Can someone please help me. I got this when I was booting my system and now it is stuck there.
/dev/sda3: recovering journal
Error reading block 19437860 (Input/output error).
/dev/sda3: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
I did try typing fsck /dev/sda3 but nothing happened.
I am very new to Linux so I don’t know how to solve this.
hi @iamkushank ,
Try opening a terminal and running it as root ,
sudo fsck /dev/sda
or
sudo fsck /dev/sda3
Can’t remember which it would be.
Hope this helps!
Edit:
In the future, when providing terminal output, wrap your output in 3 back ticks (```). This will cause it to bee rendered like this:
some
text to be
rendered like this
with proper formatting for terminal-related output, and not like this:
some
text to be
rendered like this
which is just easier to read for those trying to help you.
I’m stuck on the booting screen how do I open the terminal?
I’m super new to this so sorry if this is a stupid question.
Oh dear.
Then I recommend booting into a Live ISO environment, opening a terminal there, and running it. The root password should, in theory, be the same as a normal password, i…e. ‘manjaro’.
And get the hard drive that’s giving the errors replaced!
oh…
Okay I’ll try that. Thank you for helping me.
Yochanan
Closed
17 December 2021 04:38
8
