The system freezes for no apparent reason. It happens randomly after 2 days of uptime, after 7 days.
At first the image freezes completely, then after about 5 seconds you can move the cursor, click the mouse, the system reacts with a short acceleration of CPU cooler speeds, but nothing on the screen changes. I set the shutdown on the system unit button without any question, so that computer just shutsdown, but the normal shutdown does not happen, instead it appears a black screen without a terminal and there is nothing at all to do, only to turn off the power.
inxi -Fazy
Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=429c9339-251d-4584-80f0-d28d1d27c1cb rw quiet
resume=UUID=142716b6-7936-411c-b296-daaff078460f udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: P8Z77-V PRO v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2104 date: 08/13/2013
Info: Quad Core model: Intel Core i5-3570K bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27208
Speed: 4400 MHz min/max: 1600/4400 MHz Core speeds (MHz): 1: 4400 2: 4400
3: 4400 4: 4400
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9")
s-diag: 525mm (20.7")
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
Sound Server: ALSA v: k5.4.85-1-MANJARO
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0 chip ID: 8086:1503
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: ASUSTeK
driver: ath9k v: kernel port: d000 bus ID: 07:00.0 chip ID: 168c:0032
IF: wlp7s0 state: down mac: <filter>
Local Storage: total: 7.97 TiB used: 7.21 TiB (90.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD30EZRZ-00GXCB0
size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD30EZRZ-00GXCB0
size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
ID-3: /dev/sdc maj-min: 8:32 vendor: A-Data model: SP920SS size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1.09
ID-4: /dev/sdh maj-min: 8:112 type: USB vendor: MaxDigital
model: MD32500G SATA size: 2.27 TiB block size: physical: 4096 B
logical: 512 B serial: <filter> rev: 8102
ID-1: / raw size: 48.83 GiB size: 47.81 GiB (97.92%) used: 10.24 GiB (21.4%)
fs: ext4 dev: /dev/sdc3 maj-min: 8:35
ID-2: /boot/efi raw size: 501 MiB size: 500 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34
System Temperatures: cpu: 46.0 C mobo: 29.0 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): cpu: 871 fan-1: 0 fan-3: 0 fan-4: 1439 fan-5: 0
gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.30
Processes: 209 Uptime: 19m wakeups: 0 Memory: 15.58 GiB
used: 4.55 GiB (29.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1121 lib: 353 Shell: Bash v: 5.1.0 running in: xfce4-terminal
inxi: 3.2.01
sudo dmesg -l emerg,alert,crit,err,warn
[ 0.235221] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.962444] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.962456] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.964467] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.964479] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.965330] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.965341] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.965646] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.965658] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.967772] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT3._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.967783] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT3._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.968416] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT3._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 0.968426] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT3._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.807869] vboxdrv: loading out-of-tree module taints kernel.
[ 1.834980] VBoxNetAdp: Successfully started.
[ 1.836427] VBoxNetFlt: Successfully started.
[ 2.027424] nvidia: module license 'NVIDIA' taints kernel.
[ 2.027426] Disabling lock debugging due to kernel taint
[ 2.173572] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
[ 2.233849] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[ 2.233855] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20190816/utaddress-204)
[ 2.233857] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 2.233859] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20190816/utaddress-204)
[ 2.233860] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 2.233862] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20190816/utaddress-204)
[ 2.233863] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 2.233865] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 4.078030] proc: Bad value for 'hidepid'
[ 5.338329] kauditd_printk_skb: 10 callbacks suppressed
[ 5.362930] proc: Bad value for 'hidepid'
[ 5.434855] proc: Bad value for 'hidepid'
[ 5.773324] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[ 5.773470] caller _nv000709rm+0x1af/0x200 [nvidia] mapping multiple BARs
[ 12.088040] kauditd_printk_skb: 16 callbacks suppressed
[ 22.221538] kauditd_printk_skb: 8 callbacks suppressed
[ 37.077299] .ready
[ 38.864585] sd 9:0:0:0: [sdh] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 155.303378] SUPR0GipMap: fGetGipCpu=0x1b
[ 161.317877] vboxdrv: 000000000405fa6e VMMR0.r0
[ 161.395282] vboxdrv: 0000000079a2f0b4 VBoxDDR0.r0
[ 161.467843] VMMR0InitVM: eflags=246 fKernelFeatures=0x0 (SUPKERNELFEATURES_SMAP=0)
journalctl -x -p3 -b1
[ 37.077299] .ready
[evgeny@evgeny-pc ~]$ journalctl -x -p3 -b1
-- Journal begins at Thu 2020-12-03 22:23:39 MSK, ends at Sun 2021-01-03 01:12:06 MSK. --
дек 03 22:23:39 evgeny-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT3._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
дек 03 22:23:39 evgeny-pc kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT3._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
дек 03 22:23:39 evgeny-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
дек 03 22:23:39 evgeny-pc kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
дек 03 22:23:39 evgeny-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
дек 03 22:23:39 evgeny-pc kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
дек 03 22:24:26 evgeny-pc lightdm[913]: gkr-pam: unable to locate daemon control file
дек 03 22:24:53 evgeny-pc pulseaudio[1001]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
дек 03 22:25:36 evgeny-pc lightdm[1360]: gkr-pam: unable to locate daemon control file
дек 03 23:40:06 evgeny-pc lightdm[2916]: gkr-pam: unable to locate daemon control file
дек 04 00:02:05 evgeny-pc sudo[33139]: pam_unix(sudo:auth): conversation failed
дек 04 00:02:05 evgeny-pc sudo[33139]: pam_unix(sudo:auth): auth could not identify password for [evgeny]
дек 04 00:02:05 evgeny-pc sudo[33223]: pam_unix(sudo:auth): conversation failed
дек 04 00:02:05 evgeny-pc sudo[33223]: pam_unix(sudo:auth): auth could not identify password for [evgeny]
дек 04 00:53:54 evgeny-pc systemd-coredump[78921]: Process 78916 (xfce4-color-set) of user 1000 dumped core.
