Razer Blade Pro 17 Stuck in a sleep-loop
Hi!
I recently installed Manjaro Gnome, I’m having problem with my laptop being stuck in a loop after I closed and reopened the lid. I it would wake up and then after around 10-20s go to sleep again. I tried logging in, and it worked fine, so I’m not getting stuck anywhere, as far as I tested.
Looking through the logs, I noticed problems with ACPI:
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: No handler for Region [VRTC] (0000000064961332) [SystemCMOS] (20200528/evregion-127)
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20200528/exfldio-261)
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0.RTEC due to previous error (AE_NOT_EXIST) (20200528/psparse-529)
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: Aborting method \RWAK due to previous error (AE_NOT_EXIST) (20200528/psparse-529)
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: Aborting method \_WAK due to previous error (AE_NOT_EXIST) (20200528/psparse-529)
Oct 07 23:23:00 bladepro17 kernel: ACPI Error: AE_NOT_EXIST, While executing method \_WAK (20200528/hwesleep-47)
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: interrupt unblocked
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: event unblocked
Oct 07 23:23:00 bladepro17 kernel: nvme nvme0: Shutdown timeout set to 8 seconds
Oct 07 23:23:00 bladepro17 kernel: nvme nvme1: Shutdown timeout set to 10 seconds
which are immediately followed by nvme1 which has OS and boot partitions having a shutdown timer set. It is the first moment in the logs this happens.
I tried looking for solutions on this forum (“Razer 15 Goes to sleep whenever it is plugged in or unplugged”), but with no luck.
Lastly, I have tested and got the same exact issue on:
  • Manjaro KDE
  • Manjaro Xfce
  • Ubuntu 20.04
  • Kubuntu 20.04
  • Linux Mint 20
so I believe the problems lies somewhere in the kernel, however I also tried around 5 of those (didn’t keep track of them though) and the problem persisted.
Does anyone has ideas how to solve the problem, or how to provide better information on it?
Thanks!
Additional info:
inxi output:
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=63b4c908-96d1-4173-a12e-644f0132bd60 rw quiet apparmor=1
  security=apparmor resume=UUID=b814c82e-4241-41e9-97f2-5a53eafd6bff
  udev.log_priority=3
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Laptop System: Razer product: Blade Pro 17 (Fall 2019) v: 3.04
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Razer model: DA730 serial: <filter> UEFI: Razer v: 1.02
  date: 08/22/2019
  ID-1: BAT0 charge: 69.5 Wh condition: 69.5/70.6 Wh (98%) volts: 17.5/15.4
  model: Razer Blade type: Unknown serial: <filter> status: Full
  Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
  L2 cache: 12.0 MiB
  bogomips: 62431
  Speed: 993 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3890 2: 3930
  3: 4342 4: 3605 5: 3906 6: 3654 7: 3937 8: 3982 9: 3674 10: 4112 11: 3955
  12: 4123
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Razer USA driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Razer USA
  driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1e90
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
  bus ID: 1-7:3 chip ID: 13d3:56d5 serial: <filter>
  Display: x11 server: X.org 1.20.9 compositor: gnome-shell
  driver: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:a348
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  Device-1: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
  port: 3000 bus ID: 3d:00.0 chip ID: 10ec:8125
  IF: enp61s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
  bus ID: 3f:00.0 chip ID: 8086:2723
  IF: wlp63s0 state: up mac: <filter>
  Local Storage: total: 953.87 GiB used: 8.21 GiB (0.9%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-00000
  size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: EXA7301Q scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Sabrent model: N/A size: 953.87 GiB block size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
  rev: ECFM12.3 scheme: GPT
  ID-1: / raw size: 936.48 GiB size: 920.78 GiB (98.32%) used: 8.21 GiB (0.9%)
  fs: ext4 dev: /dev/nvme1n1p2
  ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme1n1p3
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 322 Uptime: 10m Memory: 15.54 GiB used: 2.16 GiB (13.9%)
  Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1149 lib: 311
  flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
full journalctl from waking up. (I tried copying logs from that whole boot but post was too large):
Oct 07 23:23:00 bladepro17 kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
Oct 07 23:23:00 bladepro17 kernel: OOM killer disabled.
