I was using it yesterday to update my weekly journal. I believe I did a very minor system update yesterday - one package? - possibly after I’d been using rednotebook. Memory hazy.
Today rednotebook simply won’t launch: timer goes round for a bit, then vanishes and nothing further happens.
Terminal gives this, which I don’t understand and thus this post for help:
~ rednotebook ✔
INFO Using GtkSourceView 4
Adding /usr/lib/python3.13/site-packages to sys.path
File "/usr/bin/rednotebook", line 6, in <module>
import journal
ModuleNotFoundError: No module named 'journal'
During handling of the above exception, another exception occurred:
File "/usr/bin/rednotebook", line 12, in <module>
import rednotebook.journal
File "/usr/lib/python3.13/site-packages/rednotebook/journal.py", line 71, in <module>
from rednotebook.util import filesystem
File "/usr/lib/python3.13/site-packages/rednotebook/util/filesystem.py", line 40, in <module>
gi.require_version("GIRepository", "2.0")
File "/usr/lib/python3.13/site-packages/gi/__init__.py", line 132, in require_version
raise ValueError('Namespace %s not available for version %s' %
(namespace, version))
ValueError: Namespace GIRepository not available for version 2.0
Full system info:
~ inxi --full --admin --filter --width ✔
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1
Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
UEFI-[Legacy]: American Megatrends v: 0606 date: 12/12/2017
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
vulnerable
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: none empty: DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
class-ID: 0300 temp: 44.0 C
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13.4.4:9
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
compositor: gnome-shell driver: gpu: nouveau display-ID: 0
Monitor-1: DVI-D-1 model: NEC 20WGX2 serial: <filter> built: 2007
res: 1680x1050 dpi: 99 gamma: 1.2 size: 433x270mm (17.05x10.63")
diag: 510mm (20.1") ratio: 16:10 modes: max: 1680x1050 min: 720x400
Monitor-2: HDMI-A-1 model: LG (GoldStar) W2243 serial: <filter> built: 2009
res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x269mm (18.78x10.59")
diag: 548mm (21.6") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 25.0.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: NV137 device-ID: 10de:1c82 memory: 3.89 GiB
unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: wireplumber status: active
tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:4 chip-ID: 0b05:190e
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 3.19 TiB used: 1.37 TiB (42.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 43.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Samsung model: MZVKW512HMJP-00000
lanes: 4 tech: SSD serial: <filter> fw-rev: CXA7500Q temp: 45.9 C
scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%) used: 54.6 GiB (11.7%)
fs: ext4 dev: /dev/nvme2n1p1 maj-min: 259:5
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.48 GiB used: 3.26 GiB (21.1%)
Processes: 352 Power: uptime: 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.16 GiB services: gsd-power,
tool: systemctl
Packages: 1644 pm: pacman pkgs: 1622 libs: 405 tools: gnome-software,pamac
pm: flatpak pkgs: 22 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.37
