In Arch they moved the rbenv package from the AUR to extra -
https://aur.archlinux.org/pkgbase/rbenv
https://archlinux.org/packages/extra/any/rbenv/
However the package is not in the Manjaro extra repo.
I would like to propose that rbenv and the related packages (ruby-build and potentially other that I’m not aware of) should be added to Manjaro’s extra repo.
Apologies if this is the wrong way to suggest this change - I’m a long time arch user, but running my first Manjaro install.
Ben
8 January 2025 14:34
2
mbn info rbenv -q | rg -e 'Branch' -e 'Version'| bat
│ STDIN
1 │ Branch : archlinux
2 │ Version : 1.3.0-2
3 │ Branch : unstable
4 │ Version : 1.3.0-2
5 │ Branch : testing
6 │ Version : 1.3.0-2
It appears to be here…
rbenv doesn’t seem to be in Stable currently:
I don’t know why that is; however, you could try switching to Testing or Unstable branch, as one possible workaround.
rbenv v1.3.0-2 is currently in both.
Welcome to the forum!
It’s already available in the Unstable and Testing branches, but not yet in the Stable branch, as you can see here .
If you need this package urgently, then I would advise you to switch to the Testing branch.
sudo pacman-mirrors -B testing -f && sudo pacman -Syyu rbenv
ben75
8 January 2025 14:44
6
It will be in the next stable branch update.
It already is. Manjaro has three branches. Switch to the one that works best for you.
