Random loss of sound (logs attached)
I’m running Gnome & Pipewire. Sometimes upon boot I seem to loose sound sporadically. Sound Devices under Settings would list nothing. A reboot usually fixes it. What gives?
$ inxi -Fauxi         ✔ ▓▒░
  Host: DELL Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.1 parameters: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
    root=UUID=7174802e-692b-470b-b427-772a56ab7aca rw quiet splash apparmor=1
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Laptop System: Dell product: Inspiron 16 7610 v: N/A
  Mobo: Dell model: 0599VR v: A00 serial: <superuser required> UEFI: Dell
    v: 1.15.0 date: 03/13/2023
  ID-1: BAT0 charge: 47.1 Wh (100.0%) condition: 47.1/84.3 Wh (55.9%)
    volts: 12.0 min: 11.4 model: BYD DELL M59JH16 type: Li-poly serial: 1500
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    serial: 4023-00-00-00-00 charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x42
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1525 high: 2300 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2300 2: 900 3: 961 4: 801
    5: 2300 6: 1065 7: 2300 8: 2300 9: 995 10: 945 11: 2300 12: 2300 13: 2300
    14: 988 15: 801 16: 847 bogomips: 73744
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell driver: N/A
    alternate: nouveau non-free: 530.xx+ status: current (as of 2023-05)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a2 class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 0c45:6a10
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: Lenovo Q24h-10 serial: U5HGH682 built: 2021
    res: 2560x1440 dpi: 124 gamma: 1.2 size: 526x296mm (20.71x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: eDP-1 model: AU Optronics 0x9f91 built: 2020 res: 3072x1920
    dpi: 227 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 3072x1920
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics (TGL GT1)
    direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0401
  Device-2: Plantronics Plantronics Blackwire 3220 Series
    driver: plantronics,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 047f:c056 class-ID: 0300
    serial: 3F367FA0952DB942A34A70FE42854C19
  API: ALSA v: k6.1.26-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  IF: wlp0s20f3 state: up mac: dc:21:5c:3f:9a:bc
  IP v4: 192.168.0.106/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.0.255
  IP v6: fe80::62ad:1802:701b:595/64 type: noprefixroute scope: link
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown
    mac: 02:42:a2:c8:eb:44
  IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
  IP v6: fe80::42:a2ff:fec8:eb44/64 scope: link
  IF-ID-2: veth093644f state: up speed: 10000 Mbps duplex: full
    mac: 0a:f4:ad:5c:55:59
  IF-ID-3: vethe6159e3 state: up speed: 10000 Mbps duplex: full
    mac: 92:21:3a:36:17:c8
  WAN IP: 49.204.129.248
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:6 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 137.63 GiB (14.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: KDA8N471412308805 fw-rev: 41001131 temp: 51.9 C
    scheme: GPT
  ID-1: / raw-size: 452.34 GiB size: 444.17 GiB (98.19%)
    used: 137.63 GiB (31.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    uuid: 7174802e-692b-470b-b427-772a56ab7aca
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 316 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
    uuid: A59A-5B52
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 355 Uptime: 5h 55m wakeups: 32 Memory: available: 62.55 GiB
  used: 4.3 GiB (6.9%) Init: systemd v: 252 default: graphical tool: systemctl
  Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1241 pm: pacman pkgs: 1232
  libs: 333 tools: gnome-software,pamac pm: flatpak pkgs: 9 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.27
Does this apply to both of your audio devices?
Yes, Settings → Sound would list nothing.
Here, it happened again today. Logs & screenshot attached
Things that caught my attention in the log:
[    3.101019] i2c i2c-0: Successfully instantiated SPD at 0x50
[    3.101126] input: PC Speaker as /devices/platform/pcspkr/input/input7
[    3.133071] spi-nor spi0.0: unrecognized JEDEC id bytes: 20 60 19 20 60 19
[    3.138972] resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
[    3.138975] caller __uncore_imc_init_box+0xc4/0x120 [intel_uncore] mapping multiple BARs
[    3.151492] dell_smm_hwmon: unable to get SMM Dell signature
    2.998056] wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
[    3.001915] input: Intel HID events as /devices/platform/INTC1051:00/input/input5
[    3.003352] intel-hid INTC1051:00: platform supports 5 button array
[    3.004531] input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input6
[    3.024814] i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
[    3.025279] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    3.025330] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    3.029566] ACPI: bus type thunderbolt registered
[    3.034972] ACPI BIOS Error (bug): Could not resolve symbol [\S4CT], AE_NOT_FOUND (20220331/psargs-330)
[    3.034977] ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[    3.034988] ACPI BIOS Error (bug): Could not resolve symbol [\S4HT], AE_NOT_FOUND (20220331/psargs-330)
[    3.034991] ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[    3.035003] ACPI BIOS Error (bug): Could not resolve symbol [\S4PT], AE_NOT_FOUND (20220331/psargs-330)
[    3.035005] ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[    3.035016] ACPI BIOS Error (bug): Could not resolve symbol [\S4AT], AE_NOT_FOUND (20220331/psargs-330)
[    3.035018] ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[    3.038659] systemd-journald[429]: Received client request to flush runtime journal.
[ 1282.421610] audit: type=1130 audit(1684232227.790:285): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1284.502945] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 1285.003611] audit: type=1100 audit(1684232230.373:286): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="keerthi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Full log
dmesg.log
[ 0.000000] microcode: microcode updated early to revision 0x42, date = 2022-06-28
[ 0.000000] Linux version 6.1.26-1-MANJARO (builduser@fv-az377-398) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT_DYNAMIC Wed Apr 26 22:07:35 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=7174802e-692b-470b-b427-772a56ab7aca rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: ‘AVX-512 opmask’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: ‘AVX-512 Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: ‘AVX-512 ZMM_Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using ‘compacted’ format.
[ 0.000000] signal: max sigframe size: 3632
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000060729fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006072a000-0x000000006084cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000006084d000-0x0000000064510fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000064511000-0x0000000064d71fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000064d72000-0x0000000064ffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000064fff000-0x0000000064ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000065000000-0x0000000068ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000069400000-0x00000000695fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000069e00000-0x00000000707fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000108f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by Dell
[ 0.000000] efi: ACPI=0x64ffe000 ACPI 2.0=0x64ffe014 SMBIOS=0x60dd9000 TPMFinalLog=0x64ca8000 ESRT=0x60d37818 MEMATTR=0x5bd85018
[ 0.000000] SMBIOS 3.2 present.
[ 0.000000] DMI: Dell Inc. Inspiron 16 7610/0599VR, BIOS 1.15.0 03/13/2023
[ 0.000000] tsc: Detected 2300.000 MHz processor
[ 0.000000] tsc: Detected 2304.000 MHz TSC
[ 0.000005] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000007] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000012] last_pfn = 0x108f800 max_arch_pfn = 0x400000000
[ 0.000146] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000824] last_pfn = 0x65000 max_arch_pfn = 0x400000000
[ 0.008340] esrt: Reserving ESRT space from 0x0000000060d37818 to 0x0000000060d378a0.
[ 0.008350] Using GB pages for direct mapping
[ 0.008466] Secure boot disabled
[ 0.008466] RAMDISK: [mem 0x35521000-0x36a87fff]
[ 0.008469] ACPI: Early table checksum verification disabled
[ 0.008471] ACPI: RSDP 0x0000000064FFE014 000024 (v02 DELL )
[ 0.008474] ACPI: XSDT 0x0000000064F72188 00010C (v01 DELL Dell Inc 00000002 01000013)
[ 0.008478] ACPI: FACP 0x0000000064FF2000 000114 (v06 DELL Dell Inc 00000002 01000013)
[ 0.008481] ACPI: DSDT 0x0000000064F8F000 05FCC3 (v02 DELL Dell Inc 00000002 01000013)
[ 0.008483] ACPI: FACS 0x0000000064CDB000 000040
[ 0.008485] ACPI: SSDT 0x0000000064FFA000 0024D0 (v02 CpuRef CpuSsdt 00003000 INTL 20191018)
[ 0.008487] ACPI: SSDT 0x0000000064FF3000 0066E2 (v02 DptfTb DptfTabl 00001000 INTL 20191018)
[ 0.008489] ACPI: HPET 0x0000000064FF1000 000038 (v01 DELL Dell Inc 00000002 01000013)
[ 0.008491] ACPI: APIC 0x0000000064FF0000 00012C (v04 DELL Dell Inc 00000002 01000013)
[ 0.008493] ACPI: MCFG 0x0000000064FEF000 00003C (v01 DELL Dell Inc 00000002 01000013)
[ 0.008495] ACPI: SSDT 0x0000000064F8E000 000B05 (v02 DELL DellRtd3 00001000 INTL 20191018)
[ 0.008496] ACPI: NHLT 0x0000000064F8C000 00189E (v00 DELL Dell Inc 00000002 01000013)
[ 0.008498] ACPI: SSDT 0x0000000064F8B000 00007B (v02 SaSsdt SaSsdt 00003000 INTL 20191018)
[ 0.008500] ACPI: SSDT 0x0000000064F89000 0012D2 (v02 INTEL IgfxSsdt 00003000 INTL 20191018)
[ 0.008502] ACPI: SSDT 0x0000000064F7D000 00B3B6 (v02 INTEL TcssSsdt 00001000 INTL 20191018)
[ 0.008504] ACPI: SSDT 0x0000000064F7C000 000CFC (v02 DELL UsbCTabl 00001000 INTL 20191018)
[ 0.008505] ACPI: LPIT 0x0000000064F7B000 0000CC (v01 DELL Dell Inc 00000002 01000013)
[ 0.008507] ACPI: WSMT 0x0000000064F7A000 000028 (v01 DELL Dell Inc 00000002 01000013)
[ 0.008509] ACPI: SSDT 0x0000000064F79000 000B75 (v02 DELL PtidDevc 00001000 INTL 20191018)
[ 0.008511] ACPI: SSDT 0x0000000064F78000 00012A (v02 DELL TbtTypeC 00000000 INTL 20191018)
[ 0.008513] ACPI: DBGP 0x0000000064F77000 000034 (v01 DELL Dell Inc 00000002 01000013)
[ 0.008515] ACPI: DBG2 0x0000000064F76000 000054 (v00 DELL Dell Inc 00000002 01000013)
[ 0.008517] ACPI: BOOT 0x0000000064F75000 000028 (v01 DELL CBX3 00000002 01000013)
[ 0.008518] ACPI: SSDT 0x0000000064F74000 00060E (v02 DELL Tpm2Tabl 00001000 INTL 20191018)
