Raspberry Pi Kernels (2.0)
Thanks for v6.8.5 @Darksky
Latest kernel’s -mainline/-rc and raspberrypi-utils packages pushed.
RC-x fixed keyboard repeaat issue :smiley:
edit,
after long hours running, wifi become very slow, need to reboot.
No problems with wifi here with -rc4. Been up 15 hours.
Almost all of the kernel / kernel related packages got upgraded today and pushed to the unstable branch when the mirrors sync.
linux-rpi4 6.6.28-1
linux-rpi4-headers 6.6.28-1
linux-rpi4-mainline 6.8.7-1
linux-rpi4-mainline-headers 6.8.7-1
linux-rpi5 6.6.28-1
linux-rpi5-headers 6.6.28-1
linux-rpi5-mainline 6.8.7-1
linux-rpi5-mainline-headers 6.8.7-1
raspberrypi-bootloader 20240418-1
raspberrypi-bootloader-x 20240418-1
rpi-overlays 20240418-1
ADDED 2024-04-19:
The rpi-4/5 eeprom packages were upgraded and pushed.
https://github.com/raspberrypi/rpi-eeprom/commit/c0a207f4524418d4f7d7266934dc7a1ae92110bf
The major change was with the pi5 eeprom changes and getting promoted to default:
[ray@jellyfin ~]$ sudo rpi-eeprom-update
BOOTLOADER: up to date
   CURRENT: Wed Apr 17 12:54:23 PM UTC 2024 (1713358463)
    LATEST: Wed Apr 17 12:54:23 PM UTC 2024 (1713358463)
   RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
https://github.com/raspberrypi/rpi-eeprom/commit/7a1a01c24f48f800ff9ac6fe43fe1e109abf5f9d
New packages:
rpi4-eeprom 20240418-1
rpi5-eeprom 20240418-1
These new kernel packages pushed to unstable when the mirrors sync.
linux-rpi4-rc 6.9.rc6-1
linux-rpi4-rc-headers 6.9.rc6-1
linux-rpi5-rc 6.9.rc6-1
linux-rpi5-rc-headers 6.9.rc6-1
rpi-overlays 20240429-1
Updated 2024-05-04
These new kernel related packages pushed to the unstable branch when the mirrors sync:
linux-rpi4 6.6.30-1
linux-rpi4-headers 6.6.30-1
linux-rpi4-mainline 6.8.9-1
linux-rpi4-mainline-headers 6.8.9-1
linux-rpi5 6.6.30-1
linux-rpi5-headers 6.6.30-1
linux-rpi5-mainline 6.8.9-1
linux-rpi5-mainline-headers 6.8.9-1
raspberrypi-bootloader 20240503-1
raspberrypi-bootloader-x 20240503-1
can not update pi4-rpi-eeprom 4/17 to stable?
FIRMWARE_RELEASE_STATUS=ā€œstableā€ <—
CURRENT: č„æå…ƒ2024幓04月17ę—„ UTC (1713358296)
LATEST: č„æå…ƒ2024幓04月15ę—„ UTC (1713186734)
RELEASE: default (/lib/firmware/raspberrypi/bootloader/default) <—
sudo rpi-eeprom-update -a
sudo reboot
#Remove temp files from /boot
sudo rpi-eeprom-update -r
Check update for done:
[ray@jellyfin ~]$ sudo rpi-eeprom-update (My pi5)
   CURRENT: Sat Apr 20 10:53:30 AM UTC 2024 (1713610410)
    LATEST: Sat Apr 20 10:53:30 AM UTC 2024 (1713610410)
no go, it lockup default not stable.
Looks like /etc/default/rpi-eeprom-update got renamed to /etc/default/rpi-update. Since the correct file is not there it is defaulting to the program’s default settings which is ā€œdefaultā€.
Try renaming /etc/default/rpi-update to /etc/default/rpi-eeprom-update. Then set in that file:
FIRMWARE_RELEASE_STATUS="stable"
in /etc/default/rpi-eeprom-update.
[ray@jellyfin default]$ sudo rpi-eeprom-update
*** UPDATE AVAILABLE ***
BOOTLOADER: update available
    LATEST: Mon May 13 03:15:01 PM UTC 2024 (1715613301)
   RELEASE: stable (/lib/firmware/raspberrypi/bootloader/stable)
i do set FIRMWARE_RELEASE_STATUS=ā€œstableā€, above post.
edit,
rpi4-eeprom-20240513-2, work :smiley:
edit2,
Plasma-0520.img, Calamares nomore?
@spikerguy
Hi @Darksky. V6.8.10 is out but I guess that you would prefer V6.9.1 for the unstable branche, which is also released.
These new kernel packages has been pushed to the unstable branch when the mirrors sync.
I have combined the 3 packages raspberrypi-bootloader, raspberrypi-bootloader-x, and rpi-overlays packages into one package raspberrypi-bootloader. So when you install raspberrypi-bootloader you must tell the install to remove raspberrypi-bootloader-x, and rpi-overlays or the package will not install. I have done this to make things easier on me each week.
I have also sreamlined the kernel PKGBUILD’s to build a new custom config at build time to cut down on some of my work each week so there will not be a config file in the PKGBUILD’s git. If you need to see a config do a:
sudo modprobe configs and look at /proc/config.gz
Or if you have the kernel-headers package installed look at:
/usr/lib/modules/`uname -r`/build/.config
The linux-rpi4/5 packages are now using the 6.9.y branch. The linux-rpi-rc packages are now depreciated until there is a 6.10.y branch.
linux-rpi4 6.6.31-1
linux-rpi4-headers 6.6.31-1
linux-rpi4-mainline 6.9.1-1
linux-rpi4-mainline-headers 6.9.1-1
linux-rpi5 6.6.31-1
linux-rpi5-headers 6.6.31-1
linux-rpi5-mainline 6.9.1-1
linux-rpi5-mainline-headers 6.9.1-1
raspberrypi-bootloader 20240520-1
ok, saw calamares rebuild(python), can we have delta file, not download next img to save bandwidth?
Pushed new calamares yesterday. new images should have it.
it is already in build artifacts.
bug with yarn and 6.9.
Supposedly fix:
https://lore.kernel.org/io-uring/40c7404a-f4ce-4a7d-86f3-313a9e9ee113@kernel.dk/
ADDED:
I have built the 6.9 kernels with the patch if one wants to test:
linux-rpi4-mainline 6.9.1-2:
https://gitlab.manjaro.org/manjaro-arm/packages/core/linux-rpi4-mainline/-/jobs/14431/artifacts/download?file_type=archive
linux-rpi5-mainline 6.9.1-2:
https://gitlab.manjaro.org/manjaro-arm/packages/core/linux-rpi5-mainline/-/jobs/14432/artifacts/download?file_type=archive
It’s working :+1:
Great!! I will push to the repo then. Thanks for testing!!