Stack trace of thread 78916:
#0 0x00007f0560742b3d g_type_check_instance_is_fundamentally_a (libgobject-2.0.so.0 + 0x34b3d)
#1 0x00007f056072d636 g_object_unref (libgobject-2.0.so.0 + 0x1f636)
#2 0x00005575c1b40398 n/a (xfce4-color-settings + 0x5398)
#3 0x00007f0560ad0249 n/a (libgtk-3.so.0 + 0x84249)
#4 0x00007f056073d98a g_signal_emit_valist (libgobject-2.0.so.0 + 0x2f98a)
#5 0x00007f056073db00 g_signal_emit (libgobject-2.0.so.0 + 0x2fb00)
#6 0x00007f0560d96a75 n/a (libgtk-3.so.0 + 0x34aa75)
#7 0x00007f0560e3cf07 n/a (libgtk-3.so.0 + 0x3f0f07)
#8 0x00007f0560e41478 n/a (libgtk-3.so.0 + 0x3f5478)
#9 0x00007f05609d654f n/a (libgdk-3.so.0 + 0x8954f)
#10 0x00007f05609da12f n/a (libgdk-3.so.0 + 0x8d12f)
#11 0x00007f056097e15b gdk_display_get_event (libgdk-3.so.0 + 0x3115b)
#12 0x00007f05609d9e44 n/a (libgdk-3.so.0 + 0x8ce44)
#13 0x00007f056061b914 g_main_context_dispatch (libglib-2.0.so.0 + 0x52914)
#14 0x00007f056066f7d1 n/a (libglib-2.0.so.0 + 0xa67d1)
#15 0x00007f056061ae63 g_main_loop_run (libglib-2.0.so.0 + 0x51e63)
#16 0x00007f0560c2d4ff gtk_main (libgtk-3.so.0 + 0x1e14ff)
#17 0x00005575c1b3f346 n/a (xfce4-color-settings + 0x4346)
#18 0x00007f0560428152 __libc_start_main (libc.so.6 + 0x28152)
#19 0x00005575c1b3f38e n/a (xfce4-color-settings + 0x438e)
Stack trace of thread 78917:
#0 0x00007f05604f546f __poll (libc.so.6 + 0xf546f)
#1 0x00007f056066f75f n/a (libglib-2.0.so.0 + 0xa675f)
#2 0x00007f056061a121 g_main_context_iteration (libglib-2.0.so.0 + 0x51121)
#3 0x00007f056061a172 n/a (libglib-2.0.so.0 + 0x51172)
#4 0x00007f0560648ce1 n/a (libglib-2.0.so.0 + 0x7fce1)
#5 0x00007f055fafc3e9 start_thread (libpthread.so.0 + 0x93e9)
#6 0x00007f0560500293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 78918:
#2 0x00007f056061ae63 g_main_loop_run (libglib-2.0.so.0 + 0x51e63)
#3 0x00007f0560869fe8 n/a (libgio-2.0.so.0 + 0x101fe8)
Stack trace of thread 78919:
#0 0x00007f05604fad5d syscall (libc.so.6 + 0xfad5d)
#1 0x00007f05606688bb g_cond_wait_until (libglib-2.0.so.0 + 0x9f8bb)
#2 0x00007f05605eb813 n/a (libglib-2.0.so.0 + 0x22813)
#3 0x00007f05605eb9a4 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x229a4)
#4 0x00007f056064bc3a n/a (libglib-2.0.so.0 + 0x82c3a)
#5 0x00007f0560648ce1 n/a (libglib-2.0.so.0 + 0x7fce1)
#6 0x00007f055fafc3e9 start_thread (libpthread.so.0 + 0x93e9)
#7 0x00007f0560500293 __clone (libc.so.6 + 0x100293)
░░ Subject: Процесс 78916 (xfce4-color-set) сбросил дамп памяти
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Процесс 78916 (xfce4-color-set) завершился из-за критической ошибки.
░░ Записан дамп памяти.
░░ Вероятно, это произошло из-за ошибки, допущенной в коде программы.
░░ Рекомендуется сообщить её разработчикам о возникшей проблеме.
дек 04 01:27:14 evgeny-pc kernel: watchdog: watchdog0: watchdog did not stop!
cat /var/log/Xorg.0.log.old
[ 2.782]
X.Org X Server 1.20.10
[ 2.782] Build Operating System: Linux Manjaro Linux
[ 2.782] Current Operating System: Linux evgeny-pc 5.4.85-1-MANJARO #1 SMP PREEMPT Mon Dec 21 21:38:53 UTC 2020 x86_64
[ 2.782] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=429c9339-251d-4584-80f0-d28d1d27c1cb rw quiet resume=UUID=142716b6-7936-411c-b296-daaff078460f udev.log_priority=3
[ 2.782] Build Date: 16 December 2020 10:33:32PM
[ 2.782]
[ 2.782] Current version of pixman: 0.40.0
[ 2.782] Before reporting problems, check http://wiki.x.org
[ 2.782] Markers: (--) probed, (**) from config file, (==) default setting,
[ 2.782] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 1 22:00:55 2021
[ 2.786] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2.786] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2.789] (==) ServerLayout "layout"
[ 2.789] (**) |-->Screen "Screen0" (0)
[ 2.789] (**) | |-->Monitor "Monitor0"
[ 2.789] (**) | |-->Device "Device0"
[ 2.789] (==) Automatically adding devices
[ 2.789] (==) Automatically enabling devices
[ 2.789] (==) Automatically adding GPU devices
[ 2.789] (==) Automatically binding GPU devices
[ 2.789] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2.794] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2.794] Entry deleted from font path.
[ 2.794] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2.794] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2.794] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 2.794] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2.794] (**) Extension "COMPOSITE" is enabled
[ 2.794] (II) The server relies on udev to provide the list of input devices.
