189314] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 15, base_baud = 1500000) is a meson_uart
[ 0.189453] serial serial0: tty port ttyAML6 registered
[ 0.196962] usbcore: registered new interface driver uas
[ 0.197035] usbcore: registered new interface driver usb-storage
[ 0.197128] usbcore: registered new interface driver usbserial_generic
[ 0.197150] usbserial: USB Serial support registered for generic
[ 0.198437] mousedev: PS/2 mouse device common for all mice
[ 0.198645] i2c_dev: i2c /dev entries driver
[ 0.201082] usbcore: registered new interface driver pcwd_usb
[ 0.201278] device-mapper: uevent: version 1.0.3
[ 0.201611] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 0.203516] sdhci: Secure Digital Host Controller Interface driver
[ 0.203534] sdhci: Copyright(c) Pierre Ossman
[ 0.203688] Synopsys Designware Multimedia Card Interface Driver
[ 0.204380] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.205038] meson-gx-mmc ffe05000.sd: Got CD GPIO
[ 0.205743] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.206096] No iBFT detected.
[ 0.206674] meson-sm: secure-monitor enabled
[ 0.207225] hid: raw HID events driver (C) Jiri Kosina
[ 0.207349] usbcore: registered new interface driver usbhid
[ 0.207356] usbhid: USB HID core driver
[ 0.209557] Initializing XFRM netlink socket
[ 0.210135] NET: Registered PF_INET6 protocol family
[ 0.271465] mmc0: new high speed SDHC card at address b368
[ 0.272673] mmcblk0: mmc0:b368 SD 14.7 GiB
[ 0.275214] mmcblk0: p1 p2
[ 0.422177] Freeing initrd memory: 8224K
[ 0.458571] Segment Routing with IPv6
[ 0.458650] In-situ OAM (IOAM) with IPv6
[ 0.458727] mip6: Mobile IPv6
[ 0.458750] NET: Registered PF_PACKET protocol family
[ 0.459782] registered taskstats version 1
[ 0.459808] Loading compiled-in X.509 certificates
[ 0.460626] zswap: loaded using pool lzo/zbud
[ 0.460820] debug_vm_pgtable: [debug_vm_pgtable ]: Validating architecture page table helpers
[ 0.461180] Key type .fscrypt registered
[ 0.461186] Key type fscrypt-provisioning registered
[ 0.461846] Key type encrypted registered
[ 0.616825] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
[ 0.616847] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
[ 0.619969] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
[ 0.620075] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
[ 0.620402] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[ 0.621714] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.621927] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 0.622072] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
[ 0.622121] xhci-hcd xhci-hcd.0.auto: irq 19, io mem 0xff500000
[ 0.622288] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.622413] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 0.622426] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 0.622605] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 0.622616] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.622625] usb usb1: Product: xHCI Host Controller
[ 0.622632] usb usb1: Manufacturer: Linux 6.1.12-1-MANJARO-ARM xhci-hcd
[ 0.622638] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 0.623039] hub 1-0:1.0: USB hub found
[ 0.623070] hub 1-0:1.0: 2 ports detected
[ 0.623473] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.623587] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 0.623598] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.623606] usb usb2: Product: xHCI Host Controller
[ 0.623613] usb usb2: Manufacturer: Linux 6.1.12-1-MANJARO-ARM xhci-hcd
[ 0.623620] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 0.623982] hub 2-0:1.0: USB hub found
[ 0.624009] hub 2-0:1.0: 1 port detected
[ 0.625226] OF: graph: no port node found in /soc/bus@ffd00000/i2c@1c000/fusb302@22
[ 0.642004] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[ 0.643542] ALSA device list:
[ 0.643564] No soundcards found.
