While doing latest stable upgrade 2022-02-14, I left my desktop alone and a cut in electricity occurred while I was absent, then after powering on my machine I tried booting both 5.4 and 5.15 kernels but they give me the following message :
error: file '/boot/vmlinuz-x.x-x86_64' not found
error: you need to load the kernel first
I fired up a live KDE Neon live then checked pacman log :
[2022-02-15T09:13:34+0100] [PACMAN] Running 'pacman -Syyu'
[2022-02-15T09:13:34+0100] [PACMAN] synchronizing package lists
[2022-02-15T09:14:01+0100] [PACMAN] starting full system upgrade
[2022-02-15T10:10:55+0100] [PACMAN] Running 'pacman -Syyu'
[2022-02-15T10:10:55+0100] [PACMAN] synchronizing package lists
[2022-02-15T10:11:20+0100] [PACMAN] starting full system upgrade
[2022-02-15T10:29:45+0100] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-02-15T10:29:46+0100] [ALPM] running 'firefox-pre.hook'...
[2022-02-15T10:29:46+0100] [ALPM] running 'ghc-unregister.hook'...
[2022-02-15T10:29:56+0100] [ALPM] running 'thunderbird-pre.hook'...
[2022-02-15T10:29:56+0100] [ALPM] transaction started
[2022-02-15T10:29:57+0100] [ALPM] upgraded ncurses (6.3-1 -> 6.3-2)
[2022-02-15T10:30:19+0100] [ALPM] upgraded btrfs-progs (5.16-1 -> 5.16.1-1)
[2022-02-15T10:30:20+0100] [ALPM] upgraded findutils (4.8.0-1 -> 4.9.0-1)
[2022-02-15T10:30:20+0100] [ALPM] upgraded libcap-ng (0.8.2-6 -> 0.8.2-7)
[2022-02-15T10:30:20+0100] [ALPM] upgraded libcap (2.63-1 -> 2.63-2)
[2022-02-15T10:30:20+0100] [ALPM] upgraded systemd-libs (250.3-2 -> 250.3-3)
[2022-02-15T10:30:20+0100] [ALPM] upgraded ca-certificates-mozilla (3.74-1 -> 3.75-1)
[2022-02-15T10:30:21+0100] [ALPM] upgraded llvm-libs (13.0.0-6 -> 13.0.1-1)
[2022-02-15T10:30:21+0100] [ALPM] upgraded compiler-rt (13.0.0-2 -> 13.0.1-1)
[2022-02-15T10:30:21+0100] [ALPM] upgraded libelf (0.186-3 -> 0.186-4)
[2022-02-15T10:30:22+0100] [ALPM] upgraded elfutils (0.186-3 -> 0.186-4)
[2022-02-15T10:30:23+0100] [ALPM] upgraded clang (13.0.0-4 -> 13.0.1-1)
[2022-02-15T10:30:23+0100] [ALPM] upgraded coin-or-cgl (0.60.4-2 -> 0.60.5-1)
[2022-02-15T10:30:24+0100] [ALPM] upgraded cryfs (0.11.1-1 -> 0.11.1-2)
[2022-02-15T10:30:24+0100] [ALPM] upgraded debuginfod (0.186-3 -> 0.186-4)
[2022-02-15T10:30:24+0100] [ALPM] upgraded device-mapper (2.03.14-2 -> 2.03.15-1)
[2022-02-15T10:30:24+0100] [ALPM] upgraded harfbuzz (3.3.1-1 -> 3.3.2-1)
[2022-02-15T10:30:25+0100] [ALPM] upgraded fontconfig (2:2.13.94-2 -> 2:2.13.96-1)
