Recovering Journal message on shutdown
After starting a regular shutdown (not forced, simply clicking on the Shutdown option in the application launcher), the following message is presented on the screen for some minutes:
/dev/sda2: recovering journal
/dev/sda2: clean, 521054/15613952, files, 11381735/62435619 blocks
Before the shutdown completes. On the next startup, I will briefly see the second line appear on screen before startup process continues. What could be causing this? Searching the forum didn’t give me any relevant posts.
Output of inxi command:
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=fc2eb096-2f02-4a99-896c-b61c9e648c8d rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: Z87X-D3H v: N/A serial: <filter>
  Chassis: type: 3 serial: <filter>
  Mobo: Gigabyte model: Z87X-D3H-CF v: x.x serial: <filter>
  UEFI: American Megatrends v: F9 date: 08/25/2014
  RAM: total: 15.51 GiB used: 3.95 GiB (25.5%)
  Info: Quad Core model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell
  family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
  bogomips: 27147
  Speed: 3613 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3613 2: 2436
  3: 2707 4: 2378
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
  ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
  xtpr
  Type: l1tf
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
  class-ID: 0300
  Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
  v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:13c2 class-ID: 0300
  Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 3-9.4:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 95 s-size: 1027x292mm (40.4x11.5")
  s-diag: 1068mm (42")
  Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
  size: 509x286mm (20.0x11.3") diag: 584mm (23")
  Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96
  OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
  direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
  class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-3: FiiO K3 type: USB driver: snd-usb-audio bus-ID: 3-10.4:10
  chip-ID: 2972:0047 class-ID: fe01
  Device-4: Antlion Audio Antlion Wireless Microphone type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9.1:5 chip-ID: 2f96:0100
  class-ID: 0300
  Device-5: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
  port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
  Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
  v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
  Local Storage: total: 6.15 TiB used: 2.35 TiB (38.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 6B0Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 500GB
  rotation: SSD serial: <filter> rev: BB6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST6000DM003-2CY186
  size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
  Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-208D rev: 1.10
  dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
  rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
  used: 34.81 GiB (14.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: fc2eb096-2f02-4a99-896c-b61c9e648c8d
  used: 24.4 MiB (8.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 08C6-E003
  ID-3: /media/Multimedia-6TB1 raw-size: 5.46 TiB size: 5.41 TiB (99.19%)
  used: 2.31 TiB (42.7%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
  label: Multimedia-6TB1 uuid: a7f97c08-8984-4100-9e73-cb531cca871c
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  ID-1: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: ext4 label: N/A
  uuid: 30f32a29-cc8c-44c6-b72f-97fc8b202ce9
  ID-2: /dev/sdb2 maj-min: 8:18 size: 465.2 GiB fs: ntfs label: N/A
  uuid: 6A8E3B408E3B03DB
  ID-3: /dev/sdb3 maj-min: 8:19 size: 450 MiB fs: ntfs label: N/A
  uuid: 4C22E56C22E55B88
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Device-1: 3-8:2 info: Alcor Micro Multi Flash Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Hub-6: 3-9:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 045b:0209 class-ID: 0900
  Device-1: 3-9.1:5 info: Antlion Audio Antlion Wireless Microphone
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 2f96:0100 class-ID: 0300
  Device-2: 3-9.4:7 info: Logitech Webcam C270 type: Video,Audio
  power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Hub-7: 3-10:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 3-10.4:10 info: FiiO K3 type: Audio driver: snd-usb-audio
  interfaces: 3 rev: 2.0 speed: 480 Mb/s chip-ID: 2972:0047 class-ID: fe01
  Device-2: 3-13:6 info: ROCCAT Kone Pure Owl-Eye type: Mouse,Keyboard
  power: 500mA chip-ID: 1e7d:2dcd class-ID: 0300
  Device-3: 3-14:9 info: Logitech Gaming Keyboard G610 type: Keyboard,HID
  power: 500mA chip-ID: 046d:c338 class-ID: 0300 serial: <filter>
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-5:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 045b:0210 class-ID: 0900
  Hub-10: 4-6:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 42 C
  Processes: 250 Uptime: 7m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: 1386 pacman: 1380 lib: 414 flatpak: 0
  snap: 6 Shell: Bash v: 5.1.4 running-in: yakuake inxi: 3.3.04
Hi @asorel,
The message is from the fsck module in the startup and shutdown hooks.
I’d say yours isn’t a worry as is specifiees /dev/sda2: clean...
If anyone knows else, feel free to correct me.
Anyway, hope this helps!
If nothing adverse is happening, then why is fsck displaying the message at all? This isn’t something I’ve seen previously, which would imply something about my system has changed, leading to these messages being displayed.
The only thing that may have changed is the verbosity level of systemd. :wink:
AFAIK previously fsck wasn’t enabled by default. I had to turn mine on specifically. Not that I was looking for it. Just saw it somewhere and thought it was a good idea.
So, as @Aragorn, possibly the verbosity of systemd changed, or the hook got enabled by default with the last update.
@Mirdarthos @Aragorn Thank you for your replies. Should I be worried about the long shutdown time at all? My system stays on that screen for at least two minutes before the shutdown process is complete, which seems abnormally long.
Personally, I wouldn’t worry. It feels long for me too. But I’m used to it by now. I shut it down and buzz off, leaving it to do it’s own thing.