[ 0.670026] Freeing unused kernel memory: 3776K
[ 0.705290] Run /init as init process
[ 0.705310] with arguments:
[ 0.705317] /init
[ 0.705322] splash
[ 0.705327] with environment:
[ 0.705332] HOME=/
[ 0.705337] TERM=linux
[ 0.831492] meson-drm ff900000.vpu: Queued 1 outputs on vpu
[ 0.844013] meson-drm ff900000.vpu: CVBS Output connector not available
[ 0.885586] meson-drm ff900000.vpu: Couldn't bind all components
[ 0.892986] meson-drm ff900000.vpu: CVBS Output connector not available
[ 0.905249] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 0.925260] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 0.925970] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 0.926350] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 0.927164] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
[ 1.074614] mmc1: new HS200 MMC card at address 0001
[ 1.075831] mmcblk1: mmc1:0001 D9D16G 14.5 GiB
[ 1.078260] mmcblk1: p1
[ 1.079266] mmcblk1boot0: mmc1:0001 D9D16G 4.00 MiB
[ 1.081854] mmcblk1boot1: mmc1:0001 D9D16G 4.00 MiB
[ 1.084084] mmcblk1rpmb: mmc1:0001 D9D16G 4.00 MiB, chardev (245:0)
[ 1.088673] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[ 1.088700] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.088709] usb 1-1: Product: USB Receiver
[ 1.088716] usb 1-1: Manufacturer: Logitech
[ 1.123081] input: Logitech USB Receiver as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:046D:C52B.0001/input/input0
[ 1.186049] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input0
[ 1.194378] input: Logitech USB Receiver Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input1
[ 1.195037] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input2
[ 1.265619] input: Logitech USB Receiver System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input3
[ 1.266234] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input1
[ 1.273778] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input2
[ 1.573964] Console: switching to colour frame buffer device 320x90
[ 1.617346] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 2.406735] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 3.270625] systemd[1]: System time before build time, advancing clock.
[ 3.436228] systemd[1]: systemd 252.5-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 3.436275] systemd[1]: Detected architecture arm64.
[ 3.456093] systemd[1]: Hostname set to <radxa>.
[ 3.777088] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[ 4.678588] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.720997] systemd[1]: Created slice Slice /system/getty.
[ 4.723497] systemd[1]: Created slice Slice /system/modprobe.
[ 4.725596] systemd[1]: Created slice Slice /system/serial-getty.
[ 4.727255] systemd[1]: Created slice User and Session Slice.
[ 4.727817] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.728916] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.729278] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 4.729498] systemd[1]: Reached target Remote Encrypted Volumes.
[ 4.729586] systemd[1]: Reached target Remote File Systems.
[ 4.729683] systemd[1]: Reached target Slice Units.
[ 4.729808] systemd[1]: Reached target Swaps.
[ 4.729974] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.730527] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.732740] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.744679] systemd[1]: Listening on Process Core Dump Socket.
[ 4.746003] systemd[1]: Listening on Journal Audit Socket.
[ 4.746945] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.747889] systemd[1]: Listening on Journal Socket.
[ 4.749023] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.750941] systemd[1]: Listening on udev Control Socket.
[ 4.751706] systemd[1]: Listening on udev Kernel Socket.
[ 4.752442] systemd[1]: Listening on User Database Manager Socket.
[ 4.758274] systemd[1]: Mounting Huge Pages File System...
[ 4.764438] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.770770] systemd[1]: Mounting Kernel Debug File System...
[ 4.771974] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.779236] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.785947] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.791845] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.799282] systemd[1]: Starting Load Kernel Module configfs...
[ 4.806204] systemd[1]: Starting Load Kernel Module drm...
[ 4.813292] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 4.820501] systemd[1]: Starting Load Kernel Module fuse...
[ 4.821457] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.832351] systemd[1]: Starting Journal Service...
[ 4.872869] systemd[1]: Starting Load Kernel Modules...
[ 4.879862] systemd[1]: Starting Generate network units from Kernel command line...
[ 4.880944] fuse: init (API version 7.37)
[ 4.886745] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.887420] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 4.893982] systemd[1]: Starting Coldplug All udev Devices...
[ 4.901028] systemd[1]: Starting Setup Virtual Console...
[ 4.915557] systemd[1]: Mounted Huge Pages File System.
[ 4.916799] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.917967] systemd[1]: Mounted Kernel Debug File System.
[ 4.919199] systemd[1]: Mounted Temporary Directory /tmp.
[ 4.921220] systemd[1]: Finished Create List of Static Device Nodes.
[ 4.924301] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 4.925724] systemd[1]: Finished Load Kernel Module configfs.
[ 4.928461] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 4.929936] systemd[1]: Finished Load Kernel Module drm.
[ 4.932433] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 4.933659] systemd[1]: Finished Load Kernel Module fuse.
[ 4.944015] systemd[1]: Mounting FUSE Control File System...
[ 4.955102] systemd[1]: Mounting Kernel Configuration File System...
[ 4.962612] systemd[1]: Finished Generate network units from Kernel command line.
