Realtek RTL8111F PCIe Network Card Issues - Slow System Boot & Constant Red Light On Card?
Hi,
I put in a “Realtek RTL8111F” PCIe network card into my desktop.
Desktop runs current (stable) Manjaro KDE Plasma.
My system takes over 1 minute to boot.
Also I notice that there is a constant red light on the above network card?
Any ideas about the above?
Network card appears to work, just need help with slow boot/red light
Thanks!
NOTE: Sorry, forgot system info below:
inxi -zv8         ✔
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e6904fb9-88c7-445f-92eb-bd71124dfe33 rw quiet
    cryptdevice=UUID=ea95b186-2441-4a26-bc26-1445436021f6:luks-ea95b186-2441-4a26-bc26-1445436021f6
    root=/dev/mapper/luks-ea95b186-2441-4a26-bc26-1445436021f6 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 5021 date: 09/29/2024
  System RAM: total: 64 GiB available: 62.71 GiB used: 8.06 GiB (12.8%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3593 min/max: 550/4851 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3593 2: 3593 3: 3593
    4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
    13: 3593 14: 3593 15: 3593 16: 3593 bogomips: 121418
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
    vendor: Micro-Star MSI driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
    of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
    bus-ID: 0a:00.0 chip-ID: 10de:2504 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 161 s-size: 303x170mm (11.93x6.69")
    s-diag: 347mm (13.68")
  Monitor-1: HDMI-0 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 81
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
    surfaces: xcb,xlib
  Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:2526 class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
    chip-ID: 8087:0025 class-ID: e001
  Device-1: luks-ea95b186-2441-4a26-bc26-1445436021f6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.82 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.82 TiB
  Local Storage: total: 12.73 TiB used: 1.37 TiB (10.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000VN0008-2YS101
    size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.37 TiB (76.5%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ea95b186-2441-4a26-bc26-1445436021f6 label: N/A
    uuid: e6904fb9-88c7-445f-92eb-bd71124dfe33
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 7687-2945
  Hub-2: 1-5:2 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0400 class-ID: 0301
  Device-2: 5-2:3 info: China Resource Semico USB Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4094 class-ID: 0300
  Hub-7: 5-4:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Hub-8: 5-4.1:5 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Hub-9: 5-4.3:6 info: Hitachi ports: 4 rev: 2.1
  Hub-10: 5-4.3.1:7 info: Hitachi ports: 4 rev: 2.1
  Device-1: 5-4.3.4:8 info: Brother Industries DCP-L2550DW series
    type: printer driver: usblp interfaces: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 04f9:0424 class-ID: 0701 serial: <filter>
  Hub-11: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-12: 6-4:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Hub-13: 6-4.1:3 info: Hitachi ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
  Hub-14: 6-4.3:4 info: Hitachi ports: 4 rev: 3.0
  Hub-15: 6-4.3.1:5 info: Hitachi ports: 4 rev: 3.0
  System Temperatures: cpu: 48.8 C mobo: N/A gpu: nvidia temp: 46 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 1556 pm: pacman pkgs: 1524 libs: 505 tools: pamac pm: rpm pkgs: 0
    pm: flatpak pkgs: 32
    1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    6: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    7: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 458
  1: cpu: 37.1% command: nxplayer.bin pid: 4662 mem: 304.3 MiB (0.4%)
  2: cpu: 14.2% command: Xorg pid: 938 mem: 173.4 MiB (0.2%)
  3: cpu: 5.8% command: konsole pid: 56887 mem: 177.0 MiB (0.2%)
  4: cpu: 2.7% command: zsh pid: 56899 mem: 9.78 MiB (0.0%)
  5: cpu: 2.2% command: firefox pid: 1740 mem: 1085.4 MiB (1.6%)
  Memory top: 5 of 458
  1: mem: 1085.4 MiB (1.6%) command: firefox pid: 1740 cpu: 2.2%
  2: mem: 756.7 MiB (1.1%) command: firefox pid: 1912 cpu: 1.3%
  3: mem: 630.3 MiB (0.9%) command: plasmashell pid: 1153 cpu: 0.8%
  4: mem: 561.3 MiB (0.8%) command: steamwebhelper pid: 4057 cpu: 1.7%
  5: mem: 483.2 MiB (0.7%) command: kwin_x11 pid: 1113 cpu: 1.3%
  Processes: 458 Power: uptime: 4h 33m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Have you tried the realtek 8168 driver that is appropriate for your kernel? You will have to blacklist the R8169 driver which is currently in use.
sudo pacman -S linux612-r8168
Blacklist:
su -c "echo 'blacklist r8169' > /etc/modprobe.d/99-8169blacklist.conf"
Reboot
Ok, slow boot resolved - system boots fast now.
Still have a constant red light though?
Any other ideas about the red light?
It can mean anything - check with the vendors website
Check your UEFI/BIOS.
Check with a different cable.
If you are dual-booting Windows, make sure that Windows is completely shutdown, Fast start and hibernation is disabled.
If you are now using the r8168 driver is the speed 1000 Mbps like it was before? (inxi -n --filter)
