Recent system / services RAM resources discrepancies
These last few weeks I’ve noticed a weird trend. While Gnome and Mutter are taxing a little bit more resources than they typically do (not a major issue), I am seeing an enormous ~20 GBs worth of RAM consumption that my system monitors (including CLI tools like top, bashtop, and gotop) don’t indicate the offending services under their process lists even when sorted in descending order according to memory.
My machine has 64 GBs of RAM. About 30 minutes ago it was showing 80%. So I was almost bottoming out. There was 5GBs of swap file consumed as well. I have a lot of Chrome tabs. So I closed them all. I saved all my tabs into bookmarks and shut down Chrome. That freed up 20%. That’s great. But it was then still sitting at 60%. I didn’t have many other apps or services open but I closed them all just to make sure. 41% of the RAM was still occupied. The only major app left open was Gnome showing 5.1GBs. I guess it has a big memory leak, perhaps introduced in v47.x. So I killed Gnome, freeing up the 5GBs. From GDM I re-logged into my Gnome session. Gnome was then showing 500 MBs which is more reasonable and aligns with what most would expected HOWEVER Gnome System Monitor and my CLI tools were still showing 34% RAM occupied even at this clean slate. Everything else was idle.
Only when I reboot does the cache completely flush and Gnome System Monitor shows 6% memory consumption which is where it really should be.
I can’t account for what is consuming all this memory at 4 days of uptime. I certainly hope my Manjaro box isn’t compromised by a ghost app installed which contains some kind of novel rogue rootkit targetting Linux users. I suppose it might not be an official Manjaro/AUR package, could be a Flatpack or Snap, although I don’t have many of those.
What other information could I provide to help troubleshoot and get to the bottom of this unusual behavior?
inxi -Fazy
$ inxi -Fazy
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=d8f51c21-a5ce-4611-973c-b7d694ae22a1 rw apparmor=1
    security=apparmor resume=UUID=6a544b3a-7b7d-4fc0-b121-0f55042fc081
    udev.log_priority=3 video=vesafb:mode=3840x1600-32,mtrr:3,ywrap
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: i3lock,lxlock,swaylock dm: 1: GDM v: 47.0
    2: LightDM v: 1.32.0 note: stopped 3: SDDM note: stopped Distro: Manjaro
    base: Arch Linux
  Mobo: ASUSTeK model: PRIME H670-PLUS D4 v: Rev 1.xx
    UEFI: American Megatrends v: 2014 date: 10/14/2022
  Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x12B
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 800 min/max: 800/5100:3900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
    17: 800 18: 800 19: 800 20: 800 bogomips: 139820
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
  Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3
    chip-ID: 046d:085c class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: LG (GoldStar) HDR WQHD serial: <filter> built: 2018
    res: 3840x1600 dpi: 111 gamma: 1.2 size: 879x366mm (34.61x14.41")
    diag: 952mm (37.5") modes: max: 3840x1600 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 XT (radeonsi
    navi23 LLVM 18.1.8 DRM 3.59 6.12.1-4-MANJARO) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no display-ID: :0.0
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.2.4:21 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 6.6 TiB used: 1.32 TiB (20.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
    SN850X HS 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 35.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS200T2B0A-00SM50
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 20WD scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: M4-CT256M4SSD2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 000F scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM004-2CV104
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 743.72 GiB size: 730.97 GiB (98.29%)
    used: 129.46 GiB (17.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.2 TiB (66.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: file size: 512 MiB used: 2.7 MiB (0.5%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: partition size: 187.5 GiB used: 17.9 MiB (0.0%)
    priority: -3 dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
    mem: 30.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Memory: total: 64 GiB available: 62.54 GiB used: 28.08 GiB (44.9%)
  Processes: 468 Power: uptime: 4d 16h 57m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 24.99 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 2369 pm: pacman pkgs: 2332 libs: 444
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 30 pm: snap pkgs: 7
    Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: foot
    inxi: 3.3.36
Hello Drone4four, next time this issue happens, use
df -hl -t"tmpfs"
to see if there is a large amount of ramdisk usage. Any amount of “used” will show up as normal used memory.
Also, if you have high disk IO and have enabled file system compression, this can be reported as memory use.
I’ve never used RAID, so it’s possible that is relevant as well. It may be worth looking at RAID Maintenance if you haven’t done so already.
In the event that I wanted to continue testing from forum feedback, I didn’t reboot my machine today. Up time still showing: 4 days 19 hrs 18 mins.
The tiny bare “6%” of system RAM consumption at reboot that I quoted is based from what I recall when I last rebooted and checked.
Therefore I am in a good position to test further with the dh command you suggested, @Fangdrasil. Here it is:
$ df -hl -t"tmpfs"
Filesystem      Size  Used Avail Use% Mounted on
run              32G  2.4M   32G   1% /run
tmpfs            32G     0   32G   0% /dev/shm
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-udev-load-credentials.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-vconsole-setup.service
tmpfs            32G  100K   32G   1% /tmp
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
tmpfs           6.3G  710M  5.6G  12% /run/user/1000
Not sure what to make of that output or what to look out for. What does that output tell you?
btw: I don’t use RAID either. Is that what you see in my inxi?
The values shown as used would show up in the system monitor as memory used.
My inixi shows “No RAID data found”, so I thought yours indicated a RAID configuration, but I guess not.
Tmpfs will be cleaned on reboot by the way. In case that is the culprit.
Could you please post the output of free -h?
That will give a good indication of how much of that RAM usage is just caching. The important figure is the last one in the output: Available.
I imagine that Chrome is filling up your RAM cache. The pages will stay in the cache, even after Chrome is closed, until your system decides to remove them because it wants to store something else in the cache, or it needs to free up some RAM for running applications.
It should also be remembered that unused RAM is wasted RAM. That’s why Linux uses it as a cache.
Thank you all for your replies so far.
This was with Chrome open:
$ free -h
               total        used        free      shared  buff/cache   available
Mem:            62Gi        30Gi       2.0Gi       1.3Gi        31Gi        32Gi
Swap:          187Gi        17Mi       187Gi
I then killed Chrome and ran the same command:
$ free -h
Mem:            62Gi        23Gi       8.9Gi       198Mi        30Gi        38Gi
The difference between 38 GB available without Chrome from 32 GB with Chrome is is 6 GB. I belive this indicates Chrome is consuming 6 GB before I killed the service.
I am still not quite sure I understand what this all means.
I fired Chrome back up. Here is the command again:
$ free -h
Mem:            62Gi        27Gi       5.2Gi       466Mi        31Gi        35Gi
For what it is worth, here is the relevant section in BashTOP which reflects some of the numbers quoted in $ free -h:
