Hi, everyone.
I saw the screen flickering at PC startup rarely random times. I have to restart PC, then the flicker is gone. But not always stable, sometimes the issue rarely occurs when starting the PC only. Not screen tearing!
The screen flickering looks like other photo:
My radeon RX 5700 with dual same monitors 1440p via Displayport, using Linux Kernel 5.10 and default amdgpu driver.
journalctl -b -p 3
Output:
Jul 25 20:25:42 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: failed send message: NumOfDisplays (64) param: 0x00000002 response 0xffffffc2
Jul 25 20:25:44 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
Jul 25 20:25:44 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Failed to power gate JPEG!
Jul 25 20:25:44 zesko kernel: [drm:jpeg_v2_0_set_powergating_state [amdgpu]] *ERROR* Dpm disable jpeg failed, ret = -62.
Jul 25 20:25:46 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
Jul 25 20:25:46 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Failed to power gate VCN!
Jul 25 20:25:46 zesko kernel: [drm:amdgpu_dpm_enable_uvd [amdgpu]] *ERROR* Dpm disable uvd failed, ret = -62.
Jul 25 20:25:49 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
Jul 25 20:25:51 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
After logout then login then journalctl -b -p 3:
Jul 26 20:26:53 zesko kernel: amdgpu 0000:0b:00.0: amdgpu: failed send message: SetHardMinByFreq (28) param: 0x0002036b response 0xffffffc2
PC system: inxi -Fx
System: Host: zesko Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.3
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x serial: <superuser required>
BIOS: American Megatrends v: 3202 date: 06/16/2021
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 rev: 0 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86424
Speed: 2749 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2749 2: 2094 3: 2200 4: 2200 5: 2189
6: 2199 7: 2199 8: 2196 9: 2396 10: 2127 11: 2129 12: 2198
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Tul
driver: amdgpu v: kernel bus-ID: 0b:00.0
Device-2: Microdia Dual Mode Camera (8006 VGA) type: USB driver: hid-generic,usbhid bus-ID: 1-10:4
Device-3: Realtek WEB CAMERA M9 Pro type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-2:2
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon resolution:
1: 2560x1440~60Hz 2: 2560x1440
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.40.0 5.10.52-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.5
direct render: Yes
Sorry for my bad English.
Does anybody have the same issue?
