Hi,
Sorry if I made some mistakes, I’m very new here.
The problem is that my lenovo laptop reboots after shutdown. First I only had Win10 on it, then wiped it clean and dual-booted Linux Mint and Win10, (Where this issue already appeared but only using Win10) and now I’ve wiped it again and I’m only using Manjaro.
I tried:
-using terminal commands such as: “systemctl poweroff -i” and “shutdown now”
-disabling “Wake on LAN” in BIOS
-using “acpi=force” or “acpi=noirq” in /etc/default/grub
-update-grub
-Back when I still had Win10 I also tried other options to fix this issue like not allowing
the network adapter to power it on, or some reboot after crash option.
What DID fix this issue is disabling USB 3.0 in the BIOS but I’m not sure if I want to sacrifice USB 3.0 so I’m starting this thread to see if You guys have any ideas on to how to properly fix this issue.
Thanks in advance
