Hello, i have the latest Manjaro installed. But my Realtek HD Audio is not working. Any ideas how to get it fixed? Thank you
Can you post inxi -Fza on console ?
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Here is the audio part of your command. i cannot send more because then the forum said no links allowed
This Notebook has an Realtek ALC3247 Audio Chip
Can you post the output of alsamixer on console ?
Are you running Pulseaudio or Pipewire ?
Where can i see if i run Pulseaudio or Pipewire?
When i type
sudo dmseg
This shows:
[ 18.718941] BUG?
[ 18.718945] WARNING: CPU: 1 PID: 26 at sound/pci/hda/hda_controller.c:756
azx_single_send_cmd+0xd9/0x1a0 [snd_hda_codec]
And this from the audio tool
I run pulseaudio
Can you choose default:0 HD-Audio Generic from the list ?
Tried already, still no sound. And the default:0 HD-Audio Generic is the ATI AMD Chip but not the Realtek Chip.
On my old Laptop the standard device is pulseaudio, why not in the new one ![]()
Based on the limited data posted so far and no explanation beyond “not working” it is impossible to determine what issue might be affecting audio playback
Please see post #3 where I have adjusted formatting for terminal response
If you use the Preformatted Text button </> or Ctrl + E on keyboard to format terminal responses and inactive URLS, forum software will not prevent new users posting data or links in such a format
Please post full response to previous request for system information
inxi -Fxa
and more information about audio devices detected in ALSA
sudo alsa-info.sh --upload
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3d1fb28d-d331-49a3-b280-83adcb7f3a78 rw quiet
cryptdevice=UUID=bab42309-e691-457a-a439-4d7211928214:luks-bab42309-e691-457a-a439-4d7211928214
root=/dev/mapper/luks-bab42309-e691-457a-a439-4d7211928214 splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP 255 15.6 inch G9 Notebook PC
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8A1B v: 17.24 serial: <superuser required> UEFI: Insyde
v: F.05 date: 04/07/2022
ID-1: BAT1 charge: 39.9 Wh (100.0%) condition: 39.9/40.9 Wh (97.5%)
volts: 12.8 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1858 high: 2300 min/max: 1600/4387 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2300 2: 2300
3: 1600 4: 1600 5: 1403 6: 1397 7: 2300 8: 2300 9: 1600 10: 1600 11: 1600
12: 2300 bogomips: 55122
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Barcelo vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 43.0 C
Device-2: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-4:5 chip-ID: 30c9:0064 class-ID: fe01
serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Idek Iiyama PLX2283H
serial: <filter> built: 2019 res: 1920x1080 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary model: AU Optronics 0x5799
built: 2021 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
class-ID: 0403
alternate:
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID:
04:00.5 chip-ID: 1022:15e2 class-ID: 0480 Device-3: AMD Family 17h/19h HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8
GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID:
1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek vendor: Hewlett-Packard driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b852
class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2:3 chip-ID: 0bda:b85c class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 55.91 GiB (11.7%)
model: MZVLQ512HBLU-00BH1 size: 476.94 GiB block-size: physical: 512 B
rev: HPS1NFAV temp: 43.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 55.91 GiB (11.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-bab42309-e691-457a-a439-4d7211928214
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 50.2 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 288 Uptime: 1m wakeups: 1 Memory: 14.94 GiB
used: 1.87 GiB (12.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1340 libs: 350 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Here the full system info.
The other commands i will post tomorrow.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Both Pulseaudio and Pipewire are running.
This does not work.
You need to uninstall one of them.
inxi
CPU: 6-core AMD Ryzen 5 5625U with Radeon Graphics (-MT MCP-)
speed/min/max: 1727/1600/4387 MHz Kernel: 6.1.1-1-MANJARO x86_64 Up: 1h 44m
Mem: 2559.6/15301.8 MiB (16.7%) Storage: 476.94 GiB (11.8% used) Procs: 281
Shell: Zsh inxi: 3.3.24
cat: ‘/sys/module/snd_acp3x_rn/parameters/*’: No such file or directory
/usr/bin/alsa-info.sh: line 661: tree: command not found
Uploading information to www.alsa-project.org … Done!
Problem found. The speakers was set to mute. And thats why no audio device was shown. Switched it on and now the audio device was shown. Really strange. Now it works perfectly. Thanks for your help.
Sorry, I was too optimistic. The soundproblem is back. I have resolved the problem with the two soundservers running at the same time
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel
bus-ID: 1-2:2 v: kernel chip-ID: 046d:0a14 pcie: class-ID: 0102 gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech USB Headset type: USB driver: snd-usb-audio
Sound Server-2: PulseAudio v: 16.1 running: no
The Output of sudo alsa-info.sh could be seen at https://dpaste.com/7P3XN6M7R
In the kernel log files (journalctl -b0) are numerous kernel module errors all belonging to the sound system like this:
Jan 06 00:44:28 sirius kernel: snd_hda_intel 0000:04:00.6: azx_get_response timeout, switching to single_cmd mode: last cmd=0x800f0005
Jan 06 00:44:28 sirius kernel: ------------[ cut here ]------------
Jan 06 00:44:28 sirius kernel: BUG?
