Recommended way to install Manjaro and tips for keeping NVME SSD in top condtion
Hello fellow Manjaro users,
So this not really a support thread but just a Discussions what is the recommended way to install Manjaro and if you can give me some tips for NVME too keep them healthy for a long time that would be great :+1:
Maybe some Remember my Steam Post and yeah I am about to finally reinstall my system(install from 2019) in the coming days just in time with the new release of Manjaro.
As I was testing the new ISO I noticed out of the box there are tools for Btrfs and managing snapshots for that besides Timeshift that works with every files system as I understand.
Is it recommended to Install with Btrfs because of some reason unknown to me?
I am asking that because I am reinstalling to a new gen4 NVME on a Samsung 980PRO 1 TB
and I was thinking about switching from the old stable Ext4 Files system that I used for more 10 yeas to something else newer maybe better suited for flash and NVME.
Also bought a new 2 TB Patriot P210 sata drive and I will format it to F2fs but just for my Steam Games.
But are here some people who use F2fs as their Root/Boot Partion and what are your experiences?
and last thing maybe I can reuse my old Root drive my Samsung 860 EVO 500 GB as a cache drive or /temp but with a fallback to my NVME drive so can keep some writes of my NVME as long as this old Drive is still usable?
Sorry for the long thread maybe this helps someone in the future too
Kind regards Kurogane1412
I’d go for a default install rather than custom, but do remember to include at least some swap. I’m seeing a lot of systems with no swap and it will, at some point, come back to bite.
For NVME I can’t really help, sorry, but I’d recommend sticking with ext4, for similar reasons (being relatively new, less people know about it at present).
Hi @Kurogane1412,
BTFS is, in my opinion at least a very advanced and involved filesystem. I’d not recommend it if you’re not able or willing to put time into maintaining it. Myself, I even only use ext4. The Manjaro Wiki has good documentation 'bout it:
I’ve not changed anything on my NVMe disk and it’s only used:
Percentage Used:                    7%
In the ±6 years I’ve been using it with Manjaro,
I don’t have a swap and it’s because the default install doesn’t suggest it. It’s been a couple of years now and haven’t had any issues related to it. Maybe I’m just lucky?
Definitely!
I’d suggest you remedy that:
well it seems I have forgotten that in 2019 I did forget to make a swap partition at that time on my Desktop Pc
looking now at fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=D6CA-1692                              /boot/efi                        vfat    noatime                         0 2
UUID=c13a924e-f23f-443d-93b3-0384a2541f36   /                                ext4    noatime,discard                 0 1
tmpfs                                       /tmp                             tmpfs   noatime,mode=1777               0 0
/swapfile                                   none                             swap    defaults                        0 0
#UUID=410c13a5-f1cd-4811-80ba-1592de5069fa   /run/media/dean/Data-Disk1   ext4    users               0 0
#UUID=84da62d9-01fd-4971-90d6-4602976ac9da   /run/media/dean/NVME-Data2   ext4    users               0 0
#UUID=cd4fd70b-4e24-46ac-8092-8f44409ed6d1   /run/media/dean/Data         ext4    users               0 0
#UUID=9bd1d750-888e-41c9-a5a3-8a323f1a8e8c   /run/media/dean/Game-data    ext4    users               0 0
#UUID=cd4fd70b-4e24-46ac-8092-8f44409ed6d1   /run/media/dean/Data\040\040     ext4    discard,nofail,users            0 0
UUID=9bd1d750-888e-41c9-a5a3-8a323f1a8e8c   /run/media/dean/Game-data        ext4    discard,defaults,nofail,users   0 0
UUID=410c13a5-f1cd-4811-80ba-1592de5069fa   /run/media/dean/Data-Disk1       ext4    nofail,users                    0 0
UUID=84da62d9-01fd-4971-90d6-4602976ac9da   /run/media/dean/NVME-Data2\040   ext4    discard,nofail,users            0 0
so some time after the installation I made a swap file and that worked very well and I could even keep a swap file on a different Drive just in case to not waste space on my NVME and I have 32 GB of Ram probably the swap file was not used at all for years I think
Edit. I was 1,5 years without a swap partition and that time I only had 16 GB Ram zero Problems or at least not related to swam or ram
and yeah I know Ext4 is stable and Recommended but Still if I have backups of my important files somewhere else what could happen?
