Realtek audio not showing up in audio settings / can't be selected
I have a b150m night elf motherboard with realtek audio. The device seems to show up under alsamixer but I can#t seem to see or select it in manjaro. I noticed that both pipewire and pulseaudio were running but after booting into a live manjaro usb I noticed that that seems to be default behavior.
Here is some debugging info:
$ sudo alsa-info.sh --upload
http (remove this) ://alsa-project.org/db/?f=2dc70219723e9095e858fc0004e7944a03e4766c
$ inxi -Ax
  Device-1: Intel 100 Series/C230 Series Family HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
$ aplay --list-devices
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [DELL G3223D  ]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [SAMSUNG      ]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [U28E590      ]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
  Subdevices: 1/1
$ sudo dmesg | grep snd
[   12.188029] snd_hda_intel 0000:01:00.1: Disabling MSI
[   12.188034] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   12.341111] snd_hda_codec_realtek hdaudioC0D0: ALC1150: SKU not ready 0x00000000
[   12.341745] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1150: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[   12.341747] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   12.341749] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   12.341751] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   12.341751] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   12.341753] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[   12.341754] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[   12.341755] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
ALSA data all appears to be as expected, playback devices show Subdevices: 1/1 suggesting a software sound server (PulseAudio, JACK or PipeWire) is not connected, but connection might just be suspended
If a sound server was connected to an ALSA playback device it would be shown as: Subdevices: 0/1
Please post more information about audio devices detected in PulseAudio/PipeWire
pactl info; pactl list cards; pactl list sinks
I tried installing a soundcard to avoid the issue (have been stuck on it for a while), hope the card doesn’t complicate things now. Soundcard doesn’t work either btw (see my only other post).
Here are the outputs of the commands:
$ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 4
Tile Size: 65472
User Name: ****
Host Name: ****
Server Name: pulseaudio
Server Version: 16.1
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1
Default Source: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor
Cookie: 2954:9a0d
$ pactl list cards
Card #0
        Driver: module-alsa-card.c
        Owner Module: 6
        Properties:
                alsa.card = "1"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
                device.bus_path = "pci-0000:01:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "10f1"
                device.product.name = "GP106 High Definition Audio Controller"
                device.string = "1"
                device.description = "GP106 High Definition Audio Controller"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Profiles:
                output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 38668, available: yes)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 38468, available: yes)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 38468, available: yes)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
        Active Profile: output:hdmi-stereo-extra1
        Ports:
                hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, available)
                        Properties:
                                device.product.name = "SAMSUNG
                        Part of profile(s): output:hdmi-stereo
                hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, available)
                        Properties:
                                device.product.name = "U28E590
                        Part of profile(s): output:hdmi-stereo-extra1
                hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, available)
                        Properties:
                                device.product.name = "DELL G3223D
                        Part of profile(s): output:hdmi-stereo-extra2
                hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #1
        Owner Module: 7
        Properties:
                alsa.card = "2"
                alsa.card_name = "HDA Creative"
                alsa.long_card_name = "HDA Creative at 0xdf204000 irq 16"
                device.bus_path = "pci-0000:02:00.0"
                sysfs.path = "/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/sound/card2"
                device.bus = "pci"
                device.vendor.id = "1102"
                device.vendor.name = "Creative Labs"
                device.product.id = "0012"
                device.product.name = "Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx)"
                device.string = "2"
                device.description = "Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx)"
        Profiles:
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
                input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 32823, available: yes)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
                output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 39323, available: yes)
                output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34133, available: yes)
                output:analog-surround-21+input:iec958-stereo: Analog Surround 2.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 34123, available: yes)
                output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 33968, available: yes)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34033, available: yes)
                output:analog-surround-40+input:iec958-stereo: Analog Surround 4.0 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 34023, available: yes)
                output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34133, available: yes)
                output:analog-surround-41+input:iec958-stereo: Analog Surround 4.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 34123, available: yes)
                output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 33968, available: yes)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34033, available: yes)
                output:analog-surround-50+input:iec958-stereo: Analog Surround 5.0 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 34023, available: yes)
                output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34133, available: yes)
                output:analog-surround-51+input:iec958-stereo: Analog Surround 5.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 34123, available: yes)
                output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 38268, available: yes)
                output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 38333, available: yes)
                output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 38323, available: yes)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 33133, available: yes)
                output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 33123, available: yes)
        Active Profile: output:analog-surround-51
        Ports:
                analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, available)
                        Properties:
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability unknown)
                iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
                analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability unknown)
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:iec958-stereo
                analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, available)
                        Properties:
                iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #2
        Owner Module: 8
        Properties:
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0xdf340000 irq 138"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a170"
                device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
                device.string = "0"
                device.description = "Built-in Audio"
        Profiles:
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
                output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
                output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
                output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
                output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
                output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
                output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: no)
                output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
        Active Profile: off
        Ports:
                analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo
                analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
                        Properties:
                analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
                analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo
                analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
                        Properties:
$ pactl list sinks
Sink #0
        State: SUSPENDED
        Description: GP106 High Definition Audio Controller Digital Stereo (HDMI 2)
        Owner Module: 6
        Mute: no
        Volume: front-left: 19005 /  29% / -32,26 dB,   front-right: 19005 /  29% / -32,26 dB
                balance 0,00
        Base Volume: 65536 / 100% / 0,00 dB
        Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor
        Latency: 0 usec, configured 0 usec
        Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
        Properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "U28E590"
                alsa.id = "HDMI 1"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "7"
                alsa.card = "1"
                device.bus = "pci"
                device.string = "hdmi:1,1"
                device.buffering.buffer_size = "352768"
                device.buffering.fragment_size = "176384"
                device.access_mode = "mmap+timer"
                device.profile.name = "hdmi-stereo-extra1"
                device.profile.description = "Digital Stereo (HDMI 2)"
                device.description = "GP106 High Definition Audio Controller Digital Stereo (HDMI 2)"
        Ports:
                hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, available)
        Active Port: hdmi-output-1
        Formats:
                pcm
Onboard audio device HDA Intel PCH [ALC1150] is detected PulseAudio as alsa_card.pci-0000_00_1f.3
The Active Profile is set to Off; all other Profiles for stereo or surround outputs are shown as available: no and the Ports are shown as not available
If PulseAudio detects an output is not available it will not allow Profile/Port to be changed
I suggest:
  1. Stop PulseAudio and PipeWire services
    systemctl --user stop pipewire.socket pulseaudio.socket pipewire.service pulseaudio.service
  2. Disable Auto-Mute in ALSA
    amixer --card=0 sset 'Auto-Mute Mode' Disabled
  3. use a music player configured to play audio direct to audio device in ALSA (hw:0,0 or hw:PCH,0)
  4. If audio can play direct to ALSA, delete PulseAudio user configuration files in home folder
     rm -r ~/.config/pulse/*
    and Reboot system to restart PulseAudio service without old audio settings
  5. Check if Profiles/Ports are shown as available in pactl list cards
If PulseAudio Profiles are still shown as available: no even though audio can play in ALSA,
jack detection for this card can be disabled so the Profiles are shown as available: unknown
I tried the commands, nothing really changed. The device did show up as selectable in the kde task bar audio menu though using this command
 pactl set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
After then setting the newly appearing device to active using the menu still no audio could be heard. I made extra sure that I had the correct settings in alsamixer as well and I reconfirmed that cable and headphones are working properly.
Here the relevant snippet:
$pactl list cards
Card #3
        Owner Module: 9
        Properties:
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Profiles:
        Active Profile: output:analog-stereo
        Ports:
                        Properties:
                        Properties:
                        Properties:
