I’ve encountered a peculiar problem recently while using CLion:
Whenever I try to create a new folder with CLion, the system forcibly logs out, and this issue is reproducible. I am not sure whether the problem lies with CLion or Manjaro. I have printed the system logs using sudo journalctl -rb
and discovered that Xorg has crashed. I can also provide the logs from CLion, though they do not seem to be helpful. I hope everyone can help me report this issue or offer some suggestions. Thank you!
system info:
██████████████████ ████████ OS: Manjaro 23.1.4 Vulcan
██████████████████ ████████ Kernel: x86_64 Linux 6.1.85-1-MANJARO
██████████████████ ████████ Uptime: 1h 28m
████████ ████████ Packages: 1865
████████ ████████ ████████ Shell: zsh 5.9
████████ ████████ ████████ Resolution: 4480x1600
████████ ████████ ████████ DE: KDE 5.115.0 / Plasma 5.27.11
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ GTK Theme: Breeze [GTK3]
████████ ████████ ████████ Icon Theme: WhiteSur
████████ ████████ ████████ Disk: 932G / 1.2T (81%)
████████ ████████ ████████ CPU: AMD Ryzen 7 5800H with Radeon Graphics @ 16x 3.2GHz
████████ ████████ ████████ GPU: NVIDIA GeForce RTX 3060 Laptop GPU
RAM: 9015MiB / 23392MiB
the log of journalctl:
4月 17 10:00:12 ling-20ym plasmashell[9562]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kglobalaccel5[9536]: X connection to :0 broken (explicit kill or server shutdown).
4月 17 10:00:12 ling-20ym fcitx5[9756]: I2024-04-17 10:00:12.076573 xcbmodule.cpp:76] Disconnected from X11 Display :0
4月 17 10:00:12 ling-20ym fcitx5[9756]: I2024-04-17 10:00:12.076291 inputcontextmanager.cpp:356] All display connections are gone, exit now.
4月 17 10:00:12 ling-20ym kglobalaccel5[9536]: The X11 connection broke: I/O error (code 1)
4月 17 10:00:12 ling-20ym systemd[1505]: dbus-:1.360-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
4月 17 10:00:12 ling-20ym systemd[1505]: dbus-:1.360-org.a11y.atspi.Registry@0.service: Main process exited, code=exited, status=1/FAILURE
4月 17 10:00:12 ling-20ym kglobalaccel5[9536]: QDBusObjectPath: invalid path "/component/网___乐_desktop"
4月 17 10:00:12 ling-20ym systemd[1505]: plasma-kscreen.service: Failed with result 'exit-code'.
4月 17 10:00:12 ling-20ym systemd[1505]: plasma-kscreen.service: Main process exited, code=exited, status=1/FAILURE
4月 17 10:00:12 ling-20ym kwin_x11[9484]: file:///usr/share/kwin/outline/plasma/outline.qml:14: TypeError: Cannot read property 'longDuration' of null
4月 17 10:00:12 ling-20ym systemd[1505]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
4月 17 10:00:12 ling-20ym systemd[1505]: plasma-xembedsniproxy.service: Main process exited, code=exited, status=1/FAILURE
4月 17 10:00:12 ling-20ym gmenudbusmenuproxy[9596]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kglobalaccel5[9536]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kscreen_backend_launcher[9613]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym msm_kde_notifier[9755]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kactivitymanagerd[9587]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kwalletd5[9388]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kwin_x11[9484]: The X11 connection broke: I/O error (code 1)
4月 17 10:00:12 ling-20ym ksmserver[9481]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kded5[9483]: The X11 connection broke: I/O error (code 1)
4月 17 10:00:12 ling-20ym xembedsniproxy[9600]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kdeconnectd[9708]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym optimus-manager-qt[9751]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym xdg-desktop-portal-kde[9599]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym org_kde_powerdevil[9598]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym polkit-kde-authentication-agent-1[9597]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym qbittorrent[9759]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym kaccess[9779]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym pamac-tray-plasma[9789]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym konsole[10329]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym chrome[10454]: The X11 connection broke: I/O error (code 1)
4月 17 10:00:12 ling-20ym fcitx5[9756]: W2024-04-17 10:00:12.062261 xcbeventreader.cpp:51] XCB connection ":0" got error: 1
4月 17 10:00:12 ling-20ym kded5[9483]: after 106 requests (106 known processed) with 0 events remaining.