[ 0.008520] ACPI: TPM2 0x0000000064F73000 00004C (v04 DELL Dell Inc 00000002 01000013)
[ 0.008522] ACPI: MSDM 0x0000000064FFD000 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.008524] ACPI: DMAR 0x0000000064F71000 0000A0 (v02 INTEL Dell Inc 00000002 01000013)
[ 0.008526] ACPI: SSDT 0x0000000064F69000 006048 (v02 DELL NvdTable 00001000 INTL 20191018)
[ 0.008528] ACPI: SSDT 0x0000000064F67000 0010DA (v02 DELL xh_Dell_ 00000000 INTL 20191018)
[ 0.008529] ACPI: SSDT 0x0000000064F70000 000144 (v02 Intel ADebTabl 00001000 INTL 20191018)
[ 0.008531] ACPI: PTDT 0x0000000064F66000 000D44 (v00 DELL Dell Inc 00000005 MSFT 0100000D)
[ 0.008533] ACPI: BGRT 0x0000000064F65000 000038 (v01 DELL Dell Inc 00000002 01000013)
[ 0.008535] ACPI: FPDT 0x0000000064F64000 000034 (v01 DELL Dell Inc 00000002 01000013)
[ 0.008536] ACPI: Reserving FACP table memory at [mem 0x64ff2000-0x64ff2113]
[ 0.008537] ACPI: Reserving DSDT table memory at [mem 0x64f8f000-0x64feecc2]
[ 0.008538] ACPI: Reserving FACS table memory at [mem 0x64cdb000-0x64cdb03f]
[ 0.008538] ACPI: Reserving SSDT table memory at [mem 0x64ffa000-0x64ffc4cf]
[ 0.008539] ACPI: Reserving SSDT table memory at [mem 0x64ff3000-0x64ff96e1]
[ 0.008539] ACPI: Reserving HPET table memory at [mem 0x64ff1000-0x64ff1037]
[ 0.008539] ACPI: Reserving APIC table memory at [mem 0x64ff0000-0x64ff012b]
[ 0.008540] ACPI: Reserving MCFG table memory at [mem 0x64fef000-0x64fef03b]
[ 0.008540] ACPI: Reserving SSDT table memory at [mem 0x64f8e000-0x64f8eb04]
[ 0.008541] ACPI: Reserving NHLT table memory at [mem 0x64f8c000-0x64f8d89d]
[ 0.008541] ACPI: Reserving SSDT table memory at [mem 0x64f8b000-0x64f8b07a]
[ 0.008542] ACPI: Reserving SSDT table memory at [mem 0x64f89000-0x64f8a2d1]
[ 0.008542] ACPI: Reserving SSDT table memory at [mem 0x64f7d000-0x64f883b5]
[ 0.008542] ACPI: Reserving SSDT table memory at [mem 0x64f7c000-0x64f7ccfb]
[ 0.008543] ACPI: Reserving LPIT table memory at [mem 0x64f7b000-0x64f7b0cb]
[ 0.008543] ACPI: Reserving WSMT table memory at [mem 0x64f7a000-0x64f7a027]
[ 0.008544] ACPI: Reserving SSDT table memory at [mem 0x64f79000-0x64f79b74]
[ 0.008544] ACPI: Reserving SSDT table memory at [mem 0x64f78000-0x64f78129]
[ 0.008544] ACPI: Reserving DBGP table memory at [mem 0x64f77000-0x64f77033]
[ 0.008545] ACPI: Reserving DBG2 table memory at [mem 0x64f76000-0x64f76053]
[ 0.008545] ACPI: Reserving BOOT table memory at [mem 0x64f75000-0x64f75027]
[ 0.008546] ACPI: Reserving SSDT table memory at [mem 0x64f74000-0x64f7460d]
[ 0.008546] ACPI: Reserving TPM2 table memory at [mem 0x64f73000-0x64f7304b]
[ 0.008547] ACPI: Reserving MSDM table memory at [mem 0x64ffd000-0x64ffd054]
[ 0.008547] ACPI: Reserving DMAR table memory at [mem 0x64f71000-0x64f7109f]
[ 0.008548] ACPI: Reserving SSDT table memory at [mem 0x64f69000-0x64f6f047]
[ 0.008548] ACPI: Reserving SSDT table memory at [mem 0x64f67000-0x64f680d9]
[ 0.008548] ACPI: Reserving SSDT table memory at [mem 0x64f70000-0x64f70143]
[ 0.008549] ACPI: Reserving PTDT table memory at [mem 0x64f66000-0x64f66d43]
[ 0.008549] ACPI: Reserving BGRT table memory at [mem 0x64f65000-0x64f65037]
[ 0.008550] ACPI: Reserving FPDT table memory at [mem 0x64f64000-0x64f64033]
[ 0.008780] No NUMA configuration found
[ 0.008781] Faking a node at [mem 0x0000000000000000-0x000000108f7fffff]
[ 0.008783] NODE_DATA(0) allocated [mem 0x108f7fb000-0x108f7fffff]
[ 0.008825] Zone ranges:
[ 0.008826] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.008827] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.008827] Normal [mem 0x0000000100000000-0x000000108f7fffff]
[ 0.008828] Device empty
[ 0.008829] Movable zone start for each node
[ 0.008829] Early memory node ranges
[ 0.008829] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.008830] node 0: [mem 0x0000000000100000-0x0000000060729fff]
[ 0.008831] node 0: [mem 0x0000000064fff000-0x0000000064ffffff]
[ 0.008831] node 0: [mem 0x0000000100000000-0x000000108f7fffff]
[ 0.008835] Initmem setup node 0 [mem 0x0000000000001000-0x000000108f7fffff]
[ 0.008838] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.008853] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.010387] On node 0, zone DMA32: 18645 pages in unavailable ranges
[ 0.074192] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.074202] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.074276] Reserving Intel graphics memory at [mem 0x6c800000-0x707fffff]
[ 0.074841] ACPI: PM-Timer IO Port: 0x1808
[ 0.074846] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.074847] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.074848] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.074848] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.074848] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.074849] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.074849] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.074849] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.074850] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.074850] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.074850] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.074851] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.074851] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.074851] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.074852] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.074852] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.074920] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.074922] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.074923] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.074926] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.074926] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.074932] e820: update [mem 0x5bbd2000-0x5bcc5fff] usable ==> reserved
[ 0.074937] TSC deadline timer available
[ 0.074939] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.074948] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.074949] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.074950] PM: hibernation: Registered nosave memory: [mem 0x5bbd2000-0x5bcc5fff]
[ 0.074951] PM: hibernation: Registered nosave memory: [mem 0x6072a000-0x6084cfff]
[ 0.074951] PM: hibernation: Registered nosave memory: [mem 0x6084d000-0x64510fff]
[ 0.074952] PM: hibernation: Registered nosave memory: [mem 0x64511000-0x64d71fff]
[ 0.074952] PM: hibernation: Registered nosave memory: [mem 0x64d72000-0x64ffefff]
[ 0.074953] PM: hibernation: Registered nosave memory: [mem 0x65000000-0x68ffffff]
[ 0.074953] PM: hibernation: Registered nosave memory: [mem 0x69000000-0x693fffff]
[ 0.074954] PM: hibernation: Registered nosave memory: [mem 0x69400000-0x695fffff]
[ 0.074954] PM: hibernation: Registered nosave memory: [mem 0x69600000-0x69dfffff]
[ 0.074954] PM: hibernation: Registered nosave memory: [mem 0x69e00000-0x707fffff]
[ 0.074955] PM: hibernation: Registered nosave memory: [mem 0x70800000-0xbfffffff]
[ 0.074955] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ 0.074955] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfed1ffff]
[ 0.074956] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.074956] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfeffffff]
[ 0.074956] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.074957] [mem 0x70800000-0xbfffffff] available for PCI devices
[ 0.074958] Booting paravirtualized kernel on bare hardware
[ 0.074959] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.078247] setup_percpu: NR_CPUS:320 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[ 0.078481] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.078485] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.078487] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.078501] Fallback order for Node 0: 0
[ 0.078503] Built 1 zonelists, mobility grouping on. Total pages: 16450094
[ 0.078505] Policy zone: Normal
[ 0.078505] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=7174802e-692b-470b-b427-772a56ab7aca rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.078569] Unknown kernel command line parameters “splash BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64”, will be passed to user space.
[ 0.078586] random: crng init done
[ 0.080265] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.081111] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.081278] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.081289] software IO TLB: area num 16.
[ 0.170057] Memory: 65437176K/66845476K available (16391K kernel code, 2157K rwdata, 11140K rodata, 2152K init, 5312K bss, 1408040K reserved, 0K cma-reserved)
[ 0.170124] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.170132] ftrace: allocating 46621 entries in 183 pages
[ 0.175647] ftrace: allocated 183 pages with 6 groups
[ 0.175700] Dynamic Preempt: full
[ 0.175723] rcu: Preemptible hierarchical RCU implementation.
[ 0.175724] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.175724] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.175725] Trampoline variant of Tasks RCU enabled.
[ 0.175725] Rude variant of Tasks RCU enabled.
[ 0.175725] Tracing variant of Tasks RCU enabled.
[ 0.175726] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.175726] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.178170] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[ 0.178533] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.178822] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
[ 0.178843] Console: colour dummy device 80x25
[ 0.178853] printk: console [tty0] enabled
[ 0.178866] ACPI: Core revision 20220331
[ 0.179099] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.179100] APIC: Switch to symmetric I/O mode setup
[ 0.179101] DMAR: Host address width 39
[ 0.179102] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.179106] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[ 0.179107] DMAR: DRHD base: 0x000000fed84000 flags: 0x0
[ 0.179110] DMAR: dmar1: reg_base_addr fed84000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.179112] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.179116] DMAR: dmar2: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.179118] DMAR: RMRR base: 0x0000006c000000 end: 0x000000707fffff
[ 0.179119] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 2
[ 0.179120] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.179121] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.180858] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.180860] x2apic enabled
[ 0.180921] Switched APIC routing to cluster x2apic.