[ 4.964053] systemd[1]: Mounted FUSE Control File System.
[ 4.965002] systemd[1]: Reached target Preparation for Network.
[ 4.969102] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.975958] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.977122] systemd[1]: Mounted Kernel Configuration File System.
[ 5.059735] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 5.126044] systemd[1]: Starting Load/Save Random Seed...
[ 5.126630] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 5.132729] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.134672] systemd[1]: Started Journal Service.
[ 5.135484] audit: type=1130 audit(1675140683.860:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.153467] audit: type=1130 audit(1675140683.870:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.153718] audit: type=1131 audit(1675140683.870:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.156063] audit: type=1130 audit(1675140683.880:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.215988] systemd-journald[279]: Received client request to flush runtime journal.
[ 5.794509] audit: type=1130 audit(1675140684.510:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.807555] audit: type=1130 audit(1675140684.530:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.837697] audit: type=1130 audit(1675140684.560:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.861167] audit: type=1130 audit(1675140684.580:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.861209] audit: type=1334 audit(1675140684.580:10): prog-id=19 op=LOAD
[ 5.861222] audit: type=1334 audit(1675140684.580:11): prog-id=20 op=LOAD
[ 6.677363] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { P313 } 3 jiffies s: 113 root: 0x0/T
[ 6.682237] rcu: blocking rcu_node structures (internal RCU debug):
[ 7.981353] meson-vrtc ff8000a8.rtc: registered as rtc0
[ 7.981396] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[ 7.989043] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq
[ 8.042468] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present!
[ 8.045201] random: crng init done
[ 8.059706] Registered IR keymap rc-cec
[ 8.077332] rc rc0: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0
[ 8.089353] input: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0/input5
[ 8.142803] mc: Linux media interface: v0.10
[ 8.160676] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[ 8.689626] panfrost ffe40000.gpu: clock rate = 24000000
[ 8.689727] panfrost ffe40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[ 8.694952] videodev: Linux video capture interface: v2.00
[ 8.695562] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
[ 8.695588] panfrost ffe40000.gpu: features: 00000000,000027f7, issues: 00000000,00000400
[ 8.695595] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
[ 8.695602] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1
[ 8.704391] [drm] Initialized panfrost 1.2.0 20180908 for ffe40000.gpu on minor 1
[ 8.882169] Bluetooth: Core ver 2.22
[ 8.884123] NET: Registered PF_BLUETOOTH protocol family
[ 8.884148] Bluetooth: HCI device and connection manager initialized
[ 8.884165] Bluetooth: HCI socket layer initialized
[ 8.884174] Bluetooth: L2CAP socket layer initialized
[ 8.884195] Bluetooth: SCO socket layer initialized
[ 8.910770] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input2
[ 8.953816] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.956410] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.958213] usbcore: registered new interface driver brcmfmac
[ 8.966248] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.radxa,zero.bin failed with error -2
[ 8.966371] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.bin failed with error -2
[ 8.976662] Bluetooth: HCI UART driver ver 2.3
[ 8.976696] Bluetooth: HCI UART protocol H4 registered
[ 8.976700] Bluetooth: HCI UART protocol BCSP registered
[ 8.976833] Bluetooth: HCI UART protocol LL registered
[ 8.976838] Bluetooth: HCI UART protocol ATH3K registered
[ 8.976876] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 8.977198] Bluetooth: HCI UART protocol Intel registered
[ 8.977454] Bluetooth: HCI UART protocol Broadcom registered
[ 8.977632] Bluetooth: HCI UART protocol QCA registered
[ 8.977670] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 8.977687] Bluetooth: HCI UART protocol Marvell registered
[ 8.977827] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 9.050908] input: Logitech Wireless Device PID:4069 Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input6
[ 9.051575] input: Logitech Wireless Device PID:4069 Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input7
[ 9.051915] hid-generic 0003:046D:4069.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4069] on usb-xhci-hcd.0.auto-1/input2:1
[ 9.053778] input: Logitech Wireless Device PID:4076 Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4076.0005/input/input11
[ 9.054582] hid-generic 0003:046D:4076.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4076] on usb-xhci-hcd.0.auto-1/input2:2
[ 9.058403] input: Logitech Wireless Device PID:4055 Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4055.0006/input/input15
[ 9.058884] hid-generic 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:4055] on usb-xhci-hcd.0.auto-1/input2:3
[ 9.365825] Bluetooth: hci0: BCM: chip id 107
[ 9.366111] Bluetooth: hci0: BCM: features 0x2f
[ 9.367655] Bluetooth: hci0: BCM4345C0
[ 9.367682] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 9.368259] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 9.369242] Bluetooth: hci0: BCM: 'brcm/BCM4345C0.radxa,zero.hcd'
[ 9.375546] Bluetooth: hci0: BCM: 'brcm/BCM4345C0.hcd'
[ 9.380466] Bluetooth: hci0: BCM: 'brcm/BCM.radxa,zero.hcd'
[ 9.386181] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[ 9.912956] input: Logitech MX Master 2S as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input19
[ 9.913596] logitech-hidpp-device 0003:046D:4069.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 2S] on usb-xhci-hcd.0.auto-1/input2:1
[ 9.975331] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 10.285845] input: Logitech K540/K545 as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4076.0005/input/input20