Oct 07 23:23:00 bladepro17 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Oct 07 23:23:00 bladepro17 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: interrupt blocked
Oct 07 23:23:00 bladepro17 kernel: ACPI: Preparing to enter system sleep state S3
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: event blocked
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: EC stopped
Oct 07 23:23:00 bladepro17 kernel: PM: Saving platform NVS memory
Oct 07 23:23:00 bladepro17 kernel: Disabling non-boot CPUs ...
Oct 07 23:23:00 bladepro17 kernel: IRQ 179: no longer affine to CPU1
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 1 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 180: no longer affine to CPU2
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 2 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 181: no longer affine to CPU3
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 3 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 182: no longer affine to CPU4
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 4 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 183: no longer affine to CPU5
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 5 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 184: no longer affine to CPU6
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 6 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 185: no longer affine to CPU7
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 7 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 186: no longer affine to CPU8
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 8 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 187: no longer affine to CPU9
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 9 is now offline
Oct 07 23:23:00 bladepro17 kernel: IRQ 188: no longer affine to CPU10
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 10 is now offline
Oct 07 23:23:00 bladepro17 kernel: smpboot: CPU 11 is now offline
Oct 07 23:23:00 bladepro17 kernel: ACPI: Low-level resume complete
Oct 07 23:23:00 bladepro17 kernel: ACPI: EC: EC started
Oct 07 23:23:00 bladepro17 kernel: PM: Restoring platform NVS memory
Oct 07 23:23:00 bladepro17 kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Oct 07 23:23:00 bladepro17 kernel: Enabling non-boot CPUs ...
Oct 07 23:23:00 bladepro17 kernel: x86: Booting SMP configuration:
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Oct 07 23:23:00 bladepro17 kernel: unchecked MSR access error: RDMSR from 0x123 at rIP: 0xffffffffa8271ab4 (native_read_msr+0x4/0x30)
Oct 07 23:23:00 bladepro17 kernel: Call Trace:
Oct 07 23:23:00 bladepro17 kernel:  update_srbds_msr+0x34/0x70
Oct 07 23:23:00 bladepro17 kernel:  smp_store_cpu_info+0x45/0x50
Oct 07 23:23:00 bladepro17 kernel:  start_secondary+0x61/0x1c0
Oct 07 23:23:00 bladepro17 kernel:  secondary_startup_64+0xb6/0xc0
Oct 07 23:23:00 bladepro17 kernel: unchecked MSR access error: WRMSR to 0x123 (tried to write 0x0000000000000000) at rIP: 0xffffffffa8271b64 (native_write_msr+0x4/0x20)
Oct 07 23:23:00 bladepro17 kernel:  update_srbds_msr+0x5d/0x70
Oct 07 23:23:00 bladepro17 kernel: microcode: sig=0x906ea, pf=0x20, revision=0xb4
Oct 07 23:23:00 bladepro17 kernel: intel_pstate: Disabling energy efficiency optimization
Oct 07 23:23:00 bladepro17 kernel: CPU1 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Oct 07 23:23:00 bladepro17 kernel: CPU2 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Oct 07 23:23:00 bladepro17 kernel: CPU3 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
Oct 07 23:23:00 bladepro17 kernel: CPU4 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
Oct 07 23:23:00 bladepro17 kernel: CPU5 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 6 APIC 0x1
Oct 07 23:23:00 bladepro17 kernel: microcode: sig=0x906ea, pf=0x20, revision=0xd6
Oct 07 23:23:00 bladepro17 kernel: CPU6 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 7 APIC 0x3
Oct 07 23:23:00 bladepro17 kernel: CPU7 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 8 APIC 0x5
Oct 07 23:23:00 bladepro17 kernel: CPU8 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 9 APIC 0x7
Oct 07 23:23:00 bladepro17 kernel: CPU9 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 10 APIC 0x9
Oct 07 23:23:00 bladepro17 kernel: CPU10 is up
Oct 07 23:23:00 bladepro17 kernel: smpboot: Booting Node 0 Processor 11 APIC 0xb
Oct 07 23:23:00 bladepro17 kernel: CPU11 is up
Oct 07 23:23:00 bladepro17 kernel: ACPI: Waking up from system sleep state S3
Oct 07 23:23:00 bladepro17 kernel: nvme nvme1: 8/0/0 default/read/poll queues
Oct 07 23:23:00 bladepro17 kernel: nvme nvme1: ctrl returned bogus length: 16 for NVME_NIDT_EUI64
Oct 07 23:23:00 bladepro17 kernel: nvme nvme0: 12/0/0 default/read/poll queues
Oct 07 23:23:00 bladepro17 kernel: usb 1-7: reset high-speed USB device number 3 using xhci_hcd
Oct 07 23:23:00 bladepro17 kernel: ata1: SATA link down (SStatus 4 SControl 300)
Oct 07 23:23:00 bladepro17 kernel: acpi LNXPOWER:08: Turning OFF
Oct 07 23:23:00 bladepro17 kernel: acpi LNXPOWER:04: Turning OFF
Oct 07 23:23:00 bladepro17 kernel: acpi LNXPOWER:02: Turning OFF
Oct 07 23:23:00 bladepro17 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Oct 07 23:23:00 bladepro17 kernel: acpi LNXPOWER:01: Turning OFF
Oct 07 23:23:00 bladepro17 kernel: OOM killer enabled.