I have a second Nobara Installation on one Old Samsung 970 EVO but used it only once for Gaming and troubleshooting problems with Steam on Manjaro with Btrfs I could test sme things there and see and read a bit about it
Maybe I am bit paranoid about the live span of flash storage but it is better to be safe than sorry later who knows what can happen
Just try it with an swap file that worked for for nearly 6 years but I also have 32 Gb of RAM
Famous last words!
Welp, if you know the dangers and are prepared for them, have at it!
Your system, your choice.
Well i know that sounded not that great everything could happen but I hope not for the worst
or have some fail save in case of any idea?
If I would go with F2fs as Root/Boot
I will not make the decision that fast
Honestly?
:man_shrugging:
I’m quite happy with mine as it is.
yes i am also happy with Ext4 and I will keep it on my Laptop for sure for some time longer
but the good thing about Linux is we have choice
If I am not wrong a lot Android Smartphones use F2fs and Samsung Started the Development in 2012 how long does it take for a File System to mature?
OK, check you grammar, spelling and sentence structure please. That was very hard to decipher.
Depends on the rate of adoption, I guess.
See
Sorry English is not my Native Language as may see and I am honestly trying to write correct.
Yeah and that is my Problem with F2fs it is on a lot of Phones but I do not see Data of a lot of People using it on Desktop/Laptops setups so I thought to ask about other peoples opinions.
In that case, there are many languages in the Other Languages section. There are also many other, more localized websites, for example:
Can’t help you with that, but i can help you with:
https://wiki.archlinux.org/title/F2FS
For a filesystem to be stable and widely adopted… It usually takes 1-2 decades.
The most important tip for NVMe storage on any OS, any file system type; keep your file system TRIM’ed. This technology relies on it, it’s the only way to effectively write new data.
You do not cause wear by doing this, and it only increases performance (after it completes). Manjaro does this once a week by default (the Win 10/11 default is the same).
So make sure you have an fstrim timer running. If you installed Manjaro some time ago, it might not even be enabled.
$ systemctl list-timers | grep fstrim
Thu 2024-12-12 12:38:00 MST            18h Wed 2024-12-11 15:53:04 MST  2h 9min ago fstrim.timer                     fstrim.service
And you can always run a TRIM manually. e.g.:
sudo fstrim -v /
This is not meant for NVMe storage. This is for things like micro SD cards, and some other non-standard use cases.
To use btrfs like ext4 requires very minimal knowledge, I would highly recommend it. I didn’t know it two years ago, and now I can snapshot anything and send them anywhere. It has also saved me reinstalling on several occasions.
I think Timeshift is great for a first time person jumping into snapshots. But I would recommend some light reading before this. At least some basic general knowledge about CoW file systems and what snapshots actually do, especially when you are doing lots of stuff in the middle of them.
Then the cool stuff can start. :sunglasses:
I looked at it years ago and still see a lot of issues sadly so probably not an good idea for a Root/Boot partition
interesting it seems mine was not running at all for years
(base) [dean@MeshifyC-Manjaro ~]$ systemctl list-timers | grep fstrim
and mine was:
(base) [dean@MeshifyC-Manjaro ~]$ sudo fstrim -v /
/: 92,2 GiB (99024048128 bytes) trimmed
I thought it was enough to have the discard option in fstab to trim it on every boot, was I wrong?
No if you look at the Arch wiki it says for NAND-based flash memory equipped with Flash Translation Layer
But not really a good Idea for a Root/Boot partitions
If we would have an easy way to choose in the Calamares Installer between Ext4 or Btrfs I would try it but for now it is safer to stay with Ext4
I found it just strange to include Btrfs tools in the ISO when the recommended Files System for Install is Ext4 and it is not even easy to install I had a look at a Tutorial in the Manjaro Forum
Youd be right that discard is an alternative option and ‘enough’.
Youd be wrong that it runs at login - discard is continual.
And you might be wrong if you thought it was the preferred or recommended method.
discard can cause hangups or worse depending on the hardware.
See:
https://wiki.archlinux.org/title/Solid_state_drive#Continuous_TRIM
Thank you for the Info :+1:
I did not know that
