Reboot and shutdown issues
Hi! I’m having problem with both testing and unstable branches on my notebook (Acer Nitro AN515-45 - AMD CPU). When I try to shut down the system, it goes all the way to unmounting root fs cleanly and says it is powering down, but the power doesn’t actually turn off. Same problem with reboot - reboot gets stuck at the same phase.
The problem does not happen when switching back to stable. I also tried LTS kernel instead of the latest stable one and problem is still present on the testing branch.
The minimum amount of useful information to help with this, would be the logs as your are shutting down.
You can even filter logs by the last time you powered up.
journalctl --list-boots
If it hung up the previous boot, you can use boot ID -1.
Then all the logs (in reverse) would be shown with the command:
journalctl --boot -1 --reverse
You can add --priority 3 to see only errors or worse, 4 for warnings..
Where does it get hung up?
In addition to logs as mentioned, more detail about your system may be helpful to identify other possible contributors.
Please provide your system information as described (below).
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
a) inxi command (long-form):
inxi --filter --verbosity=8
b) inxi command (short-form):
inxi -zv8
Running inxi within a chroot environment :eyes:
Your privacy is respected
Update Announcements
Technical Resources
Hi! Attaching a full journal log and inxi output from a boot that failed to shutdown (switched back to unstable, updated to latest packages, and disabled SDDM to produce minimal log).
INXI Output
  Kernel: 6.17.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.17-x86_64 root=/dev/mapper/cryptroot rw
    rd.luks.name=443a7a87-cbb1-4e53-bfbe-6502314e0f89=cryptroot
    rd.luks.name=b87614b0-18e3-42fa-adb3-252febc4c362=cryptswap
    rd.luks.options=allow-discards,timeout=0,no-read-workqueue,no-write-workqueue
    rootflags=x-systemd.device-timeout=0 root=/dev/mapper/cryptroot udev.log_priority=3
    mitigations=off amd_pstate=active preempt=lazy split_lock_detect=off nowatchdog
    nmi_watchdog=0 reboot=bios fsck.repair=yes hibernate.compressor=lz4 fbcon=map:01
    resume=/dev/mapper/cryptswap
  Console: tty 1 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Acer product: Nitro AN515-45 v: V1.11 serial: <superuser required>
  Mobo: CZ model: Scala_CAS v: V1.11 serial: <superuser required> part-nu: 0000000000000000
    uuid: <superuser required> UEFI: Insyde v: 1.11 date: 07/11/2023
  ID-1: BAT1 charge: 45.2 Wh (100%) condition: 45.2/58.8 Wh (76.9%) volts: 16.6 min: 15.4
    model: SMP AP18E7M type: Li-ion serial: <filter> charging: status: full cycles: N/A
  System RAM: total: 32 GiB available: 30.7 GiB used: 1.04 GiB (3.4%)
  Array-1: capacity: 64 GiB slots: 2 modules: 2 EC: None max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A2K43EB1-CWE serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 3
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x50 (80) stepping: 0 microcode: 0xA500012
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1100 min/max: 423/4683 boost: enabled scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 1100 2: 1100 3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100
    9: 1100 10: 1100 11: 1100 12: 1100 13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 105399
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
    cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists
    erms extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate
    ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
    popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap
    smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only;
    no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled; PBRSB-eIBRS: Not
    affected; BHI: Not affected
  Type: tsa status: Vulnerable
  Type: vmscape status: Vulnerable
  Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB] vendor: Acer Incorporated ALI
    driver: nvidia v: 580.105.08 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: none bus-ID: 01:00.0
    chip-ID: 10de:249c class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: none
    bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 42.0 C
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:a061 class-ID: 0e02