Oct 07 23:23:00 bladepro17 kernel: Restarting tasks ... done.
Oct 07 23:23:00 bladepro17 systemd-sleep[2241]: System resumed.
Oct 07 23:23:00 bladepro17 kernel: PM: suspend exit
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:65
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:88
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:82
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:69
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:68
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:84
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 226:1
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) AIGLX: Resuming AIGLX clients after VT switch
Oct 07 23:23:01 bladepro17 systemd[1]: systemd-suspend.service: Succeeded.
Oct 07 23:23:01 bladepro17 systemd[1]: Finished Suspend.
Oct 07 23:23:01 bladepro17 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:01 bladepro17 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:01 bladepro17 systemd[1]: Stopped target Sleep.
Oct 07 23:23:01 bladepro17 systemd[1]: Reached target Suspend.
Oct 07 23:23:01 bladepro17 systemd[1]: Stopped target Suspend.
Oct 07 23:23:01 bladepro17 kernel: audit: type=1130 audit(1602138181.156:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:01 bladepro17 kernel: audit: type=1131 audit(1602138181.156:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) modeset(0): EDID vendor "AUO", prod id 20637
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) modeset(0): Printing DDC gathered Modelines:
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) modeset(0): Modeline "1920x1080"x0.0  533.28  1920 1968 2000 2000  1080 1090 1095 1111 -hsync -vsync (266.6 kHz eP)
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) modeset(0): Modeline "1920x1080"x0.0  533.28  1920 1968 2000 2000  1080 1090 1095 4440 -hsync -vsync (266.6 kHz e)
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-5: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-6: disconnected
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0): Setting mode "NULL"
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) NVIDIA(G0):     Config Options in the README.
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event4  - Video Bus: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event4  - Video Bus: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event5  - Video Bus: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event5  - Video Bus: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event1  - Power Button: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event1  - Power Button: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event20 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event20 - Integrated Camera: Integrated C: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event24 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event24 - Integrated Camera: Integrated I: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event18 - Razer Razer Blade Keyboard: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event18 - Razer Razer Blade Keyboard: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:85
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event21 - Razer Razer Blade System Control: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event21 - Razer Razer Blade System Control: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:81
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event17 - Razer Razer Blade: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event17 - Razer Razer Blade: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:80
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event16 - SONiX Evoluent VerticalMouse C: is tagged by udev as: Mouse
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event16 - SONiX Evoluent VerticalMouse C: device is a pointer
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:83
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event19 - Razer Razer Blade Consumer Control: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event19 - Razer Razer Blade Consumer Control: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:66
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event2  - Power Button: is tagged by udev as: Keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event2  - Power Button: device is a keyboard
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:87
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event23 - Razer Razer Blade: is tagged by udev as: Mouse
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event23 - Razer Razer Blade: device is a pointer
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:79
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event15 - ELAN0406:00 04F3:30A6 Touchpad: is tagged by udev as: Touchpad
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event15 - ELAN0406:00 04F3:30A6 Touchpad: device is a touchpad
Oct 07 23:23:01 bladepro17 systemd-logind[529]: Operation 'sleep' finished.