[ 0.185550] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[ 0.185555] Calibrating delay loop (skipped), value calculated using timer frequency… 4609.00 BogoMIPS (lpj=7680000)
[ 0.185557] pid_max: default: 32768 minimum: 301
[ 0.187852] LSM: Security Framework initializing
[ 0.187858] landlock: Up and running.
[ 0.187859] Yama: becoming mindful.
[ 0.187865] LSM support for eBPF active
[ 0.187890] AppArmor: AppArmor initialized
[ 0.187965] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.188031] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.188189] CPU0: Thermal monitoring enabled (TM1)
[ 0.188191] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.188281] process: using mwait in idle threads
[ 0.188281] CET detected: Indirect Branch Tracking enabled
[ 0.188282] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.188283] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.188285] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.188287] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.188287] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.188288] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.188288] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.188289] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.188886] Freeing SMP alternatives memory: 40K
[ 0.188886] smpboot: CPU0: 11th Gen Intel(R) Core™ i7-11800H @ 2.30GHz (family: 0x6, model: 0x8d, stepping: 0x1)
[ 0.188886] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.188886] cblist_init_generic: Setting shift to 4 and lim to 1.
[ 0.188886] Performance Events: PEBS fmt4±baseline, AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.188886] … version: 5
[ 0.188886] … bit width: 48
[ 0.188886] … generic registers: 8
[ 0.188886] … value mask: 0000ffffffffffff
[ 0.188886] … max period: 00007fffffffffff
[ 0.188886] … fixed-purpose events: 4
[ 0.188886] … event mask: 0001000f000000ff
[ 0.188886] Estimated ratio of average max frequency by base frequency (times 1024): 2003
[ 0.188886] rcu: Hierarchical SRCU implementation.
[ 0.188886] rcu: Max phase no-delay instances is 1000.
[ 0.188886] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.188886] smp: Bringing up secondary CPUs …
[ 0.188886] x86: Booting SMP configuration:
[ 0.188886] … node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.216953] smp: Brought up 1 node, 16 CPUs
[ 0.216953] smpboot: Max logical packages: 1
[ 0.218888] smpboot: Total of 16 processors activated (73757.00 BogoMIPS)
[ 0.223504] devtmpfs: initialized
[ 0.223504] x86/mm: Memory block size: 2048MB
[ 0.223504] ACPI: PM: Registering ACPI NVS region [mem 0x64511000-0x64d71fff] (8785920 bytes)
[ 0.223504] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.223504] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.223504] pinctrl core: initialized pinctrl subsystem
[ 0.223504] PM: RTC time: 15:25:28, date: 2023-05-16
[ 0.223504] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.223504] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.223504] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.223504] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.223504] audit: initializing netlink subsys (disabled)
[ 0.223504] audit: type=2000 audit(1684250728.036:1): state=initialized audit_enabled=0 res=1
[ 0.223504] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.223504] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.223504] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.223504] thermal_sys: Registered thermal governor ‘user_space’
[ 0.223504] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.223504] cpuidle: using governor ladder
[ 0.223504] cpuidle: using governor menu
[ 0.223504] Simple Boot Flag at 0x47 set to 0x80
[ 0.223504] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.223504] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.223504] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[ 0.223504] PCI: Using configuration type 1 for base access
[ 0.225686] ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
[ 0.226337] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.226337] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.226337] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.226337] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.226337] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.226337] ACPI: Added _OSI(Module Device)
[ 0.226337] ACPI: Added _OSI(Processor Device)
[ 0.226337] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.226337] ACPI: Added OSI(Processor Aggregator Device)
[ 0.280018] ACPI: 14 ACPI AML tables successfully acquired and loaded
[ 0.295829] ACPI: Dynamic OEM Table Load:
[ 0.295836] ACPI: SSDT 0xFFFF88CF027D6200 0001CB (v02 PmRef Cpu0Psd 00003000 INTL 20191018)
[ 0.296410] ACPI: _SB
.PR00: OSC native thermal LVT Acked
[ 0.297992] ACPI: Dynamic OEM Table Load:
[ 0.297997] ACPI: SSDT 0xFFFF88CF029C7000 000496 (v02 PmRef Cpu0Cst 00003001 INTL 20191018)
[ 0.298632] ACPI: Dynamic OEM Table Load:
[ 0.298632] ACPI: SSDT 0xFFFF88CF029C1800 00051E (v02 PmRef Cpu0Ist 00003000 INTL 20191018)
[ 0.298632] ACPI: SSDT 0xFFFF88CF015BB000 0002B4 (v02 PmRef Cpu0Hwp 00003000 INTL 20191018)
[ 0.298632] ACPI: SSDT 0xFFFF88CF02840000 0008E7 (v02 PmRef ApIst 00003000 INTL 20191018)
[ 0.298632] ACPI: SSDT 0xFFFF88CF029C3800 00048A (v02 PmRef ApHwp 00003000 INTL 20191018)
[ 0.298632] ACPI: SSDT 0xFFFF88CF029C3000 0004D4 (v02 PmRef ApPsd 00003000 INTL 20191018)
[ 0.299265] ACPI: Dynamic OEM Table Load:
[ 0.299269] ACPI: SSDT 0xFFFF88CF029C2000 00048A (v02 PmRef ApCst 00003000 INTL 20191018)
[ 0.308548] ACPI: EC: EC started
[ 0.308549] ACPI: EC: interrupt blocked
[ 0.310944] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.310945] ACPI: _SB
.PC00.LPCB.ECDV: Boot DSDT EC used to handle transactions
[ 0.310946] ACPI: Interpreter enabled
[ 0.310986] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.310986] ACPI: Using IOAPIC for interrupt routing
[ 0.311020] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.311021] PCI: Ignoring E820 reservations for host bridge windows
[ 0.312410] ACPI: Enabled 10 GPEs in block 00 to 7F
[ 0.312873] ACPI: PM: Power Resource [PG00]
[ 0.313144] ACPI: PM: Power Resource [PG01]
[ 0.323169] ACPI: PM: Power Resource [PG02]
[ 0.323389] ACPI: PM: Power Resource [PG03]
[ 0.326200] ACPI: PM: Power Resource [BTRT]
[ 0.328886] ACPI: PM: Power Resource [V0PR]
[ 0.328886] ACPI: PM: Power Resource [V1PR]
[ 0.328886] ACPI: PM: Power Resource [V2PR]
[ 0.333817] ACPI: PM: Power Resource [WRST]
[ 0.335756] ACPI: PM: Power Resource [TBT0]
[ 0.335781] ACPI: PM: Power Resource [TBT1]
[ 0.335803] ACPI: PM: Power Resource [D3C]
[ 0.469313] ACPI: PM: Power Resource [PIN]
[ 0.469560] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[ 0.469565] acpi PNP0A08:00: OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.471426] acpi PNP0A08:00: OSC: platform does not support [AER]
[ 0.475139] acpi PNP0A08:00: OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.479382] PCI host bridge to bus 0000:00
[ 0.479383] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.479385] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.479386] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.479387] pci_bus 0000:00: root bus resource [mem 0x70800000-0xbfffffff window]
[ 0.479387] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.479388] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.479520] pci 0000:00:00.0: [8086:9a36] type 00 class 0x060000
[ 0.479622] pci 0000:00:01.0: [8086:9a01] type 01 class 0x060400
[ 0.479677] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.479698] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[ 0.480126] pci 0000:00:02.0: [8086:9a60] type 00 class 0x030000
[ 0.480133] pci 0000:00:02.0: reg 0x10: [mem 0x6132000000-0x6132ffffff 64bit]
[ 0.480138] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.480141] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.480154] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.480155] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[ 0.480157] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.480180] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[ 0.480181] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[ 0.480185] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[ 0.480186] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[ 0.480285] pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
[ 0.480300] pci 0000:00:04.0: reg 0x10: [mem 0x6133140000-0x613315ffff 64bit]
[ 0.480578] pci 0000:00:06.0: [8086:9a0f] type 01 class 0x060400
[ 0.480651] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.480680] pci 0000:00:06.0: PTM enabled (root), 4ns granularity
[ 0.481114] pci 0000:00:07.0: [8086:9a2b] type 01 class 0x060400
[ 0.481151] pci 0000:00:07.0: Overriding RP PIO Log Size to 4
[ 0.481203] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.481793] pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
[ 0.481800] pci 0000:00:08.0: reg 0x10: [mem 0x61331aa000-0x61331aafff 64bit]
[ 0.481904] pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000
[ 0.481911] pci 0000:00:0a.0: reg 0x10: [mem 0x6133190000-0x6133197fff 64bit]
[ 0.481931] pci 0000:00:0a.0: enabling Extended Tags
[ 0.482049] pci 0000:00:0d.0: [8086:9a17] type 00 class 0x0c0330
[ 0.482061] pci 0000:00:0d.0: reg 0x10: [mem 0x6133180000-0x613318ffff 64bit]
[ 0.482118] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.482378] pci 0000:00:0d.2: [8086:9a1f] type 00 class 0x0c0340
[ 0.482388] pci 0000:00:0d.2: reg 0x10: [mem 0x6133100000-0x613313ffff 64bit]
[ 0.482395] pci 0000:00:0d.2: reg 0x18: [mem 0x61331a9000-0x61331a9fff 64bit]
[ 0.482427] pci 0000:00:0d.2: supports D1 D2
[ 0.482428] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.482619] pci 0000:00:12.0: [8086:43fc] type 00 class 0x070000
[ 0.482638] pci 0000:00:12.0: reg 0x10: [mem 0x6133170000-0x613317ffff 64bit]
[ 0.482704] pci 0000:00:12.0: PME# supported from D0 D3hot
[ 0.483082] pci 0000:00:14.0: [8086:43ed] type 00 class 0x0c0330
[ 0.483099] pci 0000:00:14.0: reg 0x10: [mem 0x6133160000-0x613316ffff 64bit]
[ 0.483171] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.483453] pci 0000:00:14.2: [8086:43ef] type 00 class 0x050000
[ 0.483471] pci 0000:00:14.2: reg 0x10: [mem 0x61331a0000-0x61331a3fff 64bit]
[ 0.483482] pci 0000:00:14.2: reg 0x18: [mem 0x61331a8000-0x61331a8fff 64bit]
[ 0.483666] pci 0000:00:14.3: [8086:43f0] type 00 class 0x028000
