The colors (on every screen - also attached external monitors) are wrong. It seems to be blue and red that are swapped. This also happens when I log in with a new user. And it only happens on gnome classic and gnome shell on xorg. I tried xfce and wayland.
Not all applications have that issue but the most: e.g a screenshot of this very site on firefox and vivaldi:
I have the feeling it was the last updated but it could also be some messing around with amdgpu drivers as I had an issue with a game. But if it would be the driver it would be wrong in every app and in gdm.
When taking a screenshot with flameshot the colors are correct and also when I sign out the colors appear normal for may be two tenth of a second before I get gdm.
You might imagine I tried a lot already: downgrading to 46.1, switchting to wayland etc… Switchting to wayland might work but other things are not working that I often use so it is not an option. I also want to know what is the reason and try getting it solved.
Additional thought: At least one of those screenshots is a dead-ringer for tritanopia correction in the Gnome Colorblind Filters Extension. I’m not saying that this is the cause, but is it possible that you or someone else has installed some accessibility software that may be causing the issue?
ah nice extension. It was not installed before and it seems this extension would also change how chromium browsers would calculate colors. But my issue is only outside of chromium browsers. I’m just confused because vivaldi is now showing a pink manjaro logo on a purple background (even after disabling the extension).
update: this was due to a test with color profiles from the monitor… they also apply to vivaldi but it seems they are only effective after relogin and for every user…
