Hey there,
I switched from Raspbian (yes… there were no updates for a long time), to Manjaro Arm with GNOME.
Now its very slow and stuttery. Is there maybe a better build/desktop to get it working more smooth?
Hey there,
Hi @Heimdall,
AFAIK Gnome is very resource-hungry. Perhaps one of the lighter ones will be be better for you, like Mate or Sway.
Also see: (In case you haven’t yet.)
RPI 3 is a 512MB 1GB ram device - so yes Gnome will be slow even XFCE is slow.
Raspberry Pi OS is based on Debian and not a rolling release - so you will have to resort to trickery to move to the next major release.
I see.
I use Gnome on my other Manjaro Devices. But maybe I should try another one ![]()
Can’t do any harm. And as @linux-aarhus mentioned, it’s kind of lightweight in the RAM department. (So I’m guessing processor as well.)
Anyway, I’d recommend something lightweight yes. Also look at:
… as LXQt is relatively lightweight IIRC.
You can use the arm instlaler script to create a lxqt desktop for raspberry pi
absolutely - using openbox window manager - it is around 150MB
Raspberry Pi 3 / + Only has a 1 GB Ram. which is shared with the GPU.
So Running Gnome is Pushing it.
SbK looks great, but is only x86.
Looking into LXQt and how its installed later…
I really dont want to use Raspberry OS, if I dont have to ![]()
Installed the Mate Version. Seems to be a fair bit faster now. Thanks guys ![]()
