So I installed elementary os alpha build and decided to go back to manjaro. Pine 64 instructions didn’t seem to work. I tried the same method I used to install elementary. But when the pinebook boots with the micro sd card inserted it’s just a black screen with a red light on the battery indicator. It boots back to elementary when I remove it. Am I using the wrong image or something? Sorry. I’m a newb.
What Manjaro ARM image did you download?
You need one with pbpro
in the name.
I see. I used one just labeled arm. I’ll try a different image.
That seems to have been the problem. Thank you.
