Is it supposed to stop? Should I just enable it again?
systemctl status haveged.service ✔
○ haveged.service - Entropy Daemon based on the HAVEGE algorithm
Loaded: loaded (/usr/lib/systemd/system/haveged.service; enabled; vendor p>
Active: inactive (dead)
Condition: start condition failed at Sat 2021-11-20 09:22:13 IST; 2min 24s ago
└─ ConditionKernelVersion=<5.6 was not met
Docs: man:haveged(8)
http://www.issihosts.com/haveged/
cscs
November 20, 2021, 4:08am
2
Uhm. I think it says it there. It failed, because kernel is not lesser than 5.6
Are you up to date and all?
Or does this mean haveged is deprecated past then? I honestly dont know and havent checked.
Yes, we talked about it I think.
You can remove it completely if nothing else depends it.
It was enabled with kernel 5.13. I just updated my system today and moved to kernel 5.15 and removed kernel 5.13. I also have kernel 5.10 as a backup.
cscs
November 20, 2021, 4:28am
5
Oh you. Dreaming about talking to me.
Heh, but as I said I honestly dont know (…or remember then).
But I will take this as confirmation and try to remember.
random seed service taking long time to load… so i want some kind of entropy generator
haveged
will never load again as you already have a random number generator.
opened 03:41PM - 05 Feb 21 UTC
closed 12:45PM - 24 Mar 21 UTC
Hi
Sorry for the harsh question, but with the jitter entropy added in v5.4 ([… merge commit](https://github.com/torvalds/linux/commit/3f2dc2798b81531fd93a3b9b7c39da47ec689e55), [commit](https://github.com/torvalds/linux/commit/50ee7529ec4500c88f8664560770a7a1b65db72b), [LKML](https://lore.kernel.org/lkml/alpine.DEB.2.21.1909290010500.2636@nanos.tec.linutronix.de/T/)) and removal of the `/dev/random` blocking pool in v5.6 ([commit](https://github.com/torvalds/linux/commit/30c08efec8884fb106b8e57094baa51bb4c44e32), [LWN](https://lwn.net/Articles/808575/)), is `haveged` still useful/relevant? If yes, under what circumstances?
\- Kristian
So I am removing it. Think it is not needed with recent kernels. No major change in entropy with it enabled.
oh ya…thank you…
Yes or No ???
sudo pacman -Rns haveged 1 ✘
checking dependencies...
:: pacman optionally requires haveged: for pacman-init.service
Packages (1) haveged-1.9.15-1
Total Removed Size: 0.15 MiB
:: Do you want to remove these packages? [Y/n]
It’s not needed. As you can see, it’s only optional.
In the future, please edit your previous post instead of posting multiple times in a row. I’ve merged them.
system
Closed
November 22, 2021, 6:42pm
12