[2022-02-15T10:30:25+0100] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2022-02-15T10:30:55+0100] [ALPM] upgraded xkeyboard-config (2.34-1 -> 2.35-1)
[2022-02-15T10:30:55+0100] [ALPM] upgraded libxkbcommon (1.3.1-1 -> 1.4.0-1)
[2022-02-15T10:30:55+0100] [ALPM] upgraded libxkbcommon-x11 (1.3.1-1 -> 1.4.0-1)
[2022-02-15T10:30:55+0100] [ALPM] upgraded libusb (1.0.24-2 -> 1.0.25-2)
[2022-02-15T10:30:55+0100] [ALPM] upgraded gdbm (1.22-1 -> 1.23-1)
[2022-02-15T10:30:55+0100] [ALPM] upgraded hwdata (0.355-1 -> 0.356-1)
[2022-02-15T10:30:55+0100] [ALPM] upgraded libpcap (1.10.1-1 -> 1.10.1-2)
[2022-02-15T10:30:58+0100] [ALPM] upgraded systemd (250.3-2 -> 250.3-3)
[2022-02-15T10:31:06+0100] [ALPM] upgraded qt5-base (5.15.2+kde+r296-2.1 -> 5.15.2+kde+r297-1.1)
[2022-02-15T10:31:07+0100] [ALPM] upgraded kuserfeedback (1.0.0-3 -> 1.2.0-1)
[2022-02-15T10:31:08+0100] [ALPM] upgraded qt5-declarative (5.15.2+kde+r44-1 -> 5.15.2+kde+r45-1)
[2022-02-15T10:31:08+0100] [ALPM] upgraded qt5-wayland (5.15.2+kde+r46-2 -> 5.15.2+kde+r48-1)
[2022-02-15T10:31:08+0100] [ALPM] upgraded libnsl (2.0.0-1 -> 2.0.0-2)
[2022-02-15T10:31:08+0100] [ALPM] upgraded gpgme (1.16.0-3 -> 1.17.0-1)
[2022-02-15T10:31:08+0100] [ALPM] upgraded upower (0.99.13-1 -> 0.99.14-1)
[2022-02-15T10:31:10+0100] [ALPM] upgraded lvm2 (2.03.14-2 -> 2.03.15-1)
[2022-02-15T10:31:10+0100] [ALPM] upgraded nss (3.74-1 -> 3.75-1)
[2022-02-15T10:31:14+0100] [ALPM] upgraded dolphin (21.12.2-1 -> 21.12.2.1-1)
[2022-02-15T10:31:15+0100] [ALPM] upgraded espeak-ng (1.50-4 -> 1.50-5)
[2022-02-15T10:31:16+0100] [ALPM] upgraded fftw (3.3.10-1 -> 3.3.10-2)
[2022-02-15T10:31:31+0100] [ALPM] upgraded firefox (97.0-0.1 -> 97.0-1)
[2022-02-15T10:31:33+0100] [ALPM] upgraded firejail (0.9.66-3 -> 0.9.68-1)
[2022-02-15T10:31:33+0100] [ALPM] upgraded frei0r-plugins (1.7.0-1 -> 1.7.0-2)
[2022-02-15T10:31:37+0100] [ALPM] upgraded ghostscript (9.55.0-3 -> 9.55.0-4)
[2022-02-15T10:31:37+0100] [ALPM] upgraded harfbuzz-icu (3.3.1-1 -> 3.3.2-1)
[2022-02-15T10:31:38+0100] [ALPM] upgraded haskell-aeson (1.5.6.0-77 -> 1.5.6.0-79)
[2022-02-15T10:31:38+0100] [ALPM] upgraded haskell-aeson-pretty (0.8.9-27 -> 0.8.9-29)
[2022-02-15T10:31:39+0100] [ALPM] upgraded haskell-pandoc-types (1.22-133 -> 1.22-135)
[2022-02-15T10:31:40+0100] [ALPM] upgraded haskell-text-icu (0.7.1.0-5 -> 0.8.0-1)
[2022-02-15T10:31:40+0100] [ALPM] upgraded haskell-unicode-collation (0.1.3.1-18 -> 0.1.3.1-19)
[2022-02-15T10:31:41+0100] [ALPM] upgraded haskell-citeproc (0.6.0.1-5 -> 0.6.0.1-8)
[2022-02-15T10:31:41+0100] [ALPM] upgraded haskell-unicode-transforms (0.4.0-10 -> 0.4.0-11)