[ 10.287248] logitech-hidpp-device 0003:046D:4076.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K540/K545] on usb-xhci-hcd.0.auto-1/input2:2
[ 10.394830] kauditd_printk_skb: 22 callbacks suppressed
[ 10.394845] audit: type=1130 audit(1675141310.580:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-resolved comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.418553] logitech-hidpp-device 0003:046D:4055.0006: HID++ 4.5 device connected.
[ 10.502295] audit: type=1130 audit(1675141310.690:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=sound comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.516819] audit: type=1334 audit(1675141310.710:36): prog-id=27 op=LOAD
[ 10.517559] audit: type=1334 audit(1675141310.710:37): prog-id=28 op=LOAD
[ 10.517984] audit: type=1334 audit(1675141310.710:38): prog-id=29 op=LOAD
[ 10.534728] audit: type=1130 audit(1675141310.720:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.014226] zram: Added device: zram0
[ 11.025870] zram0: detected capacity change from 0 to 11611936
[ 11.131551] Adding 5805964k swap on /dev/zram0. Priority:100 extents:1 across:5805964k SSFS
[ 11.141701] audit: type=1130 audit(1675141311.330:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=zswap-arm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.177117] audit: type=1130 audit(1675141311.370:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2-zram-setup@zram0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.177146] audit: type=1131 audit(1675141311.370:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2-zram-setup@zram0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.352478] audit: type=1130 audit(1675141311.540:43): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.417518] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.417544] Bluetooth: BNEP filters: protocol multicast
[ 11.417560] Bluetooth: BNEP socket layer initialized
[ 11.426027] Bluetooth: MGMT ver 1.22
[ 11.434830] input: Logitech Wireless Device PID:4055 as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4055.0006/input/input21
[ 11.443420] logitech-hidpp-device 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:4055] on usb-xhci-hcd.0.auto-1/input2:3
[ 17.780305] kauditd_printk_skb: 24 callbacks suppressed
[ 17.780319] audit: type=1334 audit(1675141317.970:68): prog-id=35 op=LOAD
[ 17.781040] audit: type=1334 audit(1675141317.970:69): prog-id=36 op=LOAD
[ 17.781177] audit: type=1334 audit(1675141317.970:70): prog-id=37 op=LOAD
[ 17.784438] audit: type=1334 audit(1675141317.970:71): prog-id=38 op=LOAD
[ 17.788262] audit: type=1334 audit(1675141317.980:72): prog-id=39 op=LOAD
[ 17.794785] audit: type=1334 audit(1675141317.980:73): prog-id=40 op=LOAD
[ 17.795468] audit: type=1334 audit(1675141317.990:74): prog-id=41 op=LOAD
[ 17.795616] audit: type=1334 audit(1675141317.990:75): prog-id=42 op=LOAD
[ 17.797115] audit: type=1334 audit(1675141317.990:76): prog-id=43 op=LOAD
[ 17.797569] audit: type=1334 audit(1675141317.990:77): prog-id=44 op=LOAD
[ 20.318447] platform ff64c000.mdio-multiplexer: deferred probe pending
[ 29.511840] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.513170] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.521333] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.527795] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.535830] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.542321] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.550407] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.556942] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.564930] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.571494] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.580432] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.586106] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.594100] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.600665] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.608716] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.615225] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.623226] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.629797] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.637819] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.644354] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.675980] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.677312] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.685762] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.691951] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.700231] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.706562] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.714848] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.721181] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.729443] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.735815] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.746013] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.750234] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.758659] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.764788] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.773473] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.779457] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.787779] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.794060] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.802322] fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[ 29.808623] fe.dai-link-1: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-1: -22
