I did a fresh install of the current Manjaro Linux (more exact specs at the bottom).
The network manager detects all networks. But when I want to connect to wifi, after entering the correct password, the network manager doesn’t connect. After a short while he keeps asking for the password, and this goes without success. It seems he doesn’t accept my password.
I have no problems connecting with a hotspot, even though the network manager also asks for the password but here he accepts it.
Does anybody know a solution?
lspci -knn
01:00.1 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
Subsystem: Acer Incorporated [ALI] Device [1025:1193]
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31)
Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [11ad:08a6]
Kernel driver in use: ath10k_pci
Kernel modules: ath10k_pci
and
dmesg | grep ath10k
[ 2.549502] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 2.800158] ath10k_pci 0000:02:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
[ 2.800161] ath10k_pci 0000:02:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 2.800604] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 2.870120] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 2.963029] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 3.099333] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4158.590533] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 4158.859725] ath10k_pci 0000:02:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
[ 4158.859732] ath10k_pci 0000:02:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 4158.861498] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 4158.926165] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 4159.019962] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 4159.106082] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
KDE Plasma Version: 5.19.5
KDE Frameworks Version: 5.74.0
Qt Version: 5.15.1
Kernel Version: 5.8.16-2-MANJARO
OS Type: 64-bit
Processors: 8 × Intel® Core™ i5-8250U CPU @ 1.60GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics 620
You might find something in the Network Manager log:
$journalctl -u NetworkManager -r
Thanks @Chhkuot! That command gave the following:
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9390] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> scanning
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9389] device (wlp2s0): supplicant interface state: inactive -> scanning
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9150] Config: added ‘psk’ value ‘’
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9150] Config: added ‘key_mgmt’ value ‘WPA-PSK WPA-PSK-SHA256 FT-PSK’
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9149] Config: added ‘bgscan’ value ‘simple:30:-70:86400’
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9149] Config: added ‘scan_ssid’ value ‘1’
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9149] Config: added ‘ssid’ value ‘congstar.home_56C9’
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9148] device (wlp2s0): Activation: (wifi) connection ‘congstar.home_56C9’ has security, and secrets exist. No new secrets needed.
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9140] device (wlp2s0): state change: prepare -> config (reason ‘none’, sys-iface-state: ‘managed’)
Dez 04 14:33:17 torsten-aspirea51551 NetworkManager[538]: [1607088797.9125] device (wlp2s0): state change: need-auth -> prepare (reason ‘none’, sys-iface-state: ‘managed’)
Dez 04 14:33:09 torsten-aspirea51551 NetworkManager[538]: [1607088789.8722] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dez 04 14:33:09 torsten-aspirea51551 NetworkManager[538]: [1607088789.8721] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dez 04 14:33:09 torsten-aspirea51551 NetworkManager[538]: [1607088789.0944] device (wlp2s0): Activation: (wifi) asking for new secrets
Dez 04 14:33:09 torsten-aspirea51551 NetworkManager[538]: [1607088789.0921] device (wlp2s0): state change: config -> need-auth (reason ‘none’, sys-iface-state: ‘managed’)
Dez 04 14:33:09 torsten-aspirea51551 NetworkManager[538]: [1607088789.0920] device (wlp2s0): Activation: (wifi) association took too long
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.8715] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.8714] device (wlp2s0): supplicant interface state: associating -> disconnected
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.5283] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.5282] device (wlp2s0): supplicant interface state: authenticating -> associating
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.5141] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Dez 04 14:33:04 torsten-aspirea51551 NetworkManager[538]: [1607088784.5140] device (wlp2s0): supplicant interface state: scanning -> authenticating
Dez 04 14:32:59 torsten-aspirea51551 NetworkManager[538]: [1607088779.9260] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
Dez 04 14:32:59 torsten-aspirea51551 NetworkManager[538]: [1607088779.9259] device (wlp2s0): supplicant interface state: disconnected -> scanning
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.9248] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.9247] device (wlp2s0): supplicant interface state: associating -> disconnected
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.5851] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.5851] device (wlp2s0): supplicant interface state: authenticating -> associating
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.5740] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Dez 04 14:32:58 torsten-aspirea51551 NetworkManager[538]: [1607088778.5739] device (wlp2s0): supplicant interface state: scanning -> authenticating
