Recent Audio Issues with my microphone
I currently have two Dell Latitude laptops that runs the latest Manjaro OS but I am having serious audio issues with my microphone , which has disrupted my activities during online meetings.
Even if I do a fn + f4 to unmute, it shows the both state [muted and unmuted] but the light indicator on the keyboard shows it’s muted for both toggled state.
And since I Dual booted the system, I switched to Windows and saw it working super well.
I look forward to seeing this fixed.
Welcome to the Manjaro community @nuvancetechnologies
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions :point_down:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks:
or three tildes:
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Required reading
Resources
Just to rule out the usual suspects, did you disable the fast startup in windows?
@Teo
I’ll have to check that now
@scotty65
Alright, I appreciate your feedback
This issue has been resolved.
Thank you team
Mod edit: Consecutive posts merged, @mentions added.
Please advise how the issue was resolved, as it may help others who come to this forum with a similar issue.
If one of the posts in this topic provided the solution, please tick :white_check_mark: the solution box under that post. This will mark the topic as “solved” and automatically close the thread 3 days after the most recent post.
Forum Rules - Manjaro
What was the resolution?
Any Support topic is rather pointless without a clear stated resolution to a problem, or a post marked as the Solution (if someone else helped to solve it) – I’m certain you must agree.
Please provide full details of whatever fixed your problem, as they may indeed help others that find this thread.