4月 17 10:00:12 ling-20ym kded5[9483]: XIO: fatal IO error 0 (成功) on X server ":0"
4月 17 10:00:12 ling-20ym plasmashell[10460]: [10507:10507:0417/100012.061953:ERROR:connection.cc(61)] X connection error received.
4月 17 10:00:12 ling-20ym plasmashell[10460]: after 298 requests (298 known processed) with 0 events remaining.
4月 17 10:00:12 ling-20ym plasmashell[10460]: [10507:10619:0417/100012.061953:ERROR:connection.cc(61)] X connection error received.
4月 17 10:00:12 ling-20ym plasmashell[10460]: XIO: fatal IO error 25 (对设备不适当的 ioctl 操作) on X server ":0"
4月 17 10:00:12 ling-20ym kwin_x11[9484]: after 178760 requests (178760 known processed) with 0 events remaining.
4月 17 10:00:12 ling-20ym kwin_x11[9484]: XIO: fatal IO error 0 (成功) on X server ":0"
4月 17 10:00:12 ling-20ym fcitx5[9756]: The X11 connection broke (error 1). Did the X11 server die?
4月 17 10:00:12 ling-20ym at-spi2-registryd[9928]: X connection to :0 broken (explicit kill or server shutdown).
4月 17 10:00:12 ling-20ym systemd[1]: systemd-coredump@4-12303-0.service: Deactivated successfully.
4月 17 10:00:12 ling-20ym systemd-coredump[12304]: Process 9324 (Xorg) of user 0 dumped core.
Stack trace of thread 9324:
#0 0x00007f2e29ac232c n/a (libc.so.6 + 0x9132c)
#1 0x00007f2e29a716c8 raise (libc.so.6 + 0x406c8)
#2 0x00007f2e29a594b8 abort (libc.so.6 + 0x284b8)
#3 0x000056147504db00 OsAbort (Xorg + 0x159b00)
#4 0x000056147504de3b FatalError (Xorg + 0x159e3b)
#5 0x0000561475045d46 n/a (Xorg + 0x151d46)
#6 0x00007f2e29a71770 n/a (libc.so.6 + 0x40770)
#7 0x00007f2e29ac232c n/a (libc.so.6 + 0x9132c)
#8 0x00007f2e29a716c8 raise (libc.so.6 + 0x406c8)
#9 0x00007f2e29a594b8 abort (libc.so.6 + 0x284b8)
#10 0x00007f2e29a5a395 n/a (libc.so.6 + 0x29395)
#11 0x00007f2e29acc2a7 n/a (libc.so.6 + 0x9b2a7)
#12 0x00007f2e29ad0a4c malloc (libc.so.6 + 0x9fa4c)
#13 0x0000561474fce800 n/a (Xorg + 0xda800)
#14 0x0000561474f3304e n/a (Xorg + 0x3f04e)
#15 0x00007f2e29a5acd0 n/a (libc.so.6 + 0x29cd0)
#16 0x00007f2e29a5ad8a __libc_start_main (libc.so.6 + 0x29d8a)
#17 0x0000561474f33605 _start (Xorg + 0x3f605)
Stack trace of thread 9326:
#0 0x00007f2e29abcebe n/a (libc.so.6 + 0x8bebe)
#1 0x00007f2e29abf750 pthread_cond_wait (libc.so.6 + 0x8e750)
#2 0x00007f2e25f021fc n/a (radeonsi_dri.so + 0x1021fc)
#3 0x00007f2e25f18f0c n/a (radeonsi_dri.so + 0x118f0c)
#4 0x00007f2e29ac055a n/a (libc.so.6 + 0x8f55a)
#5 0x00007f2e29b3da3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 9331:
Stack trace of thread 9327:
Stack trace of thread 9330:
Stack trace of thread 9333:
Stack trace of thread 9332:
Stack trace of thread 9329:
Stack trace of thread 9328:
Stack trace of thread 9339:
#0 0x00007f2e29abd110 n/a (libc.so.6 + 0x8c110)
#1 0x00007f2e29ac3a0a pthread_mutex_lock (libc.so.6 + 0x92a0a)
#2 0x000056147503fe75 n/a (Xorg + 0x14be75)
#3 0x00005614750408e2 n/a (Xorg + 0x14c8e2)
#4 0x00005614750446e9 n/a (Xorg + 0x1506e9)
#5 0x00007f2e29ac055a n/a (libc.so.6 + 0x8f55a)
#6 0x00007f2e29b3da3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 9334:
Stack trace of thread 10222:
Stack trace of thread 10223:
4月 17 10:00:11 ling-20ym systemd[1]: Started Process Core Dump (PID 12303/UID 0).
4月 17 10:00:11 ling-20ym plasmashell[11915]: 2024-04-17 10:00:11,259 [ 14757] WARN - #c.i.o.u.WindowStateService - cannot find a project frame for ProjectDefault (Template) Project
4月 17 10:00:11 ling-20ym plasmashell[11915]: 2024-04-17 10:00:11,258 [ 14756] WARN - #c.i.o.u.WindowStateService - cannot find a project frame for ProjectDefault (Template) Project
4月 17 10:00:02 ling-20ym kwin_x11[9484]: kwin_core: XCB error: 3 (BadWindow), sequence: 41054, resource id: 56623440, major code: 129 (SHAPE), minor code: 6 (Input)
and the log of clion:
2024-04-17 10:00:01,747 [ 5245] INFO - #c.i.o.p.MergingQueueGuiExecutor - Running task: (dumb mode task) com.jetbrains.cidr.lang.symbols.symtable.building.OCInitialTablesBuildingActivity$runActivity$1@5bf5141b
2024-04-17 10:00:01,755 [ 5253] INFO - #c.i.o.p.MergingQueueGuiExecutor - Task finished: (dumb mode task) com.jetbrains.cidr.lang.symbols.symtable.building.OCInitialTablesBuildingActivity$runActivity$1@5bf5141b
2024-04-17 10:00:01,838 [ 5336] INFO - #JetprofileSource - No valid license found
2024-04-17 10:00:01,960 [ 5458] INFO - #c.i.i.p.DisabledPluginsState - Plugins to enable: [com.jetbrains.codeWithMe]
2024-04-17 10:00:01,963 [ 5461] INFO - #c.i.o.p.MergingQueueGuiExecutor - Running task: (dumb mode task) rebuildSymbols (com.jetbrains.cidr.lang.symbols.symtable.building.OCSymbolTablesBuildingActivity$$Lambda$4172/0x0000000801cd2fc0@57f4137)
2024-04-17 10:00:01,965 [ 5463] INFO - #c.i.i.p.DynamicPlugins - Plugins to load: []
2024-04-17 10:00:02,002 [ 5500] INFO - #c.j.c.lang - [Building Activity] Symbols unloaded
2024-04-17 10:00:02,022 [ 5520] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VFS Events: (1)
2024-04-17 10:00:02,022 [ 5520] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VfsEvent[property(name) changed for 'file:///run/media/ling/Data/leetcode/clion/491. Non Decreasing Subsequences/main.cpp': main.cpp -> main.cpp]
2024-04-17 10:00:02,022 [ 5520] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - end.
2024-04-17 10:00:02,048 [ 5546] INFO - #c.j.c.lang - [Building Activity] Building symbols… finished in 75 ms
2024-04-17 10:00:02,058 [ 5556] INFO - #c.j.c.lang - [Building Activity] Loading header maps… finished in 9 ms
2024-04-17 10:00:02,062 [ 5560] INFO - #c.j.c.lang - [Building Activity] Loading headers search roots… finished in 3 ms
2024-04-17 10:00:02,076 [ 5574] INFO - #c.j.c.l.m.ModuleMapLog - Loaded 0 module maps in 0 packs for 0 search roots
2024-04-17 10:00:02,076 [ 5574] INFO - #c.j.c.lang - [Building Activity] Loading module maps… finished in 12 ms
2024-04-17 10:00:02,146 [ 5644] INFO - #c.i.a.o.PathMacrosImpl - Saved path macros: {}
2024-04-17 10:00:02,157 [ 5655] INFO - #c.i.v.l.d.i.IndexDiagnosticRunner - Index diagnostic for 9 commits in [file:///run/media/ling/Data/leetcode/clion] is completed
2024-04-17 10:00:02,176 [ 5674] INFO - #c.i.c.ComponentStoreImpl - Saving appEventLogWhitelist took 27 ms
2024-04-17 10:00:02,206 [ 5704] INFO - #c.i.o.v.n.p.d.e.DurableEnumeratorFactory - [enumerator.mmapped]: .valueHashToId (in memory) was filled (20 records)
2024-04-17 10:00:02,249 [ 5747] INFO - #c.j.c.lang - [Building Activity] Collecting files finished in 172 ms
2024-04-17 10:00:02,580 [ 6078] INFO - #c.i.u.i.UnindexedFilesScanner - Scanning completed for 491__Non_Decreasing_Subsequences. Number of scanned files: 56717; number of files for indexing: 0 took 2749ms; general responsiveness: 0/4 sluggish, 4/4 very slow; EDT responsiveness: 1/1 sluggish
2024-04-17 10:00:02,581 [ 6079] INFO - #c.i.o.p.InitialVfsRefreshService - 309222c6: marking roots for initial VFS refresh
2024-04-17 10:00:02,582 [ 6080] INFO - #c.i.u.i.PerProjectIndexingQueue - Finished for 491__Non_Decreasing_Subsequences. No files to index with loading content.
2024-04-17 10:00:02,592 [ 6090] INFO - #c.i.o.p.MergingQueueGuiExecutor - Task finished: UnindexedFilesScanner[491__Non_Decreasing_Subsequences]
2024-04-17 10:00:02,597 [ 6095] INFO - #c.i.o.p.InitialVfsRefreshService - 309222c6: starting initial VFS refresh of 5 roots
2024-04-17 10:00:02,606 [ 6104] INFO - #c.i.c.ComponentStoreImpl - Saving Project(name=491__Non_Decreasing_Subsequences, containerState=COMPONENT_CREATED, componentStore=/run/media/ling/Data/leetcode/clion/491. Non Decreasing Subsequences)CommitMessageInspectionProfile took 15 ms, XDebuggerManager took 61 ms, editorHistoryManager took 18 ms
2024-04-17 10:00:03,491 [ 6989] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VFS Events: (1)
2024-04-17 10:00:03,492 [ 6990] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VfsEvent[update: /run/media/ling/Data/leetcode/clion/491. Non Decreasing Subsequences/.idea/workspace.xml, oldTimestamp:1713318215377, newTimestamp:1713319202655, oldModificationStamp:0, newModificationStamp:16, oldLength:5106, newLength:5162]
2024-04-17 10:00:03,492 [ 6990] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - end.
2024-04-17 10:00:03,502 [ 7000] INFO - #c.i.o.p.InitialVfsRefreshService - 309222c6: initial VFS refresh finished in 903 ms
2024-04-17 10:00:03,592 [ 7090] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VFS Events: (1)
2024-04-17 10:00:03,592 [ 7090] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VfsEvent[update: /home/ling/.config/JetBrains/CLion2024.1/workspace/2fCt3peDxCmpHH5pPheWX0mJWlx.xml, oldTimestamp:1713318215384, newTimestamp:1713319202675, oldModificationStamp:0, newModificationStamp:15, oldLength:4679, newLength:4679]
2024-04-17 10:00:03,592 [ 7090] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - end.
2024-04-17 10:00:03,601 [ 7099] INFO - #c.i.o.c.i.s.StoreUtil - saveProjectsAndApp took 1872 ms
2024-04-17 10:00:03,710 [ 7208] INFO - #c.j.c.lang - Loaded 3742 tables for 2156 files (2156 project files)
2024-04-17 10:00:03,710 [ 7208] INFO - #c.j.c.lang - [Building Activity] Loading symbols finished in 1 s 461 ms
2024-04-17 10:00:03,716 [ 7214] INFO - #c.j.c.l.m.ModuleMapLog - Building module maps for 0 (root, configuration) pairs
2024-04-17 10:00:03,719 [ 7217] INFO - #c.j.c.lang - [Building Activity] Building module maps… finished in 0 ms
2024-04-17 10:00:03,720 [ 7218] INFO - #c.j.c.lang - [Building Activity] Processing module maps… finished in 0 ms
2024-04-17 10:00:03,722 [ 7220] INFO - #c.j.c.lang - [Building Activity] Processing module maps… finished in 1 ms
2024-04-17 10:00:03,723 [ 7221] INFO - #c.j.c.l.m.ModuleMapLog - Saved 0 module maps in 0 packs
2024-04-17 10:00:03,725 [ 7223] INFO - #c.j.c.lang - [Building Activity] Saving module maps… finished in 2 ms
2024-04-17 10:00:03,726 [ 7224] INFO - #c.j.c.lang - Building symbols for 0 source files
2024-04-17 10:00:03,728 [ 7226] INFO - #c.j.c.lang - [Building Activity] Updating symbols… finished in 1 ms
2024-04-17 10:00:03,735 [ 7233] INFO - #c.j.c.lang - Building symbols for 0 unused headers
2024-04-17 10:00:03,735 [ 7233] INFO - #c.j.c.lang - [Building Activity] Updating symbols… finished in 0 ms
2024-04-17 10:00:03,736 [ 7234] INFO - #c.j.c.lang - [Building Activity] Symbols loaded
2024-04-17 10:00:03,737 [ 7235] INFO - #c.j.c.lang - Building symbols in FAST mode, 1 source files from total 1099 project files
2024-04-17 10:00:03,739 [ 7237] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VFS Events: (1)
2024-04-17 10:00:03,739 [ 7237] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - VfsEvent[property(name) changed for 'file:///run/media/ling/Data/leetcode/clion/491. Non Decreasing Subsequences/main.cpp': main.cpp -> main.cpp]
2024-04-17 10:00:03,739 [ 7237] INFO - #com.google.idea.blaze.base.actions.internal.AswbDumpVfs$BulkListener_vfs_diag - end.