Oct 07 23:23:01 bladepro17 ModemManager[576]: <info>  [sleep-monitor] system is resuming
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.3784] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.3785] device (enp61s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Oct 07 23:23:01 bladepro17 kernel: rfkill: input handler disabled
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) systemd-logind: got resume for 13:78
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event14 - ELAN0406:00 04F3:30A6 Mouse: is tagged by udev as: Mouse Pointingstick
Oct 07 23:23:01 bladepro17 /usr/lib/gdm-x-session[1513]: (II) event14 - ELAN0406:00 04F3:30A6 Mouse: device is a pointer
Oct 07 23:23:01 bladepro17 kernel: RTL8125 2.5Gbps internal r8169-3d00:00: attached PHY driver [RTL8125 2.5Gbps internal] (mii_bus:phy_addr=r8169-3d00:00, irq=IGNORE)
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.5273] device (wlp63s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.5281] device (p2p-dev-wlp63s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.5284] manager: NetworkManager state is now DISCONNECTED
Oct 07 23:23:01 bladepro17 kernel: r8169 0000:3d:00.0 enp61s0: Link is Down
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6068] device (wlp63s0): supplicant interface state: internal-starting -> disconnected
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6068] device (p2p-dev-wlp63s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6071] Wi-Fi P2P device controlled by interface wlp63s0 created
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6073] manager: (p2p-dev-wlp63s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6075] device (p2p-dev-wlp63s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6079] device (wlp63s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <info>  [1602138181.6085] device (p2p-dev-wlp63s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:01 bladepro17 NetworkManager[524]: <warn>  [1602138181.6149] sup-iface[8a93c5c47842d2f1,1,wlp63s0]: call-p2p-cancel: failed with P2P cancel failed
Oct 07 23:23:02 bladepro17 gnome-shell[1589]: Removing a network device that was not added
Oct 07 23:23:03 bladepro17 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Oct 07 23:23:03 bladepro17 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:03 bladepro17 kernel: audit: type=1131 audit(1602138183.140:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:03 bladepro17 ModemManager[576]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.5/0000:3d:00.0': not supported by any plugin
Oct 07 23:23:03 bladepro17 ModemManager[576]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.7/0000:3f:00.0': not supported by any plugin
Oct 07 23:23:04 bladepro17 dbus-daemon[523]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.70' (uid=1000 pid=1589 comm="/usr/bin/gnome-shell " label="unconfined")
Oct 07 23:23:04 bladepro17 systemd[1]: Starting Fingerprint Authentication Daemon...
Oct 07 23:23:04 bladepro17 dbus-daemon[523]: [system] Successfully activated service 'net.reactivated.Fprint'
Oct 07 23:23:04 bladepro17 systemd[1]: Started Fingerprint Authentication Daemon.
Oct 07 23:23:04 bladepro17 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:04 bladepro17 kernel: audit: type=1130 audit(1602138184.403:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:04 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Oct 07 23:23:07 bladepro17 gdm-password][2728]: gkr-pam: unlocked login keyring
Oct 07 23:23:07 bladepro17 audit[2728]: USER_AUTH pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 dbus-daemon[523]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.103' (uid=0 pid=2728 comm="gdm-session-worker [pam/gdm-password] " label="unconfined")
Oct 07 23:23:07 bladepro17 dbus-daemon[523]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 07 23:23:07 bladepro17 gdm-password][2728]: pam_systemd_home(gdm-password:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 07 23:23:07 bladepro17 audit[2728]: USER_ACCT pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 kernel: audit: type=1100 audit(1602138187.036:101): pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 kernel: audit: type=1101 audit(1602138187.036:102): pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 audit[2728]: CRED_REFR pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 kernel: audit: type=1110 audit(1602138187.040:103): pid=2728 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="balbok" exe="/usr/lib/gdm-session-worker" hostname=bladepro17 addr=? terminal=/dev/tty1 res=success'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0729] policy: auto-activating connection 'Tell my WiFi love her' (dd0aec20-c6f5-4e89-9769-87a482559149)
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0733] device (wlp63s0): Activation: starting connection 'Tell my WiFi love her' (dd0aec20-c6f5-4e89-9769-87a482559149)
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0734] device (wlp63s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0737] manager: NetworkManager state is now CONNECTING
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0740] device (wlp63s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0743] device (wlp63s0): Activation: (wifi) access point 'Tell my WiFi love her' has security, but secrets are required.
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0743] device (wlp63s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0758] device (wlp63s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0761] device (wlp63s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0763] device (wlp63s0): Activation: (wifi) connection 'Tell my WiFi love her' has security, and secrets exist.  No new secrets needed.
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0763] Config: added 'ssid' value 'Tell my WiFi love her'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0764] Config: added 'scan_ssid' value '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0764] Config: added 'bgscan' value 'simple:30:-70:86400'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0764] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0764] Config: added 'auth_alg' value 'OPEN'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0764] Config: added 'psk' value '<hidden>'
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: SME: Trying to authenticate with 9c:34:26:a1:3a:a4 (SSID='Tell my WiFi love her' freq=5200 MHz)
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: authenticate with 9c:34:26:a1:3a:a4
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0974] device (wlp63s0): supplicant interface state: disconnected -> authenticating
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.0974] device (p2p-dev-wlp63s0): supplicant management interface state: disconnected -> authenticating
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: send auth to 9c:34:26:a1:3a:a4 (try 1/3)
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: Trying to associate with 9c:34:26:a1:3a:a4 (SSID='Tell my WiFi love her' freq=5200 MHz)
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1276] device (wlp63s0): supplicant interface state: authenticating -> associating
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1276] device (p2p-dev-wlp63s0): supplicant management interface state: authenticating -> associating
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: authenticated
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: associate with 9c:34:26:a1:3a:a4 (try 1/3)
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: RX AssocResp from 9c:34:26:a1:3a:a4 (capab=0x1411 status=0 aid=10)
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: Associated with 9c:34:26:a1:3a:a4
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: associated
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1503] device (wlp63s0): supplicant interface state: associating -> 4way_handshake
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1503] device (p2p-dev-wlp63s0): supplicant management interface state: associating -> 4way_handshake
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: WPA: Key negotiation completed with 9c:34:26:a1:3a:a4 [PTK=CCMP GTK=CCMP]
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-CONNECTED - Connection to 9c:34:26:a1:3a:a4 completed [id=0 id_str=]
Oct 07 23:23:07 bladepro17 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp63s0: link becomes ready
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-59 noise=9999 txrate=0
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1679] device (wlp63s0): supplicant interface state: 4way_handshake -> completed
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1680] device (wlp63s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Tell my WiFi love her"
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1680] device (p2p-dev-wlp63s0): supplicant management interface state: 4way_handshake -> completed
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1681] device (wlp63s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.1684] dhcp4 (wlp63s0): activation: beginning transaction (timeout in 45 seconds)
Oct 07 23:23:07 bladepro17 dbus-daemon[1515]: [session uid=1000 pid=1515] Activating service name='org.freedesktop.FileManager1' requested by ':1.21' (uid=1000 pid=1589 comm="/usr/bin/gnome-shell " label="unconfined")
Oct 07 23:23:07 bladepro17 kernel: wlp63s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 9c:34:26:a1:3a:a4
Oct 07 23:23:07 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=26000
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Impossible to monitor trash: Gio.IOErrorEnum: Operation not supported
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Impossible to enumerate trash children: Gio.IOErrorEnum: Operation not supported
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: loading user theme: /usr/share/themes/Matcha-dark-sea/gnome-shell/gnome-shell.css
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Ignoring excess values in shadow definition
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option dhcp_lease_time      => '172800'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option domain_name          => 'hsd1.wa.comcast.net'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option domain_name_servers  => '75.75.75.75 75.75.76.76'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option expiry               => '1602310987'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option host_name            => 'bladepro17'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option ip_address           => '10.0.0.115'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option next_server          => '10.0.0.1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_broadcast_address => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_domain_name => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_domain_name_servers => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_domain_search => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_host_name  => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_interface_mtu => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_ms_classless_static_routes => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_nis_domain => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_nis_servers => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2521] dhcp4 (wlp63s0): option requested_ntp_servers => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_rfc3442_classless_static_routes => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_root_path  => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_routers    => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_static_routes => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_subnet_mask => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_time_offset => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option requested_wpad       => '1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option routers              => '10.0.0.1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): option subnet_mask          => '255.255.255.0'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2522] dhcp4 (wlp63s0): state changed unknown -> bound
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2542] device (wlp63s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 dbus-daemon[523]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=524 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 07 23:23:07 bladepro17 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 07 23:23:07 bladepro17 dbus-daemon[523]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 07 23:23:07 bladepro17 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 07 23:23:07 bladepro17 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2622] device (wlp63s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2624] device (wlp63s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2628] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 07 23:23:07 bladepro17 kernel: audit: type=1130 audit(1602138187.260:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2647] manager: NetworkManager state is now CONNECTED_SITE
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2648] policy: set 'Tell my WiFi love her' (wlp63s0) as default for IPv4 routing and DNS
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.2673] device (wlp63s0): Activation: successful, device activated.