[ 0.483685] pci 0000:00:14.3: reg 0x10: [mem 0x613319c000-0x613319ffff 64bit]
[ 0.483798] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.484124] pci 0000:00:15.0: [8086:43e8] type 00 class 0x0c8000
[ 0.484151] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.484595] pci 0000:00:15.1: [8086:43e9] type 00 class 0x0c8000
[ 0.484621] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.485000] pci 0000:00:16.0: [8086:43e0] type 00 class 0x078000
[ 0.485020] pci 0000:00:16.0: reg 0x10: [mem 0x61331a5000-0x61331a5fff 64bit]
[ 0.485100] pci 0000:00:16.0: PME# supported from D3hot
[ 0.485498] pci 0000:00:1f.0: [8086:438b] type 00 class 0x060100
[ 0.485857] pci 0000:00:1f.3: [8086:43c8] type 00 class 0x040100
[ 0.485897] pci 0000:00:1f.3: reg 0x10: [mem 0x6133198000-0x613319bfff 64bit]
[ 0.485949] pci 0000:00:1f.3: reg 0x20: [mem 0x6133000000-0x61330fffff 64bit]
[ 0.486049] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.486442] pci 0000:00:1f.4: [8086:43a3] type 00 class 0x0c0500
[ 0.486462] pci 0000:00:1f.4: reg 0x10: [mem 0x61331a4000-0x61331a40ff 64bit]
[ 0.486482] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.486696] pci 0000:00:1f.5: [8086:43a4] type 00 class 0x0c8000
[ 0.486714] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.486865] pci 0000:01:00.0: [10de:25a2] type 00 class 0x030200
[ 0.486873] pci 0000:01:00.0: reg 0x10: [mem 0x8b000000-0x8bffffff]
[ 0.486881] pci 0000:01:00.0: reg 0x14: [mem 0x6000000000-0x60ffffffff 64bit pref]
[ 0.486888] pci 0000:01:00.0: reg 0x1c: [mem 0x6100000000-0x6101ffffff 64bit pref]
[ 0.486893] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.486898] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.486943] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.486997] pci 0000:01:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.487125] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.487127] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.487129] pci 0000:00:01.0: bridge window [mem 0x8b000000-0x8bffffff]
[ 0.487131] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6101ffffff 64bit pref]
[ 0.487317] pci 0000:02:00.0: [1c5c:174a] type 00 class 0x010802
[ 0.487332] pci 0000:02:00.0: reg 0x10: [mem 0x8c000000-0x8c003fff 64bit]
[ 0.487338] pci 0000:02:00.0: reg 0x18: [mem 0x8c005000-0x8c005fff]
[ 0.487345] pci 0000:02:00.0: reg 0x1c: [mem 0x8c004000-0x8c004fff]
[ 0.487553] pci 0000:00:06.0: PCI bridge to [bus 02]
[ 0.487556] pci 0000:00:06.0: bridge window [mem 0x8c000000-0x8c0fffff]
[ 0.487583] pci 0000:00:07.0: PCI bridge to [bus 03-3a]
[ 0.487587] pci 0000:00:07.0: bridge window [mem 0x74000000-0x8a0fffff]
[ 0.487590] pci 0000:00:07.0: bridge window [mem 0x6110000000-0x6131ffffff 64bit pref]
[ 0.503320] Low-power S0 idle used by default for system suspend
[ 0.513774] ACPI: EC: interrupt unblocked
[ 0.513774] ACPI: EC: event unblocked
[ 0.513782] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.513783] ACPI: EC: GPE=0x6e
[ 0.513784] ACPI: _SB
.PC00.LPCB.ECDV: Boot DSDT EC initialization complete
[ 0.513785] ACPI: _SB
.PC00.LPCB.ECDV: EC: Used to handle transactions and events
[ 0.515574] iommu: Default domain type: Translated
[ 0.515574] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.515639] SCSI subsystem initialized
[ 0.515642] libata version 3.00 loaded.
[ 0.515642] ACPI: bus type USB registered
[ 0.515642] usbcore: registered new interface driver usbfs
[ 0.515642] usbcore: registered new interface driver hub
[ 0.515642] usbcore: registered new device driver usb
[ 0.515642] pps_core: LinuxPPS API ver. 1 registered
[ 0.515642] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.515642] PTP clock support registered
[ 0.515642] EDAC MC: Ver: 3.0.0
[ 0.515705] Registered efivars operations
[ 0.515705] NetLabel: Initializing
[ 0.515705] NetLabel: domain hash size = 128
[ 0.515705] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.515705] NetLabel: unlabeled traffic allowed by default
[ 0.515705] mctp: management component transport protocol core
[ 0.515705] NET: Registered PF_MCTP protocol family
[ 0.515705] PCI: Using ACPI for IRQ routing
[ 0.533174] PCI: pci_cache_line_size set to 64 bytes
[ 0.533304] pci 0000:00:1f.5: can’t claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 0.533422] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.533424] e820: reserve RAM buffer [mem 0x5bbd2000-0x5bffffff]
[ 0.533424] e820: reserve RAM buffer [mem 0x6072a000-0x63ffffff]
[ 0.533425] e820: reserve RAM buffer [mem 0x65000000-0x67ffffff]
[ 0.533425] e820: reserve RAM buffer [mem 0x108f800000-0x108fffffff]
[ 0.535578] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.535578] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.535578] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.535578] vgaarb: loaded
[ 0.536419] clocksource: Switched to clocksource tsc-early
[ 0.536499] VFS: Disk quotas dquot_6.6.0
[ 0.536510] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.536587] AppArmor: AppArmor Filesystem Enabled
[ 0.536605] pnp: PnP ACPI init
[ 0.536756] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.536758] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.536857] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.537610] pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.537610] system 00:05: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.537610] system 00:05: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 0.537610] system 00:05: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 0.537610] system 00:05: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.537610] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.537610] system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.537610] system 00:05: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.538328] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.538331] system 00:06: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 0.538332] system 00:06: [mem 0xfe04c000-0xfe04ffff] has been reserved
[ 0.538334] system 00:06: [mem 0xfe050000-0xfe0affff] has been reserved
[ 0.538335] system 00:06: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[ 0.538337] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.538338] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.538340] system 00:06: [mem 0xfd000000-0xfd68ffff] has been reserved
[ 0.538341] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.538343] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.538611] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.542806] pnp: PnP ACPI: found 9 devices
[ 0.547847] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.547879] NET: Registered PF_INET protocol family
[ 0.547987] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.549825] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.549864] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.550049] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.550410] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.550511] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.550641] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.550780] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.550877] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.550956] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.550961] NET: Registered PF_XDP protocol family
[ 0.550962] pci 0000:01:00.0: can’t claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.550965] pci 0000:00:07.0: bridge window [io 0x1000-0x0fff] to [bus 03-3a] add_size 1000
[ 0.550971] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[ 0.550973] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[ 0.550975] pci 0000:00:07.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.550976] pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
[ 0.551061] pci 0000:00:15.1: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
[ 0.551078] pci 0000:00:1f.5: BAR 0: assigned [mem 0x70800000-0x70800fff]
[ 0.551089] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[ 0.551090] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[ 0.551091] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.551092] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.551094] pci 0000:00:01.0: bridge window [mem 0x8b000000-0x8bffffff]
[ 0.551096] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6101ffffff 64bit pref]
[ 0.551099] pci 0000:00:06.0: PCI bridge to [bus 02]
[ 0.551105] pci 0000:00:06.0: bridge window [mem 0x8c000000-0x8c0fffff]
[ 0.551110] pci 0000:00:07.0: PCI bridge to [bus 03-3a]
[ 0.551111] pci 0000:00:07.0: bridge window [io 0x5000-0x5fff]
[ 0.551114] pci 0000:00:07.0: bridge window [mem 0x74000000-0x8a0fffff]
[ 0.551116] pci 0000:00:07.0: bridge window [mem 0x6110000000-0x6131ffffff 64bit pref]
[ 0.551120] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.551121] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.551121] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.551122] pci_bus 0000:00: resource 7 [mem 0x70800000-0xbfffffff window]
[ 0.551123] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[ 0.551123] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.551124] pci_bus 0000:01: resource 1 [mem 0x8b000000-0x8bffffff]
[ 0.551125] pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6101ffffff 64bit pref]
[ 0.551125] pci_bus 0000:02: resource 1 [mem 0x8c000000-0x8c0fffff]
[ 0.551126] pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
[ 0.551127] pci_bus 0000:03: resource 1 [mem 0x74000000-0x8a0fffff]
[ 0.551127] pci_bus 0000:03: resource 2 [mem 0x6110000000-0x6131ffffff 64bit pref]
[ 0.551772] PCI: CLS 0 bytes, default 64
[ 0.551784] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.551785] software IO TLB: mapped [mem 0x0000000050f01000-0x0000000054f01000] (64MB)
[ 0.551808] Trying to unpack rootfs image as initramfs…
[ 0.551826] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[ 0.551855] clocksource: Switched to clocksource tsc
[ 0.552622] Initialise system trusted keyrings
[ 0.552628] Key type blacklist registered
[ 0.552646] workingset: timestamp_bits=41 max_order=24 bucket_order=0
[ 0.553195] zbud: loaded
[ 0.553340] integrity: Platform Keyring initialized
[ 0.553341] integrity: Machine keyring initialized
[ 0.559809] Key type asymmetric registered
[ 0.559810] Asymmetric key parser ‘x509’ registered
[ 0.686560] Freeing initrd memory: 21916K
[ 0.688312] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.688321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.688371] io scheduler mq-deadline registered