  Display: unspecified server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9 driver: X:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch tty: 160x45
  Monitor-1: HDMI-A-1 model: LG (GoldStar) FHD serial: <filter> built: 2022 res: 1920x1080
    dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
    y: 0.047 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63") diag: 551mm (21.7")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  Monitor-2: eDP-1 model: BOE Display 0x09b8 built: 2020 res: 2560x1440 dpi: 189 gamma: 1.2
    chroma: red: x: 0.647 y: 0.325 green: x: 0.294 y: 0.627 blue: x: 0.153 y: 0.055 white: x: 0.314
    y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 2560x1440,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0 drv: nvidia device: 2
    drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
    inactive: wayland,x11,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.2.6-arch1.1 note: console (EGL sourced)
    renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2, AMD Radeon Graphics (radeonsi renoir
    ACO DRM 3.64 6.17.7-1-MANJARO), llvmpipe (LLVM 21.1.4 256 bits)
  API: Vulkan v: 1.4.328 layers: 8 device: 0 type: integrated-gpu name: AMD Radeon Graphics
    (RADV RENOIR) driver: mesa radv v: 25.2.6-arch1.1 device-ID: 1002:1638 surfaces: N/A device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 3080 Laptop GPU driver: nvidia v: 580.105.08
    device-ID: 10de:249c surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
    gpu: nvidia-smi,radeontop wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GA104 High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
    v: kernel alternate: nova_core pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Acer Incorporated ALI
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.17.7-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-1: PipeWire v: 1.4.9 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
  Device-2: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic 330] vendor: Lite-On
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961
    class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3:3 chip-ID: 0bda:8153 class-ID: 0000
    serial: <filter>
  IF: enp5s0f4u1u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: Lite-On MediaTek Bluetooth MT7921 driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04ca:3802 class-ID: e001
    serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no
    pairing: no
  Device-1: winc maj-min: 253:2 type: Crypto dm: dm-2 size: 399.34 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 399.34 GiB
  Device-2: cryptdata maj-min: 253:3 type: LUKS dm: dm-3 size: 3.64 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 3.64 TiB
  Device-3: cryptswap maj-min: 253:1 type: LUKS dm: dm-1 size: 63.98 GiB
  Components:
  p-1: sdb1 maj-min: 8:17 size: 64 GiB
  Device-4: cryptvirt maj-min: 253:4 type: LUKS dm: dm-4 size: 401.74 GiB
  Components:
  p-1: sdb2 maj-min: 8:18 size: 401.76 GiB
  Device-5: cryptroot maj-min: 253:0 type: LUKS dm: dm-0 size: 552.35 GiB
  Components:
  p-1: nvme0n1p6 maj-min: 259:6 size: 552.37 GiB
  Local Storage: total: 5.03 TiB used: 3.48 TiB (69.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530 SDBPNPZ-1T00-1114
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 21113000 temp: 30.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB size: 3.64 TiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
    scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 500GB size: 465.76 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 552.35 GiB size: 542.6 GiB (98.23%) used: 409.49 GiB (75.5%) fs: ext4
    dev: /dev/dm-0 maj-min: 253:0 mapped: cryptroot label: N/A uuid: N/A
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%) used: 286.6 MiB (29.4%) fs: ext4
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: Boot uuid: 8b7fd90c-d90d-4184-94c1-f818c007087f
  ID-3: /boot/efi raw-size: 512 MiB size: 508 MiB (99.22%) used: 36 MiB (7.1%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 42F3-4935
  ID-4: /data raw-size: 3.64 TiB size: 3.64 TiB (99.96%) used: 2.88 TiB (79.0%) fs: xfs
    dev: /dev/dm-3 maj-min: 253:3 mapped: cryptdata label: N/A uuid: N/A
  ID-5: /data_virtual raw-size: 401.74 GiB size: 401.55 GiB (99.95%) used: 204.44 GiB (50.9%)
