I type this up after hours of troubleshooting. I apparently can’t use the upper frequency range of the 5ghz wifi spectrum. I recently changed my router out with a new unit and did a fresh site survey and changed to one of the upper (above DFS) frequencies, but I simply can’t see that network on my pi4b now. After digging in, I have determined that the applicable frequencies are disabled. I’ve googled and tried a hand full of fixes:
- Installed crda, set the regdom to us, restart, etc…
- Manually run crda like COUNTRY=US crda
- Used iw reg set US
- Set the cfg80211 module param ieee80211_regdom to US
- I even played with ccode values in the nvram that loads with firmware at brcmfmac module load time and read the kernel driver comments around ccode values.
Nothing I do produces any other result other than “global” regdom is US, but the phy interface is 99 unset, and my high band 5ghz channels are disabled. To me, it feels like there is a mismatch between firmware and driver as there are clearly country code considerations in the nvram and special handling in the driver code. Not sure how long this has been going on as I historically ran under the DFS range on my old router, but every other device in the house connects fine to the upper ranges of 5ghz with the new router, and that’s how I discovered this issue.
[root@nibble brcm]# uname -a
Linux nibble 5.16.0-1-MANJARO-ARM-RPI #1 SMP PREEMPT Mon Jan 10 20:07:42 UTC 2022 aarch64 GNU/Linux
[root@nibble brcm]# iw phy5 channels
Band 1:
* 2412 MHz [1]
Maximum TX power: 20.0 dBm
Channel widths: 20MHz HT40+
* 2417 MHz [2]
* 2422 MHz [3]
* 2427 MHz [4]
* 2432 MHz [5]
Channel widths: 20MHz HT40- HT40+
* 2437 MHz [6]
* 2442 MHz [7]
* 2447 MHz [8]
* 2452 MHz [9]
* 2457 MHz [10]
* 2462 MHz [11]
* 2467 MHz [12]
* 2472 MHz [13]
* 2484 MHz [14] (disabled)
Band 2:
* 5170 MHz [34] (disabled)
* 5180 MHz [36]
* 5190 MHz [38] (disabled)
* 5200 MHz [40]
* 5210 MHz [42] (disabled)
* 5220 MHz [44]
* 5230 MHz [46] (disabled)
* 5240 MHz [48]
* 5260 MHz [52]
No IR
Radar detection
DFS state: usable (for 1036 sec)
DFS CAC time: 60000 ms
* 5280 MHz [56]
No IR
Radar detection
* 5300 MHz [60]
No IR
Radar detection
* 5320 MHz [64]
No IR
Radar detection
* 5500 MHz [100]
No IR
Radar detection
* 5520 MHz [104]
No IR
Radar detection
* 5540 MHz [108]
No IR
Radar detection
* 5560 MHz [112]
No IR
Radar detection
* 5580 MHz [116]
No IR
Radar detection
* 5600 MHz [120]
No IR
Radar detection
* 5620 MHz [124]
No IR
Radar detection
* 5640 MHz [128]
No IR
Radar detection
* 5660 MHz [132]
No IR
Radar detection
* 5680 MHz [136]
No IR
Radar detection
* 5700 MHz [140]
No IR
Radar detection
* 5720 MHz [144] (disabled)
* 5745 MHz [149] (disabled)
* 5765 MHz [153] (disabled)
* 5785 MHz [157] (disabled)
* 5805 MHz [161] (disabled)
* 5825 MHz [165] (disabled)
[root@nibble brcm]# iw reg get
global
country US: DFS-FCC
(2400 - 2472 @ 40), (N/A, 30), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), AUTO-BW
(5250 - 5350 @ 80), (N/A, 23), (0 ms), DFS, AUTO-BW
(5470 - 5730 @ 160), (N/A, 23), (0 ms), DFS
(5730 - 5850 @ 80), (N/A, 30), (N/A), AUTO-BW
(5850 - 5895 @ 40), (N/A, 27), (N/A), NO-OUTDOOR, AUTO-BW, PASSIVE-SCAN
(57240 - 71000 @ 2160), (N/A, 40), (N/A)
phy#5
country 99: DFS-UNSET
(2402 - 2482 @ 40), (6, 20), (N/A)
(2474 - 2494 @ 20), (6, 20), (N/A)
(5140 - 5360 @ 160), (6, 20), (N/A)
(5460 - 5860 @ 160), (6, 20), (N/A)
[root@nibble brcm]# COUNTRY=US crda
Failed to set regulatory domain: -7
[root@nibble brcm]#
The above output being the real issue it seems…
Wayne
