I have install react-native with the manual from react native homepage.
If I run npx react-native init name
(create a new project) or npm install
(in a existing project) I get always the error:
npm ERR! Maximum call stack size exceeded
First … did you use root or sudo at all?
Apparently that can sometimes be the cause … in which case you should fix that and run
npm rebuild
Otherwise the internet says clean cache?
npm cache clean --force
See for example:
