Device: Raspberry Pi 4b
Device addon: Official Raspberry Pi 7" touchscreen
WM: kde plasma
Image used: Manjaro ARM kde for RPi
The OS seems to stall whenever there is I/O—programs loading up, commands entered, updating, copying… It’ll stall for about 5-10 seconds, in which if I click on the window it will be non-responsive, and if I click even just a few more times the system might fully freeze and require a restart.
I’ve tried using two different Sandisk cards with similar results, both on a fresh install. The Manjaro Phosh ARM image doesn’t seem to stall for me on my RPi. Both KDE wayland and xorg stall.
Is it possible that I’ve decompressed the image file incorrectly? I used the ‘unxz’ command to uncompress, and then ‘dd’ to burn to the card.
Some additional info:
journalctl:
type or paste code hereMay 28 17:14:06 user-pc systemd[1]: Started D-Bus System Message Bus.
-- Boot c1ede2e4056544f7b4064f452298cbf2 --
May 28 17:14:06 user-pc systemd[1]: lvm2-monitor.service: Deactivated successfully.
May 28 17:14:06 user-pc systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
-- Boot 22d4e35309ff4bf386784ba5f0b0dbfb --
May 28 17:14:06 user-pc systemd[1]: Starting Network Manager...
May 28 17:14:06 user-pc systemd[1]: Reached target System Shutdown.
May 28 17:14:06 user-pc systemd[1]: Reached target Late Shutdown Services.
May 28 17:14:06 user-pc systemd[1]: Started User Login Management.
May 28 17:14:06 user-pc systemd[1]: systemd-reboot.service: Deactivated successfully.
May 28 17:14:06 user-pc systemd[1]: Finished System Reboot.
May 28 17:14:06 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.systemd1'
May 28 17:14:06 user-pc systemd[1]: Reached target System Reboot.
May 28 17:14:06 user-pc systemd[1]: Shutting down.
May 28 17:14:06 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.2' (uid=0 pid=328 comm="/usr/lib/power-profiles-daemon")
May 28 17:14:06 user-pc systemd[1]: Starting Authorization Manager...
May 28 17:14:06 user-pc systemd[1]: Using hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0, device /dev/watchdog0
May 28 17:14:06 user-pc systemd[1]: Failed to set timeout to 10min: Invalid argument
May 28 17:14:06 user-pc systemd-shutdown[1]: Using hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0, device /dev/watchdog0
May 28 17:14:06 user-pc systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
May 28 17:14:06 user-pc systemd-shutdown[1]: Syncing filesystems and block devices.
May 28 17:14:07 user-pc polkitd[355]: Started polkitd version 0.120
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.2546] NetworkManager (version 1.34.0-1) is starting... (for the first time)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.2615] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: disable-random-mac.conf)
May 28 17:14:07 user-pc systemd[1]: Started Network Manager.
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.2689] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
May 28 17:14:07 user-pc systemd[1]: Reached target Network.
May 28 17:14:07 user-pc systemd[1]: Started OpenSSH Daemon.
May 28 17:14:07 user-pc systemd[1]: Starting Permit User Sessions...
May 28 17:14:07 user-pc systemd[1]: Finished Permit User Sessions.
May 28 17:14:07 user-pc systemd[1]: Starting Hold until boot process finishes up...
May 28 17:14:07 user-pc systemd[1]: Starting Terminate Plymouth Boot Screen...
May 28 17:14:07 user-pc systemd[1]: Received SIGRTMIN+21 from PID 139 (plymouthd).
May 28 17:14:07 user-pc systemd-shutdown[1]: Sending SIGTERM to remaining processes...
May 28 17:14:07 user-pc systemd[1]: Finished Hold until boot process finishes up.
May 28 17:14:07 user-pc systemd[1]: Finished Terminate Plymouth Boot Screen.
May 28 17:14:07 user-pc systemd[1]: Started Simple Desktop Display Manager.
May 28 17:14:07 user-pc systemd-journald[190]: Journal stopped
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.4401] manager[0xaaaac725f000]: monitoring kernel firmware directory '/lib/firmware'.
May 28 17:14:07 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=354 comm="/usr/bin/NetworkManager --no-daemon")
May 28 17:14:07 user-pc systemd[1]: Starting Hostname Service...
May 28 17:14:07 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.hostname1'
May 28 17:14:07 user-pc systemd[1]: Started Hostname Service.
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.5983] hostname: hostname: using hostnamed
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.5987] hostname: hostname changed from (none) to "user-pc"
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.6071] dns-mgr[0xaaaac722e250]: init: dns=default,systemd-resolved rc-manager=symlink
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.6100] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/platform/soc/fe300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/rfkill0) (driver brcmfmac)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.6108] manager[0xaaaac725f000]: rfkill: Wi-Fi hardware radio set enabled
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.6108] manager[0xaaaac725f000]: rfkill: WWAN hardware radio set enabled
May 28 17:14:07 user-pc polkitd[355]: Loading rules from directory /etc/polkit-1/rules.d
May 28 17:14:07 user-pc polkitd[355]: Loading rules from directory /usr/share/polkit-1/rules.d
May 28 17:14:07 user-pc sshd[365]: Server listening on 0.0.0.0 port 22.
May 28 17:14:07 user-pc sshd[365]: Server listening on :: port 22.
May 28 17:14:07 user-pc polkitd[355]: Finished loading, compiling and executing 3 rules
May 28 17:14:07 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
May 28 17:14:07 user-pc systemd[1]: Started Authorization Manager.
May 28 17:14:07 user-pc polkitd[355]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
May 28 17:14:07 user-pc systemd[1]: Started Power Profiles daemon.
May 28 17:14:07 user-pc systemd[1]: Reached target Multi-User System.
May 28 17:14:07 user-pc systemd[1]: Reached target Graphical Interface.
May 28 17:14:07 user-pc systemd[1]: Startup finished in 3.669s (kernel) + 6.811s (userspace) = 10.481s.
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.7792] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-team.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.8641] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-bluetooth.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.8768] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-ovs.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.8845] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-adsl.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.8955] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-wwan.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9117] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-wifi.so)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9137] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9140] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9144] manager: Networking is enabled by state file
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9151] dhcp-init: Using DHCP client 'internal'
May 28 17:14:07 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=354 comm="/usr/bin/NetworkManager --no-daemon")
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9273] settings: Loaded settings plugin: keyfile (internal)
May 28 17:14:07 user-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9776] device (lo): carrier: link connected
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9790] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9834] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
May 28 17:14:07 user-pc NetworkManager[354]: <info> [1653772447.9887] settings: (eth0): created default wired connection 'Wired connection 1'
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.0049] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
May 28 17:14:08 user-pc kernel: bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
May 28 17:14:08 user-pc kernel: bcmgenet fd580000.ethernet eth0: Link is Down
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.0214] device (wlan0): driver supports Access Point (AP) mode
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.0256] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.0309] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
May 28 17:14:08 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 28 17:14:08 user-pc systemd[1]: Started Network Manager Script Dispatcher Service.
May 28 17:14:08 user-pc kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
May 28 17:14:08 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.5' (uid=0 pid=354 comm="/usr/bin/NetworkManager --no-daemon")
May 28 17:14:08 user-pc systemd[1]: Starting WPA supplicant...
