I usually upgrade with
sudo pacman-mirrors --fasttrack 10 && sudo pacman -Syyu
I am trying to use pamac
as default and want to know if the relevant command is:
sudo pacman-mirrors --fasttrack 10 && pamac upgrade
Thanks.
Thanks.
Hi,
The pamac command would be pamac update -a
This would also include any AUR packages you have installed.
sudo pacman-mirrors --fasttrack 10 && sudo pamac upgrade
run pamac -h
for help (or man pamac
) upgrade == update
I have the same question as chandra because i couldn’t see a Firefox update in the past under the pamac GUI and it couldn’t find it even after several days of waiting.
I had to update the mirrors to see the package and i did this with:
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
This was the time where i switched from pacman to pamac, but today after i had problems with the stable update… i saw that pamac is recommend but with pamac update
i don’t see there will be mirrors updated in background and i also can’t find the a mirror command in pamac -h or man pamac.
Edit: Correct me if im wrong, but i think that sudo pacman-mirrors --fasttrack
and after that pamac update -a
is the way to go here?
My question is now to run this both commands in a single step… will this following command work?
sudo pacman-mirrors --fasttrack && pamac update -a
Double Edit: My command won’t work, we have to use 2 commands then
2 different command. run pacman-mirror for get best mirror and after we can use pacman,pamac, yay or…
pacman-mirrors is for all
To bad this won’t work in a combo… would safe time
works for me.