[2022-02-15T10:31:42+0100] [ALPM] upgraded haskell-commonmark (0.2.1.1-3 -> 0.2.1.1-4)
[2022-02-15T10:31:42+0100] [ALPM] upgraded haskell-commonmark-extensions (0.2.2.1-4 -> 0.2.2.1-5)
[2022-02-15T10:31:42+0100] [ALPM] upgraded haskell-commonmark-pandoc (0.2.1.2-4 -> 0.2.1.2-7)
[2022-02-15T10:31:42+0100] [ALPM] upgraded haskell-x509-store (1.6.8-2 -> 1.6.9-1)
[2022-02-15T10:31:43+0100] [ALPM] upgraded haskell-x509-validation (1.6.12-5 -> 1.6.12-6)
[2022-02-15T10:31:44+0100] [ALPM] upgraded haskell-tls (1.5.7-3 -> 1.5.7-4)
[2022-02-15T10:31:44+0100] [ALPM] upgraded haskell-x509-system (1.6.7-3 -> 1.6.7-4)
[2022-02-15T10:31:44+0100] [ALPM] upgraded haskell-connection (0.3.1-171 -> 0.3.1-172)
[2022-02-15T10:31:44+0100] [ALPM] upgraded haskell-doctemplates (0.10.0.1-27 -> 0.10.0.1-29)
[2022-02-15T10:31:44+0100] [ALPM] upgraded haskell-haddock-library (1.10.0-92 -> 1.10.0-94)
[2022-02-15T10:31:45+0100] [ALPM] upgraded haskell-hslua (1.3.0.1-95 -> 1.3.0.1-96)
[2022-02-15T10:31:45+0100] [ALPM] upgraded haskell-hslua-module-path (0.1.0.1-80 -> 0.1.0.1-81)
[2022-02-15T10:31:45+0100] [ALPM] upgraded haskell-hslua-module-system (0.2.2.1-151 -> 0.2.2.1-152)
[2022-02-15T10:31:45+0100] [ALPM] upgraded haskell-hslua-module-text (0.3.0.1-139 -> 0.3.0.1-140)
[2022-02-15T10:31:46+0100] [ALPM] upgraded haskell-http (4000.3.16-125 -> 4000.3.16-128)
[2022-02-15T10:31:46+0100] [ALPM] upgraded haskell-http-types (0.12.3-207 -> 0.12.3-208)
[2022-02-15T10:31:46+0100] [ALPM] upgraded haskell-http-client (0.7.10-7 -> 0.7.10-8)
[2022-02-15T10:31:46+0100] [ALPM] upgraded haskell-http-client-tls (0.3.5.3-486 -> 0.3.5.3-488)
[2022-02-15T10:31:46+0100] [ALPM] upgraded haskell-ipynb (0.1.0.1-272 -> 0.1.0.1-274)
[2022-02-15T10:31:47+0100] [ALPM] upgraded haskell-skylighting-core (0.11-67 -> 0.11-69)
[2022-02-15T10:31:48+0100] [ALPM] upgraded haskell-skylighting (0.11-65 -> 0.11-67)
[2022-02-15T10:31:49+0100] [ALPM] upgraded haskell-texmath (0.12.3.2-8 -> 0.12.3.2-10)
[2022-02-15T10:31:51+0100] [ALPM] upgraded imagemagick (7.1.0.22-1 -> 7.1.0.23-1)
[2022-02-15T10:31:51+0100] [ALPM] upgraded imlib2 (1.7.5-1 -> 1.8.0-1)
[2022-02-15T10:32:01+0100] [ALPM] upgraded inkscape (1.1.1-8 -> 1.1.2-1)
[2022-02-15T10:32:02+0100] [ALPM] upgraded jxrlib (0.2.1-3 -> 0.2.4-1)
[2022-02-15T10:32:02+0100] [ALPM] upgraded lib32-harfbuzz (3.3.1-1 -> 3.3.2-1)
[2022-02-15T10:32:02+0100] [ALPM] upgraded lib32-fontconfig (2:2.13.94-1 -> 2:2.13.96-1)
[2022-02-15T10:32:02+0100] [ALPM-SCRIPTLET] Rebuilding 32-bit fontconfig cache...