May 28 17:14:08 user-pc kernel: Bluetooth: Core ver 2.22
May 28 17:14:08 user-pc kernel: NET: Registered PF_BLUETOOTH protocol family
May 28 17:14:08 user-pc kernel: Bluetooth: HCI device and connection manager initialized
May 28 17:14:08 user-pc kernel: Bluetooth: HCI socket layer initialized
May 28 17:14:08 user-pc kernel: Bluetooth: L2CAP socket layer initialized
May 28 17:14:08 user-pc kernel: Bluetooth: SCO socket layer initialized
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.1139] ovsdb: disconnected from ovsdb
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.1172] modem-manager: oFono is not available
May 28 17:14:08 user-pc kernel: Bluetooth: HCI UART driver ver 2.3
May 28 17:14:08 user-pc kernel: Bluetooth: HCI UART protocol H4 registered
May 28 17:14:08 user-pc kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
May 28 17:14:08 user-pc kernel: Bluetooth: HCI UART protocol Broadcom registered
May 28 17:14:08 user-pc patchram.sh[343]: Done setting line discpline
May 28 17:14:08 user-pc systemd[1]: Starting Bluetooth service...
May 28 17:14:08 user-pc sddm[369]: Initializing...
May 28 17:14:08 user-pc sddm[369]: Starting...
May 28 17:14:08 user-pc sddm[369]: Logind interface found
May 28 17:14:08 user-pc sddm[369]: Adding new display on vt 1 ...
May 28 17:14:08 user-pc dbus-daemon[325]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
May 28 17:14:08 user-pc wpa_supplicant[383]: Successfully initialized wpa_supplicant
May 28 17:14:08 user-pc systemd[1]: Started WPA supplicant.
May 28 17:14:08 user-pc bluetoothd[385]: Bluetooth daemon 5.64
May 28 17:14:08 user-pc sddm[369]: Loading theme configuration from ""
May 28 17:14:08 user-pc sddm[369]: Display server starting...
May 28 17:14:08 user-pc sddm[369]: Adding cookie to "/var/run/sddm/{b454c767-2a11-476b-beb5-e9ef30a34242}"
May 28 17:14:08 user-pc systemd[1]: Started Bluetooth service.
May 28 17:14:08 user-pc systemd[1]: Reached target Bluetooth Support.
May 28 17:14:08 user-pc bluetoothd[385]: Starting SDP server
May 28 17:14:08 user-pc kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
May 28 17:14:08 user-pc kernel: Bluetooth: BNEP filters: protocol multicast
May 28 17:14:08 user-pc kernel: Bluetooth: BNEP socket layer initialized
May 28 17:14:08 user-pc bluetoothd[385]: Bluetooth management interface 1.21 initialized
May 28 17:14:08 user-pc sddm[369]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{b454c767-2a11-476b-beb5-e9ef30a34242} -noreset -displayfd 18
May 28 17:14:08 user-pc kernel: NET: Registered PF_ALG protocol family
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4372] device (wlan0): supplicant interface state: internal-starting -> disconnected
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4376] Wi-Fi P2P device controlled by interface wlan0 created
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4389] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4398] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4424] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
May 28 17:14:08 user-pc NetworkManager[354]: <info> [1653772448.4449] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
May 28 17:14:12 user-pc sddm[369]: Setting default cursor
May 28 17:14:12 user-pc sddm[369]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
May 28 17:14:12 user-pc sddm[369]: Display server started.
May 28 17:14:12 user-pc sddm[369]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
May 28 17:14:12 user-pc sddm[369]: Session "/usr/share/wayland-sessions/plasmawayland.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
May 28 17:14:12 user-pc sddm-helper[408]: [PAM] Starting...
May 28 17:14:12 user-pc sddm-helper[408]: [PAM] Authenticating...
May 28 17:14:12 user-pc sddm-helper[408]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: pam_sm_authenticate
May 28 17:14:12 user-pc sddm-helper[408]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
May 28 17:14:12 user-pc sddm-helper[408]: [PAM] Preparing to converse...
May 28 17:14:12 user-pc sddm-helper[408]: [PAM] Conversation with 1 messages
May 28 17:14:12 user-pc sddm-helper[408]: [PAM] returning.
May 28 17:14:12 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.12' (uid=0 pid=408 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-autha")
May 28 17:14:12 user-pc dbus-daemon[325]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 28 17:14:12 user-pc sddm-helper[408]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 28 17:14:12 user-pc sddm[369]: Authenticated successfully
May 28 17:14:12 user-pc sddm-helper[408]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
May 28 17:14:12 user-pc sddm-helper[408]: pam_unix(sddm-autologin:session): session opened for user user(uid=1000) by (uid=0)
May 28 17:14:12 user-pc sddm[369]: Authentication information: "Welcome to Manjaro-ARM\n~~Website: https://manjaro.org\n~~Forum: https://forum.manjaro.org/c/arm\n~~Matrix: #manjaro-arm-public:matrix.org"
May 28 17:14:12 user-pc systemd[1]: Created slice User Slice of UID 1000.
May 28 17:14:12 user-pc systemd[1]: Starting User Runtime Directory /run/user/1000...
May 28 17:14:12 user-pc systemd-logind[333]: New session 1 of user user.
May 28 17:14:12 user-pc systemd[1]: Finished User Runtime Directory /run/user/1000.
May 28 17:14:12 user-pc systemd[1]: Starting User Manager for UID 1000...
May 28 17:14:12 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.14' (uid=0 pid=413 comm="(systemd)")
May 28 17:14:12 user-pc systemd[413]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 28 17:14:12 user-pc systemd[413]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[user] ruser=[<unknown>] rhost=[<unknown>]
May 28 17:14:12 user-pc systemd[413]: pam_unix(systemd-user:session): session opened for user user(uid=1000) by (uid=0)
May 28 17:14:12 user-pc systemd[413]: pam_env(systemd-user:session): deprecated reading of user environment enabled
May 28 17:14:13 user-pc systemd[1]: Userspace Out-Of-Memory (OOM) Killer was skipped because of a failed condition check (ConditionPathExists=/proc/pressure/memory).
May 28 17:14:13 user-pc systemd[1]: systemd-oomd.socket: Trigger limit hit, refusing further activation.
May 28 17:14:13 user-pc systemd[1]: systemd-oomd.socket: Failed with result 'trigger-limit-hit'.
May 28 17:14:13 user-pc systemd[413]: Queued start job for default target Main User Target.
May 28 17:14:13 user-pc sddm-helper[408]: pam_env(sddm-autologin:session): deprecated reading of user environment enabled
May 28 17:14:13 user-pc systemd[413]: Created slice User Application Slice.
May 28 17:14:13 user-pc sddm-helper[408]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
May 28 17:14:13 user-pc systemd[413]: Reached target Paths.
May 28 17:14:13 user-pc systemd[413]: Reached target Timers.
May 28 17:14:13 user-pc systemd[413]: Starting D-Bus User Message Bus Socket...
May 28 17:14:13 user-pc systemd[413]: Listening on PipeWire PulseAudio.
May 28 17:14:13 user-pc systemd[413]: Listening on PipeWire Multimedia System Socket.
