for some odd reason, those options dont work when i click on them, can someone guide me where to look to understand why is this happening
thx in advance
thx in advance
if you right click the menu> properties > commands
you’ll see the commands used.
run the command in a terminal & see what error it throws.
$ xfce4-session-logout --halt --fast
$ xfce4-session-logout --reboot --fast
$ xfce4-session-logout --logout --fast
nothing happens
try:
systemctl reboot
that works but i still dont know why the xfce4 way fails
did you mess with your login/session manager
did you disable anything.
i solved this in way that works but dont ask me why, i just reinstalled xfce4-session both the menu and the commands on terminal work
@kerry_s thx allot for answering the thread
