pactl list cards
comes up with nothing.
Made a new user and sound works perfectly, bluetooth included. Now to figure out what I need to do to reset my account specifically around sound.
Edit:
I checked the console output on the other account. here is the console output
Card #160
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "4"
api.alsa.card.longname = "audio-technica AT2020USB+ at usb-0000:11:00.0-5, full speed"
api.alsa.card.name = "AT2020USB+"
api.alsa.path = "hw:4"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio4"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-audio-technica_AT2020USB+-00"
device.bus_path = "pci-0000:11:00.0-usb-0:5:1.0"
device.description = "AT2020USB+"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-usb"
device.name = "alsa_card.usb-audio-technica_AT2020USB_-00"
device.nick = "AT2020USB+"
device.plugged.usec = "7547268"
device.product.id = "0x001c"
device.product.name = "AT2020USB+"
device.serial = "audio-technica_AT2020USB+"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:11:00.0/usb3/3-5/3-5:1.0/sound/card4"
device.vendor.id = "0x0909"
device.vendor.name = "Audio-Technica Corp."
media.class = "Audio/Device"
factory.id = "14"
client.id = "46"
object.id = "93"
object.serial = "160"
object.path = "alsa:pcm:4"
alsa.card = "4"
alsa.card_name = "AT2020USB+"
alsa.long_card_name = "audio-technica AT2020USB+ at usb-0000:11:00.0-5, full speed"
alsa.driver_name = "snd_usb_audio"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB0909:001c"
alsa.id = "AT2020USB"
device.string = "4"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: yes)
output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 355, available: yes)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
port.type = "mic"
card.profile.port = "0"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
card.profile.port = "1"
Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Properties:
port.type = "analog"
card.profile.port = "2"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
card.profile.port = "3"
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #161
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "HDA ATI HDMI at 0xf6c20000 irq 119"
api.alsa.card.name = "HDA ATI HDMI"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:03:00.1"
device.description = "Navi 31 HDMI/DP Audio"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_03_00.1"
device.nick = "HDA ATI HDMI"
device.plugged.usec = "7282518"
device.product.id = "0xab30"
device.product.name = "Navi 31 HDMI/DP Audio"
sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card0"
device.vendor.id = "0x1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
factory.id = "14"
client.id = "46"
object.id = "84"
object.serial = "161"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xf6c20000 irq 119"
alsa.mixer_name = "ATI R6xx HDMI"
alsa.components = "HDA:1002aa01,00aa0100,00100800"
alsa.id = "HDMI"
device.string = "0"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
device.product.name = "LC34G55T"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
device.product.name = "VG252Q"
Part of profile(s): output:hdmi-stereo-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #162
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "2"
api.alsa.card.longname = "HD-Audio Generic at 0xf6a80000 irq 122"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.path = "hw:2"
api.dbus.ReserveDevice1 = "Audio2"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:13:00.6"
device.description = "Family 17h/19h HD Audio Controller"
device.name = "alsa_card.pci-0000_13_00.6"
device.nick = "HD-Audio Generic"
device.plugged.usec = "7299793"
device.product.id = "0x15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2"
device.vendor.id = "0x1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
factory.id = "14"
client.id = "46"
object.id = "91"
object.serial = "162"
object.path = "alsa:pcm:2"
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xf6a80000 irq 122"
alsa.mixer_name = "Realtek ALC1220"
alsa.components = "HDA:10ec1168,1043886d,00100101"
alsa.id = "Generic_1"
device.string = "2"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: off
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Card #163
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "3"
api.alsa.card.longname = "KYE Systems Corp. FaceCam 1000X at usb-0000:13:00.4-2, high speed"
api.alsa.card.name = "FaceCam 1000X"
api.alsa.path = "hw:3"
api.dbus.ReserveDevice1 = "Audio3"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-KYE_Systems_Corp._FaceCam_1000X-02"
device.bus_path = "pci-0000:13:00.4-usb-0:2:1.2"
device.description = "FaceCam 1000X"
device.form_factor = "webcam"
device.icon_name = "camera-web-analog-usb"
device.name = "alsa_card.usb-KYE_Systems_Corp._FaceCam_1000X-02"
device.nick = "FaceCam 1000X"
device.plugged.usec = "7363946"
device.product.id = "0x708f"
device.product.name = "FaceCam 1000X"
device.serial = "KYE_Systems_Corp._FaceCam_1000X"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:13:00.4/usb7/7-2/7-2:1.2/sound/card3"
device.vendor.id = "0x0458"
device.vendor.name = "KYE Systems Corp. (Mouse Systems)"
factory.id = "14"
client.id = "46"
object.id = "77"
object.serial = "163"
object.path = "alsa:pcm:3"
alsa.card = "3"
alsa.card_name = "FaceCam 1000X"
alsa.long_card_name = "KYE Systems Corp. FaceCam 1000X at usb-0000:13:00.4-2, high speed"
alsa.components = "USB0458:708f"
alsa.id = "F1000X"
device.string = "3"
Profiles:
pro-audio: Pro Audio (sinks: 0, sources: 1, priority: 1, available: yes)
input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:mono-fallback
Ports:
analog-input: Analog Input (type: Analog, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): input:mono-fallback
Card #164
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "1"
api.alsa.card.longname = "HD-Audio Generic at 0xf6a88000 irq 121"
api.alsa.path = "hw:1"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:13:00.1"
device.description = "Rembrandt Radeon High Definition Audio Controller"
device.name = "alsa_card.pci-0000_13_00.1"
device.plugged.usec = "7282305"
device.product.id = "0x1640"
device.product.name = "Rembrandt Radeon High Definition Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:13:00.1/sound/card1"
factory.id = "14"
client.id = "46"
object.id = "78"
object.serial = "164"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xf6a88000 irq 121"
alsa.id = "Generic"
device.string = "1"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 2, sources: 0, priority: 1, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "hdmi"
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