[ 29.817826] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.823189] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.831270] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.837754] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.846142] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.852353] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.860722] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.866924] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.875309] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.881491] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.891601] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.896125] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.904580] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.910761] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.919165] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.925286] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.933523] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.939831] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.951075] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.954280] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.964104] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.969032] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.977397] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.983927] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 29.991855] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 29.998073] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.006304] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.012567] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.020917] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.027628] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.037597] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.041723] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.050701] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.056727] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.064616] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.071690] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.079701] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.085944] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.093793] fe.dai-link-2: ASoC: no backend DAIs enabled for fe.dai-link-2
[ 30.100672] fe.dai-link-2: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-2: -22
[ 30.144999] Bluetooth: RFCOMM TTY layer initialized
[ 30.145037] Bluetooth: RFCOMM socket layer initialized
[ 30.145068] Bluetooth: RFCOMM ver 1.11
[ 33.078630] kauditd_printk_skb: 46 callbacks suppressed
[ 33.078655] audit: type=1100 audit(1675141333.270:120): pid=1049 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=? acct="admin" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 34.696394] audit: type=1334 audit(1675141334.890:121): prog-id=54 op=LOAD
[ 34.696783] audit: type=1334 audit(1675141334.890:122): prog-id=55 op=LOAD
[ 42.125725] audit: type=1131 audit(1675141342.320:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.305720] audit: type=1334 audit(1675141342.500:124): prog-id=51 op=UNLOAD
[ 42.305748] audit: type=1334 audit(1675141342.500:125): prog-id=50 op=UNLOAD
[ 42.305756] audit: type=1334 audit(1675141342.500:126): prog-id=49 op=UNLOAD
[ 42.584015] audit: type=1130 audit(1675141342.770:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.774572] audit: type=1130 audit(1675141345.960:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.602545] audit: type=1130 audit(1675141349.790:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.368620] logitech-hidpp-device 0003:046D:4076.0005: HID++ 4.1 device connected.
[ 80.713901] audit: type=1131 audit(1675141380.900:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 111.365891] audit: type=1100 audit(1675141411.560:131): pid=1375 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=? acct="admin" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'
[ 115.921896] audit: type=1100 audit(1675141416.110:132): pid=1375 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="admin" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.923315] audit: type=1101 audit(1675141416.110:133): pid=1375 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="admin" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.924535] audit: type=1110 audit(1675141416.110:134): pid=1375 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.925371] audit: type=1105 audit(1675141416.120:135): pid=1375 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.954977] audit: type=1100 audit(1675141416.140:136): pid=1376 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.955413] audit: type=1101 audit(1675141416.150:137): pid=1376 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.957465] audit: type=1103 audit(1675141416.150:138): pid=1376 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 115.958064] audit: type=1105 audit(1675141416.150:139): pid=1376 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 127.410068] audit: type=1130 audit(1675141427.600:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-networkd-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 217.732136] audit: type=1130 audit(1675141517.920:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 218.856440] audit: type=1130 audit(1675141519.050:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 219.497772] audit: type=1115 audit(1675141519.690:143): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user entries id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498160] audit: type=1115 audit(1675141519.690:144): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498251] audit: type=1115 audit(1675141519.690:145): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498326] audit: type=1115 audit(1675141519.690:146): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498385] audit: type=1115 audit(1675141519.690:147): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498448] audit: type=1115 audit(1675141519.690:148): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498509] audit: type=1115 audit(1675141519.690:149): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 219.498570] audit: type=1115 audit(1675141519.690:150): pid=1628 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=deleting user from group id=984 exe="/usr/bin/userdel" hostname=? addr=? terminal=? res=success'
[ 250.644577] kauditd_printk_skb: 21 callbacks suppressed
[ 250.644591] audit: type=1131 audit(1675141550.830:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 250.675561] audit: type=1334 audit(1675141550.870:173): prog-id=58 op=UNLOAD
[ 250.675594] audit: type=1334 audit(1675141550.870:174): prog-id=57 op=UNLOAD
[ 250.675605] audit: type=1334 audit(1675141550.870:175): prog-id=56 op=UNLOAD