[ 2.794] (II) Module ABI versions:
[ 2.794] X.Org ANSI C Emulation: 0.4
[ 2.794] X.Org Video Driver: 24.1
[ 2.794] X.Org XInput driver : 24.1
[ 2.794] X.Org Server Extension : 10.0
[ 2.795] (++) using VT number 7
[ 2.795] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 2.795] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2.797] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 2.797] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 2.798] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3161 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 2.798] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2.798] (II) LoadModule: "glx"
[ 2.802] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2.813] (II) Module glx: vendor="X.Org Foundation"
[ 2.813] compiled for 1.20.10, module version = 1.0.0
[ 2.813] ABI class: X.Org Server Extension, version 10.0
[ 2.813] (II) LoadModule: "nvidia"
[ 2.814] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 2.821] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 2.821] compiled for 1.6.99.901, module version = 1.0.0
[ 2.821] Module class: X.Org Video Driver
[ 2.822] (II) NVIDIA dlloader X Driver 455.45.01 Thu Nov 5 23:01:05 UTC 2020
[ 2.822] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2.824] (II) Loading sub module "fb"
[ 2.824] (II) LoadModule: "fb"
[ 2.824] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2.825] (II) Module fb: vendor="X.Org Foundation"
[ 2.825] compiled for 1.20.10, module version = 1.0.0
[ 2.825] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2.825] (II) Loading sub module "wfb"
[ 2.825] (II) LoadModule: "wfb"
[ 2.826] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 2.827] (II) Module wfb: vendor="X.Org Foundation"
[ 2.827] compiled for 1.20.10, module version = 1.0.0
[ 2.827] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2.827] (II) Loading sub module "ramdac"
[ 2.827] (II) LoadModule: "ramdac"
[ 2.827] (II) Module "ramdac" already built-in
[ 2.828] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 2.828] (==) NVIDIA(0): RGB weight 888
[ 2.828] (==) NVIDIA(0): Default visual is TrueColor
[ 2.828] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2.829] (**) Option "AllowNVIDIAGpuScreens"
[ 2.829] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 2.829] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 2.829] (**) NVIDIA(0): Enabling 2D acceleration
[ 2.829] (II) Loading sub module "glxserver_nvidia"
[ 2.829] (II) LoadModule: "glxserver_nvidia"
[ 2.829] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 2.953] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 2.953] compiled for 1.6.99.901, module version = 1.0.0
[ 2.953] Module class: X.Org Server Extension
[ 2.957] (II) NVIDIA GLX Module 455.45.01 Thu Nov 5 22:58:18 UTC 2020
[ 2.960] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 3.629] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 3.629] (--) NVIDIA(0): CRT-0 (boot)
[ 3.629] (--) NVIDIA(0): DFP-0
[ 3.629] (--) NVIDIA(0): DFP-1
[ 3.629] (--) NVIDIA(0): DFP-2
[ 3.629] (--) NVIDIA(0): DFP-3
[ 3.629] (--) NVIDIA(0): DFP-4
[ 3.630] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[ 3.630] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 3.630] (--) NVIDIA(0): VideoBIOS: 84.04.84.00.29
[ 3.630] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 3.677] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 3.677] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 3.695] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 3.695] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 3.695] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 3.695] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 3.695] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 3.695] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 3.695] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 3.695] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 3.695] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 3.695] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 3.695] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 3.695] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 3.695] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 3.695] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 3.695] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 3.697] (==) NVIDIA(0):
[ 3.697] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 3.697] (==) NVIDIA(0): will be used as the requested mode.
[ 3.697] (II) NVIDIA(0): Validated MetaModes:
[ 3.697] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
[ 3.697] (II) NVIDIA(0): Virtual screen size determined to be 1680 x 1050
[ 3.700] (--) NVIDIA(0): DPI set to (99, 98); computed from "UseEdidDpi" X config
[ 3.700] (--) NVIDIA(0): option
[ 3.700] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 3.700] (II) NVIDIA: access.
[ 3.702] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 3.702] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 3.702] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 3.702] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 3.702] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 3.702] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 3.702] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 3.702] (II) NVIDIA(0): Config Options in the README.
[ 3.715] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[ 3.769] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 3.769] (==) NVIDIA(0): Backing store enabled
[ 3.769] (==) NVIDIA(0): Silken mouse disabled
[ 3.769] (**) NVIDIA(0): DPMS enabled
[ 3.770] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 3.770] (II) Loading sub module "dri2"
[ 3.770] (II) LoadModule: "dri2"
[ 3.770] (II) Module "dri2" already built-in
[ 3.770] (II) NVIDIA(0): [DRI2] Setup complete
[ 3.770] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 3.771] (II) Initializing extension Generic Event Extension
[ 3.771] (II) Initializing extension SHAPE
[ 3.771] (II) Initializing extension MIT-SHM
[ 3.771] (II) Initializing extension XInputExtension
[ 3.771] (II) Initializing extension XTEST
[ 3.771] (II) Initializing extension BIG-REQUESTS
[ 3.771] (II) Initializing extension SYNC
[ 3.771] (II) Initializing extension XKEYBOARD
[ 3.771] (II) Initializing extension XC-MISC
[ 3.772] (II) Initializing extension SECURITY
[ 3.772] (II) Initializing extension XFIXES
[ 3.772] (II) Initializing extension RENDER
[ 3.772] (II) Initializing extension RANDR
[ 3.772] (II) Initializing extension COMPOSITE
[ 3.772] (II) Initializing extension DAMAGE
[ 3.772] (II) Initializing extension MIT-SCREEN-SAVER
[ 3.772] (II) Initializing extension DOUBLE-BUFFER
[ 3.772] (II) Initializing extension RECORD
[ 3.772] (II) Initializing extension DPMS
[ 3.772] (II) Initializing extension Present
[ 3.772] (II) Initializing extension DRI3
[ 3.772] (II) Initializing extension X-Resource
[ 3.772] (II) Initializing extension XVideo
[ 3.772] (II) Initializing extension XVideo-MotionCompensation
[ 3.772] (II) Initializing extension GLX
[ 3.773] (II) Initializing extension GLX
[ 3.773] (II) Indirect GLX disabled.