[2022-02-15T10:32:15+0100] [ALPM] upgraded lib32-libelf (0.186-2 -> 0.186-3)
[2022-02-15T10:32:16+0100] [ALPM] upgraded lib32-libusb (1.0.24-1 -> 1.0.25-2)
[2022-02-15T10:32:25+0100] [ALPM] upgraded lib32-llvm-libs (13.0.0-1 -> 13.0.1-1)
[2022-02-15T10:32:27+0100] [ALPM] upgraded libical (3.0.13-1 -> 3.0.14-1)
[2022-02-15T10:32:51+0100] [ALPM] upgraded libreoffice-fresh (7.3.0-2 -> 7.3.0-4)
[2022-02-15T10:32:51+0100] [ALPM] upgraded libspeechd (0.11.1-1 -> 0.11.1-2)
[2022-02-15T10:33:17+0100] [ALPM] upgraded linux515 (5.15.19-1 -> 5.15.21-1)
[2022-02-15T10:33:33+0100] [ALPM] upgraded linux515-headers (5.15.19-1 -> 5.15.21-1)
[2022-02-15T10:33:51+0100] [ALPM] upgraded linux54 (5.4.176-1 -> 5.4.178-1)
[2022-02-15T10:34:09+0100] [ALPM] upgraded linux54-headers (5.4.176-1 -> 5.4.178-1)
[2022-02-15T10:34:10+0100] [ALPM] upgraded luajit (2.0.5-3 -> 2.1.0.beta3.r384.g1d7b5029-1)
[2022-02-15T10:34:13+0100] [ALPM] upgraded man-db (2.9.4-2 -> 2.10.0-1)
[2022-02-15T10:34:14+0100] [ALPM] upgraded mesa-demos (8.4.0-6 -> 8.4.0-7)
[2022-02-15T10:34:14+0100] [ALPM] upgraded openmp (13.0.0-1 -> 13.0.1-1)
[2022-02-15T10:34:14+0100] [ALPM] upgraded otf-font-awesome (5.15.4-1 -> 6.0.0-1)
[2022-02-15T10:34:19+0100] [ALPM] upgraded pandoc (2.14.2-26 -> 2.14.2-30)
[2022-02-15T10:34:19+0100] [ALPM] upgraded pandoc-crossref (0.3.12.2-11 -> 0.3.12.2-15)
[2022-02-15T10:34:20+0100] [ALPM] upgraded perl-http-message (6.35-1 -> 6.36-1)
[2022-02-15T10:34:21+0100] [ALPM] upgraded python-gpgme (1.16.0-3 -> 1.17.0-1)
[2022-02-15T10:34:24+0100] [ALPM] upgraded python-numpy (1.21.5-2 -> 1.22.2-1)
[2022-02-15T10:34:25+0100] [ALPM] upgraded python-pycryptodome (3.14.0-1 -> 3.14.1-1)
[2022-02-15T10:34:26+0100] [ALPM] upgraded qgpgme (1.16.0-3 -> 1.17.0-1)
[2022-02-15T10:34:27+0100] [ALPM] upgraded qt5-quick3d (5.15.2+kde+r19-4 -> 5.15.2+kde+r19-5)
[2022-02-15T10:34:29+0100] [ALPM] upgraded qt5-tools (5.15.2+kde+r17-5 -> 5.15.2+kde+r17-6)
[2022-02-15T10:34:31+0100] [ALPM] upgraded qt6-quick3d (6.2.3-2 -> 6.2.3-3)
[2022-02-15T10:34:33+0100] [ALPM] upgraded qt6-tools (6.2.3-2 -> 6.2.3-4)
[2022-02-15T10:34:40+0100] [ALPM] upgraded qtcreator (6.0.2-1 -> 6.0.2-4)
[2022-02-15T10:34:40+0100] [ALPM] upgraded systemd-sysvcompat (250.3-2 -> 250.3-3)
[2022-02-15T10:35:11+0100] [ALPM] upgraded thunderbird (91.6.0-0.1 -> 91.6.0-1)
[2022-02-15T10:35:12+0100] [ALPM] upgraded transcode (1.1.7-39 -> 1.1.7-40)
[2022-02-15T10:35:22+0100] [ALPM] upgraded webkit2gtk (2.34.4-1 -> 2.34.5-1)
[2022-02-15T10:35:22+0100] [ALPM] upgraded xorg-server-common (21.1.3-1 -> 21.1.3-2)
[2022-02-15T10:35:23+0100] [ALPM] upgraded xorg-server (21.1.3-1 -> 21.1.3-2)
[2022-02-15T10:35:26+0100] [ALPM] upgraded yt-dlp (2022.02.04-1 -> 2022.02.04-2)
[2022-02-15T10:35:56+0100] [ALPM] transaction completed
[2022-02-15T10:36:02+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-02-15T10:36:02+0100] [ALPM] running '30-systemd-catalog.hook'...
[2022-02-15T10:36:02+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-02-15T10:36:04+0100] [ALPM] running '30-systemd-hwdb.hook'...
[2022-02-15T10:36:05+0100] [ALPM] running '30-systemd-sysctl.hook'...
[2022-02-15T10:36:05+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-02-15T10:36:06+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-02-15T10:36:06+0100] [ALPM] running '30-systemd-update.hook'...
[2022-02-15T10:36:06+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-02-15T10:36:09+0100] [ALPM] running '40-fontconfig-config.hook'...
[2022-02-15T10:36:09+0100] [ALPM] running '40-update-ca-trust.hook'...
[2022-02-15T10:36:12+0100] [ALPM] running '60-depmod.hook'...
What is the correct way to recover my machine, I don’t want to reinstall those many apps and reconfigure them again. I really found it weird that both kernels were broken at the same time, then what is the need of keeping two kernels if they are upgraded in parallel. Thanks ![]()