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.9843] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.9842] device (wlp2s0): supplicant interface state: disconnected -> scanning
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.4829] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.4829] device (wlp2s0): supplicant interface state: associating -> disconnected
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.1485] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.1485] device (wlp2s0): supplicant interface state: authenticating -> associating
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.1395] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Dez 04 14:32:53 torsten-aspirea51551 NetworkManager[538]: [1607088773.1395] device (wlp2s0): supplicant interface state: scanning -> authenticating
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.5549] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.5548] device (wlp2s0): supplicant interface state: disconnected -> scanning
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.4541] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.4540] device (wlp2s0): supplicant interface state: associating -> disconnected
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.1171] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.1171] device (wlp2s0): supplicant interface state: authenticating -> associating
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.1045] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Dez 04 14:32:48 torsten-aspirea51551 NetworkManager[538]: [1607088768.1045] device (wlp2s0): supplicant interface state: scanning -> authenticating
Dez 04 14:32:43 torsten-aspirea51551 NetworkManager[538]: [1607088763.5195] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
Dez 04 14:32:43 torsten-aspirea51551 NetworkManager[538]: [1607088763.5195] device (wlp2s0): supplicant interface state: disconnected -> scanning
Dez 04 14:32:43 torsten-aspirea51551 NetworkManager[538]: [1607088763.4840] Config: added ‘psk’ value ‘’
Dez 04 14:32:43 torsten-aspirea51551 NetworkManager[538]: [1607088763.4839] Config: added ‘key_mgmt’ value ‘WPA-PSK WPA-PSK-SHA256 FT-PSK’
Still I have no connection. I suppose it has to do with the current kernel. 5.8.18.
Tried different kernels (4.4 and 4.19 and 5.4 and 5.9). The problem with the network manager persists. I cannot use wlan with my wlan card Qualcomm Atheros QCA937. Strange that there seems no solution…
I assume you already tried to delete your saved connection then reconnect to create a new one.
My bad, not enough infos in the last journal. I can see once Activation: (wifi) association took too long
but not why.
Lets try this:
- Disconnect from Internet
- Close any running application to minimize the logging
- Run $
journalctl -p 4 -f
-p 4
limits the journal to priority level 4 (warning) and up
-f
follows the log in real time
- Connect to Internet, wait for it to fail (second time asking for pwd)
- Ctrl+C to stop following the journal
I’m not asking you to post everything as it may contains identifiers. If you do post something, please enclose whithin backticks like you did in your first post.
Thanks a lot for getting back to this @Chhkuot!
journalctl -p 4 -f
-- Logs begin at Sun 2020-12-06 17:04:22 CET. --
Dez 08 15:37:22 torsten-aspirea51551 plasmashell[1030]: file:///usr/lib/qt/qml/org/kde/plasm
a/extras/ExpandableListItem.qml:314: TypeError: Cannot read property 'width' of null
Dez 08 15:37:32 torsten-aspirea51551 plasmashell[1030]: file:///usr/lib/qt/qml/org/kde/plasm
Dez 08 15:37:32 torsten-aspirea51551 kded5[958]: plasma-nm: Unhandled active connection stat
e change: 1
Dez 08 15:37:41 torsten-aspirea51551 upowerd[1086]: treating change event as add on /sys/dev
ices/pci0000:00/0000:00:14.0/usb1/1-1
Dez 08 15:37:41 torsten-aspirea51551 plasmashell[1030]: file:///usr/lib/qt/qml/org/kde/plasm
Dez 08 15:37:42 torsten-aspirea51551 upowerd[1086]: treating change event as add on /sys/dev
Dez 08 15:37:42 torsten-aspirea51551 kwin_x11[962]: qt.qpa.xcb: QXcbConnection: XCB error: 3
(BadWindow), sequence: 3064, resource id: 62914565, major code: 18 (ChangeProperty), minor
code: 0
Dez 08 15:37:47 torsten-aspirea51551 plasmashell[1030]: file:///usr/lib/qt/qml/org/kde/plasm
Dez 08 15:37:57 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438277.6995] device (
Dez 08 15:37:57 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438277.7043] device (
Dez 08 15:37:57 torsten-aspirea51551 plasmashell[1030]: file:///usr/lib/qt/qml/org/kde/plasm
Dez 08 15:38:46 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438326.7001] device (wlp2s0): Activation: (wifi) association took too long
Dez 08 15:38:46 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438326.7046] device (wlp2s0): Activation: (wifi) asking for new secrets
Dez 08 15:39:24 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438364.7017] device (wlp2s0): Activation: (wifi) association took too long
Dez 08 15:39:24 torsten-aspirea51551 NetworkManager[447]: <warn> [1607438364.7167] device (wlp2s0): Activation: failed for connection 'warmstrom'
Dez 08 15:39:24 torsten-aspirea51551 plasmashell[1030]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding lo
op detected for property "height"
Can it be that the problem lies between the kernel and the router? - Linux Mint 18.3 with Kernel 4.4.0 connects with no problem. Using Linux Mint 20.03 with a 5.4 Kernel gave me the same problem as with the current Manjaro installation. And using the current Manjaro installation with other routers worked like a charm.
