New manjaro install on AMD Ryzen 5 3600 6-Core
msi motherboard, kernel 5.15.25-1
On bootup I get this message:
[0.000000] RDRAND gives funky smelling output, might consider not using it by booting with “nordrand”
Have no idea how to do this.
edit your /etc/default/grub
Add the suggested argument to the kernel commandline - save and rebuild grub
RDRAND issue is solved! BIOS update took care of it. From what I’ve read RDRAND on AMD’s conflict with Linux systemd when comparing random set at boot.