[ 0.688374] io scheduler kyber registered
[ 0.688396] io scheduler bfq registered
[ 0.690566] pcieport 0000:00:01.0: PME: Signaling with IRQ 123
[ 0.690726] pcieport 0000:00:06.0: PME: Signaling with IRQ 124
[ 0.690875] pcieport 0000:00:07.0: PME: Signaling with IRQ 125
[ 0.690889] pcieport 0000:00:07.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.691008] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.691150] Monitor-Mwait will be used to enter C-1 state
[ 0.691162] Monitor-Mwait will be used to enter C-2 state
[ 0.691175] Monitor-Mwait will be used to enter C-3 state
[ 0.691180] ACPI: _SB
.PR00: Found 3 idle states
[ 0.692393] ACPI: AC: AC Adapter [AC] (on-line)
[ 0.692420] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.695681] ACPI: button: Lid Switch [LID0]
[ 0.695712] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.698936] ACPI: button: Power Button [PBTN]
[ 0.698954] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.698971] ACPI: button: Sleep Button [SBTN]
[ 0.704175] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.705868] serial 0000:00:12.0: enabling device (0000 → 0002)
[ 0.707353] hpet_acpi_add: no address or irqs in _CRS
[ 0.707374] Non-volatile memory driver v1.3
[ 0.707374] Linux agpgart interface v0.103
[ 0.717787] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.718097] ACPI: bus type drm_connector registered
[ 0.720009] usbcore: registered new interface driver usbserial_generic
[ 0.720011] usbserial: USB Serial support registered for generic
[ 0.720211] rtc_cmos 00:01: RTC can wake from S4
[ 0.721115] rtc_cmos 00:01: registered as rtc0
[ 0.721286] rtc_cmos 00:01: setting system clock to 2023-05-16T15:25:29 UTC (1684250729)
[ 0.721303] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[ 0.722130] intel_pstate: Intel P-state driver initializing
[ 0.723721] intel_pstate: HWP enabled
[ 0.723797] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.723908] efifb: probing for efifb
[ 0.723916] efifb: showing boot graphics
[ 0.725941] efifb: framebuffer at 0x4000000000, using 14400k, total 14400k
[ 0.725942] efifb: mode is 2560x1440x32, linelength=10240, pages=1
[ 0.725942] efifb: scrolling: redraw
[ 0.725943] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.725996] fbcon: Deferring console take-over
[ 0.725997] fb0: EFI VGA frame buffer device
[ 0.726012] hid: raw HID events driver (C) Jiri Kosina
[ 0.727291] intel_pmc_core INT33A1:00: initialized
[ 0.727339] drop_monitor: Initializing network drop monitor service
[ 0.733719] Initializing XFRM netlink socket
[ 0.733762] NET: Registered PF_INET6 protocol family
[ 0.735592] Segment Routing with IPv6
[ 0.735592] RPL Segment Routing with IPv6
[ 0.735601] In-situ OAM (IOAM) with IPv6
[ 0.735623] NET: Registered PF_PACKET protocol family
[ 0.737166] microcode: sig=0x806d1, pf=0x2, revision=0x42
[ 0.737739] microcode: Microcode Update Driver: v2.2.
[ 0.738125] resctrl: L2 allocation detected
[ 0.738128] IPI shorthand broadcast: enabled
[ 0.738143] sched_clock: Marking stable (731317029, 6804316)->(761801523, -23680178)
[ 0.738444] registered taskstats version 1
[ 0.738554] Loading compiled-in X.509 certificates
[ 0.740209] Loaded X.509 cert ‘Build time autogenerated kernel key: 14f1eda2efd09b56e99d0b897a2f38447360cde1’
[ 0.741876] zswap: loaded using pool zstd/z3fold
[ 0.742149] Key type .fscrypt registered
[ 0.742150] Key type fscrypt-provisioning registered
[ 0.742169] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.742209] integrity: Loading X.509 certificate: UEFI:db
[ 0.742219] integrity: Loaded X.509 cert ‘Dell Inc.: Dell Bios DB Key: 637fa7a9f74471b406de0511557071fd41dd5487’
[ 0.742223] integrity: Loading X.509 certificate: UEFI:db
[ 0.742233] integrity: Loaded X.509 cert ‘Dell Inc.: Dell Bios FW Aux Authority 2018: dd4df7c3f5ce7e5a77847915abc37b031f6b10bd’
[ 0.742233] integrity: Loading X.509 certificate: UEFI:db
[ 0.742243] integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
[ 0.742243] integrity: Loading X.509 certificate: UEFI:db
[ 0.742252] integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
[ 0.742754] ACPI: battery: Slot [BAT0] (battery present)
[ 0.743532] PM: Magic number: 7:162:437
[ 0.743622] RAS: Correctable Errors collector initialized.
[ 0.746199] Freeing unused decrypted memory: 2036K
[ 0.746521] Freeing unused kernel image (initmem) memory: 2152K
[ 0.832494] Write protecting the kernel read-only data: 30720k
[ 0.833699] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 0.834069] Freeing unused kernel image (rodata/data gap) memory: 1148K
[ 0.851519] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.851524] rodata_test: all tests were successful
[ 0.851528] Run /init as init process
[ 0.851529] with arguments:
[ 0.851530] /init
[ 0.851531] splash
[ 0.851532] with environment:
[ 0.851533] HOME=/
[ 0.851533] TERM=linux
[ 0.851534] BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
[ 0.953233] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.953709] i8042: Warning: Keylock active
[ 0.955998] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.956056] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.959498] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.959504] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 0.960574] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.960775] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.960778] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 0.960781] xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.960807] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 0.960808] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.960809] usb usb1: Product: xHCI Host Controller
[ 0.960811] usb usb1: Manufacturer: Linux 6.1.26-1-MANJARO xhci-hcd
[ 0.960812] usb usb1: SerialNumber: 0000:00:0d.0
[ 0.960895] hub 1-0:1.0: USB hub found
[ 0.960902] hub 1-0:1.0: 1 port detected
[ 0.961112] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 0.961113] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.961114] usb usb2: Product: xHCI Host Controller
[ 0.961115] usb usb2: Manufacturer: Linux 6.1.26-1-MANJARO xhci-hcd
[ 0.961115] usb usb2: SerialNumber: 0000:00:0d.0
[ 0.961192] hub 2-0:1.0: USB hub found
[ 0.961201] hub 2-0:1.0: 4 ports detected
[ 0.961510] usb: port power management may be unreliable
[ 0.961912] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.961915] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.963127] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.963455] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.963457] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.963458] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.963501] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 0.963503] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.963504] usb usb3: Product: xHCI Host Controller
[ 0.963504] usb usb3: Manufacturer: Linux 6.1.26-1-MANJARO xhci-hcd
[ 0.963505] usb usb3: SerialNumber: 0000:00:14.0
[ 0.963588] hub 3-0:1.0: USB hub found
[ 0.963643] hub 3-0:1.0: 16 ports detected
[ 0.964876] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 0.964877] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.964878] usb usb4: Product: xHCI Host Controller
[ 0.964879] usb usb4: Manufacturer: Linux 6.1.26-1-MANJARO xhci-hcd
[ 0.964879] usb usb4: SerialNumber: 0000:00:14.0
[ 0.964924] hub 4-0:1.0: USB hub found
[ 0.964973] hub 4-0:1.0: 8 ports detected
[ 0.965946] nvme 0000:02:00.0: platform quirk: setting simple suspend
[ 0.965975] nvme nvme0: pci function 0000:02:00.0
[ 0.969741] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.046083] nvme nvme0: 16/0/0 default/read/poll queues
[ 1.051532] nvme nvme0: Ignoring bogus Namespace Identifiers
[ 1.053558] nvme0n1: p1 p2 p3 p4 p5
[ 1.122867] EXT4-fs (nvme0n1p4): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.183479] systemd[1]: RTC configured in localtime, applying delta of 330 minutes to system time.
[ 1.203569] systemd[1]: systemd 252.10-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.203572] systemd[1]: Detected architecture x86-64.
[ 1.204541] systemd[1]: Hostname set to .
[ 1.212417] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 1.356450] usb 3-1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 1.356457] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.356460] usb 3-1: Product: USB Receiver
[ 1.356462] usb 3-1: Manufacturer: Logitech
[ 1.482339] usb 3-5: new high-speed USB device number 3 using xhci_hcd
[ 1.633218] usb 3-5: New USB device found, idVendor=0c45, idProduct=6a10, bcdDevice= 2.71
[ 1.633228] usb 3-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.633231] usb 3-5: Product: Integrated_Webcam_HD
[ 1.633234] usb 3-5: Manufacturer: C7FJH68S2434100190E0
[ 1.722172] systemd[1]: bpf-lsm: LSM BPF program attached
[ 1.759001] usb 3-9: new full-speed USB device number 4 using xhci_hcd
[ 1.833213] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.901735] usb 3-9: New USB device found, idVendor=27c6, idProduct=639c, bcdDevice= 1.00
[ 1.901743] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.901746] usb 3-9: Product: Goodix USB2.0 MISC
[ 1.901749] usb 3-9: Manufacturer: Goodix Technology Co., Ltd.
[ 1.901751] usb 3-9: SerialNumber: UID6287A4D2_XXXX_MOC_B0
[ 1.910149] systemd[1]: Created slice Slice /system/getty.
[ 1.910332] systemd[1]: Created slice Slice /system/modprobe.
[ 1.910474] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.910596] systemd[1]: Created slice User and Session Slice.
[ 1.910628] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.910714] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.910735] systemd[1]: Reached target Login Prompts.
[ 1.910742] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 1.910756] systemd[1]: Reached target Remote File Systems.
[ 1.910761] systemd[1]: Reached target Slice Units.
[ 1.910770] systemd[1]: Reached target Swaps.
[ 1.910781] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.910816] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.910871] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.911553] systemd[1]: Listening on Process Core Dump Socket.
[ 1.911613] systemd[1]: Listening on Journal Audit Socket.
[ 1.911650] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.911687] systemd[1]: Listening on Journal Socket.
[ 1.911803] systemd[1]: Listening on udev Control Socket.
[ 1.911835] systemd[1]: Listening on udev Kernel Socket.
