I’ve used Mosaico window manager http://www.soulidstudio.com/, for years. It allows you to map multiple custom window location/sizes (created on a GUI grid editor) to each CTRL+ALT+<NUMBER_KEY> combination, and cycle through the set for that combination each time you hit <NUMBER_KEY>. It’s lightning fast and is a significant part of my workflow/productivity
In attemtping to move over Linux I’ve been trying to find a way to recreate this in Linux. The closest I’ve gotten is the Ultrawide Windows script for KWin. It’s pretty good, but having 3+ left-hand combinations to get the windows sized/positioned right, etc. is to be honest, slow/awkward to me.
Are there any other window managers that can mimic the Mosaico behaviour? Is there a way to modify Mosaico to do this?