[ 3.773] (II) GLX: Another vendor is already registered for screen 0
[ 3.773] (II) Initializing extension XFree86-VidModeExtension
[ 3.773] (II) Initializing extension XFree86-DGA
[ 3.773] (II) Initializing extension XFree86-DRI
[ 3.773] (II) Initializing extension DRI2
[ 3.773] (II) Initializing extension NV-GLX
[ 3.773] (II) Initializing extension NV-CONTROL
[ 3.773] (II) Initializing extension XINERAMA
[ 3.841] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3.841] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3.841] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3.841] (**) Power Button: Applying InputClass "system-keyboard"
[ 3.841] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 3.841] (II) LoadModule: "libinput"
[ 3.841] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3.846] (II) Module libinput: vendor="X.Org Foundation"
[ 3.846] compiled for 1.20.8, module version = 0.30.0
[ 3.846] Module class: X.Org XInput Driver
[ 3.846] ABI class: X.Org XInput driver, version 24.1
[ 3.846] (II) Using input driver 'libinput' for 'Power Button'
[ 3.846] (**) Power Button: always reports core events
[ 3.846] (**) Option "Device" "/dev/input/event1"
[ 3.846] (**) Option "_source" "server/udev"
[ 3.850] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3.850] (II) event1 - Power Button: device is a keyboard
[ 3.850] (II) event1 - Power Button: device removed
[ 3.877] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 3.877] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3.877] (**) Option "xkb_layout" "us"
[ 3.877] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 3.900] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3.900] (II) event1 - Power Button: device is a keyboard
[ 3.901] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 3.901] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3.901] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3.901] (**) Power Button: Applying InputClass "system-keyboard"
[ 3.901] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 3.901] (II) Using input driver 'libinput' for 'Power Button'
[ 3.901] (**) Power Button: always reports core events
[ 3.901] (**) Option "Device" "/dev/input/event0"
[ 3.901] (**) Option "_source" "server/udev"
[ 3.903] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3.903] (II) event0 - Power Button: device is a keyboard
[ 3.903] (II) event0 - Power Button: device removed
[ 3.930] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 3.930] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 3.930] (**) Option "xkb_layout" "us"
[ 3.930] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 3.932] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3.932] (II) event0 - Power Button: device is a keyboard
[ 3.933] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 3.933] (II) No input driver specified, ignoring this device.
[ 3.933] (II) This device may have been added with another device file.
[ 3.934] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 3.934] (II) No input driver specified, ignoring this device.
[ 3.934] (II) This device may have been added with another device file.
[ 3.935] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 3.935] (II) No input driver specified, ignoring this device.
[ 3.935] (II) This device may have been added with another device file.
[ 3.935] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 3.936] (II) config/udev: Adding input device SONiX USB Keyboard (/dev/input/event2)
[ 3.936] (**) SONiX USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 3.937] (**) SONiX USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 3.937] (**) SONiX USB Keyboard: Applying InputClass "system-keyboard"
[ 3.937] (**) SONiX USB Keyboard: Applying InputClass "Keyboard Defaults"
[ 3.937] (II) Using input driver 'libinput' for 'SONiX USB Keyboard'
[ 3.937] (**) SONiX USB Keyboard: always reports core events
[ 3.937] (**) Option "Device" "/dev/input/event2"
[ 3.937] (**) Option "_source" "server/udev"
[ 3.939] (II) event2 - SONiX USB Keyboard: is tagged by udev as: Keyboard
[ 3.939] (II) event2 - SONiX USB Keyboard: device is a keyboard
[ 3.940] (II) event2 - SONiX USB Keyboard: device removed
[ 3.954] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:09DA:2268.0001/input/input2/event2"
[ 3.954] (II) XINPUT: Adding extended input device "SONiX USB Keyboard" (type: KEYBOARD, id 8)
[ 3.954] (**) Option "xkb_layout" "us"
[ 3.954] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 3.957] (II) event2 - SONiX USB Keyboard: is tagged by udev as: Keyboard
[ 3.957] (II) event2 - SONiX USB Keyboard: device is a keyboard
[ 3.959] (II) config/udev: Adding input device SONiX USB Keyboard Consumer Control (/dev/input/event3)
[ 3.959] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 3.959] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 3.959] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 3.959] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 3.959] (II) Using input driver 'libinput' for 'SONiX USB Keyboard Consumer Control'
[ 3.959] (**) SONiX USB Keyboard Consumer Control: always reports core events
[ 3.959] (**) Option "Device" "/dev/input/event3"
[ 3.959] (**) Option "_source" "server/udev"
[ 3.961] (II) event3 - SONiX USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 3.961] (II) event3 - SONiX USB Keyboard Consumer Control: device is a keyboard
[ 3.962] (II) event3 - SONiX USB Keyboard Consumer Control: device removed
[ 3.983] (II) libinput: SONiX USB Keyboard Consumer Control: needs a virtual subdevice
[ 3.984] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input3/event3"
[ 3.984] (II) XINPUT: Adding extended input device "SONiX USB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 3.984] (**) Option "AccelerationScheme" "none"
[ 3.984] (**) SONiX USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 3.984] (**) SONiX USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 3.984] (**) SONiX USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 3.986] (II) event3 - SONiX USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 3.986] (II) event3 - SONiX USB Keyboard Consumer Control: device is a keyboard
[ 3.988] (II) config/udev: Adding input device SONiX USB Keyboard System Control (/dev/input/event4)
[ 3.988] (**) SONiX USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 3.988] (**) SONiX USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 3.988] (**) SONiX USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 3.988] (**) SONiX USB Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 3.988] (II) Using input driver 'libinput' for 'SONiX USB Keyboard System Control'
[ 3.988] (**) SONiX USB Keyboard System Control: always reports core events
[ 3.988] (**) Option "Device" "/dev/input/event4"
[ 3.988] (**) Option "_source" "server/udev"
[ 3.990] (II) event4 - SONiX USB Keyboard System Control: is tagged by udev as: Keyboard
[ 3.990] (II) event4 - SONiX USB Keyboard System Control: device is a keyboard
[ 3.990] (II) event4 - SONiX USB Keyboard System Control: device removed
[ 4.010] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input4/event4"
[ 4.010] (II) XINPUT: Adding extended input device "SONiX USB Keyboard System Control" (type: KEYBOARD, id 10)
[ 4.010] (**) Option "xkb_layout" "us"
[ 4.010] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.013] (II) event4 - SONiX USB Keyboard System Control: is tagged by udev as: Keyboard
[ 4.013] (II) event4 - SONiX USB Keyboard System Control: device is a keyboard
[ 4.014] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event10)
[ 4.014] (II) No input driver specified, ignoring this device.
