Reinstalled Discover: No Internet Connectivity
Strange behavior of Discover:
I installed Discover and wanted to avoid Discover from attempting to do system updates. Search on the internet suggested to uninstall Packagekit-Qt6, which I did. Launching Discover after the removal of packagekit-qt6, Discover complains that there’s no internet connectivity.
I uninstalled Discover, removed the Discover folder in ~/.config and re-installed Discover, only to be greeted with the same message.
my inxi (should it be useful)
inxi -Faz
  Kernel: 6.11.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=3cdcf7a8-e102-4c5e-aa1e-6e5da6ebec90 rw quiet splash
    split_lock_detect=off resume=UUID=fff61947-f8bb-4176-9135-24f4c6a35e70
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.7.0
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: X515EA.309
    date: 05/16/2022
  ID-1: BAT0 charge: 28.2 Wh (80.6%) condition: 35.0/37.1 Wh (94.4%)
    volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 40
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xB8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1133 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1133 2: 1133 3: 1133 4: 1133 5: 1133 6: 1133
    7: 1133 8: 1133 bogomips: 38720
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1,HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 322e:2103
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1600x900 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 7.48 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
    name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 24.2.4-arch1.1
    device-ID: 8086:9a49 surfaces: xcb,xlib,wayland
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.11.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0032
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 931.51 GiB used: 94.33 GiB (10.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR003 temp: 25.9 C
    scheme: GPT
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 94.33 GiB (10.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.42 GiB (22.3%)
  Processes: 293 Power: uptime: 49m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1449 libs: 373 tools: pamac pm: flatpak pkgs: 0
    Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
Launched Discover from the terminal, got this (which with my limited knowledge doesn’t tell me much)
plasma-discover
libs QList("/usr/lib/qt6/plugins", "/usr/bin")
org.kde.plasma.libdiscover: OdrsReviewsBackend: Fetch ratings: false
adding empty sources model QStandardItemModel(0x6136d3c41fd0)
org.kde.plasma.libdiscover: error loading "fwupd-backend" "Cannot load library /usr/lib/qt6/plugins/discover/fwupd-backend.so: libfwupd.so.2: cannot open shared object file: No such file or directory" QJsonObject({"IID":"org.kde.muon.AbstractResourcesBackendFactory","archlevel":1,"className":"FwupdBackendFactory","debug":false,"version":395008})
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:358:9
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:361:9
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:409:13
qrc:/qt/qml/org/kde/discover/qml/BrowsingPage.qml:17:1: QML BrowsingPage: Created graphical object was not placed in the graphics scene.
PackageKitBackend: No distro component found for "org.manjaro.manjaro"
AppStreamIntegration: No distro component found for "org.manjaro.manjaro"
looking for cache entry
looking for cache entry 0
cache entry KNSCore::Entry(uniqueId: "2185639", name:"Nightglow Blue", status: Installed, installedFiles: QList("/home/henry/.local/share/aurorae/themes/nightglowblue/*")) "" ""
UPDATABLE QList()
cache entry KNSCore::Entry(uniqueId: "2186993", name:"Nightglow Blue", status: Installed, installedFiles: QList("/home/henry/.local/share/color-schemes/NightglowBlue.colors")) "1.0" "1.0"
UPDATABLE QList()
looking for cache entry 1
cache entry KNSCore::Entry(uniqueId: "1449538", name:"Spectrum Light", status: Installed, installedFiles: QList("/home/henry/.local/share/icons/spectrum-folders-light/*", "/home/henry/.local/share/icons/spectrum-light/*")) "0.2" "0.2"
looking for cache entry 3
cache entry KNSCore::Entry(uniqueId: "1367155", name:"PlasmaX icon theme", status: Installed, installedFiles: QList("/home/henry/.local/share/icons/PlasmaXDark/*")) "0.2" "0.2"
looking for cache entry 4
cache entry KNSCore::Entry(uniqueId: "2180417", name:"Aretha-Dark-Icons", status: Installed, installedFiles: QList("/home/henry/.local/share/icons/Aretha-Dark-Icons/*")) "" ""
cache entry KNSCore::Entry(uniqueId: "1449532", name:"Spectrum Dark", status: Installed, installedFiles: QList("/home/henry/.local/share/icons/spectrum-dark/*", "/home/henry/.local/share/icons/spectrum-folders-dark/*")) "0.2" "0.2"
UPDATABLE QList()
cache entry KNSCore::Entry(uniqueId: "2186817", name:"Nightglow Blue", status: Installed, installedFiles: QList("/home/henry/.local/share/wallpapers/NightglowBlue/*")) "1.0" "1.0"
UPDATABLE QList()
looking for cache entry 2
cache entry KNSCore::Entry(uniqueId: "1279924", name:"Tela-icon-theme", status: Installed, installedFiles: QList("/home/henry/.local/share/icons/Tela-dark/*", "/home/henry/.local/share/icons/Tela-light/*", "/home/henry/.local/share/icons/Tela/*")) "" ""
UPDATABLE QList(KNSCore::Entry(uniqueId: "1279924", name:"Tela-icon-theme", status: Updateable, installedFiles: QList("/home/henry/.local/share/icons/Tela-dark/*", "/home/henry/.local/share/icons/Tela-light/*", "/home/henry/.local/share/icons/Tela/*")))
The puzzling thing to me is the fact that I installed Discover, removed Discover, Packagekit-qt6, re-installed Packagekit-Qt6, re-installed Discover and it continues to show the same error.
My aim is to use Discover as a convenient means to update themes and icons without having to lurk in the KDE Store.
Discover has been updated to 6.2.1-2 and now works perfectly