Oct 07 23:23:07 bladepro17 /usr/lib/gdm-x-session[1200]: dbus-daemon[1200]: [session uid=120 pid=1200] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=1306 comm="/usr/lib/gsd-sharing " label="unconfined")
Oct 07 23:23:07 bladepro17 /usr/lib/gdm-x-session[1200]: dbus-daemon[1200]: [session uid=120 pid=1200] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Oct 07 23:23:07 bladepro17 gsd-sharing[1306]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.3805] agent-manager: agent[ee4d566c6092a4b5,:1.70/org.gnome.Shell.NetworkAgent/1000]: agent registered
Oct 07 23:23:07 bladepro17 dbus-daemon[1515]: [session uid=1000 pid=1515] Successfully activated service 'org.freedesktop.FileManager1'
Oct 07 23:23:07 bladepro17 NetworkManager[524]: <info>  [1602138187.6885] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Oct 07 23:23:07 bladepro17 gnome-shell[1589]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Oct 07 23:23:09 bladepro17 NetworkManager[524]: <info>  [1602138189.2439] dhcp6 (wlp63s0): activation: beginning transaction (timeout in 45 seconds)
Oct 07 23:23:09 bladepro17 NetworkManager[524]: <info>  [1602138189.2458] policy: set 'Tell my WiFi love her' (wlp63s0) as default for IPv6 routing and DNS
Oct 07 23:23:09 bladepro17 NetworkManager[524]: <info>  [1602138189.2753] dhcp6 (wlp63s0): option dhcp6_name_servers   => '2001:558:feed::1 2001:558:feed::2'
Oct 07 23:23:09 bladepro17 NetworkManager[524]: <info>  [1602138189.2754] dhcp6 (wlp63s0): option ip6_address          => '2601:602:9400:ceb0::a510'
Oct 07 23:23:09 bladepro17 NetworkManager[524]: <info>  [1602138189.2754] dhcp6 (wlp63s0): state changed unknown -> bound
Oct 07 23:23:17 bladepro17 /usr/lib/gdm-x-session[1513]: (EE) event18 - Razer Razer Blade Keyboard: client bug: event processing lagging behind by 33ms, your system is too slow
Oct 07 23:23:17 bladepro17 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Oct 07 23:23:17 bladepro17 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:17 bladepro17 kernel: audit: type=1131 audit(1602138197.146:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:28 bladepro17 systemd-logind[529]: Suspending...