[ 4.014] (II) This device may have been added with another device file.
[ 4.015] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event11)
[ 4.015] (II) No input driver specified, ignoring this device.
[ 4.015] (II) This device may have been added with another device file.
[ 4.015] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event12)
[ 4.016] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event13)
[ 4.016] (II) No input driver specified, ignoring this device.
[ 4.016] (II) This device may have been added with another device file.
[ 4.017] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event14)
[ 4.017] (II) No input driver specified, ignoring this device.
[ 4.017] (II) This device may have been added with another device file.
[ 4.017] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[ 4.018] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event8)
[ 4.018] (II) No input driver specified, ignoring this device.
[ 4.018] (II) This device may have been added with another device file.
[ 4.018] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event9)
[ 4.020] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/event5)
[ 4.020] (**) A4Tech USB Mouse: Applying InputClass "evdev pointer catchall"
[ 4.020] (**) A4Tech USB Mouse: Applying InputClass "libinput pointer catchall"
[ 4.020] (II) Using input driver 'libinput' for 'A4Tech USB Mouse'
[ 4.020] (**) A4Tech USB Mouse: always reports core events
[ 4.020] (**) Option "Device" "/dev/input/event5"
[ 4.020] (**) Option "_source" "server/udev"
[ 4.079] (II) event5 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 4.080] (II) event5 - A4Tech USB Mouse: device is a pointer
[ 4.080] (II) event5 - A4Tech USB Mouse: device removed
[ 4.127] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.7/0000:08:00.0/usb7/7-2/7-2:1.0/0003:09DA:C10A.0003/input/input5/event5"
[ 4.127] (II) XINPUT: Adding extended input device "A4Tech USB Mouse" (type: MOUSE, id 11)
[ 4.127] (**) Option "AccelerationScheme" "none"
[ 4.127] (**) A4Tech USB Mouse: (accel) selected scheme none/0
[ 4.127] (**) A4Tech USB Mouse: (accel) acceleration factor: 2.000
[ 4.127] (**) A4Tech USB Mouse: (accel) acceleration threshold: 4
[ 4.186] (II) event5 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 4.186] (II) event5 - A4Tech USB Mouse: device is a pointer
[ 4.188] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/mouse0)
[ 4.188] (II) No input driver specified, ignoring this device.
[ 4.188] (II) This device may have been added with another device file.
[ 4.189] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/event6)
[ 4.189] (II) No input driver specified, ignoring this device.
[ 4.189] (II) This device may have been added with another device file.
[ 4.190] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event16)
[ 4.190] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 4.190] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 4.190] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 4.190] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 4.190] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 4.190] (**) Eee PC WMI hotkeys: always reports core events
[ 4.190] (**) Option "Device" "/dev/input/event16"
[ 4.190] (**) Option "_source" "server/udev"
[ 4.191] (II) event16 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 4.191] (II) event16 - Eee PC WMI hotkeys: device is a keyboard
[ 4.192] (II) event16 - Eee PC WMI hotkeys: device removed
[ 4.257] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input16/event16"
[ 4.257] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 12)
[ 4.257] (**) Option "xkb_layout" "us"
[ 4.257] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.259] (II) event16 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 4.259] (II) event16 - Eee PC WMI hotkeys: device is a keyboard
[ 4.260] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 4.260] (II) No input driver specified, ignoring this device.
[ 4.260] (II) This device may have been added with another device file.
[ 4.267] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4.267] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.267] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 4.267] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 4.267] (II) Using input driver 'libinput' for 'SONiX USB Keyboard Consumer Control'
[ 4.267] (**) SONiX USB Keyboard Consumer Control: always reports core events
[ 4.267] (**) Option "Device" "/dev/input/event3"
[ 4.267] (**) Option "_source" "_driver/libinput"
[ 4.268] (II) libinput: SONiX USB Keyboard Consumer Control: is a virtual subdevice
[ 4.268] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input3/event3"
[ 4.268] (II) XINPUT: Adding extended input device "SONiX USB Keyboard Consumer Control" (type: KEYBOARD, id 13)
[ 4.268] (**) Option "xkb_layout" "us"
[ 4.268] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.268] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 4.268] (II) No input driver specified, ignoring this device.
[ 4.268] (II) This device may have been added with another device file.
[ 4.269] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 4.269] (II) No input driver specified, ignoring this device.
[ 4.269] (II) This device may have been added with another device file.
[ 4.269] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 4.270] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 4.270] (II) No input driver specified, ignoring this device.
[ 4.270] (II) This device may have been added with another device file.
[ 4.271] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/mouse0)
[ 4.271] (II) No input driver specified, ignoring this device.
[ 4.271] (II) This device may have been added with another device file.
