Rate limit reached
I was trying to download a lot of things and it says:
(1/9) Reloading system manager configuration...
(2/9) Creating temporary files...
(3/9) Arming ConditionNeedsUpdate...
(4/9) Probing GTK3 input method modules...
(5/9) Updating icon theme caches...
(6/9) Updating the info directory file...
(7/9) Copy Thunderbird Distribution Settings
(8/9) Updating the desktop file MIME type cache...
(9/9) Updating the MIME type database...
Rate limit reached
Does it mean something is not complete? How to update the MIME type database?
it adds new bugs like hammering the AUR RPC and getting you rate limited for a 24-hour blacklisting of your IP address if you try to install certain packages with complex deptrees
Thanks! Is there any way to get rid of this?