[ 1.912269] systemd[1]: Mounting Huge Pages File System…
[ 1.912663] systemd[1]: Mounting POSIX Message Queue File System…
[ 1.913070] systemd[1]: Mounting Kernel Debug File System…
[ 1.913485] systemd[1]: Mounting Kernel Trace File System…
[ 1.913923] systemd[1]: Starting Load AppArmor profiles…
[ 1.914375] systemd[1]: Starting Create List of Static Device Nodes…
[ 1.914779] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 1.915178] systemd[1]: Starting Load Kernel Module configfs…
[ 1.915586] systemd[1]: Starting Load Kernel Module dm_mod…
[ 1.916002] systemd[1]: Starting Load Kernel Module drm…
[ 1.916421] systemd[1]: Starting Load Kernel Module fuse…
[ 1.916834] systemd[1]: Starting Load Kernel Module loop…
[ 1.916878] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 1.917794] systemd[1]: Starting Load Kernel Modules…
[ 1.918438] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 1.919167] systemd[1]: Starting Coldplug All udev Devices…
[ 1.920032] systemd[1]: Mounted Huge Pages File System.
[ 1.920169] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.920309] systemd[1]: Mounted Kernel Debug File System.
[ 1.920421] systemd[1]: Mounted Kernel Trace File System.
[ 1.920822] loop: module loaded
[ 1.921412] EXT4-fs (nvme0n1p4): re-mounted. Quota mode: none.
[ 1.922777] device-mapper: uevent: version 1.0.3
[ 1.922819] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 1.924029] fuse: init (API version 7.37)
[ 1.943021] audit: type=1400 audit(1684230930.718:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“dovecot-anvil” pid=370 comm=“apparmor_parser”
[ 1.943081] audit: type=1400 audit(1684230930.718:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“klogd” pid=366 comm=“apparmor_parser”
[ 1.954951] audit: type=1400 audit(1684230930.728:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=359 comm=“apparmor_parser”
[ 1.955473] audit: type=1400 audit(1684230930.728:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=358 comm=“apparmor_parser”
[ 1.955822] audit: type=1400 audit(1684230930.732:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=359 comm=“apparmor_parser”
[ 1.957623] audit: type=1400 audit(1684230930.732:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“ping” pid=357 comm=“apparmor_parser”
[ 1.958428] audit: type=1400 audit(1684230930.732:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“dovecot-config” pid=372 comm=“apparmor_parser”
[ 1.959143] audit: type=1400 audit(1684230930.735:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“syslogd” pid=368 comm=“apparmor_parser”
[ 1.960621] audit: type=1400 audit(1684230930.735:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“samba-rpcd-classic” pid=364 comm=“apparmor_parser”
[ 1.972457] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.973439] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.025565] usb 3-14: new full-speed USB device number 5 using xhci_hcd
[ 2.085831] systemd[1]: Finished Load Kernel Module configfs.
[ 2.119443] systemd[1]: Finished Load AppArmor profiles.
[ 2.166000] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 2.166692] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 2.168589] usb 3-14: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 2.168600] usb 3-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.226001] systemd[1]: Finished Load Kernel Module dm_mod.
[ 2.226531] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.242772] systemd[1]: Finished Load Kernel Module drm.
[ 2.243277] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.276120] systemd[1]: Finished Load Kernel Module fuse.
[ 2.276637] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.302791] systemd[1]: Finished Load Kernel Module loop.
[ 2.319485] systemd[1]: Finished Load Kernel Modules.
[ 2.412692] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.429513] systemd[1]: Finished Coldplug All udev Devices.
[ 2.512619] systemd[1]: Mounting FUSE Control File System…
[ 2.514487] systemd[1]: Mounting Kernel Configuration File System…
[ 2.514595] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 2.521234] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 2.522847] systemd[1]: Starting Load/Save Random Seed…
[ 2.522985] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.524516] systemd[1]: Starting Apply Kernel Variables…
[ 2.526133] systemd[1]: Starting Create System Users…
[ 2.527413] systemd[1]: Starting Setup Virtual Console…
[ 2.528275] systemd[1]: Mounted FUSE Control File System.
[ 2.528353] systemd[1]: Mounted Kernel Configuration File System.
[ 2.549303] systemd[1]: Finished Apply Kernel Variables.
[ 2.632849] systemd[1]: Finished Load/Save Random Seed.
[ 2.692671] systemd[1]: Finished Create System Users.
[ 2.756022] systemd[1]: Finished Setup Virtual Console.
[ 2.756512] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 2.792776] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 2.800893] systemd[1]: Starting CLI Netfilter Manager…
[ 2.842695] systemd[1]: Finished CLI Netfilter Manager.
[ 2.902701] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.903162] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.922772] systemd[1]: Mounting /tmp…
[ 2.922876] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 2.922939] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 2.925664] systemd[1]: Starting Journal Service…
[ 2.927212] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 2.928173] systemd[1]: Mounted /tmp.
[ 2.946711] systemd[1]: Started Journal Service.
[ 2.988444] Consider using thermal netlink events interface
[ 2.998056] wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
[ 3.001915] input: Intel HID events as /devices/platform/INTC1051:00/input/input5
[ 3.003352] intel-hid INTC1051:00: platform supports 5 button array
[ 3.004531] input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input6
[ 3.024814] i801_smbus 0000:00:1f.4: enabling device (0000 → 0003)
[ 3.025279] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 3.025330] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 3.029566] ACPI: bus type thunderbolt registered
[ 3.034972] ACPI BIOS Error (bug): Could not resolve symbol [\S4CT], AE_NOT_FOUND (20220331/psargs-330)
[ 3.034977] ACPI Error: Aborting method _SB.PC00.LPCB.ECDV.NGFF._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.034988] ACPI BIOS Error (bug): Could not resolve symbol [\S4HT], AE_NOT_FOUND (20220331/psargs-330)
[ 3.034991] ACPI Error: Aborting method _SB.PC00.LPCB.ECDV.NGFF._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.035003] ACPI BIOS Error (bug): Could not resolve symbol [\S4PT], AE_NOT_FOUND (20220331/psargs-330)
[ 3.035005] ACPI Error: Aborting method _SB.PC00.LPCB.ECDV.NGFF._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.035016] ACPI BIOS Error (bug): Could not resolve symbol [\S4AT], AE_NOT_FOUND (20220331/psargs-330)
[ 3.035018] ACPI Error: Aborting method _SB.PC00.LPCB.ECDV.NGFF._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.038659] systemd-journald[429]: Received client request to flush runtime journal.
[ 3.095992] i2c i2c-0: 2/2 memory slots populated (from DMI)
[ 3.101019] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 3.101126] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 3.133071] spi-nor spi0.0: unrecognized JEDEC id bytes: 20 60 19 20 60 19
[ 3.138972] resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
[ 3.138975] caller __uncore_imc_init_box+0xc4/0x120 [intel_uncore] mapping multiple BARs
[ 3.151492] dell_smm_hwmon: unable to get SMM Dell signature
[ 3.151879] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.152095] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.154150] mei_me 0000:00:16.0: enabling device (0000 → 0002)
[ 3.157191] intel_rapl_common: Found RAPL domain package
[ 3.157193] intel_rapl_common: Found RAPL domain core
[ 3.157194] intel_rapl_common: Found RAPL domain uncore
[ 3.157196] intel_rapl_common: Found RAPL domain psys
[ 3.160068] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 3.160070] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.160071] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.160072] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.160073] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.165566] intel-lpss 0000:00:15.0: enabling device (0000 → 0002)
[ 3.165765] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 3.183311] iTCO_vendor_support: vendor-support=0
[ 3.184054] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 3.185597] cryptd: max_cpu_qlen set to 1000
[ 3.206494] Intel(R) Wireless WiFi driver for Linux
[ 3.206686] iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
[ 3.213722] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 3.213736] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 3.214120] iwlwifi 0000:00:14.3: loaded firmware version 72.daa05125.0 QuZ-a0-hr-b0-72.ucode op_mode iwlmvm
[ 3.215249] AVX2 version of gcm_enc/dec engaged.