[ 4.271] (II) config/udev: removing device SONiX USB Keyboard
[ 4.272] (II) event2 - SONiX USB Keyboard: device removed
[ 4.290] (II) UnloadModule: "libinput"
[ 4.290] (II) config/udev: Adding input device SONiX USB Keyboard (/dev/input/event2)
[ 4.290] (**) SONiX USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4.290] (**) SONiX USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.290] (**) SONiX USB Keyboard: Applying InputClass "system-keyboard"
[ 4.290] (**) SONiX USB Keyboard: Applying InputClass "Keyboard Defaults"
[ 4.290] (II) Using input driver 'libinput' for 'SONiX USB Keyboard'
[ 4.290] (**) SONiX USB Keyboard: always reports core events
[ 4.290] (**) Option "Device" "/dev/input/event2"
[ 4.290] (**) Option "_source" "server/udev"
[ 4.291] (II) event2 - SONiX USB Keyboard: is tagged by udev as: Keyboard
[ 4.291] (II) event2 - SONiX USB Keyboard: device is a keyboard
[ 4.292] (II) event2 - SONiX USB Keyboard: device removed
[ 4.307] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:09DA:2268.0001/input/input2/event2"
[ 4.307] (II) XINPUT: Adding extended input device "SONiX USB Keyboard" (type: KEYBOARD, id 8)
[ 4.307] (**) Option "xkb_layout" "us"
[ 4.307] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.308] (II) event2 - SONiX USB Keyboard: is tagged by udev as: Keyboard
[ 4.309] (II) event2 - SONiX USB Keyboard: device is a keyboard
[ 4.309] (II) config/udev: removing device SONiX USB Keyboard Consumer Control
[ 4.309] (II) UnloadModule: "libinput"
[ 4.309] (II) event3 - SONiX USB Keyboard Consumer Control: device removed
[ 4.320] (II) UnloadModule: "libinput"
[ 4.321] (II) config/udev: Adding input device SONiX USB Keyboard Consumer Control (/dev/input/event3)
[ 4.321] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4.321] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.321] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 4.321] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 4.321] (II) Using input driver 'libinput' for 'SONiX USB Keyboard Consumer Control'
[ 4.321] (**) SONiX USB Keyboard Consumer Control: always reports core events
[ 4.321] (**) Option "Device" "/dev/input/event3"
[ 4.321] (**) Option "_source" "server/udev"
[ 4.323] (II) event3 - SONiX USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 4.323] (II) event3 - SONiX USB Keyboard Consumer Control: device is a keyboard
[ 4.323] (II) event3 - SONiX USB Keyboard Consumer Control: device removed
[ 4.338] (II) libinput: SONiX USB Keyboard Consumer Control: needs a virtual subdevice
[ 4.338] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input3/event3"
[ 4.338] (II) XINPUT: Adding extended input device "SONiX USB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 4.338] (**) Option "AccelerationScheme" "none"
[ 4.338] (**) SONiX USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 4.338] (**) SONiX USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 4.338] (**) SONiX USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 4.340] (II) event3 - SONiX USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 4.340] (II) event3 - SONiX USB Keyboard Consumer Control: device is a keyboard
[ 4.340] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4.340] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.340] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 4.340] (**) SONiX USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 4.340] (II) Using input driver 'libinput' for 'SONiX USB Keyboard Consumer Control'
[ 4.340] (**) SONiX USB Keyboard Consumer Control: always reports core events
[ 4.340] (**) Option "Device" "/dev/input/event3"
[ 4.340] (**) Option "_source" "_driver/libinput"
[ 4.340] (II) libinput: SONiX USB Keyboard Consumer Control: is a virtual subdevice
[ 4.340] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input3/event3"
[ 4.340] (II) XINPUT: Adding extended input device "SONiX USB Keyboard Consumer Control" (type: KEYBOARD, id 13)
[ 4.340] (**) Option "xkb_layout" "us"
[ 4.340] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.340] (II) config/udev: removing device SONiX USB Keyboard System Control
[ 4.340] (II) event4 - SONiX USB Keyboard System Control: device removed
[ 4.356] (II) UnloadModule: "libinput"
[ 4.356] (II) config/udev: Adding input device SONiX USB Keyboard System Control (/dev/input/event4)
[ 4.356] (**) SONiX USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 4.356] (**) SONiX USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 4.356] (**) SONiX USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 4.356] (**) SONiX USB Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 4.356] (II) Using input driver 'libinput' for 'SONiX USB Keyboard System Control'
[ 4.356] (**) SONiX USB Keyboard System Control: always reports core events
[ 4.356] (**) Option "Device" "/dev/input/event4"
[ 4.356] (**) Option "_source" "server/udev"
[ 4.358] (II) event4 - SONiX USB Keyboard System Control: is tagged by udev as: Keyboard
[ 4.358] (II) event4 - SONiX USB Keyboard System Control: device is a keyboard
[ 4.358] (II) event4 - SONiX USB Keyboard System Control: device removed
[ 4.383] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:09DA:2268.0002/input/input4/event4"
[ 4.383] (II) XINPUT: Adding extended input device "SONiX USB Keyboard System Control" (type: KEYBOARD, id 10)
[ 4.383] (**) Option "xkb_layout" "us"
[ 4.383] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.384] (II) event4 - SONiX USB Keyboard System Control: is tagged by udev as: Keyboard
[ 4.385] (II) event4 - SONiX USB Keyboard System Control: device is a keyboard
[ 4.385] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/event6)
[ 4.385] (II) No input driver specified, ignoring this device.
[ 4.385] (II) This device may have been added with another device file.
