Razer 2021 Missing NVME Drive with new kernels
I just got the Razer Blade 15 2021, I tried to use the 21.1.5 installer but that installer would not see my nvme drive. I created another bootable drive with 20.2.1 installer and I was able to install manjaro.
The problem I have now is 5.10 kernel doesn’t have wifi support, and if I try to boot to any new kernel it can’t find my drive (similar to the 21.1.5 installer):
mount: /new_root: can't find UUID=<my drive UUID>
Here are some more logs:
Generated on 2021-10-12 05:37:1634031470
#################### lspci -vnn ########################
00:00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a36] (rev 05)
	DeviceName: Onboard - Other
	Subsystem: Razer USA Ltd. Device [1a58:2018]
	Flags: bus master, fast devsel, latency 0, IOMMU group 0
	Memory at <ignored> (32-bit, non-prefetchable)
00:01.0 PCI bridge [0604]: Intel Corporation 11th Gen Core Processor PCIe Controller #1 [8086:9a01] (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00003000-00003fff [size=4K]
	Memory behind bridge: 85000000-860fffff [size=17M]
	Prefetchable memory behind bridge: 0000006000000000-0000006401ffffff [size=16416M]
	Capabilities: <access denied>
	Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Device [8086:9a05] (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: 86400000-864fffff [size=1M]
	Prefetchable memory behind bridge: [disabled]
00:02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-H GT1 [UHD Graphics] [8086:9a60] (rev 01) (prog-if 00 [VGA controller])
	DeviceName: Onboard - Video
	Flags: bus master, fast devsel, latency 0, IRQ 200, IOMMU group 3
	Memory at 644c000000 (64-bit, non-prefetchable) [size=16M]
	Memory at 4000000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 4000 [size=64]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Kernel driver in use: i915
	Kernel modules: i915
00:04.0 Signal processing controller [1180]: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant [8086:9a03] (rev 05)
	Flags: fast devsel, IRQ 16, IOMMU group 4
	Memory at 644d180000 (64-bit, non-prefetchable) [size=128K]
	Kernel driver in use: proc_thermal
	Kernel modules: processor_thermal_device
00:07.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #0 [8086:9a2b] (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 126, IOMMU group 5
	Bus: primary=00, secondary=03, subordinate=2d, sec-latency=0
	I/O behind bridge: 00005000-00005fff [size=4K]
	Memory behind bridge: 78000000-841fffff [size=194M]
	Prefetchable memory behind bridge: 0000006430000000-000000644bffffff [size=448M]
00:07.2 PCI bridge [0604]: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #2 [8086:9a2f] (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 127, IOMMU group 6
	Bus: primary=00, secondary=2e, subordinate=58, sec-latency=0
	I/O behind bridge: 00006000-00006fff [size=4K]
	Memory behind bridge: 6a000000-761fffff [size=194M]
	Prefetchable memory behind bridge: 0000006410000000-000000642bffffff [size=448M]
00:08.0 System peripheral [0880]: Intel Corporation GNA Scoring Accelerator module [8086:9a11] (rev 05)
	Flags: fast devsel, IRQ 11, IOMMU group 7
	Memory at 644d1d6000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:0a.0 Signal processing controller [1180]: Intel Corporation Tigerlake Telemetry Aggregator Driver [8086:9a0d] (rev 01)
	Flags: fast devsel, IOMMU group 8
	Memory at 644d1c0000 (64-bit, non-prefetchable) [size=32K]
00:0d.0 USB controller [0c03]: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller [8086:9a17] (rev 05) (prog-if 30 [XHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 148, IOMMU group 9
	Memory at 644d1b0000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:0d.2 USB controller [0c03]: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0 [8086:9a1f] (rev 05) (prog-if 40 [USB4 Host Interface])
	Subsystem: Device [2222:1111]
	Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 9
	Memory at 644d140000 (64-bit, non-prefetchable) [size=256K]
	Memory at 644d1d5000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: thunderbolt
	Kernel modules: thunderbolt
00:0d.3 USB controller [0c03]: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #1 [8086:9a21] (rev 05) (prog-if 40 [USB4 Host Interface])
	Memory at 644d100000 (64-bit, non-prefetchable) [size=256K]
	Memory at 644d1d4000 (64-bit, non-prefetchable) [size=4K]
00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11) (prog-if 30 [XHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 150, IOMMU group 10
	Memory at 644d1a0000 (64-bit, non-prefetchable) [size=64K]
00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11)
	Flags: fast devsel, IOMMU group 10
	Memory at 644d1cc000 (64-bit, non-prefetchable) [disabled] [size=16K]
	Memory at 644d1d3000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:15.0 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 [8086:43e8] (rev 11)
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 11
	Memory at 4017200000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11)
	Flags: bus master, fast devsel, latency 0, IRQ 167, IOMMU group 12