    fs: xfs dev: /dev/dm-4 maj-min: 253:4 mapped: cryptvirt label: N/A uuid: N/A
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes compressor: zstd
    max-pool: 20%
  ID-1: swap-1 type: partition size: 63.98 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
    maj-min: 253:1 mapped: cryptswap label: N/A uuid: 52b196af-2e4e-4c30-ab8e-2bfa97b7f40a
  ID-1: /dev/dm-2 maj-min: 253:2 mapped: winc size: 399.34 GiB fs: ntfs label: Windows
    uuid: 9A88F02A88F00713
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 399.34 GiB fs: bitlocker
    label: MICHAL-NB C: 26.12.2022 uuid: 50b4fa20-8b7b-4b22-ab1a-b9d36415dc20
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 661 MiB fs: ntfs label: N/A uuid: 4E4EE24B4EE22C01
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-4:2 info: Lite-On MediaTek Bluetooth MT7921 type: bluetooth driver: btusb
    interfaces: 3 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 3-1.2:4 info: Logitech Keyboard K120 type: keyboard,HID driver: hid-generic,usbhid
    interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-2: 3-1.4:5 info: Logitech M500s Optical Mouse type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 300mA chip-ID: 046d:c093 class-ID: 0300 serial: <filter>
  Device-3: 3-3:3 info: Quanta HD User Facing type: video driver: uvcvideo interfaces: 2
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:a061
    class-ID: 0e02
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  Hub-6: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 05e3:0626 class-ID: 0900
  Device-1: 4-1.3:3 info: Realtek RTL8153 Gigabit Ethernet Adapter type: Network driver: r8152
    interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  System Temperatures: cpu: 45.2 C mobo: 34.0 C gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): N/A
  Packages: 2143 pm: pacman pkgs: 2102 libs: 482 tools: yay pm: flatpak pkgs: 41
    1: https://archlinux.nic.cz/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 347
  1: cpu: 2.6% command: systemd pid: 1 mem: 13.8 MiB (0.0%)
  2: cpu: 1.9% command: firewalld started-by: python pid: 1391 mem: 48.0 MiB (0.1%)
  3: cpu: 1.9% command: -zsh pid: 1830 mem: 12.0 MiB (0.0%)
  4: cpu: 1.0% command: systemd pid: 1819 mem: 11.4 MiB (0.0%)
  5: cpu: 0.7% command: [migration/1] pid: 67 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 347
  1: mem: 54.2 MiB (0.1%) command: systemd-journald pid: 804 cpu: 0.3%
  2: mem: 48.0 MiB (0.1%) command: firewalld started-by: python pid: 1391 cpu: 1.9%
  3: mem: 24.9 MiB (0.0%) command: NetworkManager pid: 1581 cpu: 0.5%
  4: mem: 13.8 MiB (0.0%) command: systemd pid: 1 cpu: 2.6%
  5: mem: 13.1 MiB (0.0%) command: systemd-udevd pid: 838 cpu: 0.6%
  Processes: 347 Power: uptime: 0m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.21 GiB Init: systemd
    v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.5 gcc: 15.2.1 alt: 14 Shell: Zsh (login) v: 5.9 running-in: tty 1
    inxi: 3.3.39
Journal (warnings only)
Nov 08 09:54:59 manjaro kernel: tpm tpm0: tpm_read_log_acpi: Failed to map ACPI memory
Nov 08 09:54:59 manjaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Nov 08 09:54:59 manjaro kernel: integrity: Problem loading X.509 certificate -65
Nov 08 09:54:59 manjaro kernel: ata3.00: Model 'Samsung SSD 860 EVO M.2 500GB', rev 'RVT21B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Nov 08 09:54:59 manjaro kernel: ata3.00: supports DRM functions and may not be fully accessible
Nov 08 09:54:59 manjaro kernel: ata2.00: Model 'Samsung SSD 870 QVO 4TB', rev 'SVQ02B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Nov 08 09:54:59 manjaro kernel: ata2.00: supports DRM functions and may not be fully accessible
Nov 08 09:54:59 manjaro kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WMBF method block execution control method not found
Nov 08 09:55:02 manjaro systemd-tty-ask-password-agent[290]: Failed to open '/run/systemd/ask-password/ask.1447341365786852615', ignoring: No such file or directory
Nov 08 09:55:07 Michal-NB kernel: nvidia: loading out-of-tree module taints kernel.
Nov 08 09:55:07 Michal-NB kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64  580.105.08  Release Build  (root@)
Nov 08 09:55:07 Michal-NB kernel: NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before _acpiDsmSupportedFuncCacheInit subfunction = 11.