[ 3.215490] AES CTR mode by8 optimization enabled
[ 3.216541] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 3.222886] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.225477] proc_thermal 0000:00:04.0: enabling device (0000 → 0002)
[ 3.225513] input: Dell Privacy Driver as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/6932965F-1671-4CEB-B988-D3AB0A901919/input/input9
[ 3.226494] input: Dell WMI hotkeys as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input10
[ 3.241319] intel_rapl_common: Found RAPL domain package
[ 3.251241] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.251341] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.443296] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.443362] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ 3.452596] intel-lpss 0000:00:15.1: enabling device (0000 → 0002)
[ 3.456011] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 3.461080] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.462070] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
[ 3.462692] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 3.464992] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[ 3.465045] thermal thermal_zone5: failed to read out thermal zone (-61)
[ 3.485389] intel_tcc_cooling: Programmable TCC Offset detected
[ 3.521377] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.521394] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.521400] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 → 0002)
[ 3.521547] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 3.591047] iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
[ 3.657869] iwlwifi 0000:00:14.3: base HW address: dc:21:5c:3f:9a:bc
[ 3.673997] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 3.772215] input: DLL0A81:00 04F3:314B Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-11/i2c-DLL0A81:00/0018:04F3:314B.0001/input/input11
[ 3.772426] input: DLL0A81:00 04F3:314B Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-11/i2c-DLL0A81:00/0018:04F3:314B.0001/input/input12
[ 3.772460] hid-generic 0018:04F3:314B.0001: input,hidraw0: I2C HID v1.00 Mouse [DLL0A81:00 04F3:314B] on i2c-DLL0A81:00
[ 3.778873] ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
[ 3.782140] hid-generic 001F:8087:0AC2.0002: hidraw1: SENSOR HUB HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 3.872309] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input8
[ 3.873751] input: DLL0A81:00 04F3:314B Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-11/i2c-DLL0A81:00/0018:04F3:314B.0001/input/input14
[ 3.873872] input: DLL0A81:00 04F3:314B Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-11/i2c-DLL0A81:00/0018:04F3:314B.0001/input/input15
[ 3.873896] hid-multitouch 0018:04F3:314B.0001: input,hidraw0: I2C HID v1.00 Mouse [DLL0A81:00 04F3:314B] on i2c-DLL0A81:00
[ 3.875514] mousedev: PS/2 mouse device common for all mice
[ 4.016760] NET: Registered PF_QIPCRTR protocol family
[ 4.101421] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:046D:C534.0003/input/input17
[ 4.101499] mc: Linux media interface: v0.10
[ 4.109653] videodev: Linux video capture interface: v2.00
[ 4.122602] Bluetooth: Core ver 2.22
[ 4.122616] NET: Registered PF_BLUETOOTH protocol family
[ 4.122617] Bluetooth: HCI device and connection manager initialized
[ 4.122619] Bluetooth: HCI socket layer initialized
[ 4.122620] Bluetooth: L2CAP socket layer initialized
[ 4.122622] Bluetooth: SCO socket layer initialized
[ 4.138676] usbcore: registered new interface driver btusb
[ 4.139598] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
[ 4.140534] Bluetooth: hci0: Device revision is 2
[ 4.140536] Bluetooth: hci0: Secure boot is enabled
[ 4.140537] Bluetooth: hci0: OTP lock is enabled
[ 4.140537] Bluetooth: hci0: API lock is enabled
[ 4.140538] Bluetooth: hci0: Debug lock is disabled
[ 4.140539] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 4.142472] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 4.142535] Bluetooth: hci0: Boot Address: 0x24800
[ 4.142535] Bluetooth: hci0: Firmware Version: 15-45.22
[ 4.156010] hid-generic 0003:046D:C534.0003: input,hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
[ 4.158226] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/input/input18
[ 4.158269] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/input/input19
[ 4.164306] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.164308] Bluetooth: BNEP filters: protocol multicast
[ 4.164310] Bluetooth: BNEP socket layer initialized
[ 4.212693] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/input/input20
[ 4.212969] hid-generic 0003:046D:C534.0004: input,hiddev96,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
[ 4.212992] usbcore: registered new interface driver usbhid
[ 4.212993] usbhid: USB HID core driver
[ 4.253476] usb 3-5: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6a10)
[ 4.265971] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/input/input23
[ 4.337243] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
[ 4.337338] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[ 4.363588] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 4.365352] ACPI: video: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 4.365368] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input24
[ 4.449111] usbcore: registered new interface driver uvcvideo
[ 4.449649] logitech-djreceiver 0003:046D:C534.0003: hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
[ 4.451172] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.451671] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input25
[ 4.451854] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.483829] fbcon: i915drmfb (fb0) is primary device
[ 4.483831] fbcon: Deferring console take-over
[ 4.483832] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 4.527889] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 4.555673] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 4.555676] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 4.555677] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 4.556954] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 4.556956] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 4.556959] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 4.659899] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 4.659902] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 4.670121] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ 4.670278] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 4.730104] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.730106] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.730107] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.730108] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 4.730109] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 4.730109] snd_hda_codec_realtek ehdaudio0D0: Headset Mic=0x19
[ 4.730110] snd_hda_codec_realtek ehdaudio0D0: Headphone Mic=0x1a
[ 4.745814] logitech-djreceiver 0003:046D:C534.0004: hiddev96,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
[ 4.779171] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 4.779175] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[ 4.779250] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[ 4.779252] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[ 4.779256] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[ 4.779258] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[ 4.779260] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[ 4.779263] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[ 4.779266] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[ 4.779269] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[ 4.779272] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[ 4.779275] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[ 4.779278] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[ 4.779284] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 4.806550] logitech-djreceiver 0003:046D:C534.0004: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 4.806792] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input30
[ 4.806894] hid-generic 0003:046D:4023.0005: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:14.0-1/input1:1
[ 4.808549] logitech-djreceiver 0003:046D:C534.0004: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 4.808666] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/0003:046D:4054.0006/input/input35
[ 4.808717] hid-generic 0003:046D:4054.0006: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-0000:00:14.0-1/input1:2
[ 4.813815] input: sof-hda-dsp Headphone Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input26
[ 4.813840] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input27
[ 4.813856] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input28
[ 4.813872] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input29
[ 5.342610] logitech-hidpp-device 0003:046D:4023.0005: HID++ 2.0 device connected.
[ 5.839383] kauditd_printk_skb: 111 callbacks suppressed
[ 5.839385] audit: type=1334 audit(1684230934.615:118): prog-id=37 op=LOAD
[ 5.839387] audit: type=1334 audit(1684230934.615:119): prog-id=38 op=LOAD
[ 5.839388] audit: type=1334 audit(1684230934.615:120): prog-id=39 op=LOAD
[ 5.879229] audit: type=1130 audit(1684230934.655:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 5.915897] audit: type=1130 audit(1684230934.692:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=alsa-restore comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 5.919345] audit: type=1334 audit(1684230934.695:123): prog-id=40 op=LOAD
[ 5.919356] audit: type=1334 audit(1684230934.695:124): prog-id=41 op=LOAD
[ 5.923826] audit: type=1130 audit(1684230934.698:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=rtkit-daemon comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 5.945693] audit: type=1130 audit(1684230934.722:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=geoclue comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 5.964722] audit: type=1130 audit(1684230934.738:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=upower comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 6.019438] rfkill: input handler disabled
[ 6.158776] Bluetooth: hci0: Waiting for firmware download to complete
[ 6.159565] Bluetooth: hci0: Firmware loaded in 1969804 usecs
[ 6.159695] Bluetooth: hci0: Waiting for device to boot
[ 6.174572] Bluetooth: hci0: Device booted in 14602 usecs
[ 6.174642] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 6.174724] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 6.176696] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 6.177692] Bluetooth: hci0: Firmware revision 0.4 build 15 week 45 2022
[ 6.242922] Bluetooth: MGMT ver 1.22
[ 6.246880] NET: Registered PF_ALG protocol family
[ 6.446226] usb 3-9: reset full-speed USB device number 4 using xhci_hcd
[ 6.774772] input: Logitech Wireless Keyboard PID:4023 as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input39
[ 6.774964] logitech-hidpp-device 0003:046D:4023.0005: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:14.0-1/input1:1
[ 6.838759] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C534.0004/0003:046D:4054.0006/input/input40
[ 6.838902] logitech-hidpp-device 0003:046D:4054.0006: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:14.0-1/input1:2
[ 7.987026] wlp0s20f3: authenticate with f4:f2:6d:2a:2d:a4
[ 7.987052] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 7.994168] wlp0s20f3: send auth to f4:f2:6d:2a:2d:a4 (try 1/3)
[ 8.056191] wlp0s20f3: authenticated
[ 8.058988] wlp0s20f3: associate with f4:f2:6d:2a:2d:a4 (try 1/3)
[ 8.082637] wlp0s20f3: RX AssocResp from f4:f2:6d:2a:2d:a4 (capab=0x431 status=0 aid=2)
[ 8.097607] wlp0s20f3: associated
[ 8.210287] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 8.550037] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.553073] Bridge firewalling registered
[ 8.915673] ucsi_acpi USBC000:00: PPM init failed (-110)
[ 12.600131] kauditd_printk_skb: 132 callbacks suppressed
[ 12.600134] audit: type=1100 audit(1684230941.375:176): pid=1781 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:authentication grantors=? acct=“keerthi” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=failed’
[ 15.595181] audit: type=1100 audit(1684230944.368:177): pid=1780 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct=“keerthi” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=success’
[ 15.595789] audit: type=1101 audit(1684230944.372:178): pid=1780 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=success’
[ 15.596609] audit: type=1103 audit(1684230944.372:179): pid=1780 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct=“keerthi” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=success’
[ 15.598609] audit: type=1006 audit(1684230944.372:180): pid=1780 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 15.598614] audit: type=1300 audit(1684230944.372:180): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7ffff87ab3f0 a2=4 a3=0 items=0 ppid=942 pid=1780 auid=1000 uid=0 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm=“gdm-session-wor” exe=“/usr/lib/gdm-session-worker” subj=unconfined key=(null)
[ 15.598616] audit: type=1327 audit(1684230944.372:180): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D70617373776F72645D
[ 15.696373] audit: type=1130 audit(1684230944.472:181): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user-runtime-dir@1000 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 15.705104] audit: type=1101 audit(1684230944.478:182): pid=1801 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 15.705113] audit: type=1103 audit(1684230944.478:183): pid=1801 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:setcred grantors=? acct=“keerthi” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=failed’
[ 16.178514] rfkill: input handler enabled
[ 17.436684] logitech-hidpp-device 0003:046D:4054.0006: HID++ 4.5 device connected.
[ 17.533226] Bluetooth: RFCOMM TTY layer initialized
[ 17.533232] Bluetooth: RFCOMM socket layer initialized
[ 17.533234] Bluetooth: RFCOMM ver 1.11
[ 17.639832] kauditd_printk_skb: 6 callbacks suppressed
[ 17.639834] audit: type=1130 audit(1684230946.415:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=udisks2 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 17.947331] rfkill: input handler disabled
[ 18.759847] audit: type=1106 audit(1684230947.535:189): pid=1019 uid=0 auid=120 ses=1 subj=unconfined msg=‘op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct=“gdm” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=success’
[ 18.759885] audit: type=1104 audit(1684230947.535:190): pid=1019 uid=0 auid=120 ses=1 subj=unconfined msg=‘op=PAM:setcred grantors=pam_permit acct=“gdm” exe=“/usr/lib/gdm-session-worker” hostname=DELL addr=? terminal=/dev/tty1 res=success’
[ 18.792385] audit: type=1131 audit(1684230947.568:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 29.079431] audit: type=1131 audit(1684230957.855:192): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user@120 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 29.195853] audit: type=1131 audit(1684230957.972:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user-runtime-dir@120 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 43.055903] audit: type=1131 audit(1684230988.427:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 43.115765] audit: type=1334 audit(1684230988.487:195): prog-id=42 op=UNLOAD
[ 48.342865] audit: type=1131 audit(1684230993.714:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 48.406104] audit: type=1131 audit(1684230993.777:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 48.475819] audit: type=1334 audit(1684230993.847:198): prog-id=39 op=UNLOAD
[ 48.475830] audit: type=1334 audit(1684230993.847:199): prog-id=38 op=UNLOAD
[ 48.475834] audit: type=1334 audit(1684230993.847:200): prog-id=37 op=UNLOAD
[ 48.609127] audit: type=1334 audit(1684230993.981:201): prog-id=35 op=UNLOAD
[ 48.609137] audit: type=1334 audit(1684230993.981:202): prog-id=34 op=UNLOAD
[ 48.609141] audit: type=1334 audit(1684230993.981:203): prog-id=33 op=UNLOAD
[ 58.079929] audit: type=1334 audit(1684231003.451:204): prog-id=43 op=LOAD
[ 58.080045] audit: type=1334 audit(1684231003.451:205): prog-id=44 op=LOAD
[ 58.080052] audit: type=1334 audit(1684231003.451:206): prog-id=45 op=LOAD
[ 58.118675] audit: type=1130 audit(1684231003.487:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 63.359492] audit: type=1334 audit(1684231008.731:208): prog-id=46 op=LOAD
[ 63.359568] audit: type=1334 audit(1684231008.731:209): prog-id=47 op=LOAD
[ 63.359586] audit: type=1334 audit(1684231008.731:210): prog-id=48 op=LOAD
[ 63.421193] audit: type=1130 audit(1684231008.791:211): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 66.042707] audit: type=1131 audit(1684231011.414:212): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=geoclue comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 70.954420] audit: type=1130 audit(1684231016.323:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=pamac-daemon comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 88.176744] audit: type=1131 audit(1684231033.546:214): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 88.276719] audit: type=1334 audit(1684231033.646:215): prog-id=45 op=UNLOAD
[ 88.276728] audit: type=1334 audit(1684231033.646:216): prog-id=44 op=UNLOAD
[ 88.276729] audit: type=1334 audit(1684231033.646:217): prog-id=43 op=UNLOAD
[ 90.968344] audit: type=1334 audit(1684231036.336:218): prog-id=49 op=LOAD
[ 91.257334] usb 3-9: reset full-speed USB device number 4 using xhci_hcd
[ 91.403783] audit: type=1130 audit(1684231036.773:219): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 93.497368] audit: type=1131 audit(1684231038.866:220): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 93.553787] audit: type=1334 audit(1684231038.923:221): prog-id=48 op=UNLOAD
[ 93.553798] audit: type=1334 audit(1684231038.923:222): prog-id=47 op=UNLOAD
[ 93.553802] audit: type=1334 audit(1684231038.923:223): prog-id=46 op=UNLOAD
[ 94.560943] audit: type=1100 audit(1684231039.929:224): pid=3494 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:authentication grantors=pam_unix acct=“keerthi” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
[ 94.561973] audit: type=1101 audit(1684231039.929:225): pid=3494 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
[ 111.311237] audit: type=1334 audit(1684231056.679:226): prog-id=50 op=LOAD
[ 111.311377] audit: type=1334 audit(1684231056.679:227): prog-id=51 op=LOAD
[ 111.311384] audit: type=1334 audit(1684231056.679:228): prog-id=52 op=LOAD
[ 111.368878] audit: type=1130 audit(1684231056.736:229): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 114.930761] audit: type=1334 audit(1684231060.299:230): prog-id=53 op=LOAD
[ 114.930765] audit: type=1334 audit(1684231060.299:231): prog-id=54 op=LOAD
[ 114.930767] audit: type=1334 audit(1684231060.299:232): prog-id=55 op=LOAD
[ 114.984618] audit: type=1130 audit(1684231060.352:233): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 122.064149] audit: type=1131 audit(1684231067.432:234): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 122.143880] audit: type=1334 audit(1684231067.512:235): prog-id=49 op=UNLOAD
[ 141.427153] audit: type=1131 audit(1684231086.796:236): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 141.546882] audit: type=1334 audit(1684231086.916:237): prog-id=52 op=UNLOAD
[ 141.546891] audit: type=1334 audit(1684231086.916:238): prog-id=51 op=UNLOAD
[ 141.546895] audit: type=1334 audit(1684231086.916:239): prog-id=50 op=UNLOAD
[ 143.280488] audit: type=1334 audit(1684231088.649:240): prog-id=56 op=LOAD
[ 143.280501] audit: type=1334 audit(1684231088.649:241): prog-id=57 op=LOAD
[ 143.280587] audit: type=1334 audit(1684231088.649:242): prog-id=58 op=LOAD
[ 143.342720] audit: type=1130 audit(1684231088.709:243): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 145.053742] audit: type=1131 audit(1684231090.423:244): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 145.176743] audit: type=1334 audit(1684231090.546:245): prog-id=55 op=UNLOAD
[ 173.389735] kauditd_printk_skb: 2 callbacks suppressed
[ 173.389743] audit: type=1131 audit(1684231118.760:248): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 173.482876] audit: type=1334 audit(1684231118.853:249): prog-id=58 op=UNLOAD
[ 173.482886] audit: type=1334 audit(1684231118.853:250): prog-id=57 op=UNLOAD
[ 173.482890] audit: type=1334 audit(1684231118.853:251): prog-id=56 op=UNLOAD
[ 332.746402] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 336.773150] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 839.179996] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 843.200004] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 903.683898] audit: type=1130 audit(1684231849.053:252): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-tmpfiles-clean comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 903.683911] audit: type=1131 audit(1684231849.053:253): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-tmpfiles-clean comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 999.561201] audit: type=1334 audit(1684231944.929:254): prog-id=59 op=LOAD
[ 999.847029] usb 3-9: reset full-speed USB device number 4 using xhci_hcd
[ 999.994742] audit: type=1130 audit(1684231945.363:255): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1003.039404] audit: type=1100 audit(1684231948.406:256): pid=7391 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:authentication grantors=pam_unix acct=“keerthi” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
[ 1003.040346] audit: type=1101 audit(1684231948.409:257): pid=7391 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
[ 1008.580653] audit: type=1334 audit(1684231953.949:258): prog-id=60 op=LOAD
[ 1008.580785] audit: type=1334 audit(1684231953.949:259): prog-id=61 op=LOAD
[ 1008.580792] audit: type=1334 audit(1684231953.949:260): prog-id=62 op=LOAD
[ 1008.629552] audit: type=1130 audit(1684231953.996:261): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1020.660247] audit: type=1334 audit(1684231966.029:262): prog-id=63 op=LOAD
[ 1020.660299] audit: type=1334 audit(1684231966.029:263): prog-id=64 op=LOAD
[ 1020.660317] audit: type=1334 audit(1684231966.029:264): prog-id=65 op=LOAD
[ 1020.726581] audit: type=1130 audit(1684231966.096:265): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1030.067060] audit: type=1131 audit(1684231975.436:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1030.116676] audit: type=1334 audit(1684231975.486:267): prog-id=59 op=UNLOAD
[ 1038.696969] audit: type=1131 audit(1684231984.066:268): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-localed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1038.809964] audit: type=1334 audit(1684231984.179:269): prog-id=62 op=UNLOAD
[ 1038.809975] audit: type=1334 audit(1684231984.179:270): prog-id=61 op=UNLOAD
[ 1038.809979] audit: type=1334 audit(1684231984.179:271): prog-id=60 op=UNLOAD
[ 1050.793605] audit: type=1131 audit(1684231996.163:272): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1050.886621] audit: type=1334 audit(1684231996.256:273): prog-id=65 op=UNLOAD
[ 1050.886631] audit: type=1334 audit(1684231996.256:274): prog-id=64 op=UNLOAD
[ 1050.886635] audit: type=1334 audit(1684231996.256:275): prog-id=63 op=UNLOAD
[ 1234.687225] audit: type=1334 audit(1684232180.056:276): prog-id=66 op=LOAD
[ 1234.687363] audit: type=1334 audit(1684232180.056:277): prog-id=67 op=LOAD
[ 1234.687370] audit: type=1334 audit(1684232180.056:278): prog-id=68 op=LOAD
[ 1234.731106] audit: type=1130 audit(1684232180.100:279): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1264.786805] audit: type=1131 audit(1684232210.156:280): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1264.866442] audit: type=1334 audit(1684232210.236:281): prog-id=68 op=UNLOAD
[ 1264.866454] audit: type=1334 audit(1684232210.236:282): prog-id=67 op=UNLOAD
[ 1264.866459] audit: type=1334 audit(1684232210.236:283): prog-id=66 op=UNLOAD
[ 1281.984350] audit: type=1334 audit(1684232227.353:284): prog-id=69 op=LOAD
[ 1282.273425] usb 3-9: reset full-speed USB device number 4 using xhci_hcd
[ 1282.421610] audit: type=1130 audit(1684232227.790:285): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1284.502945] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 1285.003611] audit: type=1100 audit(1684232230.373:286): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:authentication grantors=pam_unix acct=“keerthi” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1285.004643] audit: type=1101 audit(1684232230.373:287): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1285.005120] audit: type=1110 audit(1684232230.373:288): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:setcred grantors=pam_unix acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1285.005221] audit: type=1105 audit(1684232230.373:289): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1285.030345] audit: type=1106 audit(1684232230.400:290): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1285.030355] audit: type=1104 audit(1684232230.400:291): pid=8979 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:setcred grantors=pam_unix acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1288.526252] snd_hda_codec_realtek ehdaudio0D0: Unable to sync register 0x2b8000. -5
[ 1313.076757] audit: type=1131 audit(1684232258.446:292): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=fprintd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 1313.126560] audit: type=1334 audit(1684232258.496:293): prog-id=69 op=UNLOAD
[ 1324.292062] audit: type=1101 audit(1684232269.660:294): pid=9012 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“keerthi” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1324.292311] audit: type=1110 audit(1684232269.660:295): pid=9012 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:setcred grantors=pam_env,pam_fprintd acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
[ 1324.292361] audit: type=1105 audit(1684232269.660:296): pid=9012 uid=1000 auid=1000 ses=4 subj=unconfined msg=‘op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/0 res=success’
It appears the last few kernel updates has sorted this issue out. Have not experience this in kernel 6.3.4-2-MANJARO and newer.
