The microphone is not being recognized, I am using a p2 to p3 adapter for this notebook, and this is enough to work on windows.
The problem is that in Manjaro it doesn’t recognize this new device, it’s like it doesn’t even exist, try following the documentation: PulseAudio/Troubleshooting - ArchWiki
but it didn’t work, what should i do?
inxi -Fazy
Kernel: 5.18.19-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=c04917e7-7b3e-4b1d-92fd-bb47156b6f87 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82CG v: IdeaPad Gaming 3 15IMH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IMH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN
serial: <superuser required> UEFI: LENOVO v: EGCN33WW date: 12/24/2020
ID-1: BAT0 charge: 39.4 Wh (100.0%) condition: 39.4/45.0 Wh (87.5%)
volts: 12.8 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: full cycles: 106
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 899 high: 901 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 901 3: 899 4: 900
5: 900 6: 900 7: 900 8: 898 bogomips: 40009
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-08) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 928x285mm (36.54x11.22")
s-diag: 971mm (38.22")
Monitor-1: HDMI-1-0 pos: right res: 1600x900 hz: 60 dpi: 92
size: 443x249mm (17.44x9.8") diag: 508mm (20.01") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
bus-ID: 1-3:8 v: kernel chip-ID: 1c1f:2014
alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0300
bus-ID: 00:1f.3 serial: <filter> chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-3: Goldvish S.A. H310 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.19-3-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.34 TiB used: 927.02 GiB (67.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SSSTC model: CL1-4D256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 1S262 temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: KingSpec model: NE-256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S1111A0L temp: 42.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: KingSpec model: P4-960
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 60 scheme: MBR
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 37 GiB (75.6%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 483 MiB size: 482 MiB (99.80%) used: 292 KiB
(0.1%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:9
ID-3: /home raw-size: 187.99 GiB size: 183.98 GiB (97.87%) used: 108.65
GiB (59.1%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 59.0 C pch: 55.0 C mobo: N/A
Processes: 296 Uptime: 37m wakeups: 1 Memory: 15.5 GiB used: 7.85 GiB
(50.7%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1547 pm: pacman pkgs: 1526 libs: 396
tools: pamac,yay pm: snap pkgs: 21 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.21
pactl list cards
Placa #0
Nome: alsa_card.pci-0000_01_00.1
Driver: module-alsa-card.c
Módulo proprietário: 6
Propriedades:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xc5000000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10fa"
device.string = "1"
device.description = "HDA NVidia"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Perfis:
output:hdmi-stereo: Saída Digital Stereo (HDMI) (destino: 1, fontes: 0, prioridade: 38668, disponível: sim)
output:hdmi-stereo-extra1: Saída Digital Stereo (HDMI 2) (destino: 1, fontes: 0, prioridade: 5700, disponível: não)
output:hdmi-surround-extra1: Saída Digital Surround 5.1 (HDMI 2) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-surround71-extra1: Saída Digital Surround 7.1 (HDMI 2) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-stereo-extra2: Saída Digital Stereo (HDMI 3) (destino: 1, fontes: 0, prioridade: 5700, disponível: não)
output:hdmi-surround-extra2: Saída Digital Surround 5.1 (HDMI 3) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-surround71-extra2: Saída Digital Surround 7.1 (HDMI 3) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-stereo-extra3: Saída Digital Stereo (HDMI 4) (destino: 1, fontes: 0, prioridade: 5700, disponível: não)
output:hdmi-surround-extra3: Saída Digital Surround 5.1 (HDMI 4) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-surround71-extra3: Saída Digital Surround 7.1 (HDMI 4) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
off: Desligado (destino: 0, fontes: 0, prioridade: 0, disponível: sim)
Perfil ativo: output:hdmi-stereo
Portas:
hdmi-output-0: HDMI / DisplayPort (tipo: HDMI, prioridade: 5900, mudança da latência: 0 usec, disponível)
Propriedades:
device.product.name = "SMB2030N
Parte de perfil/perfis: output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (tipo: HDMI, prioridade: 5800, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (tipo: HDMI, prioridade: 5700, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (tipo: HDMI, prioridade: 5600, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Placa #2
Nome: alsa_card.pci-0000_00_1f.3
Módulo proprietário: 8
Propriedades:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xc559c000 irq 159"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "06c8"
device.product.name = "Comet Lake PCH cAVS"
device.string = "0"
device.description = "Áudio interno"
Perfis:
input:analog-stereo: Entrada Estéreo analógico (destino: 0, fontes: 1, prioridade: 32833, disponível: sim)
output:analog-stereo: Saída Estéreo analógico (destino: 1, fontes: 0, prioridade: 39268, disponível: sim)
output:analog-stereo+input:analog-stereo: Duplex estéreo analógico (destino: 1, fontes: 1, prioridade: 39333, disponível: sim)
output:hdmi-stereo: Saída Digital Stereo (HDMI) (destino: 1, fontes: 0, prioridade: 5900, disponível: não)
output:hdmi-stereo+input:analog-stereo: Saída Digital Stereo (HDMI) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 5965, disponível: sim)
