I updated Manjaro, rebooted, updated the AUR packages, rebuilded python
$ pamac build $(pacman -Qoq /usr/lib/python3.10)
than I followed the ‘Minimal short version’ of that guide ‘Reinstall non-working Python packages after a Python interpreter upgrade’
and everything went smooth, but 2 packages come up by pip check.
$ pip check
yt-dlp 2023.3.4 requires websockets, which is not installed.
electrum 4.3.2 has requirement protobuf<4,>=3.12, but you have protobuf 4.21.12
I followed all instructions by that guide, what do I miss and how to fix it?
Thanks for advice.
websockets is an optional dependency of yt-dlp, so it’s up to you if you want to install it
sudo pacman -S python-websockets --asdeps
You have the protobuf package in Manajro repos, but it seems to be newer than what electrum needs. There is a package in AUR with the version you need, but I am not sure can they both be installed at the same time and if you have some software that depends on the repo version.
The Manjaro Electrum package comes directly from Arch, and right now Arch hasn’t either updated that package. So, it’s going to take a little bit at least