Thankful for any ideas,
Torsten
Well you can, because
So you only have problem connecting to your router right? looking back at everyting you reported, your router is becoming more and more suspicious.
Were you able to successfully connect to your router (the one which now fails) from the live session when you installed Manjaro?
The journal still shows nothing else than Activation: (wifi) association took too long
, then asking for new secrets
Could you please try this:
sudo systemctl restart wpa_supplicant
- connect to your router, wait for failure
systemctl status wpa_supplicant
and post the output (edit out your router MAC address and SSID if necessary)
So far I see nothing wrong on the computer side. Could be your router’s firmware / config.
I would try:
- Checking if there are any file under
/etc/NetworkManager/conf.d/
and what they do;
- Restarting your router (duh… you probably did already )
- Updating your router’s firmware;
- Changing your router’s “Wireless Mode” (try “mixed”);
- Disabling IPv6 in your connection settings.
Thanks for your help @Chhkuot !
You are right. (Unless I use kernel 4.4.0-34-generic. With that or older kernels my router connects perfectly.)
It looks like this:
$ systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; vendor preset: disabled)
Active: active (running) since Wed 2020-12-09 16:13:55 CET; 1min 55s ago
Main PID: 2653 (wpa_supplicant)
Tasks: 1 (limit: 9378)
Memory: 1.3M
CGroup: /system.slice/wpa_supplicant.service
└─2653 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
Dez 09 16:15:02 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: SME: Trying to authenticate with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:02 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: Trying to associate with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:03 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Blablabla" auth_failures=2 duration=20 reason=CONN_FAILED
Dez 09 16:15:17 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: SME: Trying to authenticate with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:17 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: Trying to associate with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:17 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Blablabla" auth_failures=1 duration=10 reason=CONN_FAILED
Dez 09 16:15:32 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Blablabla"
Dez 09 16:15:32 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: SME: Trying to authenticate with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:32 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: Trying to associate with with BL:AB:LA:BL:AB:LA (SSID='Blablabla' freq=2432 MHz)
Dez 09 16:15:32 torsten-aspirea51551 wpa_supplicant[2653]: wlp2s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Blablabla" auth_failures=2 duration=20 reason=CONN_FAILED
Checking if there are any file under /etc/NetworkManager/conf.d/ and what they do;
There are none.
Restarting your router (duh… you probably did already :slight_smile: )
Did that.
Did that as well, yesterday.
This I couldn’t find in the router’s configuration
Did that, with no success
Alright. Now we see: auth_failures=1 duration=10 reason=CONN_FAILED
I wonder why it didn’t show up in the journal post#5, I guess -p 4
was too restrictive.
I’m still curious about that.
Also did you try to connect to your router through Ethernet?
No, Manjaro live session connection to my router did not succeed. It worked great with a Linux Mint 18.3 Live session though (Kernel 4.4.0).
I bought a cable now and it connects to my router like a charm. - So … I can either use a cable, a hotspot or try to find Manjaro with an older kernel. These options should be enough by now.
Thank you so far @Chhkuot for your assistance!
You’re welcome. Let us know if Manjaro with an older kernel solves this, thanks.
