Raspberry Pi Kernels (2.0)
The linux-rpi-mainline has been bumped to 5.15.0-1 (5.14 is no more). These new kernel and the latest 2 raspberrypi-bootloader packages has been pushed to the unstable branch when the mirrors sync.
This kernel also has support for the new pi zero 2 W device.
linux-rpi4-mainline 5.15.0-1
linux-rpi4-mainline-headers 5.15.0-1
raspberrypi-bootloader 20211028-1
raspberrypi-bootloader-x 20211028-1
every boot, back to analog device but i need headphone device for audio.
ps. analog no sound.
In Pulse Audio Volume Control Set the headphones as Fallback.
Nothing wrong with Analog here.
The latest linux-rpi kernel and the 2 raspberrypi-bootloader packages has been pushed to the unstable branch when the mirrors sync.
I hope they have settled down with making changes for the new rpi zero 2w.
linux-rpi4 5.10.76-1
linux-rpi4-headers 5.10.76-1
raspberrypi-bootloader 20211102-1
raspberrypi-bootloader-x 20211102-1
The latest linux-rpi4-mainline kernel packages has been pushed to the unstable branch when the mirrors sync.
This kernel also has the latest rpi zero 2 w adjustments.
linux-rpi4-mainline 5.15.0-2
linux-rpi4-mainline headers-5.15.0-2
What was the issue ? why did you release a second one for the same version ?
Just trying to keep up with them changing things around with the new rpi zero 2 w device.
There was an issue though I found when I saw the pi zero 2 w change this mourning I compiled the kernel and noticed they had commited another commit since the last kernel I released a few posts above that caused the screen to blank they had fixed on the 5.10 kernel so I told them and they had it fixed in 8 minutes. This issue was on my end here only and not present in the repo. Scroll down near the bottom:
https://github.com/raspberrypi/linux/issues/4660
Concerning controls for audio devices with kms. Sound starts at 100% volume, but you have to play a sound first, then you can adjust the volume level. Not great but evidently, the way it will be.
My first thought… can a pi make a pitch like a dog whistle? Something that can not be heard and then adjust it?
The latest kernels linux-rpi4 / linux-rpi4-mainline and rpi-eeprom packages has been pushed to the testing and unstable branches.
They ran into a wifi issue concerning connecting and re-connecting and there are some secure boot improvements in “beta” with the rpi-eprom package which you would have to be using “beta” and secure boot to realize any change with the rpi-eprom package.
linux-rpi4 5.10.76-2
linux-rpi4 headers-5.10.76-2
linux-rpi4 mainline-5.15.0-3
linux-rpi4 mainline-headers-5.15.0-3
rpi-eeprom 20211027-1
PiOS move to 5.15 for test and recommend switch to kms.
but, after minutes, freeze.
Disable compositing
what does that mean, how?
Disable the window compositor in you DE’s Settings. I have no clue what DE you have. Also seems like kms is not compatible with wayland either. @0n0w1c would know.
Rpi may recommend things for their images but they do not have all of the DE’s we have.
5.15 + kms + xorg + kwin compositor is a very broken combination (won’t boot). Disable the kwin compositor, then it runs fine.
Recently, kms + wayland + plasma has improved. But Firefox + youtube will freeze the desktop. If I recall correctly, Sway ran fine with kms.
I believe picom is used as the compositor for the RPiOS desktop. If your DE allows running an alternate compositor, you might give it a try.
Edit: For the firefox + youtube, maybe it is because I did not setup Firefox for Wayland. I will try to confirm this later this evening.
but, where to set kwin compositor?
in Plasma Settings → Displays → Compositor.
He will have to boot with fkms first so he can make the changes or freezing up will be an issue.
Maybe this will come to the aide of kms & 5.15.
Edit: This PR did get merged.
If he has access to the filesystem, he can edit ~/.config/kwinrc from:
[Compositing]
Backend=OpenGL
Enabled=true
to
[Compositing]
Backend=OpenGL
Enabled=false
See what it does. Pushed to unstable when the mirrors sync.
linux-rpi4-mainline 5.15.0-4
linux-rpi4-mainline headers-5.15.0-4