[ 4.385] (II) config/udev: removing device A4Tech USB Mouse
[ 4.385] (II) event5 - A4Tech USB Mouse: device removed
[ 4.420] (II) UnloadModule: "libinput"
[ 4.421] (II) config/udev: Adding input device A4Tech USB Mouse (/dev/input/event5)
[ 4.421] (**) A4Tech USB Mouse: Applying InputClass "evdev pointer catchall"
[ 4.421] (**) A4Tech USB Mouse: Applying InputClass "libinput pointer catchall"
[ 4.421] (II) Using input driver 'libinput' for 'A4Tech USB Mouse'
[ 4.421] (**) A4Tech USB Mouse: always reports core events
[ 4.421] (**) Option "Device" "/dev/input/event5"
[ 4.421] (**) Option "_source" "server/udev"
[ 4.478] (II) event5 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 4.478] (II) event5 - A4Tech USB Mouse: device is a pointer
[ 4.478] (II) event5 - A4Tech USB Mouse: device removed
[ 4.543] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.7/0000:08:00.0/usb7/7-2/7-2:1.0/0003:09DA:C10A.0003/input/input5/event5"
[ 4.543] (II) XINPUT: Adding extended input device "A4Tech USB Mouse" (type: MOUSE, id 11)
[ 4.544] (**) Option "AccelerationScheme" "none"
[ 4.544] (**) A4Tech USB Mouse: (accel) selected scheme none/0
[ 4.544] (**) A4Tech USB Mouse: (accel) acceleration factor: 2.000
[ 4.544] (**) A4Tech USB Mouse: (accel) acceleration threshold: 4
[ 4.602] (II) event5 - A4Tech USB Mouse: is tagged by udev as: Mouse
[ 4.603] (II) event5 - A4Tech USB Mouse: device is a pointer
[ 9.766] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 9.766] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 9.784] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 9.784] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 9.784] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 9.784] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.784] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.784] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.784] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.784] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.784] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 9.784] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.784] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.784] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.784] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.784] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 9.784] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 10.483] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 10.483] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 10.501] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 10.501] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 10.501] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 10.501] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10.501] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10.501] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 10.501] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.501] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.501] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 10.501] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.501] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.501] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 10.501] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10.501] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 10.501] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 15.303] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 15.303] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 15.321] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 15.321] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 15.321] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 15.321] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 15.321] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15.321] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15.321] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 15.321] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 15.321] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 15.321] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 15.321] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 15.321] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 15.321] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 15.321] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 15.321] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 30.303] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 30.303] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 30.333] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 30.333] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 30.333] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 30.333] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 30.333] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 30.333] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 30.333] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 30.333] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 30.333] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 30.333] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 30.333] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 30.333] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 30.333] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 30.333] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 30.333] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 55.327] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 55.327] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 55.360] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 55.360] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 55.360] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 55.360] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 55.360] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 55.360] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 55.360] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 55.360] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 55.360] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 55.360] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 55.360] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 55.360] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 55.361] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 55.361] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 55.361] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 574.075] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 649.845] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 1005.771] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 27ms, your system is too slow
[ 1287.936] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 1504.545] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 2567.889] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 3986.106] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 3986.106] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 4662.050] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 4990.977] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 5034.982] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 6379.410] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 6448.560] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 6448.560] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 8600.253] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 8963.325] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 10384.274] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 10470.606] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 10557.260] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 10557.260] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 11418.332] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 11465.601] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 25ms, your system is too slow
[ 12118.969] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 11ms, your system is too slow
[ 12515.450] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 13188.176] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 13331.487] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 14440.947] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 12ms, your system is too slow
[ 14690.857] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 24ms, your system is too slow
[ 14695.793] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 27ms, your system is too slow
[ 14695.793] (EE) event2 - SONiX USB Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 14771.054] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 14771.054] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 14823.293] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 14823.293] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 15919.863] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
[ 16158.515] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 23ms, your system is too slow
[ 16164.859] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 30ms, your system is too slow
[ 16228.650] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 18ms, your system is too slow
[ 16247.866] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 20ms, your system is too slow
[ 16247.866] (EE) event2 - SONiX USB Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 18023.242] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 18066.904] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 18299.968] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 18327.500] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 18468.242] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 18468.242] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 19097.880] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 21820.960] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 21952.675] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 22030.867] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 12ms, your system is too slow
[ 22044.763] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 22107.545] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 30ms, your system is too slow
[ 22112.060] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 12ms, your system is too slow
[ 22126.122] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
[ 22191.360] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 18ms, your system is too slow
[ 22191.360] (EE) event2 - SONiX USB Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 22508.286] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 22529.075] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 22529.075] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 23750.944] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 25524.213] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 25809.666] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 26015.712] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 26034.004] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 26306.684] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 26306.684] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 26740.166] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 12ms, your system is too slow
[ 29258.857] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 24ms, your system is too slow
[ 29420.734] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 29522.526] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 29716.635] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[ 29787.435] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 29787.436] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 31971.848] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 34ms, your system is too slow
[ 31978.128] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
[ 32065.546] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 32071.506] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 15ms, your system is too slow
[ 32989.650] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 33045.153] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 33085.888] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 33490.663] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 33884.990] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 33884.990] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 36769.316] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 37849.310] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 37880.172] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 22ms, your system is too slow
[ 38105.517] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 68993.013] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 23ms, your system is too slow
[ 69254.834] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 69579.658] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 69579.659] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 69579.677] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 69579.677] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 69579.677] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 69579.677] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 69579.677] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 69579.677] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 69579.677] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 69579.677] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 69579.677] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 69579.677] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 69579.677] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 69579.677] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 69579.677] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 69579.677] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 69579.677] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 69579.875] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 69579.875] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 69579.893] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 69579.893] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 69579.893] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 69579.893] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 69579.893] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 69579.893] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 69579.893] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 69579.893] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 69579.893] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 69579.893] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 69579.893] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 69579.893] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 69579.893] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 69579.893] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 69579.893] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 69978.502] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 70101.073] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 70301.862] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 70593.246] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 70593.246] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 70593.264] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 70593.264] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 70593.264] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 70593.264] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 70593.264] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 70593.264] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 70593.264] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 70593.264] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 70593.264] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 70593.265] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 70593.265] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 70593.265] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 70593.265] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 70593.265] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 70593.265] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 70593.463] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 70593.463] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 70593.480] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 70593.480] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 70593.480] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 70593.480] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 70593.480] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 70593.481] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 70593.481] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 70593.481] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 70593.481] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 70593.481] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 70593.481] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 70593.481] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 70593.481] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 70593.481] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 70593.481] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 71287.695] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 71287.695] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 71583.545] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 35ms, your system is too slow
[ 71607.513] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 30ms, your system is too slow
[ 71613.225] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 11ms, your system is too slow
[ 71761.086] (EE) event2 - SONiX USB Keyboard: client bug: event processing lagging behind by 16ms, your system is too slow
[ 71761.086] (EE) event2 - SONiX USB Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 71902.006] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 71902.006] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 71902.038] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 71902.038] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 71902.038] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 71902.038] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 71902.038] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 71902.038] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 71902.038] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 71902.038] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 71902.038] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 71902.039] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 71902.039] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 71902.039] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 71902.039] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 71902.039] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 71902.039] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 71902.321] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 71902.321] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 71902.339] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 71902.339] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 71902.339] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 71902.339] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 71902.339] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 71902.339] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 71902.339] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 71902.339] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 71902.339] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 71902.339] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 71902.339] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 71902.339] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 71902.339] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 71902.339] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 71902.339] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 73322.444] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 73376.282] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 74333.624] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 74676.885] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[ 77756.150] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 77766.126] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 77866.436] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 20ms, your system is too slow