	Memory at 644d1d1000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c0] (rev 11) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 128, IOMMU group 13
	Bus: primary=00, secondary=59, subordinate=59, sec-latency=0
	I/O behind bridge: 00007000-00007fff [size=4K]
	Memory behind bridge: 68400000-685fffff [size=2M]
	Prefetchable memory behind bridge: 0000004017000000-00000040171fffff [size=2M]
00:1b.2 PCI bridge [0604]: Intel Corporation Device [8086:43c2] (rev 11) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 129, IOMMU group 14
	Bus: primary=00, secondary=5a, subordinate=5a, sec-latency=0
	Memory behind bridge: 86300000-863fffff [size=1M]
00:1b.3 PCI bridge [0604]: Intel Corporation Device [8086:43c3] (rev 11) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 130, IOMMU group 15
	Bus: primary=00, secondary=5b, subordinate=5b, sec-latency=0
	Memory behind bridge: 86200000-862fffff [size=1M]
00:1f.0 ISA bridge [0601]: Intel Corporation Tiger Lake-H LPC/eSPI Controller [8086:438b] (rev 11)
	Flags: bus master, fast devsel, latency 0, IOMMU group 16
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Tiger Lake-H HD Audio Controller [8086:43c8] (rev 11)
	DeviceName: Onboard - Sound
	Flags: bus master, fast devsel, latency 32, IRQ 16, IOMMU group 16
	Memory at 644d1c8000 (64-bit, non-prefetchable) [size=16K]
	Memory at 644d000000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: sof-audio-pci
	Kernel modules: snd_hda_intel, snd_sof_pci
00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11)
	Flags: medium devsel, IRQ 16, IOMMU group 16
	Memory at 644d1d0000 (64-bit, non-prefetchable) [size=256]
	I/O ports at efa0 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11)
	Flags: fast devsel, IOMMU group 16
	Memory at 68600000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel-spi
	Kernel modules: intel_spi_pci
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB] [10de:249c] (rev a1) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 17
	Memory at 85000000 (32-bit, non-prefetchable) [size=16M]
	Memory at 6000000000 (64-bit, prefetchable) [size=16G]
	Memory at 6400000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 3000 [size=128]
	Expansion ROM at 86000000 [disabled] [size=512K]
	Kernel modules: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation GA104 High Definition Audio Controller [10de:228b] (rev a1)
	Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 17
	Memory at 86080000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
02:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd Device [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 18
	Memory at 86400000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
5a:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader [10ec:5260] (rev 01)
	Flags: bus master, fast devsel, latency 0, IRQ 149, IOMMU group 19
	Memory at 86300000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: rtsx_pci
	Kernel modules: rtsx_pci
5b:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
	Flags: bus master, fast devsel, latency 0, IRQ 19, IOMMU group 20
	Memory at 86200000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
#################### lspci -vt ########################
-[0000:00]-+-00.0  Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers
           +-01.0-[01]--+-00.0  NVIDIA Corporation GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
           |            \-00.1  NVIDIA Corporation GA104 High Definition Audio Controller
           +-01.1-[02]----00.0  Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
           +-02.0  Intel Corporation TigerLake-H GT1 [UHD Graphics]
           +-04.0  Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant
           +-07.0-[03-2d]--
           +-07.2-[2e-58]--
           +-08.0  Intel Corporation GNA Scoring Accelerator module
           +-0a.0  Intel Corporation Tigerlake Telemetry Aggregator Driver
           +-0d.0  Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller
           +-0d.2  Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0
           +-0d.3  Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #1
           +-14.0  Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller
           +-14.2  Intel Corporation Tiger Lake-H Shared SRAM
           +-15.0  Intel Corporation Tiger Lake-H Serial IO I2C Controller #0
           +-16.0  Intel Corporation Tiger Lake-H Management Engine Interface
           +-1b.0-[59]--
           +-1b.2-[5a]----00.0  Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader
           +-1b.3-[5b]----00.0  Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz
           +-1f.0  Intel Corporation Tiger Lake-H LPC/eSPI Controller
           +-1f.3  Intel Corporation Tiger Lake-H HD Audio Controller
           +-1f.4  Intel Corporation Tiger Lake-H SMBus Controller
           \-1f.5  Intel Corporation Tiger Lake-H SPI Controller
#################### lsusb -vt ########################
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 10000M/x2
    ID 1d6b:0003 Linux Foundation 3.0 root hub
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/16p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        ID 2109:2817 VIA Labs, Inc.
