Reconfigure network on remote box?
Hi.
I have a quartz64a running an ARM Manjaro minimal image (no graphical desktop).
It’s 2000km away and I only have ssh access. I need to complete the network configuration so I need to be careful, and, I have no experience with systemd-networkd nor dhcpcd…
Firstly. If I run systemctl --type=service one of the lines is:-
systemd-networkd.service loaded active running Network Configuration
Therefore I think that my network is already controlled by systemd-networkd
however I also have:-
dhcpcd.service loaded active running DHCP/ IPv4LL/ IPv6RA/ DHCPv6 client
how can I tell? is it both?
next.
The box has a built in ethernet port end0 and a USB ethernet port enu1
I need to keep end0 as it is (configured with DHCP) but have enu1 not configured (currently it’s also getting a DHCP address).
I want to bridge end0 to a vxlan interface instead.
The first and most dangerous stage is to create the bridge interface and deconfigure enu1.
Can anyone tell me how to do this safely please?
I already have cronie installed and working so I suppose I could create a cron job that will back out my changes and reboot, so if it goes well I can remove the cron job and if it goes badly I can wait for cron to undo it.
thanks
I created two files:-
cat /etc/systemd/network/10-ethernet.network
[Match]
Name=end*
[Network]
DHCP=yes
 cat /etc/systemd/network/11-usbethernet.network
[Match]
Name=enu*
[Network]
DHCP=no
IPv6AcceptRA=no
and rebooted, but, it’s ignoring me and giving a DHCP address to both end0 and enu1
How can I figure out why?
adding the line
denyinterfaces enu*
to /etc/dhcpcd.conf
did the trick