output:hdmi-surround: Saída Digital Surround 5.1 (HDMI) (destino: 1, fontes: 0, prioridade: 800, disponível: não)
output:hdmi-surround+input:analog-stereo: Saída Digital Surround 5.1 (HDMI) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 865, disponível: sim)
output:hdmi-surround71: Saída Digital Surround 7.1 (HDMI) (destino: 1, fontes: 0, prioridade: 800, disponível: não)
output:hdmi-surround71+input:analog-stereo: Saída Digital Surround 7.1 (HDMI) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 865, disponível: sim)
output:hdmi-stereo-extra1+input:analog-stereo: Saída Digital Stereo (HDMI 2) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 5765, disponível: sim)
output:hdmi-surround-extra1+input:analog-stereo: Saída Digital Surround 5.1 (HDMI 2) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-surround71-extra1+input:analog-stereo: Saída Digital Surround 7.1 (HDMI 2) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-stereo-extra2+input:analog-stereo: Saída Digital Stereo (HDMI 3) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 5765, disponível: sim)
output:hdmi-surround-extra2+input:analog-stereo: Saída Digital Surround 5.1 (HDMI 3) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-surround71-extra2+input:analog-stereo: Saída Digital Surround 7.1 (HDMI 3) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-stereo-extra3+input:analog-stereo: Saída Digital Stereo (HDMI 4) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 5765, disponível: sim)
output:hdmi-surround-extra3+input:analog-stereo: Saída Digital Surround 5.1 (HDMI 4) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-surround71-extra3+input:analog-stereo: Saída Digital Surround 7.1 (HDMI 4) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-stereo-extra4: Saída Digital Stereo (HDMI 5) (destino: 1, fontes: 0, prioridade: 5700, disponível: não)
output:hdmi-stereo-extra4+input:analog-stereo: Saída Digital Stereo (HDMI 5) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 5765, disponível: sim)
output:hdmi-surround-extra4: Saída Digital Surround 5.1 (HDMI 5) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-surround-extra4+input:analog-stereo: Saída Digital Surround 5.1 (HDMI 5) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
output:hdmi-surround71-extra4: Saída Digital Surround 7.1 (HDMI 5) (destino: 1, fontes: 0, prioridade: 600, disponível: não)
output:hdmi-surround71-extra4+input:analog-stereo: Saída Digital Surround 7.1 (HDMI 5) + Entrada Estéreo analógico (destino: 1, fontes: 1, prioridade: 665, disponível: sim)
Perfil ativo: input:analog-stereo
Portas:
analog-input-internal-mic: Internal Microphone (tipo: Mic, prioridade: 8900, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
analog-input-mic: Microphone (tipo: Mic, prioridade: 8700, mudança da latência: 0 usec, disponível)
Propriedades:
analog-output-speaker: Speakers (tipo: Auto-falante, prioridade: 10000, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (tipo: Fones de ouvido, prioridade: 9900, mudança da latência: 0 usec, disponível)
Propriedades:
hdmi-output-0: HDMI / DisplayPort (tipo: HDMI, prioridade: 5900, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
hdmi-output-4: HDMI / DisplayPort 5 (tipo: HDMI, prioridade: 5500, mudança da latência: 0 usec, não disponível)
Propriedades:
Parte de perfil/perfis: output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
Placa #3
Nome: alsa_card.usb-Sevenfox_Co._Ltd._H310_000000000000-00
Módulo proprietário: 26
Propriedades:
alsa.card = "2"
alsa.card_name = "H310"
alsa.long_card_name = "Sevenfox Co.,Ltd. H310 at usb-0000:00:14.0-3, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:3:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/sound/card2"
udev.id = "usb-Sevenfox_Co._Ltd._H310_000000000000-00"
device.bus = "usb"
device.vendor.id = "1c1f"
device.vendor.name = "Goldvish S.A."
device.product.id = "2014"
device.product.name = "H310"
device.serial = "Sevenfox_Co._Ltd._H310_000000000000"
device.string = "2"
device.description = "H310"
device.icon_name = "audio-card-usb"
Perfis:
input:mono-fallback: Entrada Mono (destino: 0, fontes: 1, prioridade: 1, disponível: sim)
output:analog-stereo: Saída Estéreo analógico (destino: 1, fontes: 0, prioridade: 6500, disponível: sim)
output:analog-stereo+input:mono-fallback: Saída Estéreo analógico + Entrada Mono (destino: 1, fontes: 1, prioridade: 6501, disponível: sim)
output:iec958-stereo: Saída Estéreo digital (IEC958) (destino: 1, fontes: 0, prioridade: 5500, disponível: sim)
output:iec958-stereo+input:mono-fallback: Saída Estéreo digital (IEC958) + Entrada Mono (destino: 1, fontes: 1, prioridade: 5501, disponível: sim)
output:iec958-ac3-surround-51: Saída Surround digital 5.1 (IEC958/AC3) (destino: 1, fontes: 0, prioridade: 300, disponível: sim)
output:iec958-ac3-surround-51+input:mono-fallback: Saída Surround digital 5.1 (IEC958/AC3) + Entrada Mono (destino: 1, fontes: 1, prioridade: 301, disponível: sim)
Perfil ativo: output:analog-stereo+input:mono-fallback
Portas:
analog-input-mic: Microphone (tipo: Mic, prioridade: 8700, mudança da latência: 0 usec, disponibilidade desconhecida)
Propriedades:
Parte de perfil/perfis: input:mono-fallback, output:analog-stereo+input:mono-fallback, output:iec958-stereo+input:mono-fallback, output:iec958-ac3-surround-51+input:mono-fallback
analog-output: Analog Output (tipo: Analógico, prioridade: 9900, mudança da latência: 0 usec, disponibilidade desconhecida)
Parte de perfil/perfis: output:analog-stereo, output:analog-stereo+input:mono-fallback
iec958-stereo-output: Digital Output (S/PDIF) (tipo: SPDIF, prioridade: 0, mudança da latência: 0 usec, disponibilidade desconhecida)
Parte de perfil/perfis: output:iec958-stereo, output:iec958-stereo+input:mono-fallback