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.1376] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Oct 07 23:23:28 bladepro17 ModemManager[576]: <info>  [sleep-monitor] system is about to suspend
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.1377] device (enp61s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 07 23:23:28 bladepro17 gnome-shell[1589]: Ignoring excess values in shadow definition
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.1775] device (p2p-dev-wlp63s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.1779] manager: NetworkManager state is now ASLEEP
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.1780] device (wlp63s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Oct 07 23:23:28 bladepro17 dbus-daemon[523]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=524 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 07 23:23:28 bladepro17 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 07 23:23:28 bladepro17 dbus-daemon[523]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 07 23:23:28 bladepro17 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 07 23:23:28 bladepro17 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:28 bladepro17 kernel: audit: type=1130 audit(1602138208.186:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 07 23:23:28 bladepro17 kernel: wlp63s0: deauthenticating from 9c:34:26:a1:3a:a4 by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 07 23:23:28 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-DISCONNECTED bssid=9c:34:26:a1:3a:a4 reason=3 locally_generated=1
Oct 07 23:23:28 bladepro17 wpa_supplicant[1123]: wlp63s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2087] device (wlp63s0): supplicant interface state: completed -> disconnected
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2088] device (wlp63s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2437] dhcp4 (wlp63s0): canceled DHCP transaction
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2437] dhcp4 (wlp63s0): state changed bound -> done
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2439] dhcp6 (wlp63s0): canceled DHCP transaction
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2439] dhcp6 (wlp63s0): state changed bound -> done
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2454] device (wlp63s0): set-hw-addr: set MAC address to 92:CB:FE:FA:43:68 (scanning)
Oct 07 23:23:28 bladepro17 /usr/lib/gdm-x-session[1200]: dbus-daemon[1200]: [session uid=120 pid=1200] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=1306 comm="/usr/lib/gsd-sharing " label="unconfined")
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2520] device (wlp63s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 07 23:23:28 bladepro17 /usr/lib/gdm-x-session[1200]: dbus-daemon[1200]: [session uid=120 pid=1200] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Oct 07 23:23:28 bladepro17 gsd-sharing[1306]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Oct 07 23:23:28 bladepro17 NetworkManager[524]: <info>  [1602138208.2531] device (wlp63s0): set-hw-addr: reset MAC address to 90:78:41:30:F7:A5 (unmanage)
Oct 07 23:23:28 bladepro17 gnome-shell[1589]: An active wireless connection, in infrastructure mode, involves no access point?
Oct 07 23:23:31 bladepro17 gsd-usb-protect[1781]: Error calling USBGuard DBus to change the protection after a screensaver event: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Oct 07 23:23:33 bladepro17 wpa_supplicant[1123]: nl80211: deinit ifname=p2p-dev-wlp63s0 disabled_11b_rates=0
Oct 07 23:23:33 bladepro17 wpa_supplicant[1123]: nl80211: deinit ifname=wlp63s0 disabled_11b_rates=0
Oct 07 23:23:33 bladepro17 systemd-logind[529]: Delay lock is active (UID 120/gdm, PID 1239/gnome-shell) but inhibitor timeout is reached.
Oct 07 23:23:33 bladepro17 systemd[1]: Reached target Sleep.
Oct 07 23:23:33 bladepro17 systemd[1]: Starting Suspend...
Oct 07 23:23:33 bladepro17 systemd-sleep[2794]: Suspending system...
As you seem to be having ACPI issues, have you tried sticking to one kernel (5.8 is fine) and trying out different kernel command line parameters for ACPI?
I.E.:
force -- enable ACPI if default was off
on -- enable ACPI but allow fallback to DT [arm64]
off -- disable ACPI if default was on
noirq -- do not use ACPI for IRQ routing
strict -- Be less tolerant of platforms that are not
        strictly ACPI specification compliant.
rsdt -- prefer RSDT over (default) XSDT
copy_dsdt -- copy DSDT to memory
For ARM64, ONLY "acpi=off", "acpi=on" or "acpi=force"
are available
See also Documentation/power/runtime_pm.rst, pci=noacpi
:+1:
Hi,
Thank you for such a fast response.
I have tried acpi options with following results:
  • on - sleep-loop
  • force - sleep-loop
  • off - touchpad stopped working
  • noirq - touchpad stopped working
  • copy_dsdt - sleep-loop
  • pci=noacpi - touchpad stopped working
However, I decided to approach a problem differently and force Manjaro to always hibernate instead of suspending.
It doesn’t really solve the issue, but skips it, and everything works!
The easiest way to do, is to download the power manager for xfce4, and set close-lid and suspend actions to hibernate.
Thanks! No, I spent some time on Ubuntu and Manjaro KDE before :smiley: This was on an older laptop without GPU though, so not as many things could break.
Is there a way of re-editing the solution. I decided to try to reenable the sleep, but disable “hybrid sleep” and “hibernate after sleep”, and everything works perfectly now! Wanted to add it as a second thing to try, if someone runs into such a problem in the future.
Add the following kernel param:
button.lid_init_state=open
to fix the suspend-resume-loop after closing the lid the first time after boot.
I have same problem and this fixed it.
Thank you!
This actually solves the problem, instead of going around it!