Jan 06 00:44:28 sirius kernel: WARNING: CPU: 10 PID: 97 at sound/pci/hda/hda_controller.c:756 azx_single_send_cmd+0xd9/0x1a0 [snd_hda_codec]
Jan 06 00:44:28 sirius kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr qrtr snd_acp3x_rn snd_soc_dmic snd_acp3x_pdm_dma hp_wmi hid_multi>
Jan 06 00:44:28 sirius kernel: snd_acp_config mdio_devres snd video snd_soc_acpi mc mousedev joydev k10temp i2c_piix4 snd_pci_acp3x cec soundcore rfkill libphy i2c_hid_acpi>
Jan 06 00:44:28 sirius kernel: CPU: 10 PID: 97 Comm: kworker/10:1 Tainted: G W OE 6.1.1-1-MANJARO #1 58eeef856bad441bca33a8abb39f91301fd24d8d
Jan 06 00:44:28 sirius kernel: Hardware name: HP HP 255 15.6 inch G9 Notebook PC/8A1B, BIOS F.05 04/07/2022
Jan 06 00:44:28 sirius kernel: Workqueue: events azx_probe_work [snd_hda_intel]
Jan 06 00:44:28 sirius kernel: RIP: 0010:azx_single_send_cmd+0xd9/0x1a0 [snd_hda_codec]
Jan 06 00:44:28 sirius kernel: Code: 8b 45 20 48 83 c0 64 8b 00 42 89 84 a5 b4 03 00 00 31 c0 5b 5d 41 5c 41 5d c3 cc cc cc cc 48 c7 c7 66 bd c9 c1 e8 92 1d 53 ef <0f> 0b 48>
Jan 06 00:44:28 sirius kernel: RSP: 0018:ffffb4df004b3bc0 EFLAGS: 00010286
Jan 06 00:44:28 sirius kernel: RAX: 0000000000000000 RBX: ffff9b4005e28028 RCX: 0000000000000027
Jan 06 00:44:28 sirius kernel: RDX: ffff9b42fe8a1668 RSI: 0000000000000001 RDI: ffff9b42fe8a1660
Jan 06 00:44:28 sirius kernel: RBP: ffff9b4005e28028 R08: 0000000000000000 R09: ffffb4df004b3a48
Jan 06 00:44:28 sirius kernel: R10: 0000000000000003 R11: ffffffffb24cb768 R12: 0000000000000008
Jan 06 00:44:28 sirius kernel: R13: 00000000801f0005 R14: 0000000000000001 R15: ffff9b4005e28028
Jan 06 00:44:28 sirius kernel: FS: 0000000000000000(0000) GS:ffff9b42fe880000(0000) knlGS:0000000000000000
Jan 06 00:44:28 sirius kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 06 00:44:28 sirius kernel: CR2: 00007fd870000020 CR3: 000000011fa6e000 CR4: 0000000000750ee0
Jan 06 00:44:28 sirius kernel: PKRU: 55555554
Jan 06 00:44:28 sirius kernel: Call Trace:
Jan 06 00:44:28 sirius kernel: <TASK>
Jan 06 00:44:28 sirius kernel: snd_hdac_bus_exec_verb_unlocked+0x8b/0x1b0 [snd_hda_core 932a13099e4bc6b95f05d62c6cb284591c4154be]
Jan 06 00:44:28 sirius kernel: snd_hdac_bus_exec_verb+0x3b/0x60 [snd_hda_core 932a13099e4bc6b95f05d62c6cb284591c4154be]
Jan 06 00:44:28 sirius kernel: hda_reg_read+0x95/0x230 [snd_hda_core 932a13099e4bc6b95f05d62c6cb284591c4154be]
Jan 06 00:44:28 sirius kernel: __snd_hdac_regmap_read_raw+0x84/0xe0 [snd_hda_core 932a13099e4bc6b95f05d62c6cb284591c4154be]
Jan 06 00:44:28 sirius kernel: snd_hdac_device_init+0x239/0x450 [snd_hda_core 932a13099e4bc6b95f05d62c6cb284591c4154be]
Jan 06 00:44:28 sirius kernel: snd_hda_codec_device_init+0xef/0x2c0 [snd_hda_codec fbdbc9df43df42979dd6df9d2e3a1ed591f98966]
Jan 06 00:44:28 sirius kernel: snd_hda_codec_new+0x31/0x90 [snd_hda_codec fbdbc9df43df42979dd6df9d2e3a1ed591f98966]
Jan 06 00:44:28 sirius kernel: azx_probe_codecs+0x16b/0x200 [snd_hda_codec fbdbc9df43df42979dd6df9d2e3a1ed591f98966]
Jan 06 00:44:28 sirius kernel: azx_probe_continue+0x744/0x8d0 [snd_hda_intel 51fc7997375081561ed9645fdf1dd43de6f9da98]
Jan 06 00:44:28 sirius kernel: process_one_work+0x1c7/0x380
Jan 06 00:44:28 sirius kernel: worker_thread+0x51/0x390
Jan 06 00:44:28 sirius kernel: ? rescuer_thread+0x3b0/0x3b0
Jan 06 00:44:28 sirius kernel: kthread+0xde/0x110
Jan 06 00:44:28 sirius kernel: ? kthread_complete_and_exit+0x20/0x20
Jan 06 00:44:28 sirius kernel: ret_from_fork+0x22/0x30
Jan 06 00:44:28 sirius kernel: </TASK>
Jan 06 00:44:28 sirius kernel: ---[ end trace 0000000000000000 ]---