Nov 08 09:55:09 Michal-NB kernel: NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before _acpiDsmSupportedFuncCacheInit subfunction = 11.
Nov 08 09:55:11 Michal-NB kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Nov 08 09:55:11 Michal-NB bluetoothd[1335]: Failed to set mode: Failed (0x03)
Nov 08 09:55:11 Michal-NB NetworkManager[1581]: <warn>  [1762592111.7503] keyfile: 802-1x.ca-cert: certificate or key file 'file:///home/mysak/Documents/RL/Eduroam/UVT-89-version1-digicert_assured_id_root_ca.cer%00' does not exist
Nov 08 09:55:19 Michal-NB dbus-broker-launch[1324]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 08 09:55:25 Michal-NB dbus-broker-launch[1324]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 08 09:55:29 Michal-NB NetworkManager[1581]: ((../NetworkManager/src/libnm-systemd-core/src/libsystemd/sd-event/sd-event.c:4488)): assertion '<dropped>' failed
Nov 08 09:55:37 Michal-NB sudo[2025]:    mysak : a password is required ; TTY=tty1 ; PWD=/home/mysak ; USER=root ; COMMAND=/sbin/file -s /dev/nvme0n1p2
Nov 08 09:55:46 Michal-NB systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for systemd-rfkill.socket/start is destructive (systemd-poweroff.service has 'start' job queued, but 'stop' is included in transaction).
Nov 08 09:55:46 Michal-NB systemd[1819]: sys-devices-pci0000:00-0000:00:01.1-0000:01:00.1-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Nov 08 09:55:46 Michal-NB systemd[1819]: sys-devices-pci0000:00-0000:00:08.1-0000:05:00.6-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (systemd-exit.service has 'start' job queued, but 'stop' is included in transaction).
Nov 08 09:55:46 Michal-NB systemd[1]: sys-devices-pci0000:00-0000:00:01.1-0000:01:00.1-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (poweroff.target has 'start' job queued, but 'stop' is included in transaction).
Nov 08 09:55:46 Michal-NB systemd[1]: sys-devices-pci0000:00-0000:00:08.1-0000:05:00.6-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Nov 08 09:55:46 Michal-NB dbus-broker-launch[1324]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Nov 08 09:55:46 Michal-NB systemd-cryptsetup[2484]: Device cryptroot is still in use.
Nov 08 09:55:46 Michal-NB systemd-cryptsetup[2484]: Failed to deactivate 'cryptroot': Device or resource busy
Nov 08 09:55:46 Michal-NB systemd[1]: systemd-cryptsetup@cryptroot.service: Failed with result 'exit-code'.
Full Journal: https://pastebin.com/tZbmuTix
Update: Through some experiments I discovered two workarounds that considerably narrow down the suspects.
Things I tried that did resolve the issue:
  • Removing the kernel cmdline argument fbcon=map:01 avoids the issue (I used this in the past to be able to work in console using a secondary monitor, which needs a passthrough through dedicated Nvidia GPU to work).
  • Never plugging in a secondary monitor during the whole uptime of the computer also avoids the issue. Plugging it in after completing boot and removing it before shutdown, if even for a second, does trigger the issue, however.
Things I tried that did not resolve the issue:
  • Exchanging linux617-nvidia-open for nvidia-open-dkms
  • Exchanging nvidia-open-dkms for nvidia-dkms
  • Using older kernel patch version with the dkms Nvidia modules
When I have time for more testing again, I plan on downgrading only the Nvidia drivers themselves to see if that helps or not.
This is actually a good sign. The fcon map notation is weird..
fbcon=map:01 means:
  • tty1 → fb0
  • tty2 → fb1
I think it would be worth trying: fbcon=map:10
Maybe the frame buffer device numbers flipped them in the new kernels for some reason.
Otherwise..
I don’t use LUKS, is this normal for you? But this looks like it would be a concern to me.
The beauty of -r / --reverse it should have all the log entries right before it hangs. Sometimes info log messages can give hints into what to troubleshoot, even though they aren’t warnings or errors.
And with just seeing warnings, you can’t even tell when you initiated the shutdown.