2024-04-17 10:00:03,739 [ 7237] INFO - #c.j.c.lang - Saving modified symbols for 0 files (0 tables of total 3742)
2024-04-17 10:00:03,741 [ 7239] INFO - #c.j.c.lang - [Building Activity] Saving symbols… finished in 3 ms
2024-04-17 10:00:03,743 [ 7241] INFO - #c.i.o.p.MergingQueueGuiExecutor - Task finished: (dumb mode task) rebuildSymbols (com.jetbrains.cidr.lang.symbols.symtable.building.OCSymbolTablesBuildingActivity$$Lambda$4172/0x0000000801cd2fc0@57f4137)
2024-04-17 10:00:03,746 [ 7244] INFO - #c.i.o.p.DumbServiceImpl - exit dumb mode [491__Non_Decreasing_Subsequences]
2024-04-17 10:00:05,014 [ 8512] INFO - #c.i.o.a.i.ActionPopupMenuImpl - isPopupOrMainMenuPlace(StickyLine)==false. Use ActionPlaces.getPopupPlace.
2024-04-17 10:00:05,016 [ 8514] INFO - #c.i.o.a.i.ActionPopupMenuImpl - isPopupOrMainMenuPlace(StickyLine)==false. Use ActionPlaces.getPopupPlace.
2024-04-17 10:00:05,813 [ 9311] INFO - #c.j.p.p.PyPIPackageCache - Package cache /home/ling/.cache/JetBrains/CLion2024.1/python_packages/pypi-cache.json was not found
2024-04-17 10:00:06,077 [ 9575] INFO - #c.i.w.i.i.GlobalWorkspaceModel - Sync global entities with mutable entity storage
2024-04-17 10:00:06,079 [ 9577] INFO - #c.i.w.i.i.j.s.JpsProjectModelSynchronizer - Attempt 1: Apply JPS storage (iml files)
2024-04-17 10:00:06,271 [ 9769] INFO - #c.i.w.i.i.EntitiesOrphanageImpl - Update orphanage. 0 modules added
2024-04-17 10:00:06,274 [ 9772] INFO - #c.i.w.i.i.j.s.JpsProjectModelSynchronizer - Attempt 1: Changes were successfully applied
2024-04-17 10:00:06,277 [ 9775] INFO - #c.i.w.i.i.j.s.DelayedProjectSynchronizer$Util - Workspace model loaded from cache. Syncing real project state into workspace model in 244 ms. Thread[DefaultDispatcher-worker-109,5,main]
2024-04-17 10:00:06,300 [ 9798] INFO - #c.i.w.i.i.EntitiesOrphanageImpl - Update orphanage. 0 modules added
2024-04-17 10:00:06,301 [ 9799] INFO - #c.i.w.i.i.WorkspaceModelImpl - Project model updated to version 4 in 4 ms: CIDR: apply roots
2024-04-17 10:00:07,287 [ 10785] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,290 [ 10788] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,292 [ 10790] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,296 [ 10794] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,305 [ 10803] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,306 [ 10804] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,307 [ 10805] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
2024-04-17 10:00:07,310 [ 10808] INFO - #c.i.d.d.a.DatabaseArtifactList - skipping constraint
