Hi! My computer can’t see 5G connections which I’m sure to exist. I’m new to Linux and don’t know exactly how to update drivers nor how to find the appropriate ones for my computer.
Is there any way you can help me? Thanks in advance!
Output of inxi -Fxxxz
System: Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29
info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: X541UV v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UV v: 1.0 serial: <filter> UEFI-[Legacy]: American Megatrends v: X541UV.302
date: 10/25/2016
Battery: ID-1: BAT0 charge: 24.9 Wh (85.3%) condition: 29.2/34.6 Wh (84.4%) volts: 10.8 min: 10.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging cycles: 311
CPU: Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
Speed: 500 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 01:00.0
chip-ID: 10de:134f class-ID: 0302
Device-3: Realtek USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:2 chip-ID: 0bda:57de class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus-ID: 02:00.2 chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0f2 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be v: kernel port: c000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-8:3 chip-ID: 0bda:b721 class-ID: e001
serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 238.47 GiB used: 84.37 GiB (35.4%)
ID-1: /dev/sda vendor: SK Hynix model: HFS256G32TND-N210A size: 238.47 GiB speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 0P10 scheme: MBR
Partition: ID-1: / size: 233.67 GiB used: 84.37 GiB (36.1%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Info: Processes: 258 Uptime: 1h 4m wakeups: 1 Memory: 7.63 GiB used: 2.31 GiB (30.3%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 Packages: 1242 pacman: 1216 snap: 26 Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