May 28 17:14:13 user-pc systemd[1]: systemd-rfkill.service: Deactivated successfully.
May 28 17:14:13 user-pc systemd[413]: Listening on D-Bus User Message Bus Socket.
May 28 17:14:13 user-pc systemd[413]: Reached target Sockets.
May 28 17:14:13 user-pc systemd[413]: Reached target Basic System.
May 28 17:14:13 user-pc systemd[1]: Started User Manager for UID 1000.
May 28 17:14:13 user-pc systemd[413]: Starting Update XDG user dir configuration...
May 28 17:14:13 user-pc systemd[1]: Started Session 1 of User user.
May 28 17:14:13 user-pc systemd[413]: Finished Update XDG user dir configuration.
May 28 17:14:13 user-pc systemd[413]: Reached target Main User Target.
May 28 17:14:13 user-pc systemd[413]: Startup finished in 601ms.
May 28 17:14:13 user-pc sddm-helper[426]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
May 28 17:14:13 user-pc sddm-helper[408]: Starting: "/usr/share/sddm/scripts/wayland-session /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
May 28 17:14:13 user-pc sddm-helper[429]: Jumping to VT 2
May 28 17:14:13 user-pc sddm-helper[429]: VT mode didn't need to be fixed
May 28 17:14:13 user-pc sddm[369]: Session started
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7254] policy: auto-activating connection 'dlink-DF50-5GHz' (c59573ed-382b-4a48-8537-c9b232c20c09)
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7275] device (wlan0): Activation: starting connection 'dlink-DF50-5GHz' (c59573ed-382b-4a48-8537-c9b232c20c09)
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7285] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7295] manager: NetworkManager state is now CONNECTING
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7304] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7318] device (wlan0): Activation: (wifi) access point 'dlink-DF50-5GHz' has security, but secrets are required.
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7320] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7330] sup-iface[10d8ca612216d3d9,0,wlan0]: wps: type pbc start...
May 28 17:14:14 user-pc NetworkManager[354]: <warn> [1653772454.7342] device (wlan0): no secrets: No agents were available for this request.
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7343] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7356] manager: NetworkManager state is now DISCONNECTED
May 28 17:14:14 user-pc NetworkManager[354]: <warn> [1653772454.7366] device (wlan0): Activation: failed for connection 'dlink-DF50-5GHz'
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7380] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 28 17:14:14 user-pc wpa_supplicant[383]: wlan0: WPS-PBC-ACTIVE
May 28 17:14:14 user-pc wpa_supplicant[383]: wlan0: WPS-CANCEL
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7483] device (wlan0): supplicant interface state: disconnected -> scanning
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7484] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7944] device (wlan0): supplicant interface state: scanning -> inactive
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7945] device (p2p-dev-wlan0): supplicant management interface state: scanning -> inactive
May 28 17:14:14 user-pc NetworkManager[354]: <info> [1653772454.7970] manager: startup complete
May 28 17:14:14 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.16' (uid=1000 pid=429 comm="/usr/bin/startplasma-wayland")
May 28 17:14:14 user-pc systemd[1]: Starting Locale Service...
May 28 17:14:14 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.locale1'
May 28 17:14:14 user-pc systemd[1]: Started Locale Service.
May 28 17:14:15 user-pc systemd[413]: Created slice User Core Session Slice.
May 28 17:14:15 user-pc systemd[413]: Starting D-Bus User Message Bus...
May 28 17:14:15 user-pc systemd[413]: Started D-Bus User Message Bus.
May 28 17:14:15 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'org.freedesktop.systemd1'
May 28 17:14:15 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating service name='org.kde.KSplash' requested by ':1.0' (uid=1000 pid=429 comm="/usr/bin/startplasma-wayland")
May 28 17:14:15 user-pc systemd[413]: Reloading.
May 28 17:14:17 user-pc /usr/bin/irqbalance[326]: IRQ uart-pl011(17) guessed as class 0
May 28 17:14:17 user-pc /usr/bin/irqbalance[326]: IRQ eth0(36) guessed as class 5
May 28 17:14:17 user-pc /usr/bin/irqbalance[326]: IRQ eth0(37) guessed as class 5
May 28 17:14:18 user-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
May 28 17:14:23 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'org.kde.KSplash'
May 28 17:14:26 user-pc systemd[413]: Started PipeWire Multimedia Service.
May 28 17:14:26 user-pc systemd[413]: Started PipeWire Media Session Manager.
May 28 17:14:26 user-pc systemd[413]: Started PipeWire PulseAudio.
May 28 17:14:26 user-pc pipewire-media-session[480]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
May 28 17:14:26 user-pc pipewire[478]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
May 28 17:14:26 user-pc pipewire[478]: mod.rt: could not set nice-level to -11: No such file or directory
May 28 17:14:26 user-pc pipewire-pulse[481]: mod.rt: RTKit error: org.freedesktop.DBus.Error.ServiceUnknown
May 28 17:14:26 user-pc pipewire-pulse[481]: mod.rt: could not set nice-level to -11: No such file or directory
May 28 17:14:26 user-pc pipewire-media-session[480]: mod.rt: could not make thread 483 realtime using RTKit: No such file or directory
May 28 17:14:26 user-pc pipewire[478]: mod.rt: could not make thread 487 realtime using RTKit: No such file or directory
May 28 17:14:26 user-pc pipewire-pulse[481]: mod.rt: could not make thread 488 realtime using RTKit: No such file or directory
May 28 17:14:26 user-pc pipewire-pulse[486]: 536870912
May 28 17:14:26 user-pc ksplashqml[448]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
May 28 17:14:26 user-pc ksplashqml[448]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
May 28 17:14:27 user-pc kernel: Bluetooth: RFCOMM TTY layer initialized
May 28 17:14:27 user-pc kernel: Bluetooth: RFCOMM socket layer initialized
May 28 17:14:27 user-pc kernel: Bluetooth: RFCOMM ver 1.11
May 28 17:14:27 user-pc bluetoothd[385]: Player registered: sender=:1.23 path=/media_player0
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/ldac
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSink/aptx_hd
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aptx_hd
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aac
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSink/sbc
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/sbc
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSink/sbc_xq
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/sbc_xq
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video14' VIDIOC_QUERYCTRL: Inappropriate ioctl for device
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video14' VIDIOC_ENUM_FRAMEINTERVALS: Inappropriate ioctl for device
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/faststream
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video15' VIDIOC_QUERYCTRL: Inappropriate ioctl for device
May 28 17:14:27 user-pc bluetoothd[385]: Endpoint registered: sender=:1.23 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video15' VIDIOC_ENUM_FRAMEINTERVALS: Inappropriate ioctl for device
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video21' VIDIOC_QUERYCTRL: Inappropriate ioctl for device
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video21' VIDIOC_ENUM_FRAMEINTERVALS: Inappropriate ioctl for device
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video22' VIDIOC_QUERYCTRL: Inappropriate ioctl for device
May 28 17:14:27 user-pc pipewire[478]: spa.v4l2: '/dev/video22' VIDIOC_ENUM_FRAMEINTERVALS: Inappropriate ioctl for device
May 28 17:14:27 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1531904 bytes), total 32768 (slots), used 54 (slots)
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1683] agent-manager: agent[d9766dfeea3d6452,:1.24/org.kde.plasma.networkmanagement/1000]: agent registered
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1688] policy: auto-activating connection 'dlink-DF50-5GHz' (c59573ed-382b-4a48-8537-c9b232c20c09)
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1702] device (wlan0): Activation: starting connection 'dlink-DF50-5GHz' (c59573ed-382b-4a48-8537-c9b232c20c09)
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1706] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1712] manager: NetworkManager state is now CONNECTING
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1719] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1747] device (wlan0): Activation: (wifi) access point 'dlink-DF50-5GHz' has security, but secrets are required.
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1747] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1757] sup-iface[10d8ca612216d3d9,0,wlan0]: wps: type pbc start...
May 28 17:14:27 user-pc wpa_supplicant[383]: wlan0: WPS-PBC-ACTIVE
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1890] device (wlan0): supplicant interface state: inactive -> scanning
May 28 17:14:27 user-pc NetworkManager[354]: <info> [1653772467.1891] device (p2p-dev-wlan0): supplicant management interface state: inactive -> scanning
May 28 17:14:27 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1343488 bytes), total 32768 (slots), used 166 (slots)
May 28 17:14:27 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1507328 bytes), total 32768 (slots), used 76 (slots)
May 28 17:14:27 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 274432 bytes), total 32768 (slots), used 668 (slots)
May 28 17:14:27 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.ModemManager1' unit='dbus-org.freedesktop.ModemManager1.service' requested by ':1.24' (uid=1000 pid=471 comm="/bin/kded5")
May 28 17:14:27 user-pc dbus-daemon[325]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.ModemManager1.service': Unit dbus-org.freedesktop.ModemManager1.service not found.
May 28 17:14:27 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating service name='org.kde.kwalletd5' requested by ':1.13' (uid=1000 pid=471 comm="/bin/kded5")
May 28 17:14:27 user-pc kwalletd5[513]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
May 28 17:14:28 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'org.kde.kwalletd5'
May 28 17:14:28 user-pc polkitd[355]: Registered Authentication Agent for unix-session:1 (system bus name :1.25 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 28 17:14:28 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.26' (uid=1000 pid=504 comm="/usr/lib/baloo_file")
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7593] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7603] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7613] device (wlan0): Activation: (wifi) connection 'dlink-DF50-5GHz' has security, and secrets exist. No new secrets needed.
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7616] Config: added 'ssid' value 'dlink-DF50-5GHz'
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7616] Config: added 'scan_ssid' value '1'
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7617] Config: added 'bgscan' value 'simple:30:-70:86400'
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7622] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7623] Config: added 'auth_alg' value 'OPEN'
May 28 17:14:28 user-pc NetworkManager[354]: <info> [1653772468.7623] Config: added 'psk' value '<hidden>'
May 28 17:14:28 user-pc wpa_supplicant[383]: wlan0: WPS-CANCEL
May 28 17:14:28 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating via systemd: service name='org.kde.ActivityManager' unit='plasma-kactivitymanagerd.service' requested by ':1.24' (uid=1000 pid=507 comm="/usr/lib/org_kde_powerdevil")
May 28 17:14:28 user-pc systemd[1]: Starting Disk Manager...
May 28 17:14:28 user-pc kernel: cam-dummy-reg: disabling
May 28 17:14:28 user-pc systemd[413]: Created slice User Background Tasks Slice.
May 28 17:14:28 user-pc systemd[413]: Starting KActivityManager Activity manager Service...
May 28 17:14:28 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.25' (uid=1000 pid=543 comm="/bin/gsettings set org.gnome.desktop.a11y.applicat")
May 28 17:14:29 user-pc systemd[413]: Starting User preferences database...
May 28 17:14:29 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'ca.desrt.dconf'
May 28 17:14:29 user-pc systemd[413]: Started User preferences database.
May 28 17:14:29 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 655360 bytes), total 32768 (slots), used 332 (slots)
May 28 17:14:29 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.27' (uid=1000 pid=507 comm="/usr/lib/org_kde_powerdevil")
May 28 17:14:29 user-pc udisksd[544]: udisks daemon version 2.9.4 starting
May 28 17:14:29 user-pc systemd[1]: Starting Daemon for power management...
May 28 17:14:29 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'org.kde.ActivityManager'
May 28 17:14:29 user-pc systemd[413]: Started KActivityManager Activity manager Service.
May 28 17:14:29 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.UPower'
May 28 17:14:29 user-pc systemd[1]: Started Daemon for power management.
May 28 17:14:29 user-pc dbus-daemon[325]: [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.27' (uid=1000 pid=507 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
May 28 17:14:30 user-pc wpa_supplicant[383]: wlan0: Trying to associate with SSID 'dlink-DF50-5GHz'
May 28 17:14:30 user-pc NetworkManager[354]: <info> [1653772470.1789] device (wlan0): supplicant interface state: scanning -> associating
May 28 17:14:30 user-pc NetworkManager[354]: <info> [1653772470.1790] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating
May 28 17:14:32 user-pc wpa_supplicant[383]: wlan0: Associated with 6c:72:20:11:df:52
May 28 17:14:32 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-CONNECTED - Connection to 6c:72:20:11:df:52 completed [id=0 id_str=]
May 28 17:14:32 user-pc kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
May 28 17:14:38 user-pc systemd[1]: systemd-hostnamed.service: Deactivated successfully.
May 28 17:14:44 user-pc systemd[1]: systemd-localed.service: Deactivated successfully.
May 28 17:14:53 user-pc dbus-daemon[325]: [system] Failed to activate service 'org.freedesktop.UDisks2': timed out (service_start_timeout=25000ms)
May 28 17:14:53 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.26' (uid=1000 pid=504 comm="/usr/lib/baloo_file")
May 28 17:14:54 user-pc NetworkManager[354]: <warn> [1653772494.2223] device (wlan0): Activation: (wifi) association took too long
May 28 17:14:54 user-pc NetworkManager[354]: <info> [1653772494.2225] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
May 28 17:14:54 user-pc NetworkManager[354]: <info> [1653772494.2238] sup-iface[10d8ca612216d3d9,0,wlan0]: wps: type pbc start...
May 28 17:14:54 user-pc NetworkManager[354]: <warn> [1653772494.2252] device (wlan0): Activation: (wifi) asking for new secrets
May 28 17:14:54 user-pc dbus-daemon[325]: [system] Failed to activate service 'org.kde.powerdevil.discretegpuhelper': timed out (service_start_timeout=25000ms)
May 28 17:14:59 user-pc NetworkManager[354]: <warn> [1653772499.2249] sup-iface[10d8ca612216d3d9,0,wlan0]: wps: ProcessCredentials failed to set (Timeout was reached), starting...
May 28 17:15:00 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4774] device (wlan0): supplicant interface state: associating -> completed
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4775] device (p2p-dev-wlan0): supplicant management interface state: associating -> completed
May 28 17:15:00 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-DISCONNECTED bssid=6c:72:20:11:df:52 reason=3 locally_generated=1
May 28 17:15:00 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
May 28 17:15:00 user-pc wpa_supplicant[383]: wlan0: WPS-PBC-ACTIVE
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4842] device (wlan0): supplicant interface state: completed -> disconnected
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4855] device (p2p-dev-wlan0): supplicant management interface state: completed -> disconnected
May 28 17:15:00 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4960] device (wlan0): supplicant interface state: disconnected -> scanning
May 28 17:15:00 user-pc NetworkManager[354]: <info> [1653772500.4961] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
May 28 17:15:00 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.UDisks2'
May 28 17:15:00 user-pc systemd[1]: Started Disk Manager.
May 28 17:15:08 user-pc dbus-daemon[325]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.27' (uid=1000 pid=507 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
May 28 17:15:18 user-pc udisksd[544]: Acquired the name org.freedesktop.UDisks2 on the system message bus
May 28 17:15:21 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
May 28 17:15:21 user-pc dbus-daemon[325]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.27' (uid=1000 pid=507 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
May 28 17:15:21 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
May 28 17:15:23 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 524288 bytes), total 32768 (slots), used 456 (slots)
May 28 17:15:24 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating service name='org.kde.KSplash' requested by ':1.27' (uid=1000 pid=510 comm="/usr/bin/plasmashell")
May 28 17:15:24 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 319488 bytes), total 32768 (slots), used 412 (slots)
May 28 17:15:24 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1597440 bytes), total 32768 (slots), used 22 (slots)
May 28 17:15:26 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1335296 bytes), total 32768 (slots), used 152 (slots)
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7067] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7128] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7137] device (wlan0): Activation: (wifi) connection 'dlink-DF50-5GHz' has security, and secrets exist. No new secrets needed.
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7138] Config: added 'ssid' value 'dlink-DF50-5GHz'
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7138] Config: added 'scan_ssid' value '1'
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7139] Config: added 'bgscan' value 'simple:30:-70:86400'
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7139] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7140] Config: added 'auth_alg' value 'OPEN'
May 28 17:15:40 user-pc NetworkManager[354]: <info> [1653772540.7140] Config: added 'psk' value '<hidden>'
May 28 17:15:40 user-pc wpa_supplicant[383]: wlan0: WPS-CANCEL
May 28 17:15:42 user-pc wpa_supplicant[383]: wlan0: Trying to associate with SSID 'dlink-DF50-5GHz'
May 28 17:15:42 user-pc NetworkManager[354]: <info> [1653772542.1741] device (wlan0): supplicant interface state: scanning -> associating
May 28 17:15:42 user-pc NetworkManager[354]: <info> [1653772542.1742] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating
May 28 17:15:44 user-pc wpa_supplicant[383]: wlan0: Associated with 6c:72:20:11:df:52
May 28 17:15:44 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-CONNECTED - Connection to 6c:72:20:11:df:52 completed [id=0 id_str=]
May 28 17:15:44 user-pc wpa_supplicant[383]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7306] device (wlan0): supplicant interface state: associating -> completed
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7307] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "dlink-DF50-5GHz"
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7308] device (p2p-dev-wlan0): supplicant management interface state: associating -> completed
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7311] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7424] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7845] dhcp4 (wlan0): state changed unknown -> bound, address=192.168.100.114
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.7919] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
May 28 17:15:44 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=354 comm="/usr/bin/NetworkManager --no-daemon")
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.8003] policy: set 'dlink-DF50-5GHz' (wlan0) as default for IPv4 routing and DNS
May 28 17:15:44 user-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
May 28 17:15:44 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=354 comm="/usr/bin/NetworkManager --no-daemon")
May 28 17:15:44 user-pc dbus-daemon[325]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 28 17:15:44 user-pc dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 28 17:15:44 user-pc systemd[1]: Started Network Manager Script Dispatcher Service.
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.8295] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.8300] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.8314] manager: NetworkManager state is now CONNECTED_SITE
May 28 17:15:44 user-pc NetworkManager[354]: <info> [1653772544.8393] device (wlan0): Activation: successful, device activated.
May 28 17:15:45 user-pc NetworkManager[354]: <info> [1653772545.1169] manager: NetworkManager state is now CONNECTED_GLOBAL
May 28 17:15:53 user-pc systemd[413]: Started Konsole - Terminal.
May 28 17:15:54 user-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
May 28 17:15:55 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 929792 bytes), total 32768 (slots), used 416 (slots)
May 28 17:15:55 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 516096 bytes), total 32768 (slots), used 276 (slots)
May 28 17:15:55 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1351680 bytes), total 32768 (slots), used 196 (slots)
May 28 17:15:55 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 380928 bytes), total 32768 (slots), used 194 (slots)
May 28 17:15:55 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
May 28 17:16:01 user-pc dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.40' (uid=0 pid=641 comm="sudo su")
May 28 17:16:01 user-pc dbus-daemon[325]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 28 17:16:01 user-pc sudo[641]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 28 17:16:04 user-pc sudo[641]: user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/bin/su
May 28 17:16:04 user-pc sudo[641]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
May 28 17:16:04 user-pc su[646]: (to root) root on pts/0
May 28 17:16:04 user-pc su[646]: pam_unix(su:session): session opened for user root(uid=0) by (uid=0)
May 28 17:16:27 user-pc systemd-timesyncd[308]: Initial synchronization to time server 162.159.200.1:123 (0.arch.pool.ntp.org).
May 28 17:16:44 user-pc plasma_waitforname[603]: org.kde.knotifications: WaitForName: Service was not registered within timeout
May 28 17:16:44 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activated service 'org.kde.KSplash' failed: Process org.kde.KSplash exited with status 1
May 28 17:17:52 user-pc systemd[413]: Started Firefox - Web Browser.
May 28 17:17:57 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.32' (uid=1000 pid=658 comm="/usr/lib/firefox/firefox")
May 28 17:17:57 user-pc systemd[413]: Starting Accessibility services bus...
May 28 17:17:57 user-pc dbus-daemon[434]: [session uid=1000 pid=434] Successfully activated service 'org.a11y.Bus'
May 28 17:17:57 user-pc systemd[413]: Started Accessibility services bus.
May 28 17:18:00 user-pc kernel: swiotlb_tbl_map_single: 9 callbacks suppressed
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 425984 bytes), total 32768 (slots), used 478 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 286720 bytes), total 32768 (slots), used 718 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 512000 bytes), total 32768 (slots), used 196 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1183744 bytes), total 32768 (slots), used 310 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1245184 bytes), total 32768 (slots), used 314 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 196 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 210 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 260 (slots)
May 28 17:18:00 user-pc kernel: vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 198 (slots)
May 28 17:29:50 user-pc systemd[1]: Starting Cleanup of Temporary Directories...
May 28 17:29:50 user-pc systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
May 28 17:29:50 user-pc systemd[1]: Finished Cleanup of Temporary Directories.
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.15.36-1-MANJARO-ARM-RPI (builduser@fh-mjr-build-lon-xlarge) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Apr 28 17:35:21 UTC 2022
[ 0.000000] random: fast init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001a400000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 28 pages/cpu s77400 r8192 d29096 u114688
[ 0.000000] pcpu-alloc: s77400 r8192 d29096 u114688 alloc=28*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028848
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:E7:C7:A9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=PARTUUID=f003795a-02 rw rootwait console=ttyS0,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 usbhid.mousepoll=8 audit=0
[ 0.000000] audit: disabled (until reboot)
[ 0.000000] Unknown kernel command line parameters "splash selinux=0", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 7657600K/8245248K available (12544K kernel code, 2468K rwdata, 4396K rodata, 4032K init, 1138K bss, 259968K reserved, 327680K cma-reserved)
[ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x90/0x194 with crng_init=1
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 39703 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000281] Console: colour dummy device 80x25
[ 0.000335] printk: console [tty3] enabled
[ 0.000407] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000433] pid_max: default: 32768 minimum: 301
[ 0.000628] LSM: Security Framework initializing
[ 0.000905] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001009] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002325] cgroup: Disabling memory control group subsystem
[ 0.005050] rcu: Hierarchical SRCU implementation.
[ 0.006200] EFI services will not be available.
[ 0.006740] smp: Bringing up secondary CPUs ...
[ 0.007810] Detected PIPT I-cache on CPU1
[ 0.007889] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009119] Detected PIPT I-cache on CPU2
[ 0.009171] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.010316] Detected PIPT I-cache on CPU3
[ 0.010367] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010517] smp: Brought up 1 node, 4 CPUs
[ 0.010537] SMP: Total of 4 processors activated.
[ 0.010548] CPU features: detected: 32-bit EL0 Support
[ 0.010558] CPU features: detected: 32-bit EL1 Support
[ 0.010570] CPU features: detected: CRC32 instructions
[ 0.044123] CPU: All CPU(s) started at EL2
[ 0.044199] alternatives: patching kernel code
[ 0.046037] devtmpfs: initialized
[ 0.057476] Enabled cp15_barrier support
[ 0.057516] Enabled setend support
[ 0.057537] KASLR enabled
[ 0.057737] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.057768] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.066562] pinctrl core: initialized pinctrl subsystem
[ 0.067375] DMI not present or invalid.
[ 0.067916] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.071566] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.071877] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.072787] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.073508] thermal_sys: Registered thermal governor 'step_wise'
[ 0.073735] cpuidle: using governor menu
[ 0.073987] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.074174] ASID allocator initialised with 32768 entries
[ 0.074319] Serial: AMBA PL011 UART driver
[ 0.084671] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.100134] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-04-13T14:49:18, variant start
[ 0.104147] raspberrypi-firmware soc:firmware: Firmware hash is c073992a577d160d8c30bfcf746d2208951c0537
[ 0.157816] ACPI: Interpreter disabled.
[ 0.158208] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.162437] vgaarb: loaded
[ 0.162917] SCSI subsystem initialized
[ 0.163122] usbcore: registered new interface driver usbfs
[ 0.163186] usbcore: registered new interface driver hub
[ 0.163260] usbcore: registered new device driver usb
[ 0.163590] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.164059] pps_core: LinuxPPS API ver. 1 registered
[ 0.164072] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.164094] PTP clock support registered
[ 0.165517] clocksource: Switched to clocksource arch_sys_counter
[ 0.245685] VFS: Disk quotas dquot_6.6.0
[ 0.245788] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.245968] FS-Cache: Loaded
[ 0.246282] CacheFiles: Loaded
[ 0.247308] simple-framebuffer 3ea83000.framebuffer: framebuffer at 0x3ea83000, 0x177000 bytes
[ 0.247328] simple-framebuffer 3ea83000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 0.247772] Console: switching to colour frame buffer device 100x30
[ 0.249879] simple-framebuffer 3ea83000.framebuffer: fb0: simplefb registered!
[ 0.250015] pnp: PnP ACPI: disabled
[ 0.260216] NET: Registered PF_INET protocol family
[ 0.261084] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.266774] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.266877] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.267380] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.268390] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.268697] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.268828] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.269211] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.270254] RPC: Registered named UNIX socket transport module.
[ 0.270272] RPC: Registered udp transport module.
[ 0.270282] RPC: Registered tcp transport module.
[ 0.270292] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.270311] PCI: CLS 0 bytes, default 64
[ 0.270895] Trying to unpack rootfs image as initramfs...
[ 0.279559] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.279939] kvm [1]: IPA Size Limit: 44 bits
[ 0.281302] kvm [1]: vgic interrupt IRQ9
[ 0.281564] kvm [1]: Hyp mode initialized successfully
[ 0.880395] Freeing initrd memory: 8604K
[ 1.183320] Initialise system trusted keyrings
[ 1.183722] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.190490] zbud: loaded
[ 1.192440] FS-Cache: Netfs 'nfs' registered for caching
[ 1.193182] NFS: Registering the id_resolver key type
[ 1.193219] Key type id_resolver registered
[ 1.193230] Key type id_legacy registered
[ 1.193367] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.193389] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.195804] Key type asymmetric registered
[ 1.195824] Asymmetric key parser 'x509' registered
[ 1.195897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.196168] io scheduler mq-deadline registered
[ 1.196182] io scheduler kyber registered
[ 1.196395] io scheduler bfq registered
[ 1.204482] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.204524] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.204609] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.204701] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.267661] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.268024] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.268043] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.268061] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.268146] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.268388] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.272274] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.272638] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.272762] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.273214] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.289020] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.289067] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.289090] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.289129] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.289150] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.302081] iproc-rng200 fe104000.rng: hwrng registered
[ 1.302538] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.303917] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.316829] brd: module loaded
[ 1.327792] loop: module loaded
[ 1.328581] Loading iSCSI transport class v2.0-870.
[ 1.333698] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.401702] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.402850] usbcore: registered new interface driver lan78xx
[ 1.402904] usbcore: registered new interface driver smsc95xx
[ 1.450627] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.450809] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.450853] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.451589] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.452899] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.452921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.452936] usb usb1: Product: xHCI Host Controller
[ 1.452948] usb usb1: Manufacturer: Linux 5.15.36-1-MANJARO-ARM-RPI xhci-hcd
[ 1.452961] usb usb1: SerialNumber: 0000:01:00.0
[ 1.453709] hub 1-0:1.0: USB hub found
[ 1.453805] hub 1-0:1.0: 1 port detected
[ 1.454489] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.454511] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.454533] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.454948] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.454968] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.454983] usb usb2: Product: xHCI Host Controller
[ 1.454995] usb usb2: Manufacturer: Linux 5.15.36-1-MANJARO-ARM-RPI xhci-hcd
[ 1.455008] usb usb2: SerialNumber: 0000:01:00.0
[ 1.455681] hub 2-0:1.0: USB hub found
[ 1.455747] hub 2-0:1.0: 4 ports detected
[ 1.457360] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.457708] dwc_otg: FIQ enabled
[ 1.457719] dwc_otg: NAK holdoff enabled
[ 1.457728] dwc_otg: FIQ split-transaction FSM enabled
[ 1.457741] Module dwc_common_port init
[ 1.458289] usbcore: registered new interface driver uas
[ 1.458396] usbcore: registered new interface driver usb-storage
[ 1.458599] mousedev: PS/2 mouse device common for all mice
[ 1.460583] device-mapper: uevent: version 1.0.3
[ 1.460887] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 1.464891] sdhci: Secure Digital Host Controller Interface driver
[ 1.464910] sdhci: Copyright(c) Pierre Ossman
[ 1.465754] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.470942] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.471082] No iBFT detected.
[ 1.471231] hid: raw HID events driver (C) Jiri Kosina
[ 1.471349] usbcore: registered new interface driver usbhid
[ 1.471354] usbhid: USB HID core driver
[ 1.471558] ashmem: initialized
[ 1.475829] Initializing XFRM netlink socket
[ 1.475856] NET: Registered PF_PACKET protocol family
[ 1.475927] Key type dns_resolver registered
[ 1.476463] registered taskstats version 1
[ 1.476481] Loading compiled-in X.509 certificates
[ 1.476791] Key type ._fscrypt registered
[ 1.476797] Key type .fscrypt registered
[ 1.476801] Key type fscrypt-provisioning registered
[ 1.481974] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.482119] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.482204] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 17, base_baud = 0) is a PL011 rev2
[ 1.488344] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.488563] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.489124] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.489132] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.516242] of_cfs_init
[ 1.516281] of_cfs_init: OK
[ 1.554280] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.560415] Freeing unused kernel memory: 4032K
[ 1.560529] Run /init as init process
[ 1.560534] with arguments:
[ 1.560537] /init
[ 1.560541] splash
[ 1.560544] with environment:
[ 1.560548] HOME=/
[ 1.560551] TERM=linux
[ 1.560555] selinux=0
[ 1.599508] mmc1: new high speed SDIO card at address 0001
[ 1.652679] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.653716] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.658168] mmcblk0: p1 p2
[ 1.658634] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.713544] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.864254] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.864312] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.864319] usb 1-1: Product: USB2.0 Hub
[ 1.865844] hub 1-1:1.0: USB hub found
[ 1.866163] hub 1-1:1.0: 4 ports detected
[ 1.898006] checking generic (3ea83000 177000) vs hw (0 ffffffffffffffff)
[ 1.898023] fb0: switching to vc4 from simple
[ 1.898250] Console: switching to colour dummy device 80x25
[ 1.899214] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 1.899803] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 1.905847] Console: switching to colour frame buffer device 100x30
[ 1.921610] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 2.161566] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 2.269934] usb 1-1.1: New USB device found, idVendor=413c, idProduct=1005, bcdDevice=59.00
[ 2.269959] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.269970] usb 1-1.1: Product: Dell Multimedia Pro Keyboard Hub
[ 2.269978] usb 1-1.1: Manufacturer: Dell
[ 2.278027] hub 1-1.1:1.0: USB hub found
[ 2.278934] hub 1-1.1:1.0: 3 ports detected
[ 2.361566] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 2.469986] usb 1-1.4: New USB device found, idVendor=045e, idProduct=077b, bcdDevice= 0.44
[ 2.470009] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.470024] usb 1-1.4: Product: Comfort Mouse 3000
[ 2.470037] usb 1-1.4: Manufacturer: Microsoft
[ 2.500868] input: Microsoft Comfort Mouse 3000 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:077B.0001/input/input0
[ 2.557931] input: Microsoft Comfort Mouse 3000 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:077B.0001/input/input1
[ 2.558553] hid-generic 0003:045E:077B.0001: input,hidraw0: USB HID v1.11 Mouse [Microsoft Comfort Mouse 3000] on usb-0000:01:00.0-1.4/input0
[ 2.573574] usb 1-1.1.1: new low-speed USB device number 5 using xhci_hcd
[ 2.687398] usb 1-1.1.1: New USB device found, idVendor=413c, idProduct=2011, bcdDevice=59.00
[ 2.687432] usb 1-1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.687448] usb 1-1.1.1: Product: Dell Multimedia Pro Keyboard
[ 2.687462] usb 1-1.1.1: Manufacturer: Dell
[ 2.703977] input: Dell Dell Multimedia Pro Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.0/0003:413C:2011.0002/input/input2
[ 2.762628] hid-generic 0003:413C:2011.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell Multimedia Pro Keyboard] on usb-0000:01:00.0-1.1.1/input0
[ 2.778678] input: Dell Dell Multimedia Pro Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.1/0003:413C:2011.0003/input/input3
[ 2.837949] input: Dell Dell Multimedia Pro Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.1/0003:413C:2011.0003/input/input4
[ 2.838339] hid-generic 0003:413C:2011.0003: input,hidraw2: USB HID v1.10 Device [Dell Dell Multimedia Pro Keyboard] on usb-0000:01:00.0-1.1.1/input1
[ 3.230016] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.738215] systemd[1]: System time before build time, advancing clock.
[ 3.906613] NET: Registered PF_INET6 protocol family
[ 3.907583] Segment Routing with IPv6
[ 3.907608] In-situ OAM (IOAM) with IPv6
[ 3.963017] systemd[1]: systemd 250.5-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 3.963797] systemd[1]: Detected architecture arm64.
[ 3.971448] systemd[1]: Hostname set to <user-pc>.
[ 4.658046] systemd[1]: /usr/lib/systemd/system/stop-dmesg.service:2: Unknown key name 'USER' in section 'Unit', ignoring.
[ 4.663752] systemd[1]: Configuration file /usr/lib/systemd/system/attach-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.669106] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.673155] systemd[1]: Created slice Slice /system/getty.
[ 4.674810] systemd[1]: Created slice Slice /system/modprobe.
[ 4.675618] systemd[1]: Created slice User and Session Slice.
[ 4.676052] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.676917] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.677134] systemd[1]: Reached target Login Prompts.
[ 4.677234] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 4.677366] systemd[1]: Reached target Remote File Systems.
[ 4.677434] systemd[1]: Reached target Slice Units.
[ 4.677583] systemd[1]: Reached target Swaps.
[ 4.677705] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.678101] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.683812] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.692189] systemd[1]: Listening on Process Core Dump Socket.
[ 4.699930] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[ 4.700729] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.701317] systemd[1]: Listening on Journal Socket.
[ 4.701854] systemd[1]: Listening on Userspace Out-Of-Memory (OOM) Killer Socket.
[ 4.702437] systemd[1]: Listening on udev Control Socket.
[ 4.702950] systemd[1]: Listening on udev Kernel Socket.
[ 4.703530] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 4.706525] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.709657] systemd[1]: Mounting Kernel Debug File System...
[ 4.712915] systemd[1]: Mounting Kernel Trace File System...
[ 4.717276] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.721602] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.724863] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.728901] systemd[1]: Starting Load Kernel Module configfs...
[ 4.732704] systemd[1]: Starting Load Kernel Module drm...
[ 4.736957] systemd[1]: Starting Load Kernel Module fuse...
[ 4.737556] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 4.743486] systemd[1]: Starting Journal Service...
[ 4.758939] systemd[1]: Starting Load Kernel Modules...
[ 4.762228] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.768848] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 4.773132] systemd[1]: Starting Coldplug All udev Devices...
[ 4.780598] fuse: init (API version 7.34)
[ 4.785758] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.786731] systemd[1]: Mounted Kernel Debug File System.
[ 4.787521] systemd[1]: Mounted Kernel Trace File System.
[ 4.788166] systemd[1]: Mounted Temporary Directory /tmp.
[ 4.789322] systemd[1]: Finished Create List of Static Device Nodes.
[ 4.794444] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 4.795328] systemd[1]: Finished Load Kernel Module configfs.
[ 4.796427] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 4.797270] systemd[1]: Finished Load Kernel Module drm.
[ 4.798717] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 4.798977] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 4.799441] systemd[1]: Finished Load Kernel Module fuse.
[ 4.802127] systemd[1]: Finished Load Kernel Modules.
[ 4.805377] systemd[1]: Mounting FUSE Control File System...
[ 4.807928] systemd[1]: Mounting Kernel Configuration File System...
[ 4.810874] systemd[1]: Starting Apply Kernel Variables...
[ 4.812155] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.812813] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 4.837930] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 4.840462] systemd[1]: Starting Load/Save Random Seed...
[ 4.840804] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 4.843463] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.846303] systemd[1]: Starting Setup Virtual Console...
[ 4.848644] systemd[1]: Mounted FUSE Control File System.
[ 4.849580] systemd[1]: Mounted Kernel Configuration File System.
[ 4.902726] systemd[1]: Finished Apply Kernel Variables.
[ 4.914459] systemd[1]: Started Journal Service.
[ 4.941367] systemd-journald[201]: Received client request to flush runtime journal.
[ 4.948314] random: lvm: uninitialized urandom read (4 bytes read)
[ 4.979469] systemd-journald[201]: File /var/log/journal/96ba62908fe54a02a74d8b159a7fd1a5/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.037530] random: crng init done
[ 8.451887] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 8.475925] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 8.499886] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 8.532322] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.534679] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 8.545352] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 8.550509] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input5
[ 8.561135] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.562238] mc: Linux media interface: v0.10
[ 8.562302] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.562312] [vc_sm_connected_init]: start
[ 8.589192] [vc_sm_connected_init]: installed successfully
[ 8.603226] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 8.618481] videodev: Linux video capture interface: v2.00
[ 8.715180] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.715326] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.731329] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.745650] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.753430] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.757774] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.758022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.758226] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.758383] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.758401] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.758411] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.758419] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.758425] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.761031] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.771876] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.772173] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.787775] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.788074] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.788092] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.788102] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.788123] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.788131] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.788421] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.800714] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.810243] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.810278] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.811273] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.812695] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.812727] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.819229] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.819261] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.820962] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.820997] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.824034] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 8.824079] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 8.949865] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.976409] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.983483] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 8.987141] usbcore: registered new interface driver brcmfmac
[ 9.223219] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.223368] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.234629] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 9.442868] uart-pl011 fe201000.serial: no DMA platform data
[ 9.461051] zram: Added device: zram0
[ 9.505352] zram0: detected capacity change from 0 to 23993752
[ 9.547242] Adding 11996872k swap on /dev/zram0. Priority:100 extents:1 across:11996872k SSFS
[ 10.792688] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.793123] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.839686] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.879729] Bluetooth: Core ver 2.22
[ 10.879822] NET: Registered PF_BLUETOOTH protocol family
[ 10.879827] Bluetooth: HCI device and connection manager initialized
[ 10.879843] Bluetooth: HCI socket layer initialized
[ 10.879851] Bluetooth: L2CAP socket layer initialized
[ 10.879868] Bluetooth: SCO socket layer initialized
[ 10.904222] Bluetooth: HCI UART driver ver 2.3
[ 10.904245] Bluetooth: HCI UART protocol H4 registered
[ 10.904325] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 10.904552] Bluetooth: HCI UART protocol Broadcom registered
[ 11.121800] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.121822] Bluetooth: BNEP filters: protocol multicast
[ 11.121840] Bluetooth: BNEP socket layer initialized
[ 11.144292] NET: Registered PF_ALG protocol family
[ 29.815786] Bluetooth: RFCOMM TTY layer initialized
[ 29.815824] Bluetooth: RFCOMM socket layer initialized
[ 29.815846] Bluetooth: RFCOMM ver 1.11
[ 29.861250] vc4-drm gpu: swiotlb buffer is full (sz: 1531904 bytes), total 32768 (slots), used 54 (slots)
[ 29.990713] vc4-drm gpu: swiotlb buffer is full (sz: 1343488 bytes), total 32768 (slots), used 166 (slots)
[ 30.015142] vc4-drm gpu: swiotlb buffer is full (sz: 1507328 bytes), total 32768 (slots), used 76 (slots)
[ 30.082229] vc4-drm gpu: swiotlb buffer is full (sz: 274432 bytes), total 32768 (slots), used 668 (slots)
[ 31.713562] cam-dummy-reg: disabling
[ 32.187884] vc4-drm gpu: swiotlb buffer is full (sz: 655360 bytes), total 32768 (slots), used 332 (slots)
[ 35.515448] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 85.958140] vc4-drm gpu: swiotlb buffer is full (sz: 524288 bytes), total 32768 (slots), used 456 (slots)
[ 87.189433] vc4-drm gpu: swiotlb buffer is full (sz: 319488 bytes), total 32768 (slots), used 412 (slots)
[ 87.227821] vc4-drm gpu: swiotlb buffer is full (sz: 1597440 bytes), total 32768 (slots), used 22 (slots)
[ 89.220857] vc4-drm gpu: swiotlb buffer is full (sz: 1335296 bytes), total 32768 (slots), used 152 (slots)
[ 117.818729] vc4-drm gpu: swiotlb buffer is full (sz: 929792 bytes), total 32768 (slots), used 416 (slots)
[ 117.869705] vc4-drm gpu: swiotlb buffer is full (sz: 516096 bytes), total 32768 (slots), used 276 (slots)
[ 118.610393] vc4-drm gpu: swiotlb buffer is full (sz: 1351680 bytes), total 32768 (slots), used 196 (slots)
[ 118.637844] vc4-drm gpu: swiotlb buffer is full (sz: 380928 bytes), total 32768 (slots), used 194 (slots)
[ 118.640867] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 118.643951] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 118.646449] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 118.648857] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 118.651342] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 118.653813] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 223.120220] swiotlb_tbl_map_single: 9 callbacks suppressed
[ 223.120237] vc4-drm gpu: swiotlb buffer is full (sz: 425984 bytes), total 32768 (slots), used 478 (slots)
[ 223.172168] vc4-drm gpu: swiotlb buffer is full (sz: 286720 bytes), total 32768 (slots), used 718 (slots)
[ 223.175069] vc4-drm gpu: swiotlb buffer is full (sz: 512000 bytes), total 32768 (slots), used 196 (slots)
[ 223.178101] vc4-drm gpu: swiotlb buffer is full (sz: 1183744 bytes), total 32768 (slots), used 310 (slots)
[ 223.181564] vc4-drm gpu: swiotlb buffer is full (sz: 1245184 bytes), total 32768 (slots), used 314 (slots)
[ 223.185098] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 196 (slots)
[ 223.187956] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 194 (slots)
[ 223.190753] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 210 (slots)
[ 223.193708] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 260 (slots)
[ 223.196992] vc4-drm gpu: swiotlb buffer is full (sz: 1355776 bytes), total 32768 (slots), used 198 (slots)
Any ideas?