[ 78569.149] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 79428.822] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 79428.828] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 81395.629] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 81930.422] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 82336.301] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 82501.004] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 82772.856] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 82772.856] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 83616.422] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 85008.169] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 85400.892] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 85546.561] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 85896.078] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 86235.159] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 86235.159] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 86589.902] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 86589.902] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 86589.936] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 86589.936] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 86589.936] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 86589.936] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 86589.936] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 86589.936] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 86589.936] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 86589.937] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 86589.937] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 86589.937] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 86589.937] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 86589.937] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 86589.937] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 86589.937] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 86589.937] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 86590.151] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 86590.151] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 86590.169] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 86590.169] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 86590.169] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 86590.169] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 86590.169] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 86590.169] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 86590.169] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 86590.169] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 86590.169] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 86590.170] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 86590.170] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 86590.170] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 86590.170] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 86590.170] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 86590.170] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 86623.394] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 87881.146] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 87881.146] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 87881.181] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 87881.181] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 87881.181] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 87881.181] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 87881.181] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 87881.181] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 87881.181] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 87881.181] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 87881.181] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 87881.181] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 87881.181] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 87881.181] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 87881.181] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 87881.181] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 87881.181] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 87881.395] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 87881.395] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 87881.413] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 87881.413] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 87881.413] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 87881.413] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 87881.413] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 87881.413] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 87881.413] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 87881.413] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 87881.413] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 87881.413] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 87881.413] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 87881.413] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 87881.414] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 87881.414] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 87881.414] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88358.630] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88358.630] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88358.663] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88358.663] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88358.663] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88358.663] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88358.663] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88358.663] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88358.663] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88358.663] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88358.663] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88358.663] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88358.663] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88358.663] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88358.663] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88358.663] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88358.663] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88358.862] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88358.862] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88358.879] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88358.880] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88358.880] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88358.880] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88358.880] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88358.880] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88358.880] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88358.880] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88358.880] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88358.880] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88358.880] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88358.880] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88358.880] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88358.880] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88358.880] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88382.080] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88382.080] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88382.097] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88382.097] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88382.097] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88382.097] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88382.097] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88382.097] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88382.097] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88382.097] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88382.097] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88382.098] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88382.098] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88382.098] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88382.098] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88382.098] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88382.098] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88382.313] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88382.313] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88382.330] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88382.330] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88382.330] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88382.331] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88382.331] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88382.331] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88382.331] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88382.331] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88382.331] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88382.331] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88382.331] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88382.331] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88382.331] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88382.331] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88382.331] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88391.136] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88391.136] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88391.154] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88391.154] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88391.154] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88391.154] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88391.154] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88391.154] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88391.154] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88391.154] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88391.154] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88391.154] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88391.154] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88391.154] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88391.154] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88391.154] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88391.154] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88391.353] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88391.353] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88391.371] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88391.371] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88391.371] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88391.371] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88391.371] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88391.371] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88391.371] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88391.371] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88391.371] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88391.371] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88391.371] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88391.371] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88391.371] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88391.371] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88391.371] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88394.571] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88394.571] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88394.590] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88394.590] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88394.590] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88394.590] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88394.590] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88394.590] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88394.590] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88394.590] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88394.590] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88394.590] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88394.590] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88394.590] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88394.590] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88394.590] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88394.590] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88394.806] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88394.806] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88394.823] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88394.823] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88394.823] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88394.823] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88394.823] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88394.823] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88394.823] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88394.823] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88394.823] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88394.823] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88394.823] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88394.823] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88394.823] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88394.823] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88394.823] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88457.568] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88457.568] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88457.586] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88457.586] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88457.586] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88457.586] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88457.586] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88457.586] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88457.586] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88457.586] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88457.586] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88457.586] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88457.586] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88457.586] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88457.586] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88457.586] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88457.586] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88457.801] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 88457.801] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 88457.820] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 88457.820] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 88457.820] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 88457.820] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 88457.820] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 88457.820] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 88457.820] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 88457.820] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 88457.820] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 88457.820] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 88457.820] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 88457.820] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 88457.820] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 88457.820] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 88457.820] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 88819.166] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 89060.570] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 89173.562] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 89173.562] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 89173.580] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 89173.580] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 89173.580] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 89173.580] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 89173.580] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 89173.580] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 89173.580] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 89173.580] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 89173.580] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 89173.580] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 89173.580] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 89173.580] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 89173.580] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 89173.580] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 89173.580] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 89173.778] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 89173.778] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 89173.797] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 89173.797] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 89173.797] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 89173.797] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 89173.797] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 89173.797] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 89173.797] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 89173.797] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 89173.797] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 89173.797] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 89173.797] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 89173.797] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 89173.797] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 89173.797] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 89173.797] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 89251.270] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 89251.270] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 89251.303] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 89251.303] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 89251.304] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 89251.304] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 89251.304] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 89251.304] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 89251.304] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 89251.304] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 89251.304] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 89251.304] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 89251.304] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 89251.304] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 89251.304] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 89251.304] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 89251.304] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 89251.519] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): connected
[ 89251.519] (--) NVIDIA(GPU-0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[ 89251.537] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 89251.537] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 89251.537] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 89251.537] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 89251.537] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 89251.537] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 89251.537] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 89251.537] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 89251.537] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 89251.538] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 89251.538] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 89251.538] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 89251.538] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 89251.538] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 89251.538] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 90013.347] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 90017.467] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 90547.508] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 93956.769] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 93956.774] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 93974.023] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 94017.084] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 94116.102] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 16ms, your system is too slow
[ 94652.023] (EE) event5 - A4Tech USB Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 94652.026] (EE) event5 - A4Tech USB Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 96258.384] (II) event5 - A4Tech USB Mouse: SYN_DROPPED event - some input events have been lost.
[ 96258.384] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-13ms), your system is too slow
[ 96287.919] (WW) NVIDIA: Wait for channel idle timed out.
