Hi!
unstable branch.
Pamac 10.3.0-2 - libpamac 11.2.0
command called and it’s output:
pamac update --force-refresh
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Refreshing chaotic-aur.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing community.files...
Refreshing multilib.files...
Refreshing chaotic-aur.files...
Refreshing AUR...
Nothing to do.
A few days ago I noted that new Refreshing AUR... stage appeared while calling force refresh.
I have semi-garbage PC
~/Desktop ❯ inxi -Fazy1
Kernel: 5.16.2-1-MANJARO x86_64
bits: 64
compiler: gcc
v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64 root=UUID=b3cf0f6a-55e1-4e25-83d5-88c0781c30e3 rw rootflags=subvol=@ quiet cryptdevice=UUID=ef44cf91-5209-4ff4-95bf-ffb124a71d7e:luks-ef44cf91-5209-4ff4-95bf-ffb124a71d7e root=/dev/mapper/luks-ef44cf91-5209-4ff4-95bf-ffb124a71d7e apparmor=1 security=apparmor udev.log_priority=3 ipv6.disable=1
Desktop: KDE Plasma 5.23.5
tk: Qt 5.15.2
wm: kwin_x11
vt: 1
dm: SDDM
Distro: Manjaro Linux
base: Arch Linux
Type: Laptop
System: ASUSTeK
product: K50IJ
v: 1.0
serial: <superuser required>
Mobo: ASUSTeK
model: K50IJ
v: 1.0
BIOS: American Megatrends
v: 218
date: 04/09/2010
Device-1: hidpp_battery_0
model: Logitech Wireless Mouse
serial: <filter>
charge: 55% (should be ignored)
rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1
model: Logitech Wireless Keyboard K360
serial: <filter>
charge: 100% (should be ignored)
rechargeable: yes
status: Discharging
model: Celeron T3100
bits: 64
type: MCP
arch: Core Penryn
family: 6
model-id: 0x17 (23)
stepping: 0xA (10)
microcode: 0xA0B
Topology:
cpus: 1
cores: 2
smt: <unsupported>
cache:
L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB
L2: 1024 KiB
desc: 1x1024 KiB
Speed (MHz):
avg: 1895
min/max: N/A
cores:
1: 1895
2: 1895
bogomips: 7584
Flags: ht lm nx pae sse sse2 sse3 ssse3
Type: itlb_multihit
status: KVM: VMX unsupported
Type: l1tf
mitigation: PTE Inversion
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: meltdown
mitigation: PTI
status: Vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds
status: Not affected
Type: tsx_async_abort
Device-1: Intel Mobile 4 Series Integrated Graphics
vendor: ASUSTeK
driver: i915
v: kernel
bus-ID: 00:02.0
chip-ID: 8086:2a42
class-ID: 0300
Device-2: Chicony 2.0M UVC Webcam / CNF7129
type: USB
driver: uvcvideo
bus-ID: 1-3:2
chip-ID: 04f2:b071
class-ID: 0e02
serial: <filter>
Display: x11
server: X.org 1.21.1.3
compositor: kwin_x11
driver:
loaded: modesetting
alternate: fbdev,vesa
Device-1: Intel 82801I HD Audio
vendor: Santa Cruz Operation
driver: snd_hda_intel
v: kernel
bus-ID: 00:1b.0
chip-ID: 8086:293e
class-ID: 0403
Sound Server-1: ALSA
v: k5.16.2-1-MANJARO
running: yes
Sound Server-2: JACK
v: 1.9.20
running: no
Sound Server-3: PulseAudio
v: 15.0
running: yes
Sound Server-4: PipeWire
v: 0.3.43
running: yes
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK
driver: ATL1E
v: N/A
modules: atl1e
port: ec00
bus-ID: 02:00.0
chip-ID: 1969:1026
class-ID: 0200
IF: enp2s0
state: up
speed: 100 Mbps
duplex: full
mac: <filter>
Device-1: Realtek Bluetooth Radio
type: USB
driver: btusb
v: 0.8
bus-ID: 6-1:2
chip-ID: 0bda:8771
class-ID: e001
serial: <filter>
Report: rfkill
rfk-id: 2
state: up
address: see --recommends
Local Storage:
total: 232.89 GiB
used: 90.71 GiB (38.9%)
ID-1: /dev/sda
maj-min: 8:0
vendor: Seagate
model: ST9250315AS
block-size:
physical: 512 B
logical: 512 B
speed: 3.0 Gb/s
type: HDD
rpm: 5400
serial: <filter>
rev: SDM1
scheme: MBR
ID-1: /
raw-size: 232.88 GiB
size: 232.88 GiB (100.00%)
used: 90.71 GiB (39.0%)
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
mapped: luks-ef44cf91-5209-4ff4-95bf-ffb124a71d7e
ID-2: /home
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
ID-3: /var/log
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
Kernel:
swappiness: 1 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1
type: file
used: 1.3 MiB (0.2%)
priority: -2
file: /swap/swapfile
System Temperatures:
cpu: 53.0 C
mobo: N/A
Processes: 219
Uptime: 14m
wakeups: 5
Memory: 3.8 GiB
used: 2.7 GiB (71.1%)
Init: systemd
v: 250
tool: systemctl
Compilers:
gcc: 11.1.0
clang: 13.0.0
Packages:
pacman: 1249
lib: 334
flatpak: 0
Shell: Zsh
v: 5.8
default: Bash
v: 5.1.16
running-in: konsole
inxi: 3.3.12
I got 2 system hangs while pamac doing that brand new Refreshing AUR stage: last one I have a web browser opened with about 5 youtube video tabs, at least three of them was paused, one was watching, also I have as opened a one more tab.
I decide to issue the pamac command above.
I got unresponsive PC at least for 1h 20 mins. After that I pulled out power source from the PC.
That was second time with that command run and on that mentioned stage.
After reboot I split terminal screen into two parts and executed the
watch -n 1 free -m
and
I watched for the available field value of free.
For some AUR procedure I saw pamac was downloading a 9.3 MiB file and then was the Refreshing AUR... stage. I saw that while a file was downloading RAM available value was near 2400 MiB, during the stage I saw it was as low as 980 MiB.
I think that low end PCs (with low memory is incompatible with the current algorithm of pamac's force refresh action).
The issue is absent while I update other repos, including chaotic-aur but present during that Refreshing AUR stage.
Please try to optimize the algorithm to lower RAM usage (1.5 GiB from 10 MiB file) or add pamac requirements of 1.5 of RAM to proceed the dbs force update request.
Thank you!
