I’ve done some mistakes that I do not know how to fix that cause my DE to never start automatically and I have to CTRL+ALT+F2 to switch to a terminal and run “startplasma-wayland” manually.
This itself has gotten annoying and not to mention the unstability I have caused myself.
I wish to reinstall manjaro and with a diffrent DE or WM and I want i3 . but i dont want to wipe all my data with a USB install.
I wish I could find a way to install on top of my already existing install and apply to necessary changes. such as changing config files etc.
this seems possible. yet I lack the knowledge to do such thing. I’ve asked in arch discord servers but I got bullied . I hope this community is better
Don’t do it. It will be a mess. Better start a new.
My distro is already a mess man. i installed like 11 kernels and 3 desktop environments that I had no idea how to configure
'cause of this…don’t do it…
move the data you want to keep somewhere and make a new install.
will saving you much trouble and nerves…
Edit:
ok
Where Using an Existing Linux Partition Table
nevertheless…backup the data, you want to keep.
may you post the output of
use the option of preformatted text and paste it inside
I hope that’s going to be useful
Kernel: 6.7.0-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=e376cade-1015-4977-829d-acf46108cf9d rw quiet splash
resume=UUID=a063a8c1-534d-44e0-aaf7-64feea89ca7b udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 2
Type: Laptop System: Dell product: Latitude 5480 v: N/A
Mobo: Dell model: 0RH40R v: A01 serial: <superuser required> UEFI: Dell
v: 1.17.1 date: 01/07/2020
ID-1: BAT0 charge: 26.6 Wh (94.0%) condition: 28.3/33.3 Wh (84.9%) volts: 8.1
min: 7.4 model: SMP DELL GD1JP65 type: Li-ion serial: <filter>
status: not charging
System RAM: total: 8 GiB available: 7.64 GiB used: 3.09 GiB (40.5%)
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2345 high: 2400 min/max: 400/2400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 2399
4: 2182 bogomips: 20004
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:6717
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: vesa gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.46 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.3.3-manjaro1.1
device-ID: 8086:1916 surfaces: xcb,xlib,wayland
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.7.0-0-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 238.47 GiB used: 195.17 GiB (81.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: ADHA0102 temp: 43.9 C
scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 195.16 GiB (86.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e376cade-1015-4977-829d-acf46108cf9d
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6F5C-459C
ID-1: swap-1 type: partition size: 8.8 GiB used: 14 MiB (0.2%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: a063a8c1-534d-44e0-aaf7-64feea89ca7b
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 0000:3825 class-ID: 0301
Device-2: 1-5:3 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6717 class-ID: 0e02
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 45.0 C pch: 43.0 C mobo: 38.0 C
Fan Speeds (rpm): cpu: 0
Processes: 214 Uptime: 7m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 alt: 12 clang: 16.0.6 Packages: 2663
pm: pacman pkgs: 2649 libs: 403 tools: pamac,yay pm: flatpak pkgs: 14
Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
I guess you’re right. I thought there would be an easy way to switch distros while keeping the important data. after all, it’s all linux
see my edit above…
After the reinstallation, i would recomment creating a new clean user and move your data into it.
Hey that partition thing seems like it was what I was expecting to find here. that seems like the way to go. Thanks man I’ll dive in deeper into that stuff.
That drive is full, better clean up or move your data to other storage before you install anything else.
yes and that’s one of the reasons i wanted to switch from KDE in the first place and due to my lack of knowledge I wrecked many stuff in the process
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
