Hello, something has gone peculiar with my system and despite endless suggested cures I’ve had no luck eliminating my problems which are : desktop icons don’t work, then they do, then they don’t, then the programs are slow (particularly Thunar), random freezes. So I thought the easiest and quickest way before I gathered too much data (I’m a new user as I’m sure you’ve guessed) I’d just reinstall.
Reading the Wiki it seems I can reinstall just the system and the installer will ignore my Home folder - is this correct? Is there any advice anyone can offer before I embark on this?
If you have lot’s of issue they might have been casued by your settings in your /home folder as well, you could potentially keep your issues. I would rather recommend to ignore your current install and to retinker it after a fresh install. Make notes what you adjust, then it will be easier next time you bork your system.
Hello linux-aarhus. This is very comprehensive - thank you for pointing it out to me.
I’m going to have to really digest this before I make any attempt with it! I can see the thrust of it and understand (mostly) what’s going on I just need the nerve to try it.