        |__ Port 1: Dev 5, If 0, Class=, Driver=, 480M
            ID 2109:0102 VIA Labs, Inc.
        |__ Port 2: Dev 7, If 0, Class=Hub, Driver=hub/4p, 480M
            ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
    |__ Port 7: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        ID 1532:0276 Razer USA, Ltd
    |__ Port 7: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 7: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 8: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M
        ID 13d3:5279 IMC Networks
    |__ Port 8: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 8: Dev 6, If 2, Class=Video, Driver=uvcvideo, 480M
    |__ Port 8: Dev 6, If 3, Class=Video, Driver=uvcvideo, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
    |__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        ID 2109:0817 VIA Labs, Inc.
        |__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
            ID 0bda:0411 Realtek Semiconductor Corp. Hub
            |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
                ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
        |__ Port 4: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
            ID 05e3:0749 Genesys Logic, Inc. SD Card Reader and Writer
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
#################### inxi -Fxzc0 ########################
System:    Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.5
Machine:   Type: Laptop System: Razer product: Blade 15 Advanced Model (Mid 2021) - RZ09-0409
           v: 7.04 serial: <filter>
           Mobo: Razer model: CH570 v: 4 serial: <filter> UEFI: Razer v: 1.10 date: 08/06/2021
Battery:   ID-1: BAT0 charge: 69.9 Wh (100.0%) condition: 69.9/80.2 Wh (87.2%) volts: 16.7
           min: 15.4 model: Razer Blade status: Full
CPU:       Info: 8-Core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
           arch: Tiger Lake rev: 1 cache: L2: 24 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 73744
           Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 801 3: 801 4: 801
           5: 816 6: 801 7: 904 8: 801 9: 801 10: 801 11: 801 12: 801 13: 1018 14: 801 15: 801
           16: 801
Graphics:  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Razer USA driver: i915 v: kernel
           bus-ID: 00:02.0
           Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB] vendor: Razer USA
           driver: N/A bus-ID: 01:00.0
           Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo bus-ID: 3-8:6
           Display: x11 server: X.org 1.20.13 driver: loaded: modesetting
           OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.3
           direct render: Yes
Audio:     Device-1: Intel Tiger Lake-H HD Audio vendor: Razer USA driver: sof-audio-pci
           bus-ID: 00:1f.3
           Device-2: NVIDIA GA104 High Definition Audio vendor: Razer USA driver: snd_hda_intel
           v: kernel bus-ID: 01:00.1
           Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
           bus-ID: 5b:00.0
           Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
           bus-ID: 2-3.2.1:5
           IF: enp0s13f0u3u2u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel AX210 Bluetooth type: USB driver: N/A bus-ID: 3-5:8
Drives:    Local Storage: total: 953.87 GiB used: 11.66 GiB (1.2%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 1TB size: 953.87 GiB temp: 41.9 C
Partition: ID-1: / size: 696.63 GiB used: 11.63 GiB (1.7%) fs: ext4 dev: /dev/nvme0n1p5
           ID-2: /boot/efi size: 996 MiB used: 34.1 MiB (3.4%) fs: vfat dev: /dev/nvme0n1p1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 58.0 C mobo: N/A
Info:      Processes: 413 Uptime: 1m Memory: 31.1 GiB used: 1.99 GiB (6.4%) Init: systemd
           Compilers: gcc: 11.1.0 Packages: 1257 Client: gnome-shell v: 40.5 inxi: 3.3.07
I think this has something to with device - I don’t remember the exact argument but try searching for vmd driver.
TL:DR
edit /etc/mkinitcpio.conf and add vmd to the modules line
MODULES=(... vmd ...)
Then rebuild
sudo mkinitcpio -P
And reboot
Maybe this one holds tha answer
I do have Intel VMD disabled in the BIOS
I did this and enabled VMD in the bios and I can boot the new kernels!
Now I am dealing with no sound :frowning:
Please create a new issue
Is there a way to enable this module during the installer? If I try to use 21.1.5 it can’t see the drive.
I would think that this command could work - but I don’t know as I don’t have a device requiring this driver
modprobe vmd
The fix for me was as follow:
  • Enable VDM in the bios
  • Enable CSM and allow legacy boot devices
  • Completely wipe the driver
  • Boot off the 21.1.5 image and then the drive was detected and allowed installation of manjaro.
For my audio problem it was fixed with:
