Raspberry pi 4 alternative SD copier option
Hi,
I am running Manjaro OS on RPI4 and I am looking to clone my current SD card for backing up. In official RPI repo, there is SD Copier app. However, I do not see it in Manjaro repo. I’ve tried Clonezilla but it did not seem to work well. What options are there?
Back up the /boot partition
Back up the root partition:
rsync -aWxh --stats / /mnt/clone/
Adjust your PARTUUID’s in the new cmdline.txt and etc/fstab by providing the new ones when restoring.
You also can create and image of the root partition with fsarchiver.
https://forum.manjaro.org/t/migration-from-sd-card-to-bootable-usb-nvme-vs-clean-install/26590/4
The adjust the PARTUUID again in the same places as mentioned above.
