I set up my manjaro installation using the full drive with LUKS encryption. I’d like to set up a separate, smaller partition now, with a clean install of manjaro on it. It doesn’t matter to me whether this partition is LUKS encrypted or not. I’m actually just going to use it for a software build tutorial – and I’d rather do this than use a virtual machine. I am however getting warnings when I run sudo fdisk -l
, that I want to address before continuing.
Output of sudo fdisk -l
Disk /dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: INTEL SSDPEKKF256G7L
Disklabel type: gpt
Disk identifier: A124B8E9-76EC-8340-A4C3-1536094E2C49
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 500103449 499484954 238,2G Linux filesystem
Disk /dev/mapper/luks-0cfaf780-b691-4135-a8d1-370b79dabbf3: 238,17 GiB, 255734199296 bytes, 499480858 sectors
Welcome to fdisk (util-linux 2.38.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
This disk is currently in use - repartitioning is probably a bad idea.
It's recommended to umount all file systems, and swapoff all swap
partitions on this disk.
The device contains 'crypto_LUKS' signature and it will be removed by a write command. See fdisk(8) man page and --wipe option for more details.
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x035894c8.
Command (m for help):
So what would be the proper way to go about creating a new partition with this setup?
